Sony VPL-vw1000 - Page 262 - AVS Forum | Home Theater Discussions And Reviews
 1329Likes
post #7831 of 14261 Old 12-30-2013, 09:04 PM
zombie10k's Avatar
Quoted: 3464 Post(s)
Liked: 3549
that's good you got it working. Check out the 3 min demo of 'Into Saturn's Rings' when you get a chance.
zombie10k is online now
post #7832 of 14261 Old 12-31-2013, 12:37 AM
stevenjw's Avatar
Quoted: 431 Post(s)
Liked: 512
Originally Posted by stevenjw View Post
I also took Lux readings using my meter with only an hour on the lamp (Reference 1, IRIS off, D65, BT.709, Bright 50, Contrast Max). Lamp in High mode is 500 Lux (46.45 lumen/sq ft) at the screen which is just over 15 feet away from the Sony lens. I sit around 8 feet from the screen which is a 136" diagonal Carada BW 2.35:1. I watch in Low mode which measured 349 lux (32.33 lumen).
I forgot to measure FI film (black frame insertion), but will do so later and edit this post.
At 57 hours, high lamp is 480 and low is 340 with same settings. So far, so good at about a 3-4% drop after 56 hours. I guess that might mean a 30-40% drop after 560 hours. We'll see how linear it tracks. Hopefully it'll level off at some point too.
I also measured with Motionflow Film Projection On and got 318 in high ans 219 in low. I don't use FP (black frame insertion), but apparently it's all we get with 4K and someone (I forget who - SanderDVD?) was curious if it dropped off a lot. I'm seeing about a 35% dropoff on a static field.
...Steve
"Opinions are like orgasms… mine matters most and I really don’t care if you have one or not." ;)
My HT gear
stevenjw is offline
post #7833 of 14261 Old 12-31-2013, 03:39 AM
Grifo's Avatar
Quoted: 36 Post(s)
anyway 1100 has just landed here in Italy.
The seller says it has Reality Creation 2
and is much better than 500 concerning
contrast and detail...
Grifo is offline
post #7834 of 14261 Old 12-31-2013, 05:33 AM
thrang's Avatar
Quoted: 1862 Post(s)
Liked: 1565
I have, it's one of the better ones. Some of the nature ones have their moments, but there are a few too many soft or washed out shots in them
The Jimmy Kimmel music segment (don't remember the band) is pretty sharp, and there is a film based music video of some singer with kids eating donuts at a table that is very crisp.
I didn't mind Battle:Los Angeles and Total Recall, though the effects look soft...
thrang is offline
post #7835 of 14261 Old 12-31-2013, 05:43 AM
thrang's Avatar
Liked: 1565
Originally Posted by mark haflich View Post
Same on my job. Get the same message as Thrang.
Thrang. What are you outputing resolution wise now on your Lumagen 2041 after the factory reset?
Right now, I'm not getting the Chris Matthews thrill up my leg with the 20xx series as I had hoped. It's inability to output 4k60 incoming signals is a large issue for using it for a lot of broadcast. I find that for film based material on Directv, I can set it to output 4k 24 and it seems to properly recognize the original cadence. But it is comical to try and watch 60hz material at 4k30, sort of a micro-jittery sense of movement, and 720p60 content does not fair well.
It does an excellent job with 23hz content, but the scaling differences vs the 1100 are subtle in my testing so far.
The Lumagen still has great value for its gamma/greyscale, and updated CMS capabilities, and it solves hdmi issues for me that I could not live without right now.
I hope there is a way they can upgrade the unit to properly scale 1080i/p 60 to 4k60. So for now, I am only outputting 1080p from the 2041 for broadcast.
Perhaps there's a setting I'm missing, but that's an interim update...
thrang is offline
post #7836 of 14261 Old 12-31-2013, 09:30 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
Just to clarify for other readers, in your second sentence you are criticizing not the inability to input 4K but the inability to output 4K above 30 (due to chip bandwidth limitations) so that lower resolution input sources (i.e., 720p 60, 1080i/p 60) can be output at UHD/4K 60. I expect when the next generation of Lumagens comes out (after production quantities of wider band width chips come out) , this will be rectified with a generous trade in for 2041 and 2042 owners.
