Panasonic PTAE7000/ AT5000 - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 07-30-2011, 07:24 AM
sharp360's Avatar
Any word if panasonic offer a bundled package with this? I would like the 3d version of Avatar with a couple pairs of glasses to get started.
Can 3d movies be rented anywhere? I have netflix but never thought to look before.
My Theater build
http://www.avsforum.com/avs-vb/showt...9#post21268949
xboxone gamertag: MASTERpTWINKIE
PS3: zaczimer
sharp360 is offline
Old 07-30-2011, 08:02 AM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 265
Originally Posted by Ron Jones View Post
There were prices announced last year when they had planned to release their LCoS projectors and before then ran into issues with actually manufacturing the LCoS chips (see the existing thread - HERE). However, as the market has changed over the past year I suspect the prices will be lower, especially for 2D only models. Epson has not yet announced their plans for 3D projectors, but it is expected this info will be released, and perhaps demos provided, at the IFA (Germany) and CEDIA (USA) trade shows in early Sept. There have been some hints that Epson would bring out a LCD 3D projector and given that Panasonic is usng D9 Epson LCD chips, there will probably be an Epson LCD 3D model(s) based on these same D9 chips. If Epson follows their normal pattern there will probably be at least 2 models offered. It's still unknown what plans Epson has for a LCoS based 3D model.
As I vaguely remember, the tentative prices floated last year for the Epson lcos pj's were in between their lcd pj's and the JVC's. If they are indeed still only 2d as expected--which would be my preference--I hope you are right that they will be a bit lower. If Epson actually produces a product with the performance of the prototype that cine4home reviewed last year, I think it will be my next pj--unless JVC's new product shows some very significant advances!
millerwill is offline
Old 07-30-2011, 08:21 AM
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
the panels they use are .74 higher aperature.
the D7 was .70" panels. So yes new panels should have better native contrast also.
conan48 is offline
Old 07-30-2011, 08:42 AM
Deja Vu's Avatar
Quoted: 933 Post(s)
Liked: 943
I hope you buy the Panasonic and then let us know what you think. Give it a bit of time though - let's say a month to get over that crucial honeymoon period. I believe you own the Acer 720p 3D projector and have had both the Sony VW90 and JVC RS-50 so your comments should be well informed.
Deja Vu is offline
Old 07-30-2011, 09:07 AM
m. zillch's Avatar
Quoted: 1958 Post(s)
Liked: 1237
Originally Posted by Viche View Post
I have a 240hz samsung lcd and I can still see the lcd motion blur. The 240 helps the frame creation techology, but I don't know that it overcomes the blurriness that you see in lcd motion. Not sure if its the same with projectors.
I'm very sensitive to LCD panel motion blur and as I walk around Best Buy I wonder how people can put up with it, as I see it in so many of their flat panel LCD TVs.
Plasmas, CRTs, and small panel projector LCD s [ such as the Epson D7 (I think) LCD panel based Panasonic PTAE4000 I've had for a year, or so] don't seem to have this same problem and I'm viewing in a much better setting than a department store, and on a 98" screen, so I think I'd notice it if it were a problem. I guess .7" LCDs don't have this same problem as their big brothers.
LCOS/SXRD projectors on the other hand I believe do have this problem. At least they did when I investigated them some 5 years ago or so. I'm not sure about single chip DLP, but their rainbow distortion, which I am also sensitive to, makes them a deal breaker in my book.
