Panasonic PTAE7000/ AT5000 - Page 47 - AVS Forum | Home Theater Discussions And Reviews
post #1381 of 1396 Old 07-23-2012, 11:16 AM
BartMan01's Avatar
Does the 7000 allow for any convergence correction? From what I can see the answer is no, but that seems to be a common feature at this price point. If no, what do you do if one of the panels drifts by a pixel (or more) - just have to live with it?
BartMan01 is offline
post #1382 of 1396 Old 07-29-2012, 03:02 AM
kevinuk's Avatar
Iam looking to get one of these and want to use a scope screen at 105.5 inches wide.
The projector lens will be 11.5 feet away but i am unsure if this will work from that distance using the zoom mode.
Anyone now for sure or do i need to go smaller.
Many Thanks
kevinuk is offline
post #1383 of 1396 Old 10-26-2012, 02:39 AM
aronake's Avatar
Hello,
Im not happy with the sharpness of the picutre on my AE7000. For movies it works very well, but when I use it as a screen for my computer, im not happy with it. I had a Sanyo PLV-Z2 and found it sharper for computer text. True the AE7000 should have this soft focus thing to make space between pixles disapera but still. Seems one of the panels is 1 pixel off (at least) and some ghosting light above bright areas caused by the lens shift (and possiblt bad assembled lens system).
Im using the lens shift almost to around 80%, and the sahrpest I can get is as per attached photo. Is this good enough, or resaon to demand repair?
I also have this high ptich sound people talk about and find it quite loud. Its as lound as the fan. Should/can this be repaired? I understood that some projectors had en extra lound high pitch sound because of problem that could be repaired.
aronake is offline
post #1384 of 1396 Old 12-17-2012, 06:50 AM
yellowferrari's Avatar
I have just bought a PT-AT5000 and it is a big improvement on my old Sony. However I have a problem. My picture keeps cutting out especially when first turned on. It seems especially bad on cartoons, possibly because the majority of the picture stays the same. It is also preceded sometimes by left to right bleeding. It also seems to be sensitive to temperature. When the house is hot the picture cuts out more often. I put the projector in Eco mode which was better than normal mode. I have also put it in high ceiling mode which increases the fan speed and helps. The projector is suspended from the ceiling at 2.55 mtrs (below the 2.7 mtrs max). This to me all indicates a thermal cut out problem although I am not sure about the bleed proble ( but this only really happens on cartoons). Anybody any ideas? There seems to be a mention of a service menus to adjust the fan speed, can anybody advise how to access this.
yellowferrari is offline
post #1385 of 1396 Old 01-29-2013, 11:06 AM
Alex Cole's Avatar
Originally Posted by aronake View Post
Hello,
i have exactly the same issue, can this be repaired?
Alex Cole is offline
post #1386 of 1396 Old 01-30-2013, 07:34 PM
ckenisell's Avatar
Quoted: 115 Post(s)
Liked: 64
No. I have the issue as well. I think everybody does.
Chet
ckenisell is offline
post #1387 of 1396 Old 01-31-2013, 08:31 AM
dmoneyman2323's Avatar
Quoted: 32 Post(s)
Liked: 35
I no longer have the AE7000 as i moved up to the 8000 but my focus was actually much better than that. If that is the sharpest you can get yours I would try to RMA it. I'm no expert though, but my convergence was better than this.
Displays: JVC RS4910 Projector | 125-inch 2.35:1 Elite Cinetension2 Screen | Panasonic 58V10 Plasma TV
Sources: Yamaha RX-A800 | Microsoft XBOX One | Dish Hopper | Intel i5 Nuc w/ Openelec | Behringer iNuke 3000DSP
Speakers: DIY Fusion-12 Tempest (L/R) | DIY 88-Special (C) | DIY Volt-10 Speakers (Surr L/R) | Subwoofers: MartyCube w/ Stereo Integrity SI-18 X 2
dmoneyman2323 is offline
post #1388 of 1396 Old 02-25-2013, 05:19 AM
nosys70's Avatar
do not buy the IR extender ET-TRM110, it is pure scam.
you will pay 200$ for absolutely nothing else than a piece of plastic and 5 led soldered on a little print + a minijack socket (total value, probably less than 10 buck)
ok i update this post with the technical info.
the five leds are 850 nm as specified in the ET-TRM110 manual. Leds are connected in series
the projector plug delivers 100mA (specified in projector manual) , so if you build your own emmitter make sure you do not go over 100ma, most led being between 20 and 50mA
if the connector drives the leds at 12V, you can expect that each led must have a forward voltage of 12/5= 2.4V, most common led are usually 1.4-1.6V, some are 1.6-2.0V,
so we can say if you take any cheap led on ebay there are chance they do not fit. Make sure the forward voltage is 2.3 or 2.4 V or use a resistor to lower voltage.
