DLA-X7 - 3D problems with Comcast Cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-15-2011, 01:37 PM - Thread Starter
rebn's Avatar
I recently completed an install of the X7 and was extremely pleased with the results after an ISF calibration. I connected an Oppo BDP through a Denon AVR and was able to get 3D content visible without any additional configuration. I am not having any luck with Comcast Cable. (Metro Atlanta) The two stations that we get either show top/bot or side/side. There aren't any settings inside the projector to turn 3D on/off; it just adjusts when it senses a 3D signal. I bypassed the AVR entirely and connected the cable box directly to the projector. Still no luck. I changed resolutions from 1080i to 720p and no luck. JVC tech support wasn't very helpful at all, and my sales rep mentioned to me some incompatibility issues with the way the 3D source material is encoded. Can anyone confirm or deny this? Has anyone had any luck with Comcast Cable (motorola DVR) and the X7/60U ?
"The mind is like a drunken monkey stung by a scorpion"
rebn is offline
post #2 of 9 Old 07-15-2011, 03:40 PM
Ron Jones's Avatar
Quoted: 899 Post(s)
Liked: 895
There is a setting on the JVC X7 to manaully select the side-by-side and top/bottom 3D formats. True HDMI 1.4a video sources (which current cable TV boxes are not) can include info in the HDMI exchange to tell the projector when side-by-side and top/bottom formats are being used. The JVC menu to manually set the 3D mode is under the input signal >> HDMI >> 3D Format. See page 41 of the JVC owner's manual (at least the English language version) an also more details at the top of page 52 (at the end of section 2-1 on the projector's menus).
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
post #3 of 9 Old 07-15-2011, 05:50 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
To clarify, if the signal includes a code sending the type of 3D format, the projector will switch to that format automatically if set to 3D auto. If the code is lacking in the signal being broadcast, the projector will not know what to switch to and you will have to tell the projector what to switch to by leaving the auto selection and switching to the format being sent.
mark haflich is offline
post #4 of 9 Old 07-15-2011, 06:38 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
I thought the JVC didn't work with over/under like with 3D ESPN.
Ronomy is offline
post #5 of 9 Old 07-15-2011, 06:48 PM
Liked: 1010
ESPN 3D by DTV is 720p side by side, which is non conforming with the 3D standard, The new Sony projectors have included it despite its non conformance. The Lumagen Radiances will covert 720p side by side to a conforming standard.
post #6 of 9 Old 07-15-2011, 07:42 PM
Ron Jones's Avatar
Quoted: 899 Post(s)
Liked: 895
Correct as for Directv using the 720p s-b-s which is only an optional format in the HDMI 1.4a standard. However, CableLabs that sets the cable industry standards and certifies cable TV set top boxes, specifically does not support the 720p s-b-s format and ESPN uses 720p top/bottom 3D format for cable TV which is a HDMI 1.4a required 3D format and it is supported by the JVC 3D projectors.
Ron Jones
post #7 of 9 Old 07-16-2011, 07:26 AM
Liked: 1010
You know I forgot that cable ESPN 3D is 720p top and bottom.And I have certain 3D set ups where 720p top and bottom was not handled by the projector regardling of the 3D type setting.
post #8 of 9 Old 07-16-2011, 03:58 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
I thought Top/bottom was optional and SBS was standard! Like the Monoprice converter that outputs SBS. I figured that was a standard format. SBS I would think looks better than top/bottom when combined.
Ronomy is offline
post #9 of 9 Old 07-16-2011, 04:45 PM
Ron Jones's Avatar
Quoted: 899 Post(s)
Liked: 895
For 720p top/bottom is the required format and 720p s-b-s is optional. For 1080i s-b-s is a required format. See the Basic 3D Video FAQs thread for the list of HDMI 1.4a required 3D formats.
Ron Jones
