sony announces new 3D projector in UK - Page 28 - AVS Forum | Home Theater Discussions And Reviews
post #811 of 824 Old 08-10-2011, 08:52 AM
zombie10k's Avatar
Quoted: 2802 Post(s)
Liked: 2734
Originally Posted by degrudv View Post
So we are now certain that we MUST have it mounted on top of the screen instead of on the top of the projector where it can bounce off the screen?
I have my Sony emitter sitting on top of the projector, facing my 142" 2.8 HP from a 16" foot throw, and it works just fine. I never dropped the IR signal moving around anywhere in front of the projector.
I am not sure why Sony says it has to go up front, but I would recommend trying it on top (I am a shelf mount) or bottom if you have a ceiling mount.
Originally Posted by Toe View Post
Still Up........calling in sick Any ghosting he is seeing at this point is due to sleep deprivation.
4:30am - i slept 3 hours and working on borrowed time before i pass out.
I have much to say for my first impression - stayed tuned.
zombie10k is online now
post #812 of 824 Old 08-10-2011, 09:28 AM
degrudv's Avatar
Screen shots anyone?
degrudv is offline
post #813 of 824 Old 08-10-2011, 09:35 AM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
Home waiting on mine now and looking at making an Official Owners thread. I can go ahead and make it and edit along. How does this look as a first draft sans formatting and pictures? Suggestions, ideas and content appreciated.
Sony info:
The VPL-HW30ES is our very latest 3D Full HD projector,
bringing you cinema-quality pictures. With the
VPL-HW30ES, enter a new era of ultra high quality 3D
imagery, accessible at an affordable price. Packed
with the very latest innovative features which are
easy to use and control, you can experience enhanced
immersive 3D movie content without having to leave
your sofa.
3D BRILLIANCE FOR YOUR HOME
With this projector, you can experience the awardwinning
combination of Sony’s explosive 3D imagery
and our new, unique Dynamic Lamp Control technology.
Dynamic Lamp Control boosts the appropriate
brightness when each of your 3D glasses’ shutters
flicks back open. This means that you will not lose
any brightness and attain the optimal visual experience
from the comfort of your own home.
SHARPER, SMOOTHER IMMERSIVE ACTION
When you’re viewing your favourite film, or even trialing
the latest release - you want to know that you are
watching the action the way it was meant to be seen.
Sony’s SXRD panel technology minimises the gaps
between pixels for sharper, stunning image quality.
Motionflow automatically inserts extra frames
between the images to improve the smoothness of
the film, and makes action scenes and character
movements flawless.
HUGE RANGE OF USER ENHANCEMENTS
Since the previous model was launched, we have
strived to achieve even better. This projector now allows
you to pre-select separate parameters for 2D
and 3D content for Dynamic, Standard, Photo, Game
and Cinema modes, as well as automatically recognising
2D or 3D input. You can customise your viewing,
to match the room specifications, along with the
content type.
The VPL-HW30ES has integrated 3D with frame-sequential
3D USB-chargeable glasses* and a transmitter*.
This transmitter will activate the 3D mode – and
bring your content to life.
PRIMESUPPORT
This product comes with PrimeSupport – fast, hasslefree
repairs and a helpline offering expert technical
advice. Which gives you the peace of mind that Sony
is looking after your equipment, and your business.
With VPL home projectors, PrimeSupport also includes
a free loan unit – of similar specification if repairs are
likely to exceed 10 working days, minimising your disruption.
*Products sold separately
Features
Improved 3D brightness
The VPL-HW30ES delivers 3 times the brightness of
the VPL-VW90ES through its new lamp and electronic
technology, also giving better light efficiency for time
sequential 3D pictures.
SXRD panels minimise the gaps between pixels to
0.2μm for sharper, dot-free images, making it possible
to reproduce 240 frames per second. The opening
and closing of the shutters on the 3D are synchronised
to ensure that each eye receive the correct
image, thus reducing Crosstalk to a minimum. The
result is stunningly detailed, high-definition 3D images
that you believe you can reach out and touch
Motionflow
Motionflow technology allows the VPL-HW30ES to display
twice as many images per second. This algorithm,
unique to Sony, creates completely new images
based on the incoming signal, and inserts them
between the original frames to reproduce smoother,
sharper motion.
