Sony VPL-vw1000 - Page 343 - AVS Forum | Home Theater Discussions And Reviews
 1321Likes
post #10261 of 14231 Old 08-05-2014, 04:34 PM
blee0120's Avatar
Quoted: 479 Post(s)
Liked: 261
Sure, I'll take a look and let you know. One area I was surprised at is how well the detail stays during high speed action. When I get closer to the screen I can really see the fine details in the background. This is the 780 ti card I posted about a while back.
Thanks. I read some reports about how well the 780 ti works with 4k gaming.
blee0120 is online now
post #10262 of 14231 Old 08-06-2014, 12:36 PM
stevenjw's Avatar
Quoted: 407 Post(s)
Liked: 460
Originally Posted by Johnsteph10 View Post
It's out today...just downloaded it, but haven't had time to watch it. I hope it looks good. I seem to remember the trailer looking pretty decent...
I paid for and downloaded it last night. Hope to watch it tonight.
...Steve
"Opinions are like orgasms… mine matters most and I really don’t care if you have one or not." ;)
My HT gear
stevenjw is offline
post #10263 of 14231 Old 08-06-2014, 01:19 PM
BakeApples's Avatar
Quoted: 268 Post(s)
Liked: 149
Originally Posted by Andreas21 View Post
Quote: Originally Posted by scooter_29
I have the Supernova 08-85 and I dont find it to dim, I have the 128" 2.35:1 screen in combination with the VW1000 and I love this setup.
Hi Andreas, are you running your 1000 in low lamp mode with the 08-85 Supernova?
I'm considering getting the 08-85 Supernova myself for use with my VW500 and i wonder if the light will be enough for 2D in low-lamp?
BakeApples is offline
post #10264 of 14231 Old 08-06-2014, 02:46 PM
Andreas21's Avatar
Quoted: 1133 Post(s)
Liked: 724
With a new lamp it is ok to run it in low, I get around 17fl with a new lamp in low. So it depends on your screensize, if you go bigger than me it will get dimmer and you might need to go up to high to get the brightness you like. I like a bright picture and run mine at high after about 200 hours on the lamp. I tested the VW500 here last year and it was plenty bright with my screensize.
Andreas21 is offline
post #10265 of 14231 Old 08-06-2014, 02:52 PM
BakeApples's Avatar
Quoted: 268 Post(s)
Liked: 149
Ok, good to know. I was thinking of going with a 116" in 2.35:1 so it should be ok.
post #10266 of 14231 Old 08-06-2014, 03:23 PM
Andreas21's Avatar
Liked: 724
Then you can run low lamp for a long time...
post #10267 of 14231 Old 08-07-2014, 01:04 PM
turls's Avatar
Quoted: 476 Post(s)
Liked: 204
Do you have a CIH/2.37 setup to test gaming with? I just sent my projector off, but I tried to run games off my HTPC I just got and I was having a lot of trouble with the widescreen resolutions. I was testing Titanfall, which I know is supposed to work at ultra-wide resolutions, and it refused to work at the custom resolution I setup. Even though the game said it was running at 2.37 ratio, it was going above and below the screen. I don't have anamorphic, I just use zoom (as most do I think).
Was also having issues with 4k 60p also which is supposed to work with the newest Nvidia drivers I thought. That could be a cabling issue, I didn't have time to try more than 2 cables.
Anyway, I hope you don't mind if we compare notes in the future as I try to get my HTPC setup for widescreen gaming on the 1100ES. I'm thinking the projector running zoomed adds an extra variable vs. standard ultra-wide monitor setups.
One other possible issue, I only got a 750ti because I refuse to buy a beefier card until they come out with the smaller fab chips for them. But I would think for this exercise it would work the same as your card, just slower. I will run ultra-wide in 1080 until then, which with zoom, actually should use less pixels and should perform decently. I couldn't get Titanfall to work in 1080p or UHD.
