JVC RS40/X3 Calibration Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #91 of 442 Old 01-25-2011, 04:37 PM
Kris Deering's Avatar
Quoted: 1613 Post(s)
Liked: 2561
Calibrated the 40 last night using the new Radiance Mini. The Lumagen really takes this projector to the next level with a completely dead on result for color, grayscale and gamma. The improvements in the image were immediately noticeable so anyone looking to get the nth degree from this already spectacular value should really considering putting the Lumagen in their system.
My Home Theater
Kris Deering is online now
post #92 of 442 Old 01-25-2011, 04:39 PM
Shepardos's Avatar
Quoted: 51 Post(s)
What was your Base!? Userprofile with Wide1? Can you please share your Approach!?
Shepardos is offline
post #93 of 442 Old 01-25-2011, 04:59 PM
dangc's Avatar
Hi Kris,
I have been looking for some feedback with this combo and heavily considering it. Are you using the Radiance Mini with with a package like CalMan or built in tools that Lumagen provides with unit to perform calibration? Is the Radiance pretty strait forward to use and make adjustments?
dangc is offline
post #94 of 442 Old 01-25-2011, 05:00 PM
Liked: 2561
I believe I used Film with Wide 1 color profile but I'll have to check.
My Home Theater
post #95 of 442 Old 01-25-2011, 05:36 PM
Toe
Toe's Avatar
Quoted: 1474 Post(s)
Liked: 1839
Probably hard to say since there is variation from unit to unit, BUT what preset gamma is considered the most accurate on the 40? I have cycled through the options and keep coming back to "A".
Toe is online now
post #96 of 442 Old 01-25-2011, 07:02 PM
Liked: 2561
Accurate in terms of what? Some people prefer a 2.2 gamma, others a 2.4. The 2.3 preset tracks at 2.2 pretty well if that is what you're after. I've found that 2.3 is a very nice setting for this PJ, 2.4 is a bit overkill given the contrast performance and ends up being just a bit too dark, even in my batcave.
My Home Theater
post #97 of 442 Old 01-25-2011, 08:25 PM
Toe
Toe's Avatar
Liked: 1839
Sorry, I meant the most accurate as far as 2.2 goes. Sounds like 2.3 is the way to go if 2.2 is what you are after from what you are saying........thanks
Toe is online now
post #98 of 442 Old 01-25-2011, 08:32 PM
Liked: 2561
Just checked the PJ and I used User 1 with Wide 1 for the calibration. From there I just followed the tips laid out by Lumagen on their website. Used the Custom gamma 2.3 preset for a baseline.
My Home Theater
post #99 of 442 Old 01-25-2011, 09:41 PM
lovingdvd's Avatar
Quoted: 2220 Post(s)
Liked: 360
Tom - thanks for the very detailed report! Looking at the CIE chart, it seems the position of the red would suggest a dE considerably greater than 2-ish. From your report it doesn't seem like it though so that is good.
You mentioned 650 lumens in high lamp mode. Was this from long throw? I would have expected this in normal mode... ?
lovingdvd is offline
post #100 of 442 Old 01-26-2011, 01:05 PM
TomHuffman's Avatar
Quoted: 688 Post(s)
Liked: 615
http://www.avsforum.com/avs-vb/showp...2&postcount=44
It was about mid throw, so more light is possible at shortest throw installation.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #101 of 442 Old 01-26-2011, 01:12 PM
Kelvin1965S's Avatar
Quoted: 260 Post(s)
Liked: 160
I'm hoping to get the Mini3D soon, but initially to use with my existing HD350. Pleased to see that you got such good results with it following the Lumagen tips which I've been reading up on in readyness.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
post #102 of 442 Old 01-26-2011, 09:39 PM
lovingdvd's Avatar
Liked: 360
Thanks - that makes sense. The Sharp 10K and RS1 had red in a similar position on the CIE chart. At this position it has a tendency to make oranges look more like red.
Kris - from you experiments with the RS40 service menu CMS-ish adjustments, is there anything in there that can improve the red?
post #103 of 442 Old 01-27-2011, 08:29 AM
Liked: 2561
Not that I could tell. You can definitely move the color points, but at the expense of image quality. They aren't cut and dry CMS adjustments, they affect too many other things with each adjustment, so while you think you're getting red good, your probably screwing up yellow and orange and vice versa. I wouldn't recommend messing with it.
My Home Theater
post #104 of 442 Old 02-04-2011, 02:14 PM
stevenjw's Avatar
Quoted: 318 Post(s)
Liked: 340
Finally got around to calibrating my RS40 using Calman 4.1 and Chroma 5 in 2D through my A-lens. I'm at work now, so I'll add the charts later (once I figure out easy way to do that. I'm new to Calman). My lamp indicates 70 hours of use.
