Ceiling Mounts fo JVC RS 40/50/60 - Page 7 - AVS Forum | Home Theater Discussions And Reviews
Old 12-21-2010, 05:30 PM
promike's Avatar
Quoted: 109 Post(s)
Liked: 98
I am happy to report that the Peerless PRG-UNV works out of the box. I did have to use longer screws than were provided due to the recessed mounting holes on the X3. The length of the arms is perfect. I'll be taking down my Sony and hanging the X3 tomorrow along with a new Belkin HDMI cable. Let the fun begin.
Speakers: Klipsch RF-7II(2), RC-64II, RS-62II(2), RP-160M(2), Velodyne HGS-15, HSU VTF-15H, Atlantic Technology IC-6-OBA(4)
AVP: Yamaha CX-A5100, BJC certified cables
Amps: Emotiva XPA-5(2), XPA-3
Oppo UDP-203, Roku Ultra, Nvidia Shield, Philips BDP7501
JVC DLA-RS500U, (132" screen), Vizio P75-C1 and Vizio SB4551-D5 Soundbar
promike is offline
Old 12-21-2010, 08:12 PM
krichter1's Avatar
Quoted: 1652 Post(s)
Liked: 1904
Originally Posted by krichter1 View Post
BTW - I mounted the RS50 last night and by drilling two holes in each back corner (one each) of the uni plate I was able to get the mount to sit perfectly (both vert & horiz) on the PJ. I'll be posting pictures tonight, but I would tell everyone needing a "right now" solution, don't hesitate to buy the RPMAU. The yaw and tilt worked perfectly.
Mark was right . . . this mount is the best I have ever used (solid as a rock!). Also anyone mounting in to a drop ceiling the CMS440 plate is a MUST for a great looking sturdy install! I'll post pics tonight.
Here are the pics of RPMAU mod!
Kevin
You only live once, but if you live it right, once is enough.
==> The Richter Family 4K/3D Theater
krichter1 is offline
Old 12-22-2010, 08:21 AM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
Which screws did you end up with? No sticking or grabbing when they were put in?
beastaudio is offline
Old 12-22-2010, 01:14 PM
promike's Avatar
Quoted: 109 Post(s)
Liked: 98
I used 5M 20mm and with hex cap heads and they worked perfectly. This is an excellent mount and uses a worm gear for L/R and tilt adjustments. Very pleased.
promike is offline
Old 12-26-2010, 07:51 PM
krichter1's Avatar
Liked: 1904
For those interested I found out Chief is shipping the 281 plates to customers starting tomorrow.
Kevin
Old 12-26-2010, 08:14 PM
adidino's Avatar
Quoted: 311 Post(s)
Liked: 238
Where did that number come from? Do we need to contact Chief directly to get on the mailing list?
adidino is online now
Old 12-27-2010, 08:56 AM
krichter1's Avatar
Liked: 1904
If you followed the original thread prior to release we discovered the RPMAU did not work. Chief confirmed this issue, then designed a new plate (281) and if you had already bought the RPMAU prior to this discovery, you can call them to make exchange arrangements.
This should also mean if you don't want to use/purchase the universal SLBU part you can use the specific plate designed for the new JVC's.
Kevin
Old 12-27-2010, 08:57 AM
adidino's Avatar
Quoted: 311 Post(s)
Liked: 238
Figured that out after I posted... one is on the way.
Old 12-27-2010, 09:16 AM
zbroke's Avatar
I assume that you were on the list and received an email?
GO HABS GO!
zbroke is offline
Old 12-27-2010, 01:23 PM
alk3997's Avatar
Liked: 92
I just put up a Chief joist mount kit into the attic with a standard chief 1.5"-diameter, 3" long pipe going through the attic floor into the theater room ceiling. Good project...
I was fishing the wiring through the pipe and realized I probably don't want to leave the pipe open to the attic in the Houston summer. How do people plug the pipe after the wires are sent through? Is there a reason not to do this?
Sorry - this feels like a newbie question but I haven't tried this before.
alk3997 is offline
Old 12-27-2010, 08:55 PM
lovingdvd's Avatar
Quoted: 2214 Post(s)
Liked: 360
Indeed my understanding is that these did start shipping out today.
lovingdvd is offline
Old 12-27-2010, 08:56 PM
adidino's Avatar
Quoted: 311 Post(s)
Liked: 238
I got on the list this morning and one shipped today. I should have the plate on Wed.
Old 12-27-2010, 10:12 PM
krichter1's Avatar
Liked: 1904
Nothing to apologize about it's a legitimate question. I used some ~1.5" round styrofoam pieces I found at Home Depot. I also did it to isolate the power cord from the two HDMI's & emitter cable, (I split it down one side like a hot dog bun to the center then notched a bit out for the power cord so that none of the other cables made contact; then wrapped it in pro grade aluminum duct tape). I pushed it up the outer pipe first then put the inner pipe mount in while making sure it stayed in place from up top.
