The Ultimate 3D projection system: A Practical Discussion Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #61 of 2420 Old 10-06-2010, 01:28 PM - Thread Starter
rdjam's Avatar
Originally Posted by darinp2 View Post
I asked you for a source and instead you just say that is how it works. Honestly, I get the feeling that you don't really know, are making an assumption, and passing it off as fact here. Maybe you actually do have some information to back this up, so please provide it if you have it. I'm not trying to get personal...
Drexler and omicronian had it right, Darin. No need for the tone. That's why the proper lenses for the projectors can cost in the thousands, and the glasses cost under $100. There is plenty of discussion about this on various 3D forums if you do a search. If I get some time I'll go back and do another search for you.
The other reason not mentioned above by the others is that the viewer glasses themselves are not designed to be subjected to as much light energy as the proper lenses, and they can literally "wear out" due to heat and stress, when used on the projector barrel.
rdjam is offline
post #62 of 2420 Old 10-06-2010, 02:34 PM
darinp2's Avatar
Quoted: 1130 Post(s)
Liked: 1765
Okay, so what relevant wavelengths do the glasses not block that the other filters do? Maybe those people have it wrong on that one issue given that my actual measurements show that about 99.7% of even sunlight outside is getting blocked by using 2 lenses stacked according to a high end meter measuring off a white piece of paper. Or maybe the wavelengths they and you are talking about aren't even in the visible range, or are blocked by projectors with UHP lamps normally anyway (especially by LCD projectors using LCD lamps). From anybody who thinks the filters won't work strictly on the basis that "... the glasses are designed to allow, not block, certain light frequencies" (not the heat/too much light issue) I would love to hear what the specific wavelengths are that the glasses don't block, but are blocked by the other filters.
And I would like to hear why they would make the glasses let light through at wavelengths that the internal filters don't if somebody is claiming that the glasses have 3 bands that are wider than the internal filter bands.
Ghosting at .3% with 2 lens filters stacked could definitely be worse than with the other filters put inside, but I'm talking about the issue of it being a problem because, "... the glasses are designed to allow, not block, certain light frequencies."
For the record, my numbers measuring off the white piece of paper outside about half an hour ago using a Minolta LS-110 were (in cd/m2):
No filter: 17500
Green filter: 3600
Red filter: 8200
Both filters: 56
--Darin
This is the AV Science Forum. Please don't be gullible and please do remember the saying, "Fool me once, shame on you. Fool me twice, shame on me."
darinp2 is offline
post #63 of 2420 Old 10-06-2010, 04:27 PM
omicronian's Avatar
I have a few unordered thoughts :
If it's black with both lens superposed, they obviously allow only the 3 narrow bands.
I think a 300:1 extinction ratio is better than probably any silver screens (haven't found anything significantly better than 200:1 on axis, including Stewart and Harkness), so this could still be a high quality alternative to passive polarizers.
Depending on how sensitive the angle is, it could be a problem with any projectors unless they are very long throw. Otherwise there would be a need for an (expensive) spherical filter, or putting the filters inside the projector. This is an even bigger problem because we want the shortest throw possible for the highest light output.
I don't know exactly how it works, but if the glasses are based on some form of waveplates, and other weird optics requiring precise thickness, the wavelength of those would probably shift based on the angle (thickness augments at an angle). The projector's filters would need to have narrower bands than the glasses, then the glasses would have some wiggle room to fit the narrow filters inside of their wider filters. That would improve the extinction ratio.
The 94% quoted loss could make sense, depending on how they calculated it:
- Darin's "red filter" measurements gets 7.4, on a total available light of 51.8
- I assume it would be less with the correct white point, let's say (this is completely arbitrary) it would be 6
- the other eye would need to perfectly match the white point, the brightness, and the gamut, so it can't possibly get more than 6, it needs to be exactly the same.
- Each eye see only one projector, the total effective brightness is 6, the total initial available light is 103.6. Calculating that way would give the 94% loss.
- Calculating the same way, a single DLP with those 6 different colors on the wheel (instead of the RGBRGB wheel) would get 3 of the 51.8 available light, so half the brightness of the dual projector setup, and also 94% effective loss.