Matt
turls is offline
post #10268 of 14231 Old 08-07-2014, 07:02 PM
joerod's Avatar
Quoted: 671 Post(s)
Liked: 570
The Amazing Spider-Man 2 is my first official voucher purchase!!!!
We have a weekend movie!!!!
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is offline
post #10269 of 14231 Old 08-08-2014, 02:27 PM
turls's Avatar
Quoted: 476 Post(s)
Liked: 204
Uggh, the saga continues with the botched/defective upgrade board ... that Sony should have made other arrangements besides making me ship my baby to Laredo.
The thing was picked up Standard Overnight FedEx over 24 hours ago. The only notation on the tracking is that it was picked up. Nothing since.
I should have all kinds of notations on that by now. FedEx says it should have been delivered by now.
The only way this happens in my mind is it either fell off the truck or "walked" away.
I hope Sony insures these...it was their shipping tag.
EDIT:Well that was pretty good customer service, got a call back already from the escalation team. Seems the label had to be reprinted in transit. Not sure what happened there, or why the tracking wouldn't note that. Still not good because it likely delays the shipment over the weekend and we all know the longer this stuff is in the shipping channel the more likely bad things happen...
Matt
turls is offline
post #10270 of 14231 Old 08-08-2014, 11:25 PM
zombie10k's Avatar
Quoted: 3114 Post(s)
Liked: 3207
My screen is a 16:9 but I can try the widescreen modes to see how it works. I've tried several games in UHD 3840x2160, they all loaded fine and look impressive.I'm using a regular HDMI cable to the 1100 2nd HDMI port and a DVI -> HDMI to provide sound to the AVR.
I don't recall, what issue did you run into with your update that required sending it back to Sony?
a fellow member noted on the 600 thread that Nvidia kept the 60hz UHD setting in the latest non-beta drivers so that's very cool to see them push the cutting edge of HDMI 1.4. I get that the subsampling isn't ideal, it still looks awesome nonetheless.
zombie10k is online now
post #10271 of 14231 Old 08-11-2014, 05:30 AM
turls's Avatar
Quoted: 476 Post(s)
Liked: 204
Thanks for verifying your setup. I was also going into the 2nd HDMI port. I have some rack reconfiguration I need to do before I get the audio part going, but that's great to know you can run that from the same card with a DVI to HDMI converter. Thanks for verifying that change made it into non-beta as well, since I couldn't get it to work even though it showed up as an option. That may be my card, cabling, or some other issue, but at least there is hope that setting will stay supported indefinitely for when I do get a card I know can run well at 60p.
My upgrade board never had working serial or IP ports for me. I'm assuming they must have worked for the upgrade but it must have died soon after that. Because of unrelated issues with my home automation, I thought it was just that I didn't have it actually hooked up to my network, but it was more than that. Bad timing. And then my Sony tech confirmed he had my original files from the upgrade but never provided them to me. I felt like I should have either gotten on-site service to correct an issue with an in-home visit component that died within a couple months or I should have been able to transport my unit locally to get it worked on, since it was known the new board was the issue. No luck on either, even though my original tech would have still been available to do the work.
Matt
turls is offline
post #10272 of 14231 Old 08-12-2014, 08:06 PM
joerod's Avatar
Quoted: 671 Post(s)
Liked: 570
DVDO Mini 4K Scaler
So I spent the last 4 hours experimenting with a fresh one from Amazon (just came in stock) and I have to say I am really impressed. Reading the first couple Reviews on Amazon I was expecting to return it after 20 minutes or so. I now can say I know what Mark is always talking about when he mentioned Ringing. I spent the evening checking out NFL preseason games. I can say the image is cleanest I have seen using its Ringing Suppression and Smoothing. I went back and forth quite a bit and during the plays the difference is also noticeable. The numbers on jerseys and score boxes look damn clear. Jaggies are virtually non existent! I am using a Monoprice IR Extender (model 8060) which their manual suggested with perfect results. It works fine with the DVDO Duo and 103D in the chain. Though it is harder to justify the Duo but I love its extra controls and options. If you send in Blu-ray 1080p/24 it passes right through. 3D works fine with it too. Tomorrow I plan to spend more time comparing them. As for now I am very impressed with their VRS Clearview chip and its 4K scaling abilities. The front row just got as good as the back for football!
joerod is offline
post #10273 of 14231 Old 08-12-2014, 08:50 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1011
Me? Ringing scaling? Joe finally getting it? Hell has frozen over. No more lying eyes.
mark haflich is offline
post #10274 of 14231 Old 08-13-2014, 01:42 PM
joerod's Avatar
Quoted: 671 Post(s)
Liked: 570
YES.
