Projecting onto a building wall... I need some help with this one... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-08-2010, 11:26 AM - Thread Starter
JTrinity7's Avatar
So I have a fairly unique project here... Simply put, I have to project a large image onto the side of a building. What kind of requirements am I going to need to accomplish this project?
I wish I simply had a pic of the area... but a description will have to do.
1. The projected image will have to be roughly 30-40 ft (from corner to corner)
2. I will be projecting from roughly 40-50 ft away.
3. It will be at night, medium levels of ambient light. Hours are from approx. 7pm to Midnight.
4. The surface of the building is old, white painted brick.
5. Obviously I would like the image to be as clean and clear as possible.
I have a decent sized budget but nothing ridiculous. What about lumens? Would 5000-6500 work? Or would I need something like 10,000 and above. Thanks a ton!!!
JTrinity7 is offline
post #2 of 7 Old 11-08-2010, 02:06 PM
Jason Turk's Avatar
First you have some obstacles. A 30-40' diagonal at 40-50' throw is a very short throw distance...that will limit your choices. Secondly, forget running it when there is outside ambient light...it won't work. You pretty much need the sun completely set (I have experience with this). Also, your wall is going to limit how good the image is...you could put a $100k projector on it...but painted brick will never yield a great result.
Jason Turk is offline
post #3 of 7 Old 11-08-2010, 02:37 PM
emf
emf's Avatar
Projecting on a wall
Your guess looks good at 5k to 6.5k lumens, but for outdoor purposes the brighter the better. Most vendors list what they offer. Your best bet is to call and ask them as to suitability and price. Tell them what images you wish to project. Some images don't require good blacks.
Picture size: for large images use measurement left to right. Diagonal measurement originates with marketers of small TV sets.
emf is offline
post #4 of 7 Old 11-08-2010, 07:57 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
What sort of gathering is this?
I'd like to see picts after you've decided the equipment/etc.
Before, set-up, testing, and during.
Cool to see.
btw JTrinity7, are there 2 threads on this subject now??
I need to project on a 3 story building!!! What specs do I need
mtbdudex is offline
post #5 of 7 Old 11-09-2010, 02:44 PM
Ericglo's Avatar
Quoted: 1695 Post(s)
Liked: 795
Not sure why you started a new thread, but exactly how big is your budget? If it is under $20k, then you are looking for a used pj. Curt Palme has a line on some used Sanyos that may be good enough for you.
Current projector - JVC RS25 and Marantz VP15S1
Future projector - pre-ordered new JVC from AVScience
Ericglo is online now
post #6 of 7 Old 11-09-2010, 07:44 PM
emf
emf's Avatar
What sort of image?
If you want a computer image that says Merry Christmas and Happy New Year, all you need is adequate brightness.
If you want to project a movie from DVD or BD, ask studio first and obtain permission.
Movies look better on a smoothly plastered surface and for this purpose you might get an estimate before purchase of projector.
If you want to try plastering yourself, go to Home Depot and tell them you want to plaster a wall. If this is your first plaster job, try a small portion, maybe 6 ft tall by 10 ft wide. From this experience, you can determine if you can handle a larger job and extimate how long you may need. You need time estimate to rent scafolding and come up with reasonable cost estimate.
emf is offline
post #7 of 7 Old 11-11-2010, 10:22 AM - Thread Starter
JTrinity7's Avatar
Thanks guys,
Yes it is most definitely going to have to be a used projector, from looking around, it seems most companies that do outdoor projection, use 10 -12k lumen projectors. Video is not what I'm after, only static images.
And I apologize for the new thread, I wasn't getting anymore replies and wanted some input so I posted again.