I agree with your assessment.
mark haflich is offline
post #7837 of 14261 Old 12-31-2013, 10:15 AM
howdydoody's Avatar
So, to clarify for those of us that contacted our dealer immediately after upgrade was announced, we won't be getting the ten free movies?
howdydoody is offline
post #7838 of 14261 Old 12-31-2013, 10:33 AM
thrang's Avatar
Liked: 1565
Yes, though I wouldn't even say criticizing Lumagen - it's more shame on me for not catching that published spec.
thrang is offline
post #7839 of 14261 Old 12-31-2013, 10:39 AM
Liked: 1012
I am not criticizing Lumagen either. Its a realization that 4K 60 out is needed and it can't be done until chips become available. I didn't realize that 4K 60 was available but I should have known that because of the unavailability of chips. The Sony server can only output UHD at 24 or 30 also.
post #7840 of 14261 Old 12-31-2013, 10:42 AM
Mike Garrett's Avatar
Quoted: 6693 Post(s)
Liked: 4382
It is not looking that way. Sony has barely started shipping these with just a few on their way to us.
mjgarrett100@gmail.com
Mike Garrett is online now
post #7841 of 14261 Old 12-31-2013, 11:05 AM
KRGM1's Avatar
Quoted: 77 Post(s)
Liked: 37
So the people fortunate enough to get the earlier appointments for the upgrade get the 10 free movies and the rest of us are left in the cold. Seems about right.
KRGM1 is offline
post #7842 of 14261 Old 12-31-2013, 11:13 AM
Liked: 1012
You won't be left out in the cold.
post #7843 of 14261 Old 12-31-2013, 09:26 PM
zombie10k's Avatar
Liked: 3549
This concert looks amazing.. wow. There is a lot of detail and great color in this clip.
post #7844 of 14261 Old 12-31-2013, 09:37 PM
thrang's Avatar
Liked: 1565
Zombie and Oz, since you have FMP's...
Any luck connecting an external hard drive? I just tried a 3tb high speed external USB, and nothing happens - no acknowledgment of a connect drive, no formatting options...
Tested the drive on both mac and pc, and it comes up fine...
And Happy New Year to all here...
thrang is offline
post #7845 of 14261 Old 01-01-2014, 04:41 AM
Grifo's Avatar
Quoted: 36 Post(s)
Happy new year!!!!!!!!!!!!!
Grifo is offline
post #7846 of 14261 Old 01-01-2014, 06:33 AM
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
I was seriously thinking about the new Sony 4k camera, but its just too big to lug around to everything I would want to film (kids sports, events, etc).
For those that know about the quality of imaging devices, sensors, etc.... is it likely we will see truly great quality 4k cameras in the sizes we get 1080p cameras now? I am sure they will get smaller, but people already complain that the 4k imaging chip isnt large ENOUGH right now for great low light capability even with the size of the current "consumer" 4k camcorders, so making them smaller is only going to compromise that, I assume.
Do you guys think we will be "stuck" with fairly large cameras if we want great 4k quality from both the lens and sensor?
Sony could release a cheaper one without the huge boom mic / viewfinder / LCD apparatus and integrate that more on the body. That would help. I'm sure that would be a step backwards for real filmmakers, but I think taking video as just a parent at an event with one of these things would be embarrassing, if not at least pretentious. smile.gif
hifiaudio2 is offline
post #7847 of 14261 Old 01-01-2014, 06:42 AM
thrang's Avatar
Liked: 1565
The lenses are also a factor in 4k capture - even today, the best digital images are captured with full sized SLR styled cameras with large quality glass...so you will definitely see smaller "4k" cameras as the consumer market dictates, but there will be quality compromises, Just like the FMP online delivery concept.
thrang is offline
post #7848 of 14261 Old 01-01-2014, 06:46 AM
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
Yeah I have a full frame DSLR and some good lenses, but even those are dwarfed by this camcorder, unless the pics are tricking me into thinking its bigger than it is. I guess I am just mostly wondering if its size is a necessary component of the quality its trying to achieve, or more because it it s a first gen device. Or even if its because its aimed at a filmmaker that doesn't need it any smaller.
post #7849 of 14261 Old 01-01-2014, 02:23 PM
thrang's Avatar
Liked: 1565
Here's a nice cat scan view...
thrang is offline
post #7850 of 14261 Old 01-01-2014, 02:44 PM
coderguy's Avatar
Quoted: 496 Post(s)
Liked: 345
That image makes me want to run out and buy something I really don't need. Sony is sure good at that :P
Access HERE from this thread
coderguy is offline
post #7851 of 14261 Old 01-01-2014, 04:24 PM
OzHDHT's Avatar
Quoted: 912 Post(s)
Liked: 500
Tried again, no difference. Then tried a third time, first using the app to shut down the FMP and quit the software, then deleted and reinstalled. Manually turned the FMP on, reinstalled the app, and the store returned...thanks Oz
No probs. Glad it worked. I found also with the app, unlike with IOS, when deleted into the trash, you still get the option to uninstall when you get to the Play store to re-download it. I've made sure to hit that option first, then done the re-install from there. Fortunately I only encountered that error the once, hopefully it never comes back. Also another tip, if you ever run into the E4400 connection error with downloads, close the app fully, power down the FMP manually, then restart the app. It happens to me when I've got several movies queued to download across a few days.