Oh and here's a pic of the finished product I promised (and forgot about!):
Kevin
Old 12-30-2010, 02:58 PM
krichter1's Avatar
Liked: 1904
Just got the 281 plate in the mail today. What a great company to deal with; they were awesome in every respect!
Kevin
Old 12-30-2010, 03:04 PM
adidino's Avatar
Quoted: 311 Post(s)
Liked: 238
Yep. Installed mine yesterday. Works like a champ..
Old 12-30-2010, 03:18 PM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Kevin,
JOOC, how tall is that plate?
Geof
Geof is offline
Old 12-30-2010, 03:56 PM
krichter1's Avatar
Liked: 1904
Originally Posted by Geof View Post
Kevin,
The ears are 1" high (about the same as the uni arms).
Kevin
Old 12-30-2010, 04:06 PM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Thanks Kevin. I was trying to figure out how much drop there is but Chief doesn't give the dimensions for this plate.
Geof
Geof is offline
Old 12-30-2010, 05:03 PM
aztech's Avatar
that's a big damn plate.
mine is on it's way, i should get it monday or tuesday. chief was AWESOME to work with. i'm glad i ponied up the extra money for them.
aztech is offline
Old 12-30-2010, 05:58 PM
GeorgeHolland's Avatar
Quoted: 45 Post(s)
Liked: 46
Did you originally order the RPMAU? I thought the compatible plate for the RPMAU was the SLM281 in order to support keyed locking?
GeorgeHolland is offline
Old 12-30-2010, 06:38 PM
unclemat's Avatar
Yeah, RPMAU requires SLM281. SLB281 won't fit...
unclemat is offline
Old 12-30-2010, 09:24 PM
Point Source
beastaudio's Avatar
Liked: 2826
ok so the peerless and the cheifs are both in working order now. I need to make a mount that will allow me to mount to brace between two joists, come down about 12" through the drop ceiling, and then the plates and whatever needed to mount the PJ onto the pipe coming down. please help me put together all the different parts I need as this is my first rodeo and I have no idea where to start really!
Thanks in advance
Old 12-30-2010, 10:24 PM
krichter1's Avatar
Liked: 1904
What did you receive for your RPMAU Adi? They knew I had an RPMAU so I wonder if they sent me the wrong one (that would suck).
Kevin
Old 12-30-2010, 10:35 PM
krichter1's Avatar
Liked: 1904
Thanks in advance
You don't need to mount to a joist if you buy the CMS440 with the RPM281. The 440 sits on top of your grid about 1/4" above the tile. It's worth the $75 from buy.com (or AVS of course). You'll need a threaded pipe of you choice of length you can find at a hardware store. I posted all this in the original thread.
Kevin
Old 12-31-2010, 12:17 AM
lincoln_husker's Avatar
Quoted: 23 Post(s)
what is the difference between the Chief RPA and RPMA ?
lincoln_husker is offline
Old 12-31-2010, 01:14 AM
monstosity12's Avatar
Quoted: 17 Post(s)
Hey Kritcher. What does your "all points security kit" say... SLB281 or SLM281.
Im wondering since I just got my SLB281, but the all points security kit says SLM281? And since you got he SLB281 as well, need to know if this is a mistake, or intentional. By the way, chief was exceptional to work with. This is why putting up the extra $ for them is the way to go. Not to mention, you get top notch build quality - Just cant get better than chief.
The RPMA comes with a key to lock projector to ceiling mount. The RPM is without a locking key.
monstosity12 is offline
Old 12-31-2010, 06:34 AM
adidino's Avatar
Quoted: 311 Post(s)
Liked: 238
I have the RPMU. Mitch (the support guy) verified it with me before sending it. There's a sticker on the top of the mount which I read off to him.That determined which one he needed to send me. The "A" is with the quick release? If so, he wanted to confirm which I had before sending since it was a different plate.
I got a little confused myself with all these variations from Chief.
Old 12-31-2010, 07:56 AM
alk3997's Avatar
Liked: 92
Deleted by author
alk3997 is offline
Old 12-31-2010, 08:00 AM
MatrixVideo's Avatar
So I have an X7 coming monday - have no mount - but don't even have paint or carpet finished yet --screen two week out --
question is this ---
will this work --
RPA281 chief mount
Chief Easy Installation Kit - CMA-700
Kurt Schneider
Matrix Video Pro
MatrixVideo is offline
Old 12-31-2010, 08:08 AM
alk3997's Avatar
Liked: 92
Thanks in advance
Answer deleted by author
alk3997 is offline
Jvc Dla Rs40u , Jvc Rs50u , Peerless Prg Mount , Chief Speed Connect Rpmau Projector Ceiling Mount With Keyed Locking Rpmau
