RS20 Pink Band - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 07-09-2011, 08:24 PM - Thread Starter
arkay's Avatar
Well at exactly 1200 hours my RS20 developed a pink band on the left edge of the screen. Is this an optical block problem.
How many of you have had the same experience?
Ron
arkay is offline
post #2 of 26 Old 03-04-2012, 07:43 AM - Thread Starter
arkay's Avatar
Well over the past few months is has become obvious the pink band issue has effected many of the JVC projectors--RS1,RS10,RS20....
Bad optical block at a cost of over $2000 for repair if out of warranty!
Has anyone succeeded in getting JVC to acknowledge the manufacturing problem? Recall????
Arkay
arkay is offline
post #3 of 26 Old 03-05-2012, 08:08 AM
How long ago did you buy the unit?
AV Science Sales 3 is offline
post #4 of 26 Old 03-06-2012, 05:28 AM - Thread Starter
arkay's Avatar
I bought it new about 2.5 years ago. As I said it has 1200 hrs on it.
Seems funny to me that an expensive projector is only expected to last until the warranty expires--kind of like the "made in Japan" of the 70's.
arkay is offline
post #5 of 26 Old 03-06-2012, 05:38 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Arkay
I thought this problem popped up within the first couple hundred hours. You are talking about the brownish pink horizontal bands or shading? I don't think they usually surface later.
Ronomy is offline
post #6 of 26 Old 03-06-2012, 10:53 PM
703
703's Avatar
Photos?
One is banding
Another one is discolouration (this is to do with screen uniformity).
Founder | BullsEye Calibration | www.bullseyecal.co.nz
703 is offline
post #7 of 26 Old 03-07-2012, 10:30 AM - Thread Starter
arkay's Avatar
Picture attached
arkay is offline
post #8 of 26 Old 03-07-2012, 12:21 PM
KBMAN's Avatar
Quoted: 255 Post(s)
Liked: 139
yeah, that seems like a fairly common problem (after time) with this pj. My RS20 has 700 hours on it and just HOPE I can get a couple more years out of it. This problem could very well be caused by too much internal heat, which then cooks the prism block. Don't ask how much they cost to replace!!!
KBMAN is offline
post #9 of 26 Old 03-07-2012, 12:38 PM
KBMAN's Avatar
Quoted: 255 Post(s)
Liked: 139
BTW, your 20 is still good...just zoom out until the pink goes into the black velvet border of the screen.
KBMAN is offline
post #10 of 26 Old 03-07-2012, 01:12 PM
spbozeman's Avatar
I purchased a JVC HD350 in September 2009, and the optical block had to be replaced after 800 hours in November 2010 because of this problem. I haven't had any trouble since then, knock on wood.
https://picasaweb.google.com/1051132...54938764725810
spbozeman is offline
post #11 of 26 Old 03-07-2012, 06:02 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
I don't ever recall that pink stripe on RS1`s. The uniformity issue I know about on RS1`s.
Close to 3000 hours on my RS1 and still clean but I do use high altitude mode with low lamp. The air exhaust is a lot cooler. Later with older bulbs I use high lamp but high altitude not required. Air still cool enough.
Ronomy is offline
post #12 of 26 Old 07-18-2012, 03:37 AM
Steve Dodds's Avatar
I also have the pink band. It started after my projector was out of warranty.
You can use the masking setting to make it invisible and/or zoom out to hide it in frame, but it is annoying to find out a fix would be more than the projector is worth and that it has happened to many.
What it really affects is resale value if you wish to trade up. Even though you can't see it on screen, I would have to tell any prospective buyer and it surely drops quite a bit off the price.
Previously I was able to upgrade my RS1 to an RS2 to the RS20 (all used) without taking too much of a hit.
Fortunately I have no interest in 3D so the difference between the RS20 and the newer models is probably less than it was in years past.
Steve Dodds is offline
post #13 of 26 Old 07-20-2012, 01:26 PM
cbaseuser's Avatar
Quoted: 31 Post(s)
It's weird how different projectors have specific reoccurring issues. My epson 6500ub has a pink band across the bottom. This issue has popped up on what seems like many epsons. The JVC has the problem on the left/right edges. VERY frustrating to say the least.
cbaseuser is offline
post #14 of 26 Old 07-21-2012, 03:43 AM
danielo's Avatar
Quoted: 24 Post(s)
Liked: 53
Mine has this (rs-20) , i have masked it too. It becomes less after 30min but still visible. It does make me wonder if i should have moved from something more direct as DLP/DMD the aging seems to much more stable on that tech.
