Do Most Projectors Have AR Patterns For Zooming? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 03-21-2010, 09:05 AM - Thread Starter
R Harkness's Avatar
Quoted: 1939 Post(s)
Liked: 1646
To clarify my question:
I'm using the JVC RS20 in a "zooming" set up, using 4 way masking. It's working wonderfully well. Re-sizing the image and zooming takes seconds.
What is very helpful is that when I press the "Zoom" and "Shift" function on the RS20 it throws up a nice clear pattern on the screen, outlining various ARs (16:9, 1:85:1 I think, 2:35:1 and 4:3). That pattern makes it super easy to re-size the image even without a movie playing.
So, when it comes to upgrading my projector in the future, I'm wondering about other projectors: is it typical for a projector (especially around this price point) to have such a lens pattern feature with the ARs depicted? I might be bummed a bit if my next projector doesn't have this.
It wouldn't be a deal breaker; I could always use the actual movie image to fit, but I do like the option of the lens pattern.
R Harkness is offline
post #2 of 14 Old 03-21-2010, 09:11 AM
stanger89's Avatar
Quoted: 2653 Post(s)
Liked: 1355
I've never seen anything like that, though I've also never had a projector with remote control zoom.
stanger89 is online now
post #3 of 14 Old 03-21-2010, 09:20 AM
Fabricator's Avatar
Quoted: 29 Post(s)
this is what mine puts up.
excuss the screen. that is a mock up.
chasing rattles ......Pro8100 & Da-Lite HP 2.8 Cult member
Fabricator is online now
post #4 of 14 Old 03-21-2010, 11:39 AM - Thread Starter
R Harkness's Avatar
Liked: 1646
What projector is that, Fabricator?
The JVC pattern is definitely more detailed.
I wonder if Jason or another AVSforum employee can chime in, having seen so many projectors in their line of work.
post #5 of 14 Old 03-21-2010, 03:00 PM
Fabricator's Avatar
Quoted: 29 Post(s)
http://www.amazon.com/Viewsonic-PRO8...9205118&sr=8-1
it had a msrp of $5000
how about some pics ...
post #6 of 14 Old 03-22-2010, 07:21 AM
ilsiu's Avatar
Rich - can you post a pic of the JVC pattern?
ilsiu is offline
post #7 of 14 Old 03-22-2010, 08:27 AM - Thread Starter
R Harkness's Avatar
Liked: 1646
Ok, I'll try to post a photo of the JVC pattern.
Can anyone - Jason? - else chime in on this?
post #8 of 14 Old 03-22-2010, 08:28 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
The Samsung SP-900B has one in the user test patterns. Its called size.
mark haflich is offline
post #9 of 14 Old 03-22-2010, 08:38 AM
RonF's Avatar
Quoted: 257 Post(s)
Liked: 258
Rich, are you needing to refocus with each change? Am guessing yes as someone prior had said even small changes in zoom / shift changed the focus a bit.
When are you going to post some pics???
RonF is offline
post #10 of 14 Old 03-22-2010, 08:44 AM - Thread Starter
R Harkness's Avatar
Liked: 1646
You know what? The focus seems to change so little when I re-size that I almost never bother re-focusing (and when I do check focus up close I can rarely see a difference). The image looks pin-sharp whether it's blown up big or made smaller. I'm frankly amazed how convenient this zooming system has turned out to be.
At some point I plan to post pictures and hopefully some video of the masking system + zooming feature in action.
post #11 of 14 Old 03-22-2010, 09:31 AM
christopher a's Avatar
Rich, the zooming on the JVC's are indeed convienient. Almost too much, as I find myself tweaking way too much I always refocus after doing anything with the zoom. While the difference isn't drastic, I still find a subtle shift. What PJ are you thinking of upgrading to? Moving away from JVC in general?
Chris
christopher a is offline
post #12 of 14 Old 03-22-2010, 09:38 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3044 Post(s)
Liked: 2977
I've never found the need to refocus when zooming either my previous dVision 1080p or my Lumis, but I am only zooming from 106" wide to 118" wide, so it isn't a big change. And my 2 screens are only 5" apart at most.
While the Lumis has an AR pattern, I never use it. I use a paused movie - whatever we are about to watch that is requiring me to zoom to a different aspect ratio.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #13 of 14 Old 03-22-2010, 10:00 AM - Thread Starter
R Harkness's Avatar
Liked: 1646
Chris
I'm not planning on a change in projectors soon. It's just that, when I was recently programming more pre-set image size/ARs into my remote, I noted how convenient the AR pattern has been to use on my JVC, so I wondered if
that was something I'd have to likely give up, or if it's something I should expect to have, when I decide to upgrade projectors.
ETA: For kicks I was fooling around with my zoom/remasking while timing how long it takes. I've got it down to around 15 seconds to re-size the screen and fit the image to the screen. (E.g. changing from a 16:9 AR to a new 2:35:1 AR sized image). Lowest time was 12 seconds.
post #14 of 14 Old 03-22-2010, 10:33 AM
Liked: 1010
Changing the iris setting affects the focus enough to require a refocus to obtain maximum sharpness on the JVCs. See Mark Petersen`s Bloq Videovantage.