I get it now.
joerod is offline
post #10275 of 14231 Old 08-13-2014, 09:25 PM
iwanrs's Avatar
Quoted: 48 Post(s)
Sorry folks, I am desperate. I snitch into this thread for Sony 1100 (Sony 1000 and 1100 are twin sisters).
I am about to install my Sony 1100. Ceiling mount.
I tried to find any unofficial or Sony official "Installation Manual", but no where to find ?
Available only Instruction manual for using the Projector, Remote etc.
Usually Sony issue 2 kind of manuals, Instruction and INSTALLATION manuals.
This is odd enough, for this kind of high-end product Sony try to save some paper cost or web-listing ?
Can someone help me and give me hints, links etc.
iwanrs is offline
post #10276 of 14231 Old 08-13-2014, 10:43 PM
zombie10k's Avatar
Liked: 3207
post #10277 of 14231 Old 08-13-2014, 11:15 PM
RapalloAV's Avatar
Quoted: 1378 Post(s)
Liked: 333
Can anyone tempt me to upgrade from my VW-500/600 to the VW-1100.
I have a 145" scope screen and a fully blackout room.
What will I really notice in the changeover please?
Will the blacks be noticeably any better?
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is online now
post #10278 of 14231 Old 08-13-2014, 11:30 PM
Jamo8's Avatar
Quoted: 17 Post(s)
Smile
Why don't go for a demo ?
Jamo8 is offline
post #10279 of 14231 Old 08-13-2014, 11:38 PM
RapalloAV's Avatar
Liked: 333
I don't think a demo will produce the correct results.
Different rooms, different size screens, just never works.
The only way to tell is in my room next to my 500/600 and that's not easy to setup.
I really need someone from here who has set the two up side by side and compared.
Murray Thompson
X Owner RapalloAV
post #10280 of 14231 Old 08-13-2014, 11:43 PM
iwanrs's Avatar
Quoted: 48 Post(s)
The installation section starts on page 16, what specific info are you looking for?
https://docs.sony.com/release/VPLVW1000ES.pdf
ZOMBIE10000,
This is basically what I need:
1. Screen high from floor for 150" 16:9 screen, watching from recliner sofa, eye level at about 70cm high from floor. HT room is 5m x 8m.
2. Optimal Sony lens distance from screen, ceiling mount, any point between 5.5m to 7.5m. Brightness is important. Dedicated HT, no windows no outside light Bat-cave.
3. Sony lens center placing in compare to Screen top edge.
Hope you can give me some real bites.
iwanrs is offline
post #10281 of 14231 Old 08-14-2014, 01:28 AM
Andreas21's Avatar
Liked: 724
I have seen them side by side and the VW1000/1100 is better, but I wold recommend you sice you have the store you have to side by side test them and see if you find the upgrade worth it.
post #10282 of 14231 Old 08-14-2014, 02:53 AM
raczkri's Avatar
Quoted: 14 Post(s)
Liked: 2
Originally Posted by iwanrs View Post
ZOMBIE10000,
Iwanrs, no offence, but based on your posts in the other thread you started on the topic, I think you should ask someone to help you install the projector.
As for your specific questions
1. your preference. I would put this screen around 40-50cm from the floor. Why don't you set up the pj temporarily and try what is comfortable for you?
