Official InFocus Sp8602 owners thread. - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 2008 Old 02-26-2010, 08:21 AM - Thread Starter
luelf21's Avatar
Originally Posted by Almost60 View Post
Which Blu Ray?
Pandorum especially, with alot of others showing, I guess you would call it typical grain. But yeah pandorum was pretty grainy.
luelf21 is offline
post #92 of 2008 Old 02-26-2010, 08:23 AM - Thread Starter
luelf21's Avatar
Originally Posted by John Schneider View Post
Do you have access to a different BluRay player?
I'd swap it out and make sure that it's an issue there, and not an issue with a new projector where the controls are DOA.
I'll hook up my panny bdp up to it today and try it
luelf21 is offline
post #93 of 2008 Old 02-26-2010, 09:52 AM
SaintJD's Avatar
Originally Posted by danieledmunds View Post
The DLP chip is the 0.65" DMD not the 0.95" as used in the IN83. According to Mark Peterson, the 0.95" is sharper although that might be to do with the optics of the Optoma used in the article. Better optics may offset the size difference of the chip, if not, then it might be considered a downgrade to some. However, I am sure the black levels are better on the sp8602
Hi there. I'm not sure the comparison would be that straightforward because the sp8602 uses a newer version of DarkChip than the IN83 as far as I'm aware. Let me know if that's wrong, but I think so.
SaintJD is offline
post #94 of 2008 Old 02-26-2010, 09:54 AM
Poagman's Avatar
Originally Posted by luelf21 View Post
"Luelf21" The blacks are simply not very black compared to the letterbox top and bottom black bars. Maybe its just the movie, or the fact that my projector isnt offically calibrated.
In the menu there is a "Set Black Level" option which is described as Analyzes the current input image and calculates an offset
value which is then added to the analog to digital converter black level
value. This ensures optimum black level for each analog source.
When I try this setting what it seems to do is take the black borders on top and bottom which may appear as a dark grey and adjust the projectors settings to make it a true black. Works great at getting true blacks in a hurry, but it affects the brights too...
Poagman is offline
post #95 of 2008 Old 02-26-2010, 10:04 AM
SaintJD's Avatar
Can you confirm if it looks like film grain you're seeing or digital noise?
Film grain wouldn't be uncommon, especially if you're viewing it particularly big, for instance the Hurt Locker is very grainy. Surprised with a sci-fi movie.
When you say the films you've viewed lately are grainy, have you tried re-viewing the ones you'd viewed before? If they still look OK it's obviously the films.
SaintJD is offline
post #96 of 2008 Old 02-26-2010, 10:07 AM - Thread Starter
luelf21's Avatar
for some reason that option on my projector menu is disabled. how do I enable it to where I can adjust it. Also, what do you have your iris set at? Mine is at auto.
luelf21 is offline
post #97 of 2008 Old 02-26-2010, 10:14 AM
SaintJD's Avatar
Hi Poagman. I take it from your comment you're a new owner too. Quite a few people on here are looking for reviews of the new machine – can you give us your early thoughts?
I own an IN83 but am thinking of swapping it. Would appreciate any advice you can offer and comparison with anything you've used before.
In fact anyone who's got one! You have a captive audience!
I'm a bit concerned that Infocus shipped these without prioritising early delivery to online reviewers.
Seems a bit odd, because it has been a bit of a soft launch, especially after such a long wait.
Haven't seen anyone say they've been stunned by the quality yet either or that it is a step up from previous units, which is what I'd generally expect of something from Infocus.
SaintJD is offline
post #98 of 2008 Old 02-26-2010, 10:23 AM
Poagman's Avatar
I set the Iris to manual so accomodate different lighting conditions. Perhaps the auto settings needs to be disabled? It would make sense that you use the "Set Black Level" setting to take a snapshot of signal to make the adjustment and having the Iris on auto would cause it to move from the optimal black level settings. I am not home and can't try now unfortunately.
Poagman is offline
post #99 of 2008 Old 02-26-2010, 10:30 AM
Poagman's Avatar
Originally Posted by SaintJD View Post
Quite a few people on here are looking for reviews of the new machine - can you give us your early thoughts?
I actually posted my opinion earlier today on here at http://www.avsforum.com/avs-vb/showt...9#post18210279
I am not a professional installer, calibrater, just a long-time PJ user. I just wanted to point out pots of interest and major differences I saw between the IN83 and SP8602.
Poagman is offline
post #100 of 2008 Old 02-26-2010, 10:32 AM
Almost60's Avatar
There isn't yet "Pandorum" in Italy.
But , if you see grain in Blu ray of Peter Jackson's King Kong (for example) , would mean that is the projector...
Almost60 is offline
post #101 of 2008 Old 02-26-2010, 10:38 AM
Almost60's Avatar
@ Poagman
The SP8602 is razor like IN83?
You see difference between 0,65" and 0,95" DMD?
Almost60 is offline
post #102 of 2008 Old 02-26-2010, 10:41 AM
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
When using HD source many options may go away, and the feature mentioned is for analog sources
Noah
noah katz is offline
post #103 of 2008 Old 02-26-2010, 10:56 AM
Poagman's Avatar
@ Poagman
With the IN83 I could notice the lines between the DLP mirrors when i got close. Kind of like looking through a screen door. With the SP8602 it was a lot harder to see. I would think it would have been worse, but it wasn't.
