Sony VPL-vw1000 - Page 253 - AVS Forum | Home Theater Discussions And Reviews
 1316Likes
Old 12-18-2013, 09:03 AM
stevenjw's Avatar
Quoted: 307 Post(s)
Liked: 317
Originally Posted by discodol View Post
I am not sure what the starting point actually was since the person who setup the pj for me may have changed things to his liking.
How do my end results compare to what yours are?
What are you settings after calibration? Also, please post your lamp hours and screen used including its gain.
...Steve
"Opinions are like orgasms… mine matters most and I really don’t care if you have one."
My HT gear
stevenjw is offline
Old 12-18-2013, 09:46 AM
d.j.'s Avatar
Quoted: 165 Post(s)
Liked: 73
Originally Posted by sanderdvd View Post
stevenjw, d.j. is right on this one. The REFERENCE preset is the best starting point because that is closest to D65. I ISF calibrate projectors and of course I know how all things exactly works. I ll post my calibration results thonight wink.gif
The only thing I asked was to see if my measured light output is normal. The FILM MODE i am talking about is the PROJECTION MODE. Yes, I also know this is a dark frame insertion method that cuts off approx 50% light output but again, I m only trying to find out if my light output is 'normal'.
Btw, the DFI option does VERY good things to the PQ and moreover, it works in 4K too. The only downside is the native on/off contrast, this is cut down when using DFI. With no DFI i measure a native contrast 8800:1 while with DFI enabled it is 4250:1. The black floor level is good with DFI enabled but the contrast is noticable worse with it enabled. Compromises compromises smile.gif
Thanks for feed back Sanderdvd
Some numbers for you:
My 1000ES with 170 hours on lamp, clossed possible distance to screen ( 280 cm wide screen - projector 370 cm from it ) Screen research 110" wide CP 2 gain 0.95 ( in reality, probely 0.9 gain ) and with "normal" mode ( not full panel, if full panel / 2.35 zoom mode approx. + 10% ). Projector adjusted to D65 and with no clipping ( contrast about 88 ) at 255
110" wide with 100% ( 235 ) White test pattern: low = 15,5 fl high = 22,8 fl
IN general gives high lamp mode arround 45% more light ( meassured on 3 1000ES )
2.35 zoom mode / full panel 10 % more
And from 100% test pattern ( 235 ) to test pattern 109% ( 255 ) gives about 20% more light output ( or if you adjust the projector to clipping arround 235 - contrast setting 98-max. - you will win 20 % more light, but lose WTW information )
dj
d.j. is offline
Old 12-18-2013, 01:07 PM
d.j.'s Avatar
Quoted: 165 Post(s)
Liked: 73
@ Mark Hahlich: I found a post from you that this firmware is supposed to be the latest (at that time):
SC ROM Version SC1:01.05/SC2:01.02
NVM Version 01 / 01.04
Sub ROM Version 01.00
IP ROM Version 01.02
DE ROM Version 01.02
I just checked mine and it shows:
SC ROM Version SC1:01.07/SC2:01.03
NVM Version 02 / 01.06
IP ROM Version 01.03
What does this tell me? Is mine newer? btw. My unit was labled (on the box) as VPL-VW1000ES3 and my serial number is 10100XX
Could someone check with a pretty new VW1000 unit their software version? You can check the software by going into the service menu: ENTER, ENTER, LEFT, ENTER, TOGGLE YES. When you go in the menu after you did this you can see all the additional information as described above in the INFO part of the MENU.
I think, I got one off the newest software now ( not that I think it is better then any off the others - have had your version too and I cant see any difference except a on/off toggle in the RC menu) , here it is :
SC ROM Version SC1:01.08/SC2:01.04
NVM Version 03 / 01.07
DE ROM Version 01.03
dj
d.j. is offline
Old 12-18-2013, 03:31 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
To get the newest software the unit has to back to Sony service. With the upgrade to 1100ES maybe the unit can be flashed with the new stuff externally. Not sure though.
mark haflich is offline
Old 12-18-2013, 03:59 PM
d.j.'s Avatar
Quoted: 165 Post(s)
Liked: 73
Why do the hassle? immediately, there is no significant difference in the last few versions of software IMO ( And there is no guarantee that the latest software is the "best" as some people allways think )
dj
d.j. is offline
Old 12-18-2013, 05:51 PM
thrang's Avatar
Quoted: 1605 Post(s)
Liked: 1381
With the 1100 update, it seems all the firmware values are reset to 1.00...
thrang is offline
Old 12-18-2013, 05:55 PM
OzHDHT's Avatar
Quoted: 784 Post(s)
Liked: 417
I was going to say I'm pretty sure that's what my factory 1100 has when you go into the service menu.
