The Sony VPL VW90ES 3D Owner's Thread - Page 46 - AVS Forum | Home Theater Discussions And Reviews
post #1351 of 1363 Old 05-24-2014, 06:41 AM
graysonhoover's Avatar
I hope someone can help me here. LONG time reader first time poster. I just received a 90es. So far love it. Glad I got it , not a bad price. Anyways the question
I hook to blu ray player and play a 3d movie works perfect.
Hook to Apple TV and steam sbs 3d and all I get is 2pics side by side. The troubleshooting says to manually enter 3d mode and then select side by side or top bottom. My menu only lists simulated and top bottom. No side by side.
Any help would be greatly appreciated.
graysonhoover is offline
post #1352 of 1363 Old 05-24-2014, 02:03 PM
Don Landis's Avatar
Quoted: 1288 Post(s)
Liked: 351
This is a known problem. I'm not sure what causes it but it happens with my PS3 when I want to watch You Tube SBS half. Exactly as you described. A couple of times I was able to get it to work but I couldn't tell you what I did to make the SBS appear in the projector menus. I finally got a WDTV streaming box and that works. The big difference is that the PS3 limits 3D output to 720p while the WDTV allows for full HD at 1080p. If the Apple TV does the same, limit the output of SBS to 720p then that may be the problem.
Now, when I want to watch a SBS You Tube video, I have a macro that with one click on my remote control, pushes the Sony Projector into SBS mode. Once the movie is over, I have another macro that switches back to 3D AUTO. The WDTV box isn't as well known as the Roku or Apple but it is less money and has good apps for all the major players and is 3D compatible. I love Vudu 3D and Netflix 3D through it. Both are sent to the Projector as Frame Packed signals so the box does some conversion. YT is the only one I have to switch to SBS.
My 3D videos and more
Don Landis HT System: Projector Sony VPL VW665ES Players: Samsung UBD K8500 OPPO BD93 Sony BDP S6200 All Regions Player Denon AVR 4311ci, 7.1 JBL Professional series and Klipsch PS3, XBOX360, Dish VIP722K; 3D Edit Suite: Edius7.53, Vegas Pro v13, Power Director15, i7-950, LG 3D TV DM2752
Don Landis is offline
post #1353 of 1363 Old 06-15-2014, 07:37 AM
todcp's Avatar
Originally Posted by SpiderGW View Post
Hello
If it possible to find some manual how setup 3d setting, and don''t have any problems, like head ache and etc. Sony sopport just said TURN IT OF, but this is solution what I don't real like. I was happy with my Infocus for 2D pictures, and now I have this Sony VPL-VW90ES for 4 times more money and use also for 2d only. Thanks
I found this review to be helpful. My room is an extremely dark Theater room with flat black front wall and ceiling with brown flat walls. This reviewer lists specific stock settings he felt gets this unit to produce a great picture. I am not an expert but the picture does look phenomenal. I was planning to hire someone to set it up but I am pleased so far with what this accomplished for me.
http://www.avforums.com/review/sony-...tor-review.163
todcp is offline
post #1354 of 1363 Old 06-24-2014, 03:07 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3769 Post(s)
Liked: 3756
We have one B stock VW90es projector left. Give us a call if you want dibs on it !!
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #1355 of 1363 Old 10-31-2014, 12:03 PM
Bytehoven's Avatar
Quoted: 55 Post(s)
Liked: 77
Greetings Sports Fans…
Today, out of the blue, my VW90ES lamp will not start. I recently had the filter cleaning message appear, but have not had any warning regarding the lamp.
I see "Starting" in the lower right screen corner, but then the lamp does not start and the projector shuts off and displays (3) red flashing sequence at the Lamp/Cover indicator. Well given the lamp is not too hot, I assume it's telling me to replace the lamp. I did try removing the lamp and reinstalling but that did not work, so it appears something in the lamp itself might have failed.
I would note earlier in the day, the projector did shut off once while starting, but then started and ran for several hours.
I have a new LMP-H201 lamp headed my way and I hope that resolves the issue.
I must say the projected image was still excellent. If I recall correctly, I am right around 1400 hours on the lamp.
I welcome any comments from other VW90 owners who have experienced the same thang.
Cheers
Byte
XBL GT: J05HB4G05H
PSN ID: Bytehoven
Battle Log: Bytehoven
Bytehoven is offline
post #1356 of 1363 Old 10-31-2014, 12:20 PM
Don Landis's Avatar
Liked: 351
Sounds typical. Just replaced mine a couple weeks ago. I always keep a spare handy.