Is there something else i should be looking for in regards to the chip size?
Poagman is offline
post #104 of 2008 Old 02-26-2010, 11:00 AM
Almost60's Avatar
OK... Thanks
Almost60 is offline
post #105 of 2008 Old 02-26-2010, 11:38 AM
Mikenificent1's Avatar
Quoted: 74 Post(s)
are the pixels as sharp? can you see the dimple of the individual mirrors when you get really close?
Mikenificent1 is offline
post #106 of 2008 Old 02-26-2010, 12:41 PM - Thread Starter
luelf21's Avatar
When you say you set it to manual, do you mean the selections from 10%-100%? If so, what is yours set at?
After reading the description of "set black levels" I found that it is disabled on mine because I am using HDMI connections. The "set black level" selection is for analog signals ONLY.
luelf21 is offline
post #107 of 2008 Old 02-26-2010, 08:17 PM - Thread Starter
luelf21's Avatar
You can take a look at the very first post in this thread and see the black levels of my projector. the clones wars, the dark city shot, and the dark WB emblem give a pretty good idea.
luelf21 is offline
post #108 of 2008 Old 02-26-2010, 08:33 PM
JDecleri's Avatar
My experience in setting brightness when using HDMI input is that the projector can display black, the 2% pluge pattern (using DVE disk) and up to 100% white but will not display blacker than black or whiter than white levels. It does not make a difference if the auto iris is engaged or not.
Its interesting that my manual and the on line manual does not indicate the motion flow feature which is accessible in the menu. I tried using it on 1080p 24fps dvd and it made quick movements very "blocky". When the feature is disabled the motion was much smoother.
Compared to my old DLP this unit puts out a very sharp image with typical DLP 3d "pop".
Joe
JDecleri is offline
post #109 of 2008 Old 02-26-2010, 09:23 PM - Thread Starter
luelf21's Avatar
Joe
so maybe I should try component video?
Also, should I put my iris to auto? 100%? what is best and y?
luelf21 is offline
post #110 of 2008 Old 02-26-2010, 10:40 PM
Quoted: 74 Post(s)
Joe
Did you check the settings for some kind of HDMI input level, or black level setting (i.e. "standard" or "enhanced")? changing that on most pj's allows btb and wtw to pass. Also, are you sure that the rest of your equipment in the signal chain are able to pass BTB and WTW?
post #111 of 2008 Old 02-26-2010, 11:19 PM - Thread Starter
luelf21's Avatar
There is a 'set black level' but is only for analog sources. Other than that there's no settings I can find that are equivalent to what you're explaining.
luelf21 is offline
post #112 of 2008 Old 02-27-2010, 08:04 AM
JDecleri's Avatar
It is my understanding that there is no reason to display BTB or WTW. On a grayscale ramp as long as you can see between the 100% black and 100% white your OK.
I did notice that the gamma adjustments make somewhat of a difference when viewing the gray ramp especially at low IRE values.
I would leave the iris set to auto as its a great feature to enhance black levels for dark scenes.
JDecleri is offline
post #113 of 2008 Old 02-27-2010, 10:33 AM - Thread Starter
luelf21's Avatar
1 for auto...anyone else.
I actually use reduced gamma to reduce clipping the red and blue channels.
luelf21 is offline
post #114 of 2008 Old 02-27-2010, 11:05 AM
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
Not really.
Cameras have limited dynamic range and crush the dimmest parts of an image to black.
The archives are full of screenshots showing the inky blacks of early LCD pj's with 400:1 CR.
Noah
post #115 of 2008 Old 02-27-2010, 01:55 PM
JDecleri's Avatar
How do you know you are clipping? Which end are you clipping - high or low IRE values?
JDecleri is offline
post #116 of 2008 Old 02-27-2010, 03:05 PM - Thread Starter
luelf21's Avatar
Based on the spears and munsil cal disc's clipping image.
luelf21 is offline
post #117 of 2008 Old 02-27-2010, 03:10 PM
Quoted: 74 Post(s)
There IS reason. It makes black level much easier to calibrate properly and WTW can be in the source.
I can't believe Infocus in 2010 is making the mistake of not passing
WTW and BTB. Especially after Planar made that mistake a couple of years ago with the 8150 and when they released a firmware upgrade to fix it, everyone commented at how much better the PJ looked after the change!
post #118 of 2008 Old 02-27-2010, 03:56 PM
Almost60's Avatar
How is the quality image of SP8602 whith HDTV 1080i?
Almost60 is offline
post #119 of 2008 Old 02-28-2010, 12:28 PM
Almost60's Avatar
How it works?
At 10% iris is in maximum aperture or maximum closure?
Almost60 is offline
post #120 of 2008 Old 02-28-2010, 02:31 PM - Thread Starter
luelf21's Avatar
How it works?
10% iris is maximum closure. As you start moving up the scale from 10% to 100% you can actually hear the iris opening little by little and start to see the image bet brighter.
luelf21 is offline
Infocus , In Focus
