Epson Pro Cinema 9700UB Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
Old 04-04-2011, 08:54 PM
william06's Avatar
Quoted: 111 Post(s)
Liked: 63
Originally Posted by fraisa View Post
These units have a dust filter at the back of the unit.
No need to take the unit apart what so ever...
THX Settings
here is updated settings,
these ones are different from my other posted settings.
For me with a black diamond screen they work great.
Used the DIsney wow bluray to adjust brightness , contrast, hue and chroma
Thx mode
Brightness 2
Contrast -6
Saturation 1
Tint 3
Power Normal
Iris off
sharpness....2..advanced....12/12..2/2
Gamma 2.3
RGR...
offset (R,G,B) 5,-6,4
Gain.....(R,G,B) 2,-4,1
RGBCMY advanced
R: -3,-8,2
G: -26,-64,63
B: -14,5,0
C: 0,-43,45
M: -10,-1,0
Y: 1,-22,20
Contrast Enhancement 1
SuperResolution 3
NoiseReduction 2...
Again these are newer settings Use these to start and adjust per your room...
Thanks for sharing. Tried these on my 9500 worked very well on my daylight High contrast cinemavision screen.
william06 is online now
Old 04-04-2011, 09:36 PM - Thread Starter
fraisa's Avatar
That's Really Good to hear.
My concern for other people was The brightness and Contrast levels.
Since my screen is a BD i didn't know how it would work for others.
I do find that these levels help eliminate Black and White Clipping...
My blacks are now not as buried and have proper detail.
I have new Modified Vivid settings geared for HDTV that i will post
later this week.
fraisa is offline
Old 04-04-2011, 11:04 PM
goducks44's Avatar
I just installed my Epson 9700 just in time for the final 4. Picture looks great when action is still. During the action/motion of the game it seems jittery and out of focus at times. At times the players looked robotic- if that makes sense. At time the picture seemed to have a lot of noise. I have the projector set to the THX setting. I have put 15 hours on the unit. I will eventually have it set up but I want to make sure that there is not something wrong or the quality of the projector is not all that good......
This unit replaced my Runco CL420 - 720P project. I never had any issues like this.
Has any experienced this???
goducks44 is offline
Old 04-05-2011, 06:00 AM
william06's Avatar
Quoted: 111 Post(s)
Liked: 63
later this week.
Hey great thanks looking forward to them. Seems to work very well on my screen. It is high contrast grey 110" with a separate mask. Settings look great. The VIVid best on tv and the thx on dve and bd. Although I used your thx on the borgias and it looked terrific. Hate using the normal but have a couple extra bulbs in case.
Old 04-05-2011, 06:48 AM - Thread Starter
fraisa's Avatar
I put the noise Reduction setting at 2
Vivid is the best for watching hdtv
What screen do you have it on?
Also when watching BluRay make sure your 4/4 pulldown is on
and when not make sure its off
fraisa is offline
Old 04-05-2011, 07:49 AM
goducks44's Avatar
I am using a Stewart Screen - Fox Fire?
How do I activate the 4/4 drop down as it is greyed out?
Have you had any of the same issues that I am experiencing? Is it the machine, quality or set-up?
Old 04-05-2011, 07:56 AM - Thread Starter
fraisa's Avatar
you need to read your manual...
The 9700 is dealer sold only. unless you got one used
Dealers are suppose to go thru all these options with you..
you should direct these questions to your dealer...
What Color mode are you in...
Thx or Vivid or Silver Screen?
fraisa is offline
Old 04-05-2011, 08:20 AM
goducks44's Avatar
I have/am reading my manual. I bought the unit "new", I will call and discuss with them today. I am using this venue as an avenue to see if others are experiencing some of the same issues.
I am currently using THX.
Old 04-05-2011, 09:25 AM - Thread Starter
fraisa's Avatar
If your Source doesnt give out the 4/4 info then the unit wont offer the option ,
thats why its grayed out...
then you will be stuck with just using the Frame Interpolation but this can make the image look unfilm like ...
What source are you using for bluRay...?
How is it connected
are you using hdmi...
My system is connected like this
Projector to Receiver...Yamaha a 2000 via hdmi
then My components are connected separately to the Yamaha..
Ie
Bluray, Media Player, Dish HD PVR, Bell HD PVR, Xbox 360, PS3, FTA HD Satellite PVR, all connected thru HDMI
D-VHS JVC connected via Component, Wii connect to D VHS...
fraisa is offline
Old 04-05-2011, 09:50 AM
goducks44's Avatar
My blue ray source is an Oppo - brand new. I just purchased a Marantz AV7005. I am connecting the Project to the 7005 via HDMI. I am running HDMI from all source components to the 7005. I have watched limited movies (time). I was not impressed watching the game last night, as I mentioned earlier the picture at times was jittery and seemed out of focus and had a lot of noise during motion.
I have watched about 10 minutes of a blue ray and I didn't notice the same issues.
Comcast is my cable provider could it be something with the cable box?