Screen: Carada BW 1.4 gain 136" 2.35:1
Ambient light: none (complete bat-cave with flat black ceiling and flat burgendy walls and carpet)
Measured ft-L: 7.4
Lamp: normal
Lens App: -10
Color Space: Standard
Gamma: Custom 2 (2.3)
HDMI: enhanced
Contrast: 15
Brightness: -6
Color: 10
Tint: 0
Sharpness: 0
Color Mode: User1
Gain Red: -5
Gain Green: -4
Gain Blue: 0
Offset Red: -3
Offset Green: -5
Offset Blue: 0
I'll be tackling very minor CMS adjustments to D65 perfection via Lumagen XS next, but have to say that the RS40 has very acceptable Grayscale, Gamma, and D65 gamut using above settings and no CMS. Very impressive machine.
...Steve
"Opinions are like orgasms… mine matters most and I really don’t care if you have one."
My HT gear
stevenjw is offline
post #105 of 442 Old 02-04-2011, 05:46 PM
Dave Vaughn's Avatar
Quoted: 895 Post(s)
Liked: 1346
I have a Lumagen Radiance XE-3D that will be here next week and will be doing a full calibration once it arrives.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
My Atmos Renovation Part 1 http://www.soundandvision.com/conten...odyssey-part-1
My Atmos Renovation Part 2 http://www.soundandvision.com/conten...odyssey-part-2
Dave Vaughn is online now
post #106 of 442 Old 02-05-2011, 09:00 PM
desray2k's Avatar
Quoted: 276 Post(s)
Liked: 114
For those interested to know how well the RS40 perform before and after calibration using the DVDO iScan Duo (with 3D CMS)...can take a look at my review in this forum: http://www.xtremeplace.com/yabbse/in...?topic=90193.0
For those interested with the settings on my Projector (After calibration)
Settings on the Projector
Contrast: 1
Brightness: 0
Color: 8
Tint: 1
Gamma: 2.32
Sharpness: 7
Detail Enhancement: 4
RNR: 8
Color Temp: 6500K
Custom Preset:
Gain Rd: 0
Gain Green: -40
Gain Blue: -18
Offset Red: -10
Offset Green: 3
Offset Blue: 5
desray2k is offline
post #107 of 442 Old 02-06-2011, 02:06 AM
Thebes's Avatar
Hi,
the result of a calibration with the software HCFR and a ColorMunki.
The thread where is the file is here :
http://www.homecinema-fr.com/forum/v...087#p174477087
that is not my "calibration" or my projector, but except problems on saturation and luminance, the other issue is brightness.
After 200 hours of use, only 10 Fl in eco mode (around 105-110 lux or 440-450 lumens) (12 fL out of the box) with the shortest throw (closest to the screen) on a 275 cm wide screen. It seems he is not so bright in eco mode.
The other files follow.
Thebes is offline
post #108 of 442 Old 02-06-2011, 02:09 AM
Thebes's Avatar
Hi,
the other "files"
Thebes is offline
post #109 of 442 Old 02-08-2011, 02:19 PM
stereomandan's Avatar
Originally Posted by Thebes View Post
Hi,
Interesting files. Thanks for sharing.
HCFR now works with the colorMunki? I was not aware of this. Do you have confirmation of this? Thanks.
Dan
stereomandan is offline
post #110 of 442 Old 02-08-2011, 07:34 PM
zombie10k's Avatar
Quoted: 2828 Post(s)
Liked: 2790
Custom Preset:
Gain Rd: 0
Gain Green: -40
Gain Blue: -18
Offset Red: -10
Offset Green: 3
Offset Blue: 5
I'm glad I'm not the only one having to pull so much green out of the gain. My RS50 which replaced my RS40 (poor convergence, uneven focus) seems to have a noticeable green push out of the box. I've had to pull back the green (although not quite as much as you did).
I'll know better when my Chroma 5 Pro arrives later this week from Tom, I don't trust the Display LT meter I have here.
I've had a number of members email their calibrations (some from AVS) and it appears these projectors (RS40 & RS50) have a wide variance from copy to copy in regard to color performance out of the box. Some are lucky and only had to make minor adjustments, others are off quite a bit. My guess would be variances in the bulb affecting the color. If it's not the bulb, then it's a little more alarming as to why there would be such a difference.
zombie10k is online now
post #111 of 442 Old 02-09-2011, 02:59 PM
Point Source
beastaudio's Avatar
Quoted: 3539 Post(s)
Liked: 2839
SOrry, im a calibration super newbie and was just curious what all I can calibrated without a meter, but just with the AVS calibration disk? I can tell that the green/blue levels are elevated in several scenes of movies and would love to, just for the time being, get those levels back to respectable. I havent even broken ground on calibration yet so there is much to learn but any advice to the above question would be great thanks
beastaudio is offline
post #112 of 442 Old 02-10-2011, 03:39 AM
desray2k's Avatar
Quoted: 276 Post(s)
Liked: 114
Hi zombie, I'm contemplating of getting a chroma 5 colorimeter as well. Do post your feedback after use with your new colorimeter. If it's really good and show a vast difference in terms of the calibrated values. I'll probably get one for myself as well.
desray2k is offline
post #113 of 442 Old 02-10-2011, 04:34 AM
tjgar's Avatar
Measured ft-L: 7.4
Lamp: normal
Lens App: -10
HDMI: enhanced
Contrast: 15
Brightness: -6
Color: 10
Tint: 0
Sharpness: 0
Color Mode: User1
Gain Red: -5
Gain Green: -4
Gain Blue: 0
Offset Red: -3
Offset Green: -5
Offset Blue: 0
Thanks Steve,
considering I have a very similar set-up as you. (same pj, screen,semi bat cave, even our amplification) I will give your settings a try. I know every pj and lamp are different, but its a good starting point.
