NEW MITSUBISHI HC 9000 : FULL HD, 3D and..... Lcos panels - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 838 Old 07-27-2011, 12:44 AM
hamish b's Avatar
Originally Posted by david555 View Post
The new firmware for the cms is for august!
Will you have to update it at the service center or will it be able to be done ourselves
hamish b is offline
post #452 of 838 Old 07-27-2011, 02:20 AM
david555's Avatar
They tell me service center. (sorry for my English)
david555 is offline
post #453 of 838 Old 07-28-2011, 01:47 AM
hamish b's Avatar
has any body been able to use other 3d glasses/emitter other than the mits ones
the 5 pin vesa plug i would think would need an adapter or something
hamish b is offline
post #454 of 838 Old 07-28-2011, 02:23 AM
blee0120's Avatar
Quoted: 619 Post(s)
Liked: 316
blee0120 is online now
post #455 of 838 Old 08-13-2011, 06:14 PM
mtdking's Avatar
Quoted: 24 Post(s)
Any firmware update yet?
mtdking is offline
post #456 of 838 Old 08-22-2011, 12:35 PM
kabrumbs's Avatar
NotÃ*cias da Mitsubishi para a IFA 2011
http://www.cine4home.de/blog/2011/08...-der-ifa-2011/
"Der bereits eingeführte HC-9000 wird in einer überarbeiteten Version „HC9000 Advanced“ vorgestellt, neu sind hier die 2D->3D Konvertierung und ein verbessertes Colormanagement."
Google Translator:
"The already established HC-9000 is presented in a revised version of "HC9000 Advanced", here are the new 2D-> 3D conversion and an improved color management."
HC9000 Advanced???? Improved CMS????
Is this some kind of joke or bad translation?
kabrumbs is offline
post #457 of 838 Old 08-22-2011, 02:02 PM
clehner's Avatar
Having an actually WORKING CMS is no joke, my friend.
OTOH: Having a good preset will do the trick, too.
Regards
Christoph
Contact via Public Profile
clehner is offline
post #458 of 838 Old 08-22-2011, 02:16 PM
rovingtravler's Avatar
I think they are making a joke of why MITs is re-releasing a PJ as new and improved when all they have done is fix their OWN mistakes and make the PJ work as it should have from day one.
David
"You buy a Ferrari when you want to be somebody. You buy a Lamborghini when you are somebody." - Frank Sinatra
rovingtravler is offline
post #459 of 838 Old 08-22-2011, 04:26 PM
fraisa's Avatar
Can someone explain what this issue is
and why do you need it fixed
fraisa is offline
post #460 of 838 Old 08-22-2011, 06:02 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
The CMS did not fully work. Not fully working for a CMS is like being only partially pregnant.
mark haflich is offline
post #461 of 838 Old 08-22-2011, 07:32 PM
fraisa's Avatar
the units that Mits is putting out now or the last 3 months would this be fixed?
Define CMS is it Color Managment system
fraisa is offline
post #462 of 838 Old 08-22-2011, 08:14 PM
Liked: 1012
CMS is color management system. Its the chromacity point system that isn't fully working. Supposedly Mits was coming out with a software fix or some other for it. I don't know if they did or whether the problem was fixed in recent production.
post #463 of 838 Old 08-22-2011, 08:15 PM
mjg100's Avatar
Yes it is color management system. Can't fully calibrate the projector with out a 3D CMS unless you buy a VP like the lumagen.
Added
I see Mark beat me to it. Mark was your HC9000 calibrated using your lumagen?
mjg100 is offline
post #464 of 838 Old 08-22-2011, 08:24 PM
fraisa's Avatar
Added
Gotcha,
Next Question
With regards to 3d if the emitter is on the projector and it is ceiling mounted and you are sitting under and behind the projector will the 3d work or would the glasses loose communication with the emitter.