Old 04-05-2011, 12:46 PM
william06's Avatar
Quoted: 111 Post(s)
Liked: 63
I believe what you are experiencing is handshake issues or as some call it studder. I have had this and have learned all tv through my Onkyo 5008 and direct to my pj that is not already 1080p/24 especially tv should be sent at the most 1080/60 or 720 with 4/4 off and fI off that way it works fine with me. I hope I explained it correctly. Frasia correct me if I am wrong. I can upscale sddvd to 1080p/24 with no problem. The only issues I have is with the comcast cable box and setting it as I explained above takes care of that. These are awesome PJ's but like any other piece of CE gear today there is a learning curve. Mine by the way is a 9500. At the time I purchased I also had a choice of a runco Floor sample 720p and glad I went with the epson. good luck.
Old 04-05-2011, 02:30 PM - Thread Starter
fraisa's Avatar
You should re read thru this thread there are settings for hdtv that elimates tv judder
but William is Right your Amp cant send everything thru as 1080p/24 or it will Shake..
Actually for Hdtv tv show i have frame Int. set to Low...
For Hdtv Sports it is set to Normal...
I have my yamaha A2000 Rec transmit the single thru with no processing..
I also find that with my HDTV PVR i set it to 1080i and not 720p...
you also want to double check your oppo BluRay and see how its sending video to your Rec. It should be set to 1080p/24hrz....
fraisa is offline
Old 04-08-2011, 01:11 AM - Thread Starter
fraisa's Avatar
Screen Shots from Adjusted Vivid Settings
HDTV Dish Net
I find that the skin tones are more accurate.
shots not taken on tripod.
this shot a little blur but you can still see the skin tones..
She does have a caked face but thats tv....
fraisa is offline
Old 04-08-2011, 03:34 AM
krisha's Avatar
i love o own epson cameras. this is nice..
krisha is offline
Old 04-08-2011, 06:25 AM
william06's Avatar
Quoted: 111 Post(s)
Liked: 63
HDTV Dish Net
Those are beautiful shots. if you get time would you post them? your settings work well on my system. Nice work.
Old 04-08-2011, 03:06 PM - Thread Starter
fraisa's Avatar
More...
Link to All Idol Screen Shots from my Facebook Page....
http://www.facebook.com/profile.php?...5737&aid=65255
fraisa is offline
Old 04-08-2011, 04:04 PM - Thread Starter
fraisa's Avatar
Will say this ,
Idol is the hardest show to take screen shots from
There colors are so up and down the saturation grid.
and for fun...
fraisa is offline
Old 04-08-2011, 10:18 PM - Thread Starter
fraisa's Avatar
Been a while since i put up a ambient light shot..
here is a new one...
I am on Team Bring It...
fraisa is offline
Old 04-09-2011, 12:04 AM - Thread Starter
fraisa's Avatar
Here is the start to the settings
Camera battery died will continue with the rest...
fraisa is offline
Old 04-10-2011, 04:23 PM
mech27's Avatar
Those are beautiful images
mech27 is offline
Old 04-10-2011, 05:02 PM - Thread Starter
fraisa's Avatar
Baseball Season Finally Is Hear...
fraisa is offline
Old 04-10-2011, 05:03 PM - Thread Starter
fraisa's Avatar
Hear is one more for ya
fraisa is offline
Old 04-11-2011, 08:36 PM
william06's Avatar
Quoted: 111 Post(s)
Liked: 63
those are amazing waiting with batrd breath for thr rest of your settings
Old 04-11-2011, 09:57 PM - Thread Starter
fraisa's Avatar
Will post the full settings tomorrow....
til then you will have to go to the scope bottle...he he
fraisa is offline
Old 04-12-2011, 05:06 AM
william06's Avatar
Quoted: 111 Post(s)
Liked: 63
thanks those are great
Old 04-12-2011, 11:56 AM
GrandPooPaw's Avatar
Considering purchasing an Epson 9700 to go with a just ordered an OPPO93 and am leaning toward the Anthem MRX700 using my existing Paradigm studio 100's. Any thoughts? This is my first post, so sorry if this is in the wrong section.
GrandPooPaw is offline
Old 04-12-2011, 03:17 PM - Thread Starter
fraisa's Avatar
The Epson unit will work well with the equipment you have mentioned.
That Anthem MRX700 is that the latest piece that is also a AV Receiver?
YOur Oppo unit is one of the best on the market so again paired with a epson 9700 your in good hands.
You have chosen all higer end equipement and the 9700 will place very well.
fraisa is offline
Old 04-12-2011, 04:18 PM
Thank you
Old 04-13-2011, 07:38 AM
rr330i's Avatar
Guys, seems there was a mistake made when I ordered my system.
I have a 9700 and a Dragonfly High Contrast 100" Screen that I won't be needing.
All new in unopened boxes. Let me know of any interest.
rr330i is offline
Old 04-13-2011, 11:26 AM
jgriffin99's Avatar
Anybody use the FIXED anamorphic lens with the PC9700. I have a job that was originally scheduled to use the PC-61000 but since that is not coming I am trying to use the PC9700 with the fixed lens.
Any thoughts or experiences.
jgriffin99 is offline
Epson Powerlite Pro Cinema 9700ub Projector 3lcd 3 Chip Technology