OzHDHT is offline
post #7852 of 14261 Old 01-01-2014, 04:35 PM
thrang's Avatar
Liked: 1565
Now I'm trying to add an external drive. Anything over 2 TB seems not to be recognized; 1tb is recognized, I'm given the option to format, but when it's done, the app simply reports the drive is ready to format again and is not used..
Apple, please release a 4k ATV already so things just work....
thrang is offline
post #7853 of 14261 Old 01-01-2014, 04:51 PM
OzHDHT's Avatar
Quoted: 912 Post(s)
Liked: 500
I have brand new 1TB Toshiba drive attached. It doesn't seem to be recognised so far at all. I even re-formatted it myself to FAT32. I haven't wanted to play around too much with external drives whilst still downloading movies as the FMP seems to be a bit temperamental when you start doing things to mid download. I will have a try again tomorrow. Will try some other brands of drives as well and see what I can learn.
+1, ATV's just plain work. Wondering how that little ATV lookalike Nuvola 4K player will go when they get released shortly...
OzHDHT is offline
post #7854 of 14261 Old 01-02-2014, 06:31 AM
KRGM1's Avatar
Quoted: 77 Post(s)
Liked: 37
I measured my lamp at 0 hours and again at 66 hours in high lamp and there was no change that I could measure with my CA813.
KRGM1 is offline
post #7855 of 14261 Old 01-02-2014, 06:56 AM
Hello, World!
Mark_H's Avatar
Quoted: 297 Post(s)
Liked: 205
Did you have the CA813 turned on? I find this result rather hard to believe...
My cinema: The Cave!
My kit: 15' 2.35:1 Screen Research CP2 4-way mask, JVC Z1, Lumagen Pro, Meridian 861/621/7x5500/2xSW5500
Mark_H is offline
post #7856 of 14261 Old 01-02-2014, 07:18 AM
thrang's Avatar
Liked: 1565
Zero point zero...
thrang is offline
post #7857 of 14261 Old 01-02-2014, 07:51 AM
Liked: 1012
Thrang. When I saw the internal view of the camera, I thought was the use of the word schematic appropriate. I actually looked the definition up and I do think it was appropriate though I think the edit is a better description. Maybe no cat scan but xray Man I hope the updates come soon so we have something more to talk about. I have been home four days now and have not even turned my projector on. Football over the weekend for sure fed 1080p 60 out of the Lumagen.
post #7858 of 14261 Old 01-02-2014, 08:16 AM
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
Good pic. Looks like they could definitely eliminate the front hood and pretty much everything attached the the handle up top, integrating the LCD and viewfinder into the body like other camcorders and going back to an internal, inferior mic. Should get the whole thing back to being on par with a larger 1080p camcorder with no or very little loss of image fidelity. Those that need the better mic could still have a mic jack for an external.
OK I will quit designing camcorders for Sony in the vw1000 thread now. smile.gif
post #7859 of 14261 Old 01-02-2014, 08:17 AM
turls's Avatar
Quoted: 476 Post(s)
Liked: 205
I've ended up with quite a collection of Mastered in 4k Blu-rays with all the holiday sales. Even Smurfs 2, although only for the 2D version. Starting to look like many newer Sony releases are Mi4k, but what I don't get is how they did all the re-releases without extras, but now they admit they can do extras, since all the new releases include them. Why would they want to open themselves up to the criticism?
At this point with my backlog I probably will wait for the magic of the 1100 upgrade to play any of these, so I get the full effect.
Matt
turls is offline
post #7860 of 14261 Old 01-02-2014, 08:22 AM
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
Been a while since I thought about the mi4k titles. I forget, do they require a specific or special Blu Ray player as well for the "special" color? Must it be a Sony, or do Oppo players work, etc?
Casio Rs 232 Adapter Catalog Category Projectors Accessories , Sony Vpl Vw1000es Projector
