Infocus Lens Swap, no differance...!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-04-2010, 12:41 AM - Thread Starter
mmmadman's Avatar
Hi All
I have recentley bought a used Infocus SP7205 and a SP5700 (don't ask its a long story) The 7205 was very dirty so I stripped it down have have thoughrly cleaned it.
While I had it in bits I also took the 5700 apart and swapped the lenses over. They have differnet throw ratios and the 5700 is more suitable to my living room. The lenses look identicle and had the same fixings so the job went very smoothly.
When I fired the 7205 back up the lens throw ratio hasn't changed, I cannot understand why or is it to do with the relationship between the lens and the light tube etc that gives the throw ratio.
Any feedback would be great......................
mmmadman is offline
post #2 of 7 Old 03-04-2010, 05:10 AM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
Was the distance from the image to the end of the lens the same in both projectors?
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 7 Old 03-04-2010, 05:52 AM - Thread Starter
mmmadman's Avatar
Yes it was, that's whats baffling me...........
I know that the 7205 has a different chipset, maybe that is a difference...!!
I think I have answered my own question it may be because the 7205 is 720p or would that just be more detail on the same size sensor......
mmmadman is offline
post #4 of 7 Old 03-04-2010, 10:26 AM
noah katz's Avatar
Quoted: 887 Post(s)
Liked: 305
Could be because the chips are different sizes and/or the distance from the chip to the lens is different.
Noah
noah katz is offline
post #5 of 7 Old 03-04-2010, 12:06 PM
Tryg's Avatar
Infocus projectors are compliant with the adage: "The more things change the more they stay the same"
Tryg is offline
post #6 of 7 Old 03-04-2010, 03:11 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
Tryg. I think the same would be a very accurate description of you too. No offense.
mark haflich is offline
post #7 of 7 Old 03-05-2010, 12:52 PM
Jason Turk's Avatar
Originally Posted by mmmadman View Post
Hi All
It's because as I recall the optics are the same. The reason they have different throws is due to the different sizes of the chips inside the projector. Your findings don't surprise me.
Jason Turk is offline