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
Old 07-30-2011, 09:11 AM
tbase1's Avatar
Quoted: 43 Post(s)
Liked: 66
no thx i'll keep my 4k....3D is okay, but i can't see buying 8 pairs of glasses to fill my HT.
tony4k
tbase1 is offline
Old 07-30-2011, 09:26 AM
hogdad's Avatar
Quick question: Will HDMI 1.3a support 3D or will I need to upgrade my receiver to support the new Panny?
hogdad is offline
Old 07-30-2011, 09:42 AM
m. zillch's Avatar
Liked: 1237
check: hdmi.org
I think you need 1.4 for 3D, IIRC.
specifically:
http://www.hdmi.org/manufacturer/hdmi_1_4/3d.aspx
Old 07-30-2011, 09:47 AM
lovingdvd's Avatar
Quoted: 2672 Post(s)
Liked: 550
I'm a pretty big fan of 3D. Hopefully the new Epson 4000 will support 3D. If the pj doesn't do 3D but is amazing in just about every other way, and if JVC doesn't get their act together, then I would strongly consider it even without 3D.
lovingdvd is offline
Old 07-30-2011, 09:48 AM
lovingdvd's Avatar
Liked: 550
...If Epson actually produces a product with the performance of the prototype that cine4home reviewed last year, I think it will be my next pj--unless JVC's new product shows some very significant advances!
Does anyone have a link to the cine4home review of the prototype mentioned above? I tried the cine4home site but didn't see it. Thanks.
Old 07-30-2011, 10:06 AM
hogdad's Avatar
thanks, I'll probably get a Blu-ray 3D disc player that has both 1.3 and 1.4 outputs and use the 1.3 output for the audio to my receiver. I'm nowhere near ready to replace my Denon 3808CI just because it doesn't support 1.4.
hogdad is offline
Old 07-30-2011, 10:29 AM
Avatar26's Avatar
Panasonic DMP-BDT310 has dual HDMI outs for around $200 street.
Avatar26 is offline
Old 07-30-2011, 10:52 AM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 265
Sorry; try this.
http://www.cine4home.de/tests/projek...00_Preview.htm
Old 07-30-2011, 11:05 AM
kriktsemaj99's Avatar
Quoted: 645 Post(s)
Liked: 364
Originally Posted by JamesN View Post
On the 4000 it matters. If your lens isn't centered, and you use the manual horizontal shift to center a zoomed 2.35:1 image, then the "unzoomed" 16:9 image is slightly off center. It's an even bigger deal if you have masking.
I was really hoping they would add power lens shift to the lens memory on this model. I didn't see anyone commenting either way, but I guess it's not there otherwise Panasonic would have made a point of mentioning it.
The manual lens shift controls are no longer on top of the case though, so where did they go?
kriktsemaj99 is offline
Old 07-30-2011, 11:08 AM
Viche's Avatar
Quoted: 430 Post(s)
Liked: 109
Great info! That's good news. So where can I find a list of LCD projectors using the .7" chip?
There was an interesting line from the projectorpoint review:
"Viewing the AE7000U side by side against the previous AE4000U clearly shows the smokier, gray look to the black areas of the AE4000U. By comparisson the AE7000U produced blacks that were inkier."
I'd really like someone to compare shadow detail. I've found that an image that is overall more black looking sometimes means that shadows are being crushed. When you have good shadow detail, there should be a slightly more grey overall look to the entire image.
Viche is offline
Old 07-30-2011, 11:14 AM
widerscreen's Avatar
The manual lens shift controls are in the front hidden behind a door see the image
widerscreen is offline
Old 07-30-2011, 11:26 AM
Quoted: 645 Post(s)
Liked: 364
Pity they didn't add powered shift, that would have made the lens memory work for a lot more people who have limited mounting options.
Old 07-30-2011, 12:14 PM
ckenisell's Avatar
Quoted: 110 Post(s)
Liked: 62
Originally Posted by ckenisell View Post
I just received my 65" VT30 plasma (the 3D glasses will work with this 3D projector), but I just decided to move to a new city and, with the move, comes a new house. This house has an optional media room, which, of course, will become my home theater.
Floor plan here. Click Interactive Floor Plan tab > Second Floor > Media Room
The room is 15'-9" by 15'-8" and I will have the slope to 9' ceilings.
Since I am new to the projector scene, I could use a little advice:
  • What are the length limits for high speed HDMI cables? [Edit]I think I answered this one by looking at Monoprice and I see 100 ft. high speed HDMI cables. I don't need anything near that long, but would that work?