This technology would be a revolution if we had those 6 wavelengths available in high-power leds or even laser, inside a single chip DLP projector.
omicronian is offline
post #64 of 2420 Old 10-07-2010, 09:44 AM - Thread Starter
rdjam's Avatar
Omicronian - yes - it would be extremely efficient and bright, if LEDs were used that were designed to produce JUST those 6 wavelengths. Would certainly be a revolution for the format, which right now suffers a lot of light loss in comparison to polarised.
Darin - wish I could help you there, but I just would have no way of knowing what the specific wavelengths are that are blocked or allowed by the respective lenses. Perhaps you can find some of that info on their site.
But, since you are experimenting with these glasses lenses right now, the best feedback should probably be coming from you. Are you getting an enjoyable picture right now, by using the eyewear lenses on the projectors, combined with the glasses?
When you view an image from the projector with the green lens, through the red lens in the glasses, are you getting 100% extinction? ie: Is the screen totally black? If so, then it's working for you. If not, then you will see ghosting, to whatever extent you are not getting 100% extinction.
Give us some feedback on what you see.
rdjam is offline
post #65 of 2420 Old 10-07-2010, 09:57 AM - Thread Starter
rdjam's Avatar
OK - so here is the 3D dream system I am putting together, as I visualise it right now....
2 x JVC RS 40 projectors
2 x Optoma 3D-XL boxes (to split the 3D stream into left and right streams)
? x eeColor HDMI 1.4 box with Darbee color (unsure how many I will need yet, 1 or 2...)
1 x Pair of circular polarised, glass Encased AR treated high transmission (80%) filters from SilverFabric
Set of 10 or 20 RealD-style circular polarised glasses..
Notes: If it were not for the eeColor box in my plan, I would have selected the RS 50 for this project, because CMS color correction may be very important to handle the color shifts created by the polarising filters. However, because the eeColor will be part of the system, color correction can be handled there, instead of in the projector, which saves about $4,000 on the price of the setup - which will be applied to the eeColor boxes, thereby getting the advantage of Darbee color thrown in at essentially no extra charge - hopefully!
rdjam is offline
post #66 of 2420 Old 10-07-2010, 10:35 AM
Drexler's Avatar
Quoted: 95 Post(s)
Liked: 65
If you really want to know - lend me a piece of glass from one of the glasses and I could do a wavelength scan in the spectrophotometer at work and we'll have in black and white the exact part of the spectrum that is blocked and how much is let through. (I'm a scientist in a biochemistry lab).
Drexler is offline
post #67 of 2420 Old 10-07-2010, 11:52 AM
omicronian's Avatar
rdjam, how will you have a working system by adding circular polarizers, considering the projectors are already circular poalrized ?
How much light do you expect to have compared to a single rs40 with shutter glasses if you put a polarizer on each projector ?
post #68 of 2420 Old 10-07-2010, 12:58 PM
darinp2's Avatar
Liked: 1765
We should keep in mind that the 300:1 isn't white to black since they also reduce the white level. Looks like closer to 100:1.
As I've mentioned, I don't have a way to drive 3D to them. Only experimented with simple test patterns and used the glasses to play a videogame full screen with 2 people getting their own image. Worked pretty well, but one image is very greenish and one very reddish.
No, as I pretty much mentioned earlier.
That isn't really the case because our eyes can adjust quite a bit with a little time, so you can't just go by what you see when just looking at the one image that should be black. Obviously if it is black then you are good to go, but it doesn't have to be that dark to human vision when looking at one to work without visible ghosting when looking at both images at the same time.
--Darin
darinp2 is offline
post #69 of 2420 Old 10-07-2010, 01:00 PM
darinp2's Avatar
Liked: 1765
Thanks. I could send you a pair of glasses or just the lenses out of them. Just let me know what you want and where I should send it.
--Darin
darinp2 is offline
post #70 of 2420 Old 10-07-2010, 02:29 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1011
Got it Darin. The spirit CAN still be with you without you seeing any ghosts.
mark haflich is offline
post #71 of 2420 Old 10-07-2010, 07:34 PM - Thread Starter
rdjam's Avatar
According to the fellow I've been speaking to, when the light is not polarized, a LOT more is blocked and the transmissivity of the polarisation is low.