The Osram SFH4350 is rated 1.5-2.4V and 100mA with an angle of 26 degree (do not take the the 4550, the angle is 6 degree only ) so it is a perfect match, but you will not be able to fill the missing led with it, because you would then reach 200ma.
that could possibly burn the output port on the projector.
If you need more power It is better in that case to build a second emitter with 5 more leds and use the 2nd output port on the projector.
you can find the leds here http://www.led-eshop.de
If you make your own, there is no need to have a plug at the emitter side, just solder the cable directly to the circuit.
Use a cheap shielded cable (audio grade)
You should be able to buiild an emitter for less than 20$
nosys70 is offline
post #1389 of 1396 Old 02-25-2013, 05:42 AM
David Susilo's Avatar
Quoted: 636 Post(s)
Liked: 592
LOL! It's not just a regular IR extender, it runs on a different frequency (different than the 2 main IR frequencies used by all manufacturers). Just try make it yourself and see whether it's going to work. biggrin.gif
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #1390 of 1396 Old 02-25-2013, 09:54 AM
Quoted: 636 Post(s)
Liked: 592
If I have to spend more than two hours sourcing and building the thing, it's not even worth my time doing it myself. It'll be cheaper for me just to buy the thing.
my home theatre
post #1391 of 1396 Old 03-21-2014, 02:57 PM
Freak1's Avatar
I have had mine for a few years now using it with my 21:9 screen and i3 HTPC with HD4000 graphics. Its working great.
But for getting it to fill the screen i have to make the image larger and then have xbmc to calibrate the screen to fit. Its fine for most movies but especially for 3D, but also others it will not move the subtitles up in the picture and remains under the picture. Is there anything i can do about that? Like make everything fit in the 21:9 picture by changing the resolution on windows? I tried but i cant seem to get windows to do that.
Freak1 is offline
post #1392 of 1396 Old 04-06-2014, 04:44 AM
EL Duke's Avatar
Quoted: 107 Post(s)
Liked: 122
Is there any other 3d glasses you can use with this that are better than the panasonic ones supplied?
EL Duke is offline
post #1393 of 1396 Old 04-06-2014, 06:25 AM
Quoted: 636 Post(s)
Liked: 592
I tried several different brands, they are all worse and not far cheaper either.
my home theatre
post #1394 of 1396 Old 04-11-2014, 09:29 AM
EL Duke's Avatar
Quoted: 107 Post(s)
Liked: 122
Cheers for the reply Dave. Maybe ive been spoilt with just getting a sony 905 ive not really been using the projector that much recently for 3d. I popped in the latest hobbit film though and im so disappointed with the 3d I actually think there might be a problem with the projector. The glasses are so dark I had hoped a new lighter pair might have popped up to give them a try. But crosstalk is a major problem with my 7000 just now and I cant remember it being that bad!
The picture looks blurry with crosstalk im checking to see if the glasses are on sometimes its that bad. Even with avatar it can be pretty distracting and I would say avatar is one of the best crosstalk less disks out there. Any suggestions? ???
EL Duke is offline
post #1395 of 1396 Old 04-11-2014, 02:23 PM
ckenisell's Avatar
Quoted: 115 Post(s)
Liked: 64
How many hours should be on a bulb before it's replaced? My bulb has about 770 hours on it and I think it might be getting too dark for 3D. But, I don't know if it's actually getting dimmer or if it's just my imagination. Desolation of Smaug is already a dark movie. So, it could just be the movie.
And, of course, I know that everybody's experience will be different based on brighness settings, eco settings, etc. I'm just looking for a ball park number. If 2,000 hours is the norm, then that's one thing, but if 500 - 800 is the norm, that's another.
Chet
post #1396 of 1396 Old 04-11-2014, 02:36 PM
ckenisell's Avatar
Quoted: 115 Post(s)
Liked: 64
EL Duke, I have the EXACT same problem. The crosstalk with this project is soooo bad that I am thinking of going with another brand. I bought this projector for it's 3D capabilities. BIG mistake. Since Panasonic is now out of the plasma business, I think I'm done with Panasonic. Even after I just won a WT600. I have 3 Panasonic displays:
PT-AE7000U - Too much crosstalk
65" VT30 - Won't update the Viera Market, so there's a really old version of Netflix on it
65" WT600 - No HEVC Codec Support (which is gonna be the codec used for most 4K content) - No Netflix 4K
It's always something.
Chet
