Do you protect your theater with emergency power supply? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
Old 02-26-2011, 03:54 PM
rgathright's Avatar
Quoted: 216 Post(s)
Liked: 26
I have my projector along with my Directv receivers (2), an A/V receiver, a Panny Blu-ray player and a HTPC (with external hard drive) all connected to an APC 1500 UPS. This morning for some reason I had an "overload failure" and everything went off. I was worried that my projector lamp may blow, but it did not. I turned the UPS off and then after about 5 minutes restarted it. Everything started back fine. But just in case I bought an additional 750 UPS and splilt up some of my equipment.
I was glad that the lamp would not blow if it does not have time to cool off.
Sony XBR-75X850C - Living Room
Samsung UN60J6300AFXZA - Bedroom
rgathright is offline
Old 02-27-2011, 05:04 AM
rgathright's Avatar
Quoted: 216 Post(s)
Liked: 26
This is what I have and since my previous post I have had it shut down twice since. So it has shut down 3 times in one day. As stated in my previous post when it shut down the first time I bought a smaller UPS to spread out some of my equipment. I was sure this would solve this problem. The second and third time it shut down by itself with no alarms and restarted itself. It had no info on the screen except for the startup info. I have had this J15 for about 3 1/2 years with no issues.
Any ideas what is going on?
Old 02-27-2011, 06:54 AM
mjg100's Avatar
My guess would be the batteries need replacement.
mjg100 is offline
Old 02-27-2011, 08:23 AM
rgathright's Avatar
Quoted: 216 Post(s)
Liked: 26
That is where I am leaning for now. I have been monitoring the battery runtime and it has been staying right at 35 to 36 minutes all morning. When I power up the HTPC it goes down to 22 minutes.
I plan on unplugging anything non-essential from the UPS to see what happens.
Old 02-27-2011, 08:56 AM
Quoted: 21 Post(s)
The pj and HTPC you definitely want on the UPS. The BD player has a motor; maybe that too. But the other stuff you can put on the "surge-only" side of the UPS (if you have that).
Laserfan is offline
Old 03-02-2011, 12:10 PM
rdjam's Avatar
I always have.
Anyone who runs one of these projectors without a UPS just hasn't thought about it much YET. But there's no going back and undoing the damage if they get caught out. PCs can't get damaged by a power cut the way a projector can, yet everyone thinks about the PC first..
The reason these projectors do a cool-down cycle when powered down normally is not simply to protect the blub - hell that easy (if expensive) to replace.
But the REAL damage done by an abrupt power cut can be MASSIVE damage to the internals of the projector by the incredibly hot bulb - I'm talking MELTED plastics and parts in the light engine. You'll WISH it was just the bulb...
Trust me folks, it doesn't take much to protect your baby...
rdjam is offline
Old 03-02-2011, 12:13 PM
rdjam's Avatar
It's not good for the lamp, for sure, but the real risk is the damage to the optics and the light engine from the residual heat of the lamp.
rdjam is offline
Old 10-16-2011, 06:57 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
So, the dreaded power on-off-on hit me yesterday, Sat Oct-15, 2011.
Very windy here in Hartland, we were watching college football in the basement HT, MSU vs U of M.
Then, a "blink" and everything turned off then 1 second later back on.
The PJ stayed in off mode, but the fan went into cool down mode for the usual time.
(I have a Sony VPL-VW60, the Black Pearl).
After it was totally off, I pressed on, and the PJ came on same as usual.
Breathed a sigh of relief.
2 things:
-the PJ was smart enough to go into a cooled shutdown once the power came back on.
-if there was a power surge, fortunately the PJ was not damaged.
(nor any of my other AV equipment)
Fwiw, I have the PJ powered thru a Panamax 5400
In the 3,000 hrs of watching since May-2008, 3+ years, this is first time it's happened to me.
mtbdudex is online now