  • I would like to put the equipment rack in the closet. Since I have a Logitech Harmony H1, how do I point the remote at the screen, but have the signal reach all of the equipment that's in the closet? Is that was an IR repeater does? How does this work? [Edit]I just looked on Logitech's web site. It looks like I need the Harmony 900 with IR blaster.
  • What type of screen do I need to get for the best results with this projector?
  • Why not have a large 16x9 screen and just have the black bars during 2.35:1 movies? What does all of this "lens memory" stuff actually accomplish? I really don't want to have to get some kind of shifting screen cropping mechanism.
  • Am I correct in assuming that this projector mounts to a pole or platform that hangs from the ceiling?
  • What are some of the best room acoustical treatments available that also reduce light reflection such as the light reflecting from a projector screen?
Anybody?
Chet
ckenisell is offline
Old 07-30-2011, 12:28 PM
Daniel Hutnicki's Avatar
I saw the Panasonic yesterday along with Brad at the Panasonic Labs. I agree with Brads comments about the new AE7000. I think there is a good difference in brightness and detail quality between the AE7000 and the AE4000 in 2D. Nothing to compare in 3D of course
Still has the memory lens everyone seems to love. Great for scope screens. Panasonic glasses from their flatscreen tvs will work with the projector. The projector has a built in emitter that works within 6 meters. They do sell an external emitter for those who need a longer range. It connects to the 12 volt trigger
Let me first say that I dont really like 3D and I havent changed my mind after watching the Panasonic. However, i did think the 3D was done very well and I saw no ghosting. Just like any other projector, there is a big difference in brightness between wearing the glasses and not wearing them. They used a 1.0 white screen in both demos and to be honest, i have no idea how well those screens deal with polarization. I do know that Stewart has a type of material that deals really well with it and probably makes the 3D look a lot brighter. Panasonic likes to includes a lot of bells and whistles in their projector and has added those for 3D. They have a wave monitor that allows you to adjust the colors by displaying what the right eye and left eye sees and you can adjust both so they match. I would like to add that i was impressed by the 2-3D conversion. You know it wasnt filmed in 3D, but it does a great job in faking it. Its not exactly 3D, but not exactly 2D either.
As a fan of 2D, i think Panasonic did a really nice job with the AE7000. If you like the 4000, you are really going to like the 7000.
As for Panasonic coming out with a new projector., don't get excited. While they didnt exactly say so, its more likely going to be a less expensive projector, probably not 3D although that's my guess. Panasonic usually has an expensive model and a cheaper model
Daniel Hutnicki is offline
Old 07-30-2011, 01:38 PM
darinp2's Avatar
Quoted: 1129 Post(s)
Liked: 1765
They usually do, but if Epson gets things worked out with their reflective-LCD chips (like LCOS) I could see Panasonic having a more expensive projector using those chips. While I don't recall them doing this before, they could even have 3 projectors by the end of the year or early next year, with this AE7000/AT5000 in the middle (R-LCD being the highest end and maybe a 2D model being the lowest end).
Just speculating though.
--Darin
This is the AV Science Forum. Please don't be gullible and please do remember the saying, "Fool me once, shame on you. Fool me twice, shame on me."
darinp2 is offline
Old 07-30-2011, 06:16 PM
JamesN's Avatar
Originally Posted by Bob Whitefield View Post
You're correct if the lens throw is exactly perpendicular to the screen. And yes, you don't want to use horizontal shift.
But if the projector is angled just a tad horizontally, you won't notice the tiny amount of horizontal keystoning and overscan caused by a 6" offset, if you split the difference between 16:9 and 2.35. Even with 16:9 masking.
At least I don't, and I'm pretty picky. You may be pickier...
"Picky" is the polite term for what I am. More like anal-retentive.
