LED Longevity Overrated? - Page 3 - AVS Forum
post #61 of 81 Old 09-16-2010, 06:48 PM
BobL's Avatar
Liked: 52
You can replace the LED module on the Samsung DLP RPTV but they are pricey ~$900 from Samsung parts.
BobL is offline
post #62 of 81 Old 09-17-2010, 07:02 AM
Verge2's Avatar
Originally Posted by DaViD Boulet View Post
* LED has instand on/off ability which allows single-chip DLP to be driven without a mechanical color-wheel completely eliminating spoke time and any hint of "rainbow" artifacts for the majority of viewers who are sensitive to color-wheel discomfort with single-chip DLP designs.
How fast do they cycle?
With 3d being the new fad, how exactly are they planning on getting the lumens required?
Verge2 is offline
post #63 of 81 Old 09-17-2010, 10:10 AM
Mendo's Avatar
Looking around on Google, the predominant answer seems to be under a microsecond. So somewhere around a million times a second.
Mendo is offline
post #64 of 81 Old 09-17-2010, 11:10 AM
Verge2's Avatar
Doesn't mean the projector manufacturer will have them cycling at such a speed. That was my point.
There are rainbows on the cheapy LEDs out right now.
Verge2 is offline
post #65 of 81 Old 09-17-2010, 01:54 PM
stanger89's Avatar
Quoted: 59 Post(s)
Liked: 115
Cine4Home's tests had the Vivitek 9080 running 800-900Hz, or about 3x faster than the fastest current DLP color wheels. That would, I think, put it in the 20x range.
See what an anamorphoscopic lens can do, see movies the way they were meant to be seen
stanger89 is offline
post #66 of 81 Old 09-17-2010, 02:41 PM
AVS Club Gold
JapanDave's Avatar
Liked: 98
No rainbows on the Vango.
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is online now
post #67 of 81 Old 09-17-2010, 03:35 PM
MCaugusto's Avatar
Liked: 30
There are at least two online articles concerning "On/Off PhlatLight Chipset Cycling Speed" which stated that they cycle on/off at speeds of 2.9 KHz/second, or almost three million times per second.
The speed of the first generation 1x color wheels was 60 times/second (namely 60 Hz), or 3.600 RPM; Then they came up with 2x color wheels (120 Hz) or 7.200 RPM, and finally 3x color wheels (180 Hz) spinning at 10.800 RPM.
So, these PhlatLight chipsets cycling on/off at 2.9 KHz are theoretically 16 times faster than 3x color wheels running at 180 Hz.
Apparently color wheels cannot spin safely any faster than 10.000 to 15.000 RPM/second, so 3x color wheels running at 10.800 RPM is about as fast as the technology allows.
Am i correct in these figures and assumptions ?
BTW : Luminus Devices state that "PhlatLight chipsets run very cool because they emit directly into air unlike conventional LEDs which emit into an epoxy-based encapsulant, have very low failure rates and median lifetime that are well over 100.000 hours under extreme high current operating conditions and passed a rigorous suite of environmental and mechanical stress tests".
Marcos
MCaugusto is offline
post #68 of 81 Old 09-17-2010, 10:32 PM
Drexler's Avatar
MCAugusto,
They have double sets of color filters on the wheels (two reds, two blues, two greens) which makes the color wheel speed at 6X even though the wheel only rotates at 3X.
Drexler is offline
post #69 of 81 Old 09-18-2010, 05:49 AM
MCaugusto's Avatar
Liked: 30
Originally Posted by Drexler View Post
MCAugusto,
Yeah, i'm aware of the implementation of double-segment color wheels (RGBRGR) but is it fair to classify them as 6x wheels when they're still running at 3x speeds ?
If the idea behind double-segment color wheels was that RGB would be displayed at faster rates, which would imply less visible artifacts ("rainbows"), then why not make triple-segment wheels, quadruple-segment, etc ?
And whatever happened to that Archimedes color wheel design, which i believe had RGB spokes emanating from its center that progressively widened towards the edges of the wheel ?
Didn't Marantz had a 7-segment color wheel some years back, as in RGB/RGB/deepG ?
post #70 of 81 Old 09-18-2010, 08:53 AM
stanger89's Avatar
Quoted: 59 Post(s)
Liked: 115
Yes it is fair, for the reason you say the "x" refers to how many times RGB are repeated per frame, it's got nothing to do with the speed the wheel actually spins.
As for why not make more segments? Probably because the light beam that passes through it is of a finite, non-zero area, so each segment first has to be large enough to completely encompass the light beam, and has to do so, while moving/spinning for long enough to display a frame. I'd guess RGBRGB is about as small as you can practically get away with and still be able to display frames and keep everything in sync.
post #71 of 81 Old 09-18-2010, 10:17 AM
pjpoes's Avatar
Having been involved in some of the statistical analysis of product longevity data, one project involving a related LED technology, I can tell you that they have not actually tested their life span. Phatlight doesn't likely know, its estimated. The estimates are based on sophisticated statistical models which take into account actual known parameters, which have been measured. This makes the models relatively accurate.