However, when the light is already polarised, the circular polarisers do not have to block most of the light, and accepts the polarised light before converting it to "circular". Or something along those lines.
Circular polarised filters that have to deal with a non-polarised source top out at 46% or so passthru - however, when designed for and working with a polarised source, they can exceed 75% transmissivity.
That's why I'm so excited about this.
The actual perceived light I expect from this dual projector setup will be roughly 1400 lumens, times 80% (for the lenses), times 80% for the glasses. So the 1400 lumens will turn into ROUGHLY the equivalent of 896 lumens. Not far off of what I currently get from the 950 and 550 right now.
Yes - calibration can affect BOTH of these numbers equally.
rdjam is offline
post #72 of 2420 Old 10-08-2010, 05:51 AM - Thread Starter
rdjam's Avatar
OK - GaryB from JVC in the UK has given some feedback that it appears that the colors on the X7/RS50 are also aligned together, making this suitable for circular polarising systems.
http://www.avsforum.com/avs-vb/showt...5#post19306385
I will get confirmation as soon as I can.
rdjam is offline
post #73 of 2420 Old 10-08-2010, 08:24 AM
omicronian's Avatar
Yes, I understand you want to do what we assume LG did with the CF3D, but what you are trying to do won't work.
The main issue is that both of your projectors will be polarized the same way, you'll get either two left eyes or two right eyes. You don't need a polarizer if you already have polarized light. You have to reverse the polarization on one of the projectors, and you cannot do that with a polarizer, it would simply block the light.
I think the Runco system is using a glass that reverse the polarization with a current applied. That kind of assembly is possibly available from scientific optics suppliers. From what I understand of circular polarization, you'd need a half-wave plate.
(EDIT: I found some documentation, a half-wave plate works to reverse the circular polarization)
http://www.redoptronics.com/waveplate.html
It works for lasers, with a single wavelength, Not sure how much it will work on white light. Probably not well.
post #74 of 2420 Old 10-08-2010, 01:06 PM
omicronian's Avatar
Something difficult to setup physically, but inexpensive and higher quality, would be to use a first-surface mirror at 45 degrees on one projector. You'd get 98% of one projector.
Mount one of them normally, and the other shooting at 90 degrees, very close to the lens of the other projector, with a mirror at 45 degrees as close as possible to the lens.
post #75 of 2420 Old 10-08-2010, 04:30 PM
AJSJones's Avatar
There are pictures at this link - real spectra and also the spectrum of the light being filtered by the two types of filter. There are also lasers available (at least in the physics world) to fit into each window and be super duper low crosstalk with the eixisting filters...
(I used to be a scientist in a biochemistry lab and spectroscopy was a specialty )
I finally read the last sentence at that link (I'm a glasses wearer)
Another aspect of practical relevance may be the feasibility of depositing the dielectric multilayer, which causes the interference filter characteristic, onto glasses with optical correction. So, users with eyeglasses do not need extra-glasses as they can use correction glasses with the specific dielectric multilayer deposition.
AJSJones is offline
post #76 of 2420 Old 10-08-2010, 07:50 PM - Thread Starter
rdjam's Avatar
Maximum respect, omicronian, but that it incorrect. The beauty of circular polarisation is that you can start from the same linear polarized angle, and flip it each way for left or right. It's like the perfect set up. You don't lose anything. The lenses i am looking at take the exact same linear polarised light and flip one direction or the other, which is why they have higher transmissivity.
rdjam is offline
post #77 of 2420 Old 10-08-2010, 08:18 PM
omicronian's Avatar
Okay, wait a sec, is the output of the JVC linear or circular ? I only have an SXRD to test and it's already circular, are you saying the JVC is linear ?
post #78 of 2420 Old 10-08-2010, 08:38 PM
Liked: 1011
Wire grid polarizers are linear polarizers, not circular. At least that is what I have read so far. Of course, I only understand a fraction of what I have read.
post #79 of 2420 Old 10-08-2010, 09:05 PM - Thread Starter
rdjam's Avatar
Yes - JVC is linear polarised, all colors to same 0 degrees. I've confirmed on 550 and 950, and GaryB has indicated the same on the RS 50. This sets up high efficiency circular polarisers like the unit I'm looking at from SilverFabric.
rdjam is offline
post #80 of 2420 Old 10-08-2010, 09:23 PM
omicronian's Avatar
Oh wow, that's great, it's linear so it's full of options !