Happily I am using a Chief RPA mount, and after a bit a research I found this:
Lateral Shift Bracket
It provides a 3" right/left lateral shift and adds only about 7/8" to the overall mount height. Seems like just the ticket.
Now I just need to find out if I also need a new mounting plate. It would be nice if the plate for the 4000 fit the 7000 as well.
JamesN is offline
Old 07-30-2011, 06:47 PM
I am not expert on Panasonic, but i have been following their projector now since the AE500. While they do fast in terms of releasing a new projector every year, I dont think they would all of sudden come out with a new projector just because a new chip comes out. I think they already have the 2012 model already in the design stage and while It could very easily be change before a 9/12 release, i cant see them creating a new projector and releasing in early 2012 just because there is a new chip
Old 07-30-2011, 08:15 PM
lovingdvd's Avatar
Liked: 550
How would you compare the AE7000 with the RS50?
Old 07-30-2011, 09:43 PM
David Susilo's Avatar
Quoted: 617 Post(s)
Liked: 585
my worry is still with the non-centre-mounted lens and dust-blob problem.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
Old 07-30-2011, 09:58 PM
Quoted: 617 Post(s)
Liked: 585
If one does get a dust blob, can it be cleaned at home - or do you have it send it in for service? If that later, I don't think I could consider such a machine.
In theory you can clean it at home, but it's not for the faint of heart. It's not as simple as opening the lid, blow some air, close the lid. It's tricky and requires (relatively) a lot of work.
They should've addressed this issue even on the 4000 but they didn't. I hope they REALLY address the issue on the 7000 or at the very least have a lid with only one screw (with rubber surround seal) to make the cleaning process much easier at home.
my home theatre
Old 07-30-2011, 11:01 PM
blee0120's Avatar
Quoted: 450 Post(s)
Liked: 239
I hated cleaning mines
blee0120 is offline
Old 07-31-2011, 01:01 AM
coderguy's Avatar
Quoted: 377 Post(s)
Liked: 306
Panasonic should just add the Sanyo cleaning design to their projectors, especially since they own Sanyo now. I don't think even the Sanyo design got rid of them 100%, but close enough as it blows them into such fine pieces you can't see them anymore.
My biggest concern with the Panasonic 7000 will be if it still produces a slightly softer image like the 4000 did, I wonder if this Panny is finally in the class as one of the sharper and punchier projectors for bright scenes, or if its still a bit soft like the old Panny's were (at least to me they appeared softer). A lot of people will not care either way, but sharper is especially better when you want to use it for HTPC.
Also, about time they added a stronger lamp, as some of the numbers these LCD's pump out in best mode is too DIM for those of us that like bigger screens. I guess it took 3D to make them finally increase the lumens. I guess heat/reliability issues keeps these LCD manufacturers trying to keep the lamp wattage at the minimums they think are suitable for their market.
Access HERE from this thread
coderguy is offline
Old 07-31-2011, 01:30 AM
darinp2's Avatar
Liked: 1765
In this case the new chips from Epson have been public knowledge for almost a year (they were demoed at CEDIA last year), so I would be surprised if Panasonic hasn't been working on a model to use those chips. To be clear, I'm talking about the chips Epson announced for the 2000 and 4000 models last year, but have been delayed. I don't know if Epson will insist on an exclusivity period for the chips (if they ever work all the issues out) given the long delay.
--Darin
darinp2 is offline
Old 07-31-2011, 02:14 AM
Thebes's Avatar
Hi,
product sheet (in english) is available here :
http://www.homecinema-fr.com/forum/v...180#p174916180
Thebes is offline
Old 07-31-2011, 03:02 AM
Grubert's Avatar
A year ago, rumor had it that Epson had one year's exclusivity for their "reflective LCD" panels. Even if that were true, it might be one year from product announcement or from the actual launch. Which would make a big difference in this case.
Freedom is the freedom to say that two plus two make four. If that is granted, all else follows.
-George Orwell, Nineteen Eighty-Four
Grubert is offline