I played around with this once but i was standing up.
fraisa is offline
post #465 of 838 Old 08-23-2011, 11:17 AM
Liked: 1012
Mike. We did it using my Lumagen.
Emitters work better if placed in front of the theater high up and aimed at the viewing audience. The will usually work if aimed at the screen from a position near the projector with the glasses picking up the IR signal bounced off the screen. This does require some experimentation as to aim and the strengtht of the emitter beam, the distances involved, and even the screen material type.
post #466 of 838 Old 08-23-2011, 11:24 AM
mjg100's Avatar
In other words, best if you can mount at the top of the screen facing toward the audience.
mjg100 is offline
post #467 of 838 Old 08-23-2011, 02:42 PM
fraisa's Avatar
Wonder if a BD Screen would stop it from bouncing off the screen because of the Anti reflection...
fraisa is offline
post #468 of 838 Old 08-23-2011, 02:56 PM
Liked: 1012
IR is just light of a certain wavelength band. Screens reflect direct light so if the emitter shines on the screen and hits it at the right (correct angle) it should reflect back. How the particular reflective characterics are might affect things but I really don't know.
post #469 of 838 Old 08-23-2011, 06:41 PM
noah katz's Avatar
Quoted: 1095 Post(s)
Liked: 380
If the BD's reflectivity is purely a function of angle then it will inhibit reflection of IR signal the same as visible light.
It may inhibit it more or less depending on how reflectivity varies with wavelength.
noah katz is offline
post #470 of 838 Old 08-23-2011, 06:51 PM
Liked: 1012
So basically Noah, you are saying you really can't answer the question with respect to a BD screen. You could do it if you had a 3D projector using an emitter and at least one pair of the appropriate glasses and a BD screen but since you have none of the above you can't answer the question either. Just messing with you.
post #471 of 838 Old 08-23-2011, 09:15 PM
fraisa's Avatar
My 9000d will come in Friday,
Will let everyone know my thoughts when I get to play with it.
I will be using it on my Gen 3 Black Diamond .8 Gain ,,,,,
fraisa is offline
post #472 of 838 Old 08-24-2011, 09:55 AM
noah katz's Avatar
Liked: 380
Well now that I look at what you said more closely, I have to agree that it's fair to say that my answer is just a more elaborate way of saying "I don't know"
post #473 of 838 Old 08-24-2011, 12:50 PM
fraisa's Avatar
Has anyone had to do indepth calibrating to there 9000 or is it good out of the box...
Also has anyone used the Mits Flush Mount with this unit
is there any link to the flush mount instructions?
fraisa is offline
post #474 of 838 Old 08-24-2011, 02:44 PM
Personally I thought it needs a good calibration as the colors were noticably shifted.
David
post #475 of 838 Old 08-24-2011, 07:01 PM
fraisa's Avatar
what about the mount?
fraisa is offline
post #476 of 838 Old 08-24-2011, 10:02 PM
clehner's Avatar
The HC9000 has no preset that is close to REC709 and you are - with the current version of the CMS - not able to tune anything in close to that.
Regards
Christoph
clehner is offline
post #477 of 838 Old 08-25-2011, 06:28 AM
F,
What about the mount? there are many mounts that work. AVS sells them. Chief, etc.
David
post #478 of 838 Old 08-25-2011, 12:37 PM
fraisa's Avatar
F,
The mount i got is made for Mits by Premier.
the item number is
XL9000CM
Will take a pic of it and post it.
New Projector just was dropped off ,
Cant wait to put this on my .8 BD Screen
Think i may even play some Christmas music while unpacking the box and setting it up... he he
fraisa is offline
post #479 of 838 Old 08-25-2011, 01:57 PM
LOL
Have to love christmas in August!
David
post #480 of 838 Old 08-25-2011, 02:24 PM
fraisa's Avatar
LOL
Heck Ya....
fraisa is offline
Mitsubishi Hc9000d 3d 1080p Lcd Projector