2. You could use the Projectorcentral calculator to determine the possible range of projector distance from the screen. This data for your specific screen size 150" diagonal(?) is also listed on page 80 in your manual. https://docs.sony.com/release/VPLVW1100ES.pdf
The projector distance from your screen can be between 447 – 973 cm (or 176 – 383 in.) as listed. It is your choice in this range. The closer you put the projector (in this range) the brighter image you get. The farther you put, the more uniform the light distribution will be (this may not be noticable with this excellent projector).
Based on the above, ideally you may put the projector somewhere around 450-500cm from your screen to maximize light output. But it all depends on the design of your room and your preferences also.
3. On page 80 of the manual the projector's lens shift range is listed. Based on this, the answer to your question is 0-48,8cm from the top edge of your screen (if your screen is 150" diagonal 16:9). it is fine anywhere in this range.
Also, on the other thread you say you will get a 2,4 gain sreen. this is completely unnecessary and I would advise against it unless you always want you use the projector with the room lights on.
As you say your room is a Bat cave, a 1.0-1.3 gain screen will give you a very bright picture with this projector and screen size. A higher gain screen will compromise your image quality and really not needed.
This projector has around 1700-1800 Lumens calibrated light output (according to reports in this forum), so if you put your projector around 5meter from your 150" screen you'll get around 26 ft.Lamberts screen brightess with a 1 gain screen and around 34 ftL with a 1.3 gain screen. That is plenty! your typical commercial cinema has around 14-16 ftL.
hope this helps
raczkri is offline
post #10283 of 14231 Old 08-14-2014, 06:02 AM
Liked: 1011
I responded to your email request to me. Remember guys his request is for the 1000/1100ES not the 500/600ES and he already has his screen.
post #10284 of 14231 Old 08-14-2014, 06:49 AM
iwanrs's Avatar
Quoted: 48 Post(s)
Thanks Mark for your very helpful advises.
iwanrs is offline
post #10285 of 14231 Old 08-14-2014, 06:56 AM
iwanrs's Avatar
Quoted: 48 Post(s)
Thanks raczki,
You reply is more than useful for me.
How can I miss that page 80 of Instruction Manual
iwanrs is offline
post #10286 of 14231 Old 08-14-2014, 09:07 AM
samalmoe's Avatar
iwanrs..if you put up a 150inch wide screen, with the sony which will lose lumens after a while[12-1500 new bulb]..i strongly suggest a 2.4 hipower screen. i have a 2.4 168incher and its great with a brand new bulb.did have a 144incher before that. you will like the brightness, not the dimness..check this forum for true lumen output of the projector..i wouldnt go over 10ft wide with a no gain screen..good luck
samalmoe is offline
post #10287 of 14231 Old 08-14-2014, 10:39 AM
iwanrs's Avatar
Quoted: 48 Post(s)
samalmoe,
My screen is EluneVision 4K Reference 150" 16:9 with 2.40 gain.
Many said that with 2.40 gain you are practically look into the sun, so bright.
Manufacturer said: You will experience watching a true BIG SCREEN LCD TV ???
I need more brightness for my aging eyes.
I am anxious after I mounted it, how bright it is, and how good it is?
iwanrs is offline
post #10288 of 14231 Old 08-14-2014, 11:13 AM
Liked: 1011
urgent. With a 2.4 gain screen you will have hot spotting if you mount a close throw. With that screen I suggest you mount it at the longest throw possible which on the Sony is around 2.27. This is a very serious and significant issue. I would put the projector on a table and experiment with throw distances. close throw at 1.25 screen widths will give you horrible results. Go long. Experiment to make sure you do not overfill the screen. do not ignore this advice.
post #10289 of 14231 Old 08-14-2014, 11:47 AM
samalmoe's Avatar
if its too bright run it on low power
samalmoe is offline
post #10290 of 14231 Old 08-14-2014, 12:11 PM
Liked: 1011
Hi. That won't fix a high spotting issue which is a function of throw and screen gain and becomes more complex with a gray substrate and sprayed on gain which in that case becomes determinative of the minimum throw.
Casio Rs 232 Adapter Catalog Category Projectors Accessories , Sony Vpl Vw1000es Projector