OzHDHT is offline
Old 12-18-2013, 06:10 PM
zombie10k's Avatar
Quoted: 2824 Post(s)
Liked: 2775
Any signs that it will work with the RF glasses?
zombie10k is online now
Old 12-18-2013, 06:36 PM
OzHDHT's Avatar
Quoted: 784 Post(s)
Liked: 417
Nope I have 4 pairs from my panel and I sat there to try them with MV3D RF transmitter running and no sync. The 1100 still comes with IR glasses as per the 1000. I also tried to sync to the MV3D transitter by holding down the power button put it into RF sync mode on the glasses but no dice. I think the RF freq must be in a different range to the Monster/Optoma ones. Not so much a loss though as the Sony RF glasses look nice but I don't think the open sides will help the image quality over the current Optoma super light wrap arounds.
OzHDHT is offline
Old 12-18-2013, 06:40 PM
zombie10k's Avatar
Liked: 2775
I didn't expect that the MV3D's would work, they are not part of the RF standard. I was hoping maybe you had a pair of the glasses that ships with the VW600.
I ordered a pair to test Mike's VW600 and will likely keep them just to see if they work with the 1000 after the mobo swap.
Old 12-18-2013, 08:00 PM
stevenjw's Avatar
Quoted: 307 Post(s)
Liked: 317
great! Could you also check what your firmware version is? (see my post from a few back). And what is your opinion on DFI? Like I said, I like it very much but the downside is that is native contrast is cut down 50%.
My unit was labeled as VPL-VW1000ES2 and my serial number is 11100XX
I'll post back later with DFI impressions, but I run low lamp so may not like the loss. I'll also try with lamp in high mode to help compensate.
...Steve
My HT gear
stevenjw is offline
Old 12-18-2013, 08:09 PM
Liked: 1010
dj
Since we are all getting the conversion to the 1100ES, its at this point a moot point. I am curious if the Roms are on the new mother board or whether they are inside and just flashed during the conversion process by the Sony tech wherever the praised may be out there in upgrade land. May one of they speedily visit all of us and enable us to see the Sony No Baloney 4K promised land. UHD output at 24 or 30 from the server.
Old 12-18-2013, 10:24 PM
stevenjw's Avatar
Quoted: 307 Post(s)
Liked: 317
More later including my conspiracy theory why Sony is not shipping the 1100ES until years end and why I think upgrade kits won't be shipped until then. smile.gif
If your theory is correct, we may not want a speedy visit just yet....right?
...Steve
My HT gear
stevenjw is offline
Old 12-18-2013, 10:39 PM
OzHDHT's Avatar
Quoted: 784 Post(s)
Liked: 417
The promise land awaits you Brother Haflich! May you soon join us there....Hallelujah! Just gimme the glory of Lawrence of Arabia and I will be in rapturous delight across this very weekend!...God bless his sole that fine fellow, Mr. O'Toole!! biggrin.gif
OzHDHT is offline
Old 12-18-2013, 10:42 PM
zombie10k's Avatar
Liked: 2775
Oz - quick question - did the menu fonts change from the 1000 to the 1100? The 500/600 uses a different font, it looks better than the 1000. It's no big deal, just curious if it's different.
Old 12-18-2013, 10:45 PM
OzHDHT's Avatar
Quoted: 784 Post(s)
Liked: 417
Zero diff. Would be same as upgraded 1000's i.e. no change.
OzHDHT is offline
Old 12-19-2013, 12:04 AM
zombie10k's Avatar
Liked: 2775
Thanks. you may have mentioned this when first receiving the 1100 - is the RC any less harsh than it is on the 1000?
on first look at the 600 and 1000, the 600 RC appears more subtle and not as aggressive looking. I was hoping to hear this was dialed back a bit with the update.
Old 12-19-2013, 12:57 AM
sanderdvd's Avatar
Quoted: 164 Post(s)
Liked: 30
Thanks for all the input on the different firmware versions that are available guys. So until now I have found 5 different firmware versions and 3 different VW1000 types:
SC ROM Version SC1 01.01 SC2 01.01
NVM Version 01 / 01.01
IP ROM Version 01.01
SC ROM Version SC1 01.03 SC2 01.02
NVM Version 01 / 01.02
SC Rom Version SC1 01.05 SC2 01.02
SC ROM Version SC1 01.07 SC2 01.03
SC ROM Version SC1 01.08 SC2 01.04
VPL-VW1000ES1
VPL-VW1000ES2
VPL-VW1000ES3
Now we need to find out what the different values mean and what the actual differences are between the firmware version. There could be important fixes we don t know about. Just an example: it was mentioned a while ago that the HDMI range setting (Full-Auto-Limited) had some issues when feeding the VW1000 with a RGB signal. This is pretty important for HTPC users. Also, there COULD be fixes in the dynamic iris, FI etc.