Thanks again
Tony
tjgar is offline
post #114 of 442 Old 02-10-2011, 05:10 AM
stevenjw's Avatar
Quoted: 318 Post(s)
Liked: 340
Originally Posted by tjgar View Post
Thanks Steve,
Thanks again
Tony
Feel free to try, but just remember that each PJ is different. Mostly due to different lamps and number of hours on them. Mine had 70 hours when I performed this calibration.
Also keep in mind that there's really no "correct" gamma setting. Depending on your environment, it's probably best to use something between 2.2 and 2.4. Those are really preset as Custom 1 through 3. They're close enough. I found that setting gamma varies with source material too. In other words, don't be afraid to use a different gamma setting based on your tastes in dark scenes, etc. during any given movie. It's not written in stone. Your eyes are the only ones that count for gamma. Color is different and really requires a meter if accuracy is what you're after.
Good luck and hope they work for you.
...Steve
My HT gear
stevenjw is offline
post #115 of 442 Old 02-10-2011, 09:40 AM
Quoted: 260 Post(s)
Liked: 160
Another point re gamma is that you can lower the gamma near black to increase shadow detail and help avoid black crush. I run my HD350 at 2.3 which looks good on brighter scenes, but the 5 and 10% gamma points are raised in brightness to be at the same settings as the custom 2.2 gamma for these points, which stops the dark areas looking too featureless on a lower contrast projector like mine. I know the X3/RS40 doesn't have the black adjust of the X7, but I guess you can still do this in the custom gamma area?
Having seen JonStatt's comments regarding the X7 contrast, then I may as well look to an X3 myself as I've got the Lumagen Mini3D coming...unless a used X9 turns up for a song once the next range is annouced.
post #116 of 442 Old 02-10-2011, 10:49 AM
lovingdvd's Avatar
Liked: 360
Have you tried doing the same thing, except with a target of 2.4 instead of 2.3? I go up from 2.2 to 2.4 from 5% to 30% and then 2.4 from 35-95% and it looks fantastic. This is with my RS20 but same would apply with your pj.
post #117 of 442 Old 02-11-2011, 01:15 AM
Thebes's Avatar
Dan
Hi,
[HS on]
as you can see, "we" are working on a HCFR version with a colormunki pilot, but at this time it's only a "beta".
Some HCFR, AVS or AV Forum members (as Pando2 or me (I use a colormunki with HCFR software for my HD1 and an Iscan Duo)) use this beta version, but it is not available for "public" currently (and I don't know when it will be available for end-user, sorry).
[HS off]
Thebes is offline
post #118 of 442 Old 02-11-2011, 01:22 AM
Quoted: 260 Post(s)
Liked: 160
This may work well with the RS20 and the RS40 due to the higher on/off, but the HD350 just lacks enough to run at 2.4 even in my batcave IMHO. I'm getting my Lumagen today (hopefully) so I may try it again, but I think I'll have to wait until I get an X3/X9 to run that gamma permanently.
post #119 of 442 Old 02-12-2011, 10:32 AM
LarryChanin's Avatar
Measured ft-L: 7.4
Lamp: normal
Lens App: -10
HDMI: enhanced
Contrast: 15
Brightness: -6
Color: 10
Tint: 0
Sharpness: 0
Color Mode: User1
Gain Red: -5
Gain Green: -4
Gain Blue: 0
Offset Red: -3
Offset Green: -5
Offset Blue: 0
Hi Steve,
Thanks for the information.
Have you done any viewing in 3D on such a large screen?
If so, I assume that the lamp power is on high and the iris setting is open?
What color temperature do you use when viewing 3D?
Do you use the 3D Picture mode when viewing 3D?
If so, do you use the 3D gamma settings? A or B?
Thanks again.
Larry
LarryChanin is offline
post #120 of 442 Old 02-12-2011, 11:14 AM
nightfly85's Avatar
Quoted: 71 Post(s)
Liked: 41
Update: These reading were taken with a "bad" i1 LT. Got a new one and it produces entirely different results.
Is it just me? My RGB Gain controls can only be adjusted to the negative, i.e., they are not on 0 like the Offset controls.
User 1 - Wide1, 65000K temp, with everything else @ defaults.
Using Eye One LT/HCFR
The problem for me is that I apparently need to increase Green Gain & Offset but am unable to increase Gain! How can I pull that Green line up?
Oddly nice and linear but still way off. My Delta-E sucks.
Ok, I re-read this thread.
- Looks like I need to drop the + adjustment to my Green Offset and use 0.
- I need to get the RGB to line up using two of the gains with neg offsets only.
- Use gamma RGB controls to tweak final settings @ various IREs.
- Start in Film Mode, Standard Color Space, 65K Temp
- Use 80%, 30% IRE fields to dial in the greys.
nightfly85 is offline
Jvc Dla Rs40u