Dynamic Lamp Control Technology
When each of the shutters on your 3D glasses opens,
Dynamic Lamp Control Technology automatically
boosts the brightness in the image to that eye, maximising
the picture’s impact and the lamp’s efficiency.
Separate 2D and 3D modes
The VPL-HW30ES allows you to pre-select separate
parameters for 2D and 3D content under a variety of
application modes – Dynamic, Standard, Game, Living,
Cinema and Presentation – as well as automatically
recognising 2D or 3D input.
Advanced Iris3 control
This is an automatic Iris control feature that enhances
the contrast in accordance with the scene. It maximises
black and white levels without diminishing peak
brightness.
Extremely low fan noise (22dB)
The VPL-HW30ES runs very quietly with an advanced
air discharge system. Through a highly efficient cooling
system, fan noise is suppressed to a mere 22dB.
With whisper-quiet fan noise, users can concentrate
on a movie or game in a quiet environment without
distraction
New remote commander
The VPL-HW30ES is supplied with a new remote commander,
with backlit buttons for ease of use in
darkened rooms, one-touch control for many popular
adjustments, and easy grip for practical convenience.
Adjustable Lens Shift
The VPL-HW30ES has an adjustable ‘Lens Shift’ function.
Picture position (both horizontal and vertical)
can be easily adjusted with the motorised adjustable
‘Lens shift’ function, which expands the projector’s
placement and installation options without distorting
image quality.
Vertical range : Max. +/- 0.65V
Horizontal range : Max.+/- 0.25H
Panel Alignment Function
The VPL-HW30ES is configured with a function that
compensates for gaps in character or colour management.
It is possible to select R(Red) or B(Blue) to
make adjustments based on G(Green), and to adjust
the horizontal and vertical direction by shifting the full
image or selecting points of each colour.
RCP (Real Color Processing) Ver.2
The VPL-HW30ES offers an "RCP (Real Color Processing)"
function to adjust the colour and hue of
each target colour of the projected picture independently.
Additionally, version 2 adds the ability to adjust
the brightness at the same time. With this capability,
dealer and enthusiastic users can tweak the images to
perfection.
Fully Digital Signal Processing
Incorporated High quality Engine in the VPL-HW30ES
is a fully digital integrated picture enhancement engine,
optimally engineered by Sony for front projectors.
This high quality Engine relies on a collection of
Sony-unique algorithms such as noise reduction and
colour enhancement to produce sharp, vibrant, lifelike
images.
BRAVIA Sync
BRAVIA Sync simplifies and enhances the home
theatre experience. Through the control capabilities of
HDMI (High Definition Multimedia Interface), the
devices sync with one another for intuitive operations
such as One Touch Play and System Stand-by.
Specifications:
Models (2) VLP-HW30AES (3D package) and VLP-HW30ES (projector only)
Brightness: 1300 lumens
Contrast Ratio: 70,000:1 (with Iris)
Contrast Ratio: XXXX (Native)
SXRD Panel: 0.61", 15.4mm
Lens: F2.52 - F3.02 1.6x manual zoom
Lens Shift: +/-0.65 Vertical, +/-0.25 Horizontal
Lamp 200W UHP
Video Inputs: 2 HDMI 1.4a, Component and HD-Dsub 15 pin (VGA)
Other Connections: RS-232 (remote commands), Mini jack (IR input) and Ethernet (RJ45) Port (3D Emitter only)
Dimensions: 16 1/8"x7 1/8"x18 3/8", 407.4mmx179.2mmx463.9mm
Weight: 22.2lb, 10kg
Power Requirements: 100V to 240V AC, 3A to 1.3A 50/60Hz
Power Consumption: 300W, Standby 8W, Standby Low 0.5W
Fan Noise: 22db (max speed)
Replacement Lamp: LMP-H202
Glasses: TDG-PJ1
3D Emitter: TRM-PJ1
Features:
3D (all standards supported) and 2D to 3D simulation
Real Color Processing or RCP (aka: CMS)
Picture Modes: 9 (2 users defined)
Motionflow (240Hz): high, low and off
Color Temperature: 9 (5 user defined)
Gamma Settings: 8
Color Space: Normal, Wide 1, Wide 2 and Wide 3
Panel Alignment:
Reviews:
Cinetson (French) and English Translation
Projector central (coming soon)
AVS (coming soon)
Suggested Settings for closest to D65 picture “out of the box”:
2D:
xxxx
xxxx
xxxx
xxxx
3D
xxxx
xxxx
xxxx
xxxx
William is offline
post #814 of 824 Old 08-10-2011, 09:57 AM
browerjs's Avatar
Quoted: 23 Post(s)
Maybe get rid of all the Sony marketing stuff, and just include the Specs on down. Then link to the page with all the data.