Be careful as there are lots of replacement bulbs and most fit fine, last for about 1500 hours for full brightness setting and about 2000-2500 for economy lower brightness setting.
Generally I pay no more than $120 and no less than $90. The more expensive are generally the same just from bigger named supplier. The cheaper ones like $65 will be some retrofit and the one I bought for $65 lasted only 240 hours. Even the housing looked different.
Your symptoms sound like the bulb's life is over. I once tried an OSRAM bulb and got 3800 hours on economy mode but paid $200. Then I bought another and it lasted 1900 so its really a crap shoot. Most of the cheaper ones are Phillips.
post #1357 of 1363 Old 10-31-2014, 12:30 PM
Bytehoven's Avatar
Quoted: 55 Post(s)
Liked: 77
I'm in your price zone with a "Genuine" replacement lamp rather than an OEM $$$ Sony lamp. I would have bought the lamp from PureLandSupply but they wanted 2x the next day FedEx fee of everyone else. I ended up buying from LampPros, so I'll be sure to report on my customer experience.
XBL GT: J05HB4G05H
PSN ID: Bytehoven
post #1358 of 1363 Old 10-31-2014, 01:36 PM
Don Landis's Avatar
Liked: 351
You should be good. I failed to say that my prices included shipping cheapest rate. I don't do overnight since I'm always replacing a spare.
BTW- I keep my projector on a UPS to prevent flash brownouts that can shorten bulb life.
post #1359 of 1363 Old 11-01-2014, 10:36 AM
Bytehoven's Avatar
Quoted: 55 Post(s)
Liked: 77
OK… new lamp assembly arrived today.
Old lamp read Philips on the outside of the lamp. New lamp reads nothing. There is some chinese lettering on the very back ceramic section holding the back wire.
Old lamp assembly had (2) metal shields on the top and bottom ports around the lamp, with the side to side ports for air flow were open. I moved these (2) metal shields from the old assembly to the new assembly.
New lamp assembly had a couple of finger prints on the outside of the glass front of the lamp assembly which cleaned up perfectly.
New lamp is installed and running fine. White balance appears normal to the eye with no apparent color shifts.
I have my fingers crossed and will report if any odd behavior develops.
XBL GT: J05HB4G05H
PSN ID: Bytehoven
post #1360 of 1363 Old 01-05-2015, 01:55 PM
Farkonas's Avatar
Hi everyone. Very late to the party, of course, since VW90ES is practically obsolete by now... but I've run into trouble and maybe you guys can help.
I've connected the projector to a Sony STR-5800ES receiver, on the second HDMI out, and I cannot get any kind of picture from it, to either HDMI1 or HDMI2 of the VW90ES. It just blinks on the blue background in regular intervals. It's as if it cannot sync or communicate with the receiver at all.
Both inputs function properly, I have tested them through my Media Center PC.
I have updated 5800ES's firmware to the latest version and I have deactivated 4K upscaling on it. Basically stripped all settings to their minimum, to no avail.
The first HDMI out of the 5800ES also works properly, connected to a Bravia 65X9005A.
The cable I used is this http://www.amazon.co.uk/gp/product/B...ilpage_o09_s00 which I deemed to be OK for my needs (I am not at all interested in 3D picture).
Any ideas why the 90ES will not receive any signal from the 5800ES? Thanks in advance!
Farkonas is offline
post #1361 of 1363 Old 01-07-2015, 06:48 AM
buckley44's Avatar
Quoted: 56 Post(s)
Liked: 33
Did you go into your receiver under the source you are using and select HDMI - although I am not familiar with the receiver.
buckley44 is offline
post #1362 of 1363 Old 02-22-2015, 09:30 AM
Farkonas's Avatar
Back just to let the matter rest on my end. :-) The problem didn't have to do with any settings after all - the HDMI cable at the 5800ES's second HDMI out did not like to be bent near its base. Once it got straightened out it worked perfectly.
Initial impressions on the projector - even after ISF calibration - are positive but not overwhelmingly so. The 90ES does not produce good blacks by today's standards and the image, therefore, lacks "punch" and depth. Good enough for general viewing, but I hope to upgrade to a Sony 4K projector at some point this year - all models, even the 300ES, probably have better blacks than the 90ES. Cross fingers!
Farkonas is offline
post #1363 of 1363 Old 02-24-2015, 08:45 AM
Gilmour's Avatar
Probably the contrast of your projector is not greater than 2000: 1
http://www.hifi-forum.de/index.php?a...4&thread=13697
Gilmour is offline
Sony , Sony Brand , Sony Corp , Sony Corporation , Sony Projectors , Sony Electronics , Sony Vpl Vw90es 3d 240hz Sxrd Projector