Daniel.
for men to evolve we have to upgrade
danielo is offline
post #15 of 26 Old 07-22-2012, 10:08 AM
dvcdude's Avatar
Quoted: 14 Post(s)
My HD750 (RS20) developed the pink fringe down the left side in about February of this year. About 1400 hours on unit and out of warranty. To expensive to fix. 2.5 mask and zoom seems to be ok for now.
ISF Level II Certified Calibrator
CEDIA Member
Serving Central Indiana
www.indyvideocal.com
dvcdude is offline
post #16 of 26 Old 07-23-2012, 01:34 PM
Oppenheimer's Avatar
Funny, I came in this forum to look for replacement ideas for my RS1 I bought about 5 years ago. Mine has the pinkish band down the right edge... sometimes it seems to go away, sometimes its a greenish colored band. I have it set so the band is mostly off the screen... it doesn't bother me all that much under normal circumstances, but if the screen goes white its very obvious. I was very, very mad when I first noticed it. It really doesn't bother me as much as I thought it might, but my bulb has 1200 hours on it and when its time to replace it I'm not sure if it won't make more sense to just upgrade the projector.
Oppenheimer is offline
post #17 of 26 Old 07-24-2012, 08:28 AM
interceptor007's Avatar
KBMAN- Yes that is a perfect representation of what mine looks like. I will mask it out, (pink) as all have suggested. I only have 700 hrs on the bulb will, but have not read the warranty info either. Will check on it today. Like everyone has stated at first It kind of pissed me off but over the yrs I have become immune to my electronics going on the fritz. The thing is, this PJ really has a fantastic picture, again last night my wife commented that she can not believe how clear it is, she says it reminders her of watching movies in (Soap Opera) mode, I know its due to the settings I have set up but Im not going to tell her that. Anyway, thanks everyone for the responses and advice solutions to, as I call it now (PInk Panther) of my PJ. One good thing has come of all this though!!! The HUNT begins again for another PJ to replace the HC9000 next year. My wife will go nuts with me showing her all the new PJ's that have hit the market this fall!!! Let the research begin. Regards Tony
interceptor007 is offline
post #18 of 26 Old 09-07-2012, 04:08 AM
xton's Avatar
xton is offline
post #19 of 26 Old 09-07-2012, 05:01 AM
John Ballentine's Avatar
Wonder what causes this? Overheating?
John Ballentine is offline
post #20 of 26 Old 09-07-2012, 05:32 AM
xton's Avatar
In my case it should not, because I have put an air conditioner that leads directly to the appliance and never will be above 25 ° C
xton is offline
post #21 of 26 Old 09-08-2012, 05:00 AM
Good to know. So your A/C vent some how blows directly to the front of your RS20? What fan speed do you run your RS20 at? I always run mine at the lowest (quietest)
post #22 of 26 Old 09-09-2012, 06:23 PM
JVCTECHAU's Avatar
Hi there people.. if you are from sydney australia and u have a fault with your jvc projector and any other brands you are welcome to send it to us. yes we can fix the Pink Banding !
JVCTECHAU is offline
post #23 of 26 Old 09-10-2012, 02:05 AM
deandob's Avatar
Quoted: 40 Post(s)
Liked: 24
I'm in Brisbane - can you tell me approx. how much it costs to fix this issue?
deandob is offline
post #24 of 26 Old 09-10-2012, 05:31 AM
xton's Avatar
Yeah, me too I have it so, in the lowest mode (in my case it's because I appreciate a higher decibel noise if the fan speed is higher and that bothers me).
Here in Palma de Mallorca, the summers are very hot, so I was careful to put the air conditioning and avoid the possibility of overheating. In addition, the projector I have it connected to a battery to avoid possible electric current oscillations. The problem is generated by the apparatus.
xton is offline
post #25 of 26 Old 11-12-2014, 07:49 AM
stefan.schmidi's Avatar
Liked: 0
Hello,
please can you help me? I have some troubles with my JVC DLA-HD550!
I have a pink stripe on the right side of the picture,
I think it´s a problem in the optical block...
Can you give me an repair tip?
Please give me any feedback )
best regards,
Stefan
stefan.schmidi is offline
post #26 of 26 Old 11-12-2014, 05:11 PM
GoCaboNow's Avatar
Quoted: 864 Post(s)
Liked: 758
Originally Posted by stefan.schmidi View Post
Hello,
best regards,
Stefan
Not much help but a little more detail in this thread.
ATTENTION: MAGENTA (or any colored) STRIPE DEFECT ON THEIR JVC PROJECTOR
My Dedicated Home Theater Room
GoCaboNow is online now
