Vivitek H5082? - Page 18 - AVS Forum
post #511 of 539 Old 09-15-2010, 02:30 AM
tskalecki's Avatar
All new optomas have 6x weel, hd82, hd86, in january come new models with better black during iris work is improwed
tskalecki is offline
post #512 of 539 Old 09-15-2010, 04:26 AM
joey.r's Avatar
yeah ..i like optoma pj's... loved my h56a.. great pj even though it was 720...mmmmm.... tom any news on optoma's.. coming soon...
ps; jan. well that is a little far away.. need one in the next month or so ..
ps .. i know this is a vivitek thread.. so still considering .. any name..maybe vivitek has something coming soon also ... mmmm... that would be good also ...
joey.r is offline
post #513 of 539 Old 10-13-2010, 12:34 PM
bannani's Avatar
Is there news about a firmware to avoid judder when not enabling their interpolation system ??
When we feed with a 24p, the vivitek is not smooth at all , we have to use their interpolation menu
bannani is offline
post #514 of 539 Old 10-13-2010, 01:09 PM
drhankz's Avatar
Liked: 44
STRANGE since there is no Judder on the H1080FD at 24 fps.
drhankz is offline
post #515 of 539 Old 10-23-2010, 03:41 PM
bannani's Avatar
any news, Any other owners experience and opinions ?
bannani is offline
post #516 of 539 Old 10-23-2010, 06:14 PM
guitarman's Avatar
Yeah seems they have a HD87 in Europe coming with double the numbers. Haven't found out anything on how yet.
Tom/guitarman
VideoDementia
Are you twisted also?
http://www.videodementia.com/sales/TomWithWires.jpg
guitarman is offline
post #517 of 539 Old 11-21-2010, 02:07 PM
bannani's Avatar
no news about vivitek stutering new firmware; I emailed the product chief in europe but no answer...
bannani is offline
post #518 of 539 Old 07-01-2011, 11:40 AM
wkumar's Avatar
Does anyone know how to check the run time of this projector? The manual talks shows how to check current lamp time, but not total time of projector. Is there a way?
wkumar is offline
post #519 of 539 Old 07-01-2011, 02:46 PM
Electric_Haggis's Avatar
Yep. I have an HD87 (which I unfortunately have to sell due to financial strains)
It's native contrast is so good, I hardly ever use the DI. It's brilliant.
Electric_Haggis is offline
post #520 of 539 Old 07-03-2011, 07:17 AM
wkumar's Avatar
Is anyone here using a anamorphic lens with the Vivitek? How well does it work, is the scaling and trigger system good?
wkumar is offline
post #521 of 539 Old 08-15-2011, 03:02 AM
synerg's Avatar
Hi,
Reading the user's manual of the H5080, Optoma HD8600 and Infocus SP8604, i have found contradictory information.
What is the real maximum vertical offset between the top of screen and the optical center when the projector is installed on the ceiling ?
20% of the screen height or 10% ?
S.
synerg is offline
post #522 of 539 Old 09-27-2011, 09:51 AM
BTDGreg's Avatar
Yesterday I bought the H5082 at Best Buy's Magnolia Store. They had it drastically reduced for clearance (less than half of MSRP). Seemed like a great deal. Now I'm having second thoughts. What makes this PJ better than the others I was looking at, the Mitsu hc4000 or the Optoma H33 (which would be the same price as I paid for the H5082)?
Is Vivitek a trustworthy brand?
If anyone is looking to pick up one of these, you might try checking out the Best Buy Magnolia store. The store I was at had two of them on clearance, but there was no clearance price marked--if the sales associate hadn't mentioned it, I never would have known.
Also, I ended up buying Best Buy's 2-year extended warranty, which they told me will cover everything in the box, including the bulb. Considering it was about half the price of the bulb, it seemed like a very good deal.
BTDGreg is offline
post #523 of 539 Old 09-27-2011, 09:57 AM
Joesyah's Avatar
Your pj should easily out perform the units you've mentioned. I wouldn't worry about it. Sounds like you got a good deal!
Joesyah is offline
post #524 of 539 Old 09-27-2011, 10:08 AM
drhankz's Avatar
Liked: 44
My Vivitek is a year old and I have been very happy with it.
I never trust in-store warranties. Good Luck with that part of your purchase.
drhankz is offline
post #525 of 539 Old 09-27-2011, 10:22 AM
BTDGreg's Avatar
I kept going back and forth on it. I'm also very skeptical. But the bulb warranty on the h5082 is only 90 days and the BB manager said it would be covered for 2 years. Hope it works out that way.
BTDGreg is offline
post #526 of 539 Old 09-28-2011, 10:46 AM
fleaman's Avatar
Liked: 83
90 days sounds about right for the lamp warranty.
2 years would be the warranty for the rest of the projector.
I've never heard of a 2-year lamp warranty. Either BB mis-spoke or you mis-heard....