For those familiar with statistics, you may also know that one potential pitfall in such models is that if you extrapolate out passed known ranges, the predicted values can be way off. If you utilized human growth characteristics for the first 10 years of life to extrapolate height and weight at 45 years, people would be 50 feet tall and 1000lbs. That isn't true because our height and weight from birth to adulthood is non-linear. The big difference is that much of this is known for devices like LED's, and so they are far more linear devices. Additionally, if we find that they do decay in a non-linear fashion (most bulbs do, but LED's are very different), we can account for that in the model and create more accurate predictions.
My understanding is that the specified life of the LED bulbs for these projectors is actually far less than what is being statistically predicted. LED's are known to dim very little over their life time compared with other bulbs, and we will not see them needing replacement every 2000 hours by any means. Getting 10,000 or 50,000 or even 100,000 hours is another story, I think we will see the low end, not the high end. Still, from even own look at the statistical data for the "related" devices, I'm fairly certain you won't see 50% loss in output at 50,000 hours, it will actually be more likely to just die than dim greatly.
Because of how they are currently being implemented, I am fairly certain they will be very expensive to replace. I'm sure these manufacturers are doing their best to make this as reasonable as possible, but its not going to be as simple as replacing the LED chip. An entire assembly including parts of the cooling components are going to be replaced, however the boards can be rebuild with new LED chips, as most of the other components will not age much.
pjpoes is offline
post #72 of 81 Old 09-18-2010, 01:11 PM
DaViD Boulet's Avatar
Liked: 38
Sigh. Can we keep to legit conversation rather than distraction?
The cheap LED PJs *use color wheels*. They are not using the actual RGB LEDs to sequence like higher-end HT models... they just push "white" light through a color wheel like old-fashioned bulb PJs.
Regarding brightness for 3D, LED will continue to get brighter and brighter. Does that need explaining???
1080p and lossless audio. EVERY BD should have them both.
DaViD Boulet is online now
post #73 of 81 Old 09-18-2010, 01:14 PM
Liked: 38
Color wheels waste light because the DMD "goes black" while the color transitions from one color to another. The more color segments you add to a wheel the more time is wasted. This is called "spoke time".
LED would be instant on/off with *no* spoke time at all. It would mean you could have a DMD that cycles colors incredibly fast bcs you wouldn't have any disadvantage with faster color sequencing as long as your DSP engine could handle it.
post #74 of 81 Old 09-18-2010, 06:38 PM
mark haflich's Avatar
Quoted: 112 Post(s)
Liked: 312
David. Does that mean that bulbs will be getting brighter and brighter or that posters will be getting brighter and brighter?
Mark Haflich
markhaflich@yahoo.com
call me at: 240 876 2536
mark haflich is online now
post #75 of 81 Old 09-19-2010, 12:58 PM
Liked: 38
post #76 of 81 Old 09-21-2010, 09:52 AM
mlang46's Avatar
Do they perform accelerated (increased Temperature tests) on Leds as they do on lasers than extrapolate the room temperature lifetimes from those tests.
mlang46 is offline
post #77 of 81 Old 09-21-2010, 03:12 PM
Brandon B's Avatar
Sigh back. No they don't. At least not any of the dozen or so models of pocket and pico LED projectors we are buying. They are all RGB LED sequencing models that emulate very low color wheel speed and rainbow like hell. And I know this for a fact because we have taken all of them apart.
We have seen only one pico unit that used white LEDs and LCOS out of all of them.
Brandon B is offline
post #78 of 81 Old 09-21-2010, 03:17 PM
Brandon B's Avatar
As I posted earlier in this thread, we actually ran a few units out to their projected lifetimes of 20,000 hours and saw brightness drops in the range the manufacturer claimed.
But these were <100 lumen pocket models, not HT units where they are pushing the envelope to get usable brightness, so you are probably correct in your predictions nonetheless.
post #79 of 81 Old 09-21-2010, 04:10 PM
Liked: 38
Thanks for the correction. However, even if there are cheap designs using LED light source that, even in the absence of a color wheel, don't bother to implement sequencing speed fast enough to eliminate color separation artifacts, that doesn't negate that LED light source makes possible the elimination of color-separation artifacts for a product designed with high-quality images as an objective. There are products in every technology category that fall well below the performance levels possible when cost or size or some other non-fidelity criteria is the primary objective of the product designers.
Otherwise, we can't talk about the benefits of *any* technology because there's a bad implimentation of everything out there that doesn't live up to the technology's capability.
In a few short year's LED lamp sources will be able to replace bulbs in single-chip DLP HT oriented projectors and in doing so eliminate color separation artifacts for virtually all viewers. Naturally there will be cheap products available that don't live up to the technology's capability. Just like there are cheap bulb-lit DLP units today that don't live up to bulb-based DLP performance levels we're accustomed to in HT products. That doesn't say anything about "bulbs", it just demonstrates how cheap products cut corners.
post #80 of 81 Old 09-21-2010, 07:08 PM
FiveMillionWays's Avatar
I use my led tv every day and leave it on over night and I have yet to notice any light output change. DLP LED TV!!!
FiveMillionWays is offline
post #81 of 81 Old 09-22-2010, 12:34 AM
rogo's Avatar
Quoted: 35 Post(s)
Liked: 382
Thank goodness we have an accurate, calibrated test of light loss. Your efforts are appreciated.
There is no difference in HDMI cables. If you can see the picture without visible dropouts or sparklies, the cable is working at 100%. No other cable will display a better version of that picture. You're simply wrong if you think there is a better digital cable than one that is already working.
rogo is offline
User Tag List