I assume that Sony updates the firmware through the LAN input and simply by some kind of install procedure with using a Windows platform. All we need to have is the firmware and a detailed firmware upgrade 'manual'.
d.j. Did yours got a repair? Because your firmware version seems newer then mine but my VW1000 is labeled as VPL-VW1000ES3 while you say your is labeled as VPL-VW1000ES2.
sanderdvd is offline
Old 12-19-2013, 04:57 AM
Liked: 1010
All the software differences make no difference if one is having their machine transformed into a 1100ES given Thrang's report of the 1100ES transformation of his 1000 has a whole new set of software.
Any internal hardware differences between the ES1, ES2, abd ES3 are unknown. That's what we need to know and I doubt Sony US will tell us but maybe someone could ask them. I am not sure if they will say anything except they are al the same etc. But suppose there are say a different power supply board that reduces the arc flash circut caused banding, It wiuld be nice to know.
Old 12-19-2013, 05:06 AM
adidino's Avatar
Quoted: 320 Post(s)
Liked: 254
It may be as simple as a Sony internal designate for warehouse location or build revision. I believe Apple does something similar when they have slight change in internal components on the same model device. I doubt there is any difference between them at all that we would ever notice.
adidino is online now
Old 12-19-2013, 05:10 AM
OzHDHT's Avatar
Quoted: 784 Post(s)
Liked: 417
Yep I did. I found it to be as it should be, identical aka same as upgraded 1000. To clarify for anyone still unsure, the 1100 is the same as a late model 1000 but of course already upgraded, so ie better converged from factory than my early prod 1000. Nothing handed across from the 500/600...as much as I'd love to have the autocal and any RC improvements. Prob have to wait for a VW2000 to see that I reckon..
OzHDHT is offline
Old 12-19-2013, 05:17 AM
Liked: 1010
I am pretty sure Sony will say something like that but I would like to know the actual differences in circuits and boards and what those accomplished or were done for. We just don't knw any thing.
Old 12-19-2013, 05:43 AM
sanderdvd's Avatar
Quoted: 164 Post(s)
Liked: 30
I agree, maybe it s indeed just 'warehouse differences' but maybe it are actual hardware changes/upgrades like a change in a power supply like Mark says. The same goes for firmware upgrades: maybe they are not important at all but maybe they contain pretty important updates in eg. dynamic iris, RC etc.
Old 12-19-2013, 05:44 AM
adidino's Avatar
Quoted: 320 Post(s)
Liked: 254
I am pretty sre Sony will say something like that but I would like to know the actual differences in circuits and boards and what those accomplished or were done for. We just don't knw any thing.
In most cases it's due to availability of the original component from their supplier which required a change in component or supplier.. Typically not an engineering improvement.
Old 12-19-2013, 05:56 AM
sanderdvd's Avatar
Quoted: 164 Post(s)
Liked: 30
In my opinion a firmware update that needs to be done by the manufacturer is so 2012 biggrin.gif
Serious, it would be so much better and easier if we could update the firmware ourselves. Just put a simple USB input on the projector, download the update.file from Sony's site and let it install on the projector.
Old 12-19-2013, 06:05 AM
Liked: 1010
2012? Its 2014 in a few days. CEDIA is only 9 months off, its almost time to start flipping the stuff we haven't even got yet.
Old 12-19-2013, 06:14 AM
sanderdvd's Avatar
Quoted: 164 Post(s)
Liked: 30
Has anyone been able to get the Sony Image Director software to connect to the projector? I downloaded the latest version, 3.1, from Sony's esupport site, which allows it to work natively under Wndows 7, but I cannot connect to the projector via USB/RS232 or via the allegedly supported network connection....
I also want to get this working but I have no succes just like you. Installed Image Director 3.1 from Sony site and connected my VW1000 with the network output to my PC but I can t get it working.
Old 12-19-2013, 06:15 AM
sanderdvd's Avatar
Quoted: 164 Post(s)
Liked: 30
Mark, you know how to get Image Director 3.1 work with our VW1000?
Old 12-19-2013, 07:26 AM
d.j.'s Avatar
Quoted: 165 Post(s)
Liked: 73
VPL-VW1000ES1
VPL-VW1000ES2
VPL-VW1000ES3
d.j. Did yours got a repair? Because your firmware version seems newer then mine but my VW1000 is labeled as VPL-VW1000ES3 while you say your is labeled as VPL-VW1000ES2.[/quote]
Yes, it has been exchanged and later repaired and no, it is (are certainly on the box smile.gif ) a VPL-VW1000ES3 , and the software was on it from start ( before the rep. ) seriel numbers is in the 10102XX
dj
d.j. is offline
Old 12-19-2013, 07:58 AM
sanderdvd's Avatar
Quoted: 164 Post(s)
Liked: 30
WHy was your unit exchanged? And why later repaired? I think our units are from a same production or something like that. We are both from Europe and my unit is 10100XX. What says the date with your unit (you can find this on you label on the unit itself to the left of the serial#).
Casio Rs 232 Adapter Catalog Category Projectors Accessories , Sony Vpl Vw1000es Projector