browerjs is offline
post #815 of 824 Old 08-10-2011, 09:03 PM
Toe
Toe's Avatar
Quoted: 1450 Post(s)
Liked: 1831
Nice! Curious to read your report!
Toe is online now
post #816 of 824 Old 08-10-2011, 10:09 PM
zombie10k's Avatar
Liked: 2734
edit: moving comments to the official Sony HW30 thread
post #817 of 824 Old 08-10-2011, 10:55 PM
teetee_trinidad's Avatar
nice one zombie We give you permission to sleep for....4 hours lol
Then you can start the rs40 vs hw30 assignment ok?
teetee_trinidad is offline
post #818 of 824 Old 08-11-2011, 06:10 AM
tigerfan33's Avatar
Quoted: 350 Post(s)
Liked: 168
How is the FI on the Sony compared to the JVC in 2D?
tigerfan33 is offline
post #819 of 824 Old 08-11-2011, 08:07 AM
UC7
UC7's Avatar
I've read that the Xpand glasses aren't working with this new Sony unit. Hopefully Sony will get some more pairs out there soon. Having only two would seem to limit the usefulness of the HW30's 3D capabilities.
UC7 is offline
post #820 of 824 Old 08-11-2011, 08:13 AM
zombie10k's Avatar
Liked: 2734
I could not get either of my Xpand 103's working last night on the Sony HW30. Mode 4 will sync, but ghosting is bad and they lose sync every 10-15 seconds.
post #821 of 824 Old 08-14-2011, 07:19 AM
22emmittfan's Avatar
got a couple of more 3d discs yesterday, watched the cirque du soleil and last air bender in 3d. this thing is really pretty sharp and extremely clear to watch in 3d. i had some reservations about buying a 3d projector, but i am really loving this one so far. the glasses are pretty nice but i do feel a little pinching after wearing them for a while on my nose. outside of that i have no issues at all. people have asked about screens with gain, but the theater room paint i bought for this as my screen is working fantastic.
22emmittfan is offline
post #822 of 824 Old 08-25-2011, 01:39 PM
SeattleHTGuy's Avatar
Liked: 54
OK, I have interest in this thing and the dang thread has just stopped. Everyone too busy playing with the new toy or have comments headed elsewhere?
SeattleHTGuy is offline
post #823 of 824 Old 08-25-2011, 01:49 PM
ScoHo's Avatar
http://www.avsforum.com/avs-vb/showthread.php?t=1353988
ScoHo is offline
post #824 of 824 Old 11-17-2011, 01:14 PM
InCali's Avatar
Originally Posted by Smackrabbit View Post
Going off past Sony projectors in this range, ones that check in at 2,000 UKP have been $3,000 USD, and the most recent VPL-20/PRO1 was 2,400 UKP and $3,400 USD, so this coming in at $3,000 would be about right based on past models.
Now please just have zoom memory and I will be all over it.
Since we're further down the road, here's some info you might want to check out before buying a 3D projector.
http://www.projectorcentral.com/shoo...ony_hw30es.htm
The Panasonic is offered by visual apex (bought my projector from them and they are on time and have excellent customer service) for $2,999.
Home Theater: Acer H9500BD 3D Projector, 120" Elite Screen, Sony BDP-S780 3D Blu-Ray Player, Logitech Z-5500 5.1 Surround
Family Room: Mitsubishi 73" 3D DLP, Sony BDP-S5100 3D Blu-Ray Player, Onkyo TX-SR333 5.1-Channel Home Theater Receiver; Polk Audio TL250 HP Surround w/PSW10 Subwoofer
InCali is offline