EDIT: The manufacture warranty is 90 days for the lamp and 1-year for the rest http://www.vivitekusa.com/v_display_...product_id=175 (click on the warranty tab)
So no 2-year unless BB is extending it.
fleaman is offline
post #527 of 539 Old 09-28-2011, 11:54 AM
BTDGreg's Avatar
Yes, two years is only through the BB extended warranty. The literature I got when I bought the extended warranty did say that it covers "wear and tear" items, and the sales associate specifically said that it includes "everything in the box" including the bulb. If so, then I think the 2-year extended warranty is well worth it. If not, maybe not.
BTDGreg is offline
post #528 of 539 Old 09-28-2011, 02:02 PM
fleaman's Avatar
Liked: 83
Perhaps. Though in cases like that, I would have the salesman write or print it on your receipt. Makes it much easier if you have to make a claim.
Also, my guess is that it would cover a blown lamp, not just a worn lamp.
Also, my understanding of extended warranties is that if anything happens within the manufactures warranty period, you would be using the manufactures warranty. That might mean the lamp may not be covered between 91-360 days period
fleaman is offline
post #529 of 539 Old 11-23-2011, 07:57 AM
KJA613's Avatar
I am dealing with BB right now. Supervisor of Magnolia is stating the BB extended warranty includes replacement of bulb when it wears out.
I am also looking at the Vivitek on clearance. Trying to decide between the Vivitek for $1400 or the Epson 8350 for $1050? Any input?
I have an 18X13.5 basement room that is 100% light controlled. Use will be gaming 50%, movies 30%, and HDTV 20%.
KJA613 is offline
post #530 of 539 Old 11-23-2011, 10:07 AM
fleaman's Avatar
Liked: 83
If it were me, I'd ask them to point out where it says that in the fine print, and if they can't do that, have him hand print (or type) it into your receipt.
Otherwise you'll have no hard evidence to point to when/if they deny ever mentioning that.
fleaman is offline
post #531 of 539 Old 11-27-2012, 08:55 PM
keanu916's Avatar
Bad luck for me!I got a refurb H5080,but in the menu I can not find the manual IRIS!!!Is it because of the update of firmware?Cuz it DO has white balance adjustment now!mad.gif
keanu916 is offline
post #532 of 539 Old 03-31-2013, 10:12 AM
mbw23air's Avatar
Liked: 27
I recently got Chromapure with advanced auto-cal and need to access service menu to calibrate grayscale or at least for 100% ire before I start auto-cal. Does anyone have the code to access the service menu? Please PM me if you do.
Mike
The Mayans were full of sh*t!!!
mbw23air is offline
post #533 of 539 Old 03-31-2013, 06:55 PM
vereekej's Avatar
Is the 5080 still a quality projector? Most of the posts in here are several years old. Wondering if people still have them and if they're still happy. Also are there better units out now.
When purchasing HT equipment remember that it's always easier to beg for forgiveness than ask for permission.
vereekej is offline
post #534 of 539 Old 03-31-2013, 07:21 PM
Seegs108's Avatar
Quoted: 43 Post(s)
Liked: 139
DLP hasn't really had a lot of technological breakthroughs in the last few years. You can expect upgrades on newer projectors to be on the software side of things. The Vivitek performs very closely to this years crop of .65" DLP projectors in the 2D department. The only thing this projector is missing out on is 3D. But if you are looking for a straight 2D projector, like I said, it performs on par with this years set of .65" DLP projectors in regards to brightness, sharpness, black levels, contrast, color managment, FI system, motion handling, placement, audible noise, ect.
Seegs108 is online now
post #535 of 539 Old 04-01-2013, 09:39 AM
mbw23air's Avatar
Liked: 27
Dylan is correct. It's a shame DLP hasn't progressed with improving black level as they may have maxed out the technology until 4k DLP chips are implemented. I've had my H5082 for a few years as I bought it for just watching HDTV that had lens shift and is plenty bright. It fits all those needs and I got a great deal on an open box item.
Mike
mbw23air is offline
post #536 of 539 Old 04-01-2013, 11:45 AM
noah katz's Avatar
Quoted: 29 Post(s)
Liked: 125
Not sure 4K will bring better blacks.
4k for the tiny consumer market will likely be trickle-down from commercial, and I don't see a lot of incentive for getting uber blacks when the black level floor is determined by required safety lighting.
Noah
noah katz is online now
post #537 of 539 Old 04-01-2013, 07:21 PM
vereekej's Avatar
What would be comparable projectors to the vivitek? Saw a vivitek in person and was very impressed.
vereekej is offline
post #538 of 539 Old 04-01-2013, 07:59 PM
Seegs108's Avatar
Quoted: 43 Post(s)
Liked: 139
The Optoma HD8600 is virtually identical to the Vivitek 5085 (not quite sure what makes the 5082 and 5085 different). Apparently, even though they are the same projector, Vivitek can sell if for less. I think the projectors are manufactured by Delta and branded for each company and I'm pretty sure Vivitek is owned by Delta and that would account for the projector being offered for less under the Vivitek name.
As for something from another company, you could look at the Mitsubishi HC8000. Performance wise, in 2D, they offer a comparable picture.
post #539 of 539 Old 12-10-2013, 12:42 PM
vchris's Avatar
Somebody know how to acess to service menu, please?
Thanks in advance
vchris is offline
Vivitek
User Tag List