This makes me consider trying it, but I'm a chicken, so I'll wait for you to tell me if it works well
post #81 of 2420 Old 10-08-2010, 10:34 PM - Thread Starter
rdjam's Avatar
I'm closing my eyes and taking the jump
I'll let you know how it works as soon as the projectors arrive!
rdjam is offline
post #82 of 2420 Old 10-08-2010, 10:41 PM
Liked: 1011
Good night all.
post #83 of 2420 Old 10-09-2010, 10:48 AM
Deja Vu's Avatar
Quoted: 933 Post(s)
Liked: 950
O.K. for those who have not already seen this thread - here it is, the most definitive dual projector passive setup thread I've seen. This forum member, who is using this system, supports Mark Haflich's claim that 2 projectors for 3D is considerably brighter than any single projector system. He's using 2 Epson LCD pjs with passive filters so apparently it does work! See posts 1305 and 1307 (Blackshark)
http://www.avsforum.com/avs-vb/showt...1#post19099091
Deja Vu is offline
post #84 of 2420 Old 10-09-2010, 11:15 AM
omicronian's Avatar
EDIT: I don't think the Epson setup can take advantage of the polarization.
It remains to be seen how much light gets through, considering all 3 panels are not aligned the same way, and the solution was to put the polarizers at 45 degrees (cutting half the brightness in the process). I assume the JVC will probably be much less problematic and more efficient because all panels have the polarization aligned.
In light of rdjam's mention that the JVCs are linear polarized and aligned, I'm rewriting all my assumptions about the efficiency of different 3D systems right here. It all depends on how exact the numbers are and the reliability of the sources. For the record I think the realD glasses are more than 66% but it's the numbers from realD and other's claiming 60% to 70%. I am also beginning to doubt the 1300 versus 900 advantage. I also doubt the 17% from realD as they possibly don't account for blanking. Measurements will tell, so I keep those number until proven otherwise. All percentages are transmittance, not loss. The total is a percentage relative to a single projector's light output in 2D.
EDIT: I found some more detailed documentation from RealD, and glasses specs are 80%, not 66%. My guess is that the 66% was for the whole system, not just the glasses (80% * 80% = about 66%) So I changed all numbers.
Sony vw90es and other simple shutter systems, including single DLP:
17% shutters
total : 17%
JVC RS40 with (still unconfirmed) 1300 lumens in 3D compared to 900 in 2D at D65:
17% shutters
1300/900 gain in lumens
total : 24%
Dual LCD like the Epsons (unaligned panel polarization) :
80% polarizers
50% 45 degrees polarization angle
80% RealD glasses
Total = 32%
Dual DLP (not polarized):
40% polarizers
80% RealD glasses
Total = 32%
rdjam dream system above or other LCD or LCOS with all panels with a linear polarization aligned:
80% polarizers
80% RealD glasses
Total = 64%
LG with all panels circular polarization aligned (assumed):
80% RealD glasses
Total = 80% (of one light engine, this is 2 projectors in one case)
I am beginning to get a much better understanding of exactly why all dual projector setups at CEDIA were perceived A LOT brighter than the JVC.
- I previously calculated 24% vs 27% for a single RS40, versus dual 900 lumens projectors with realD polarizers.
- It is now 24% vs 32% because the realD glasses transmittance number was wrong.
- With the JVC being linear and aligned polarization it is possible to get 64%, similar to what the LG is doing (but we already knew that about the LG).
- DLP systems are still 32% with the numbers I used.
24 versus 32 is not significant enough, so my next hypothesis to test are :
- The 17% number is possibly wrong because it doesn't account for the blanking
- The 1300 lumens might not be at D65 through the glasses, it could be less than what the hype suggested (or 2D at D65 is more than 900)
- The expensive DLP systems might have a light source significantly above 200W, and they were calculating the light output AFTER polarization
- Those DLPs have a light source that is already polarized (a special kind of LED perhaps), DLP, being a mirror, would retain that polarization
- Things were lost in translation because I don't speak german
post #85 of 2420 Old 10-09-2010, 01:14 PM
omicronian's Avatar
rdjam, I think you could get more than 80%, possibly near 100% by using a quarter wave plate at 45 degrees and 135 degrees instead of complete polarizers. A circular polarizer being a linear polarizer with a wave plate added, since your light is already linear polarized, you only need the wave plate. Less loss in the process. Maybe it's worth a try, you might get about the same efficiency as the LG. Of course it depends what the loss is on the polarizer part, and the waveplate part. Maybe it's all in the waveplate...
Another idea, you could also use an LCD plate to rotate one projector's polarization by 90 degrees (essentially an LCD shutter element without a polarizer), and use linear IMAX glasses, they have better extinction ratio than realD, and you'd also get possibly much more than 80% efficiency. The IMAX glasses are also 80% to 90% versus realD 80%. Those glasses don't have any of the purple ghosting that the realD glasses have. As long as you keep you head straight
post #86 of 2420 Old 10-09-2010, 03:15 PM
Liked: 1011
I can lock my head in a vice for viewing. But when I try to understand all this, I definately can`t keep my head straight.
post #87 of 2420 Old 10-09-2010, 07:54 PM - Thread Starter
rdjam's Avatar
That is certainly worth exploring. Given that it appears the JVC is polarised already, and at the same angle, I will investigate the wave plate idea. Haven't bumped into any yet, but that's probably becayse I wasn't searching for them.
Hmmm... I'm not keen on linear polarisation. Based on my IMAX experience, it's just too finicky, IMO. I may prefer to stick with circular for this one.
rdjam is offline
post #88 of 2420 Old 10-09-2010, 08:32 PM
omicronian's Avatar
I just found a small problem that could prevent the system from working well. I was reading about wave-plates and I am now sure they don't work well with white light. The problem I found is that realD glasses are made with a wave plate.
The impact of this is that the realD glasses are NOT circular polarizers on all visible light, they are tuned on green, so they become a mix between linear and circular with red and blue, that is because the wave plate in it only works with green light.
You can test that problem by wearing a pair of realD glasses, and looking through a second pair level (with the branches away from you) toward a bright white wall. Closing one eye, the lens which you expect to be black is actually purple. To get a good black and white, you need to put the second pair vertical at 90 degrees, because red and blue are still linear polarization and are still dependent on the angle. This is a problem because it means you will need to have the projectors polarization aligned with the glasses, or you'll lose light and/or extinction ratio.
I thought of a test to verify if it will be a problem with a specific projector.
- Put some realD glasses on the projector (branches must be toward the projector, not toward you) and rotate it, looking at the effect the angle has on light output.
- There should be an angle with almost no loss of light, and it should be black exactly 90 degrees from that point.
- If the highest light output is with the glasses at 90 degrees vertical,the standard realD glasses will work. Otherwise they might cause a heavy purple ghosting.
Of course I can't do this test with my projector (sxrd), but I tried it with an LCD monitor which is linear polarized, and I need a 45 degrees angle to get the most light output, I don't know if it's the monitor that is at 45 degrees or the realD glasses. Please tell me if you test it with a JVC !
post #89 of 2420 Old 10-09-2010, 10:43 PM - Thread Starter
rdjam's Avatar
In light of rdjam's mention that the JVCs are linear polarized and aligned...
Yes - I read 80% transmission for the RealD style glasses also. I guestimate your 64% for the setup I'm looking at is about right.
However, re: the LG, you may not be quite apples to apples, as the 2500 lumens measured is already after the filters, so actually you are only measuring the loss to the glasses. The projector was likely even brighter before polarisation. My guess is that the 2500 lumens stated for the LG is actually in 2D mode with both light engines, and that each light engine is actually closer to 1200 or 1300 lumens. So it may be very similar to the JVC setup im buildng, except cheaper, and with FI and higher CR and detail
rdjam is offline
post #90 of 2420 Old 10-09-2010, 10:57 PM
omicronian's Avatar
Agreed, the LG is 2 projectors in one case after all...
Sony Vpl Hw50es 3d Projector
