Sony VPL-vw1000 - Page 347 - AVS Forum | Home Theater Discussions And Reviews
 1331Likes
post #10381 of 14274 Old 08-29-2014, 09:24 AM
Mike Garrett's Avatar
Quoted: 6957 Post(s)
Liked: 4648
Originally Posted by hermosa View Post
Thanks Mike.
Room is neutral gray with dark gray carpet. Width would be 96". I use the 1100 only at night. No light issues. Throw distance probably exactly at 11 feet.
I do watch 3D on occasion.
I have never experienced hotspotting with current .95 gain 103" screen.
Since you do some 3D, I would go with the ST130. If we can help you with pricing, give us a call.
mjgarrett100@gmail.com
Mike Garrett is offline
post #10382 of 14274 Old 08-29-2014, 09:26 AM
Liked: 4648
Thanks everyone for the screen advice. Seems like the ST 100 is the way to go. Since my current screen has a .95 gain, I won't miss the 130's brightness. Also, I would just be at the minimum throw distance recommended by Stewart for the 130. Better to be sure and go with the ST 100.
AVS Forum is invaluable for getting everyone's experience with the same equipment.
ST100 will give you great results with 2D, but 3D would be a little better with ST130. It is going to be a slight compromise, which ever way you go.
post #10383 of 14274 Old 08-29-2014, 09:33 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
OK. You want substance, I will give you substance.
At his throw, 11 ft, he will be within 1 ft of the closest possible throw with his projector, 10 ft.
This will give more brightness than I am getting in 3D at 15 ft. At 15 ft, the 3D is watchable, just a tad dim. But he has a good room and will watch in the dark. The gains in image quality of 2D of the ST100 over the ST130 are substantial and as an owner easily outweigh the dimness of the 3D.
To my knowledge, every one here who has made the switch has reached the same conclusion.
mark haflich is offline
post #10384 of 14274 Old 08-29-2014, 09:47 AM
hermosa's Avatar
Quoted: 37 Post(s)
Thanks, Mark. I tend to agree with you. My projector is almost at the minimum throw distance. And Stewart's recommendation for the ST 130 would also have me at the minimum. I am worried about hotspots with the ST 130 at that short distance.
My current Screen Research is .95 gain. I have been happy with the brightness level. It could always be brighter but artifacts would drive me crazy if they came with a higher gain screen. 3D is not bad with the current screen, but dimmer than I would like. I think my 3D with active shutter glasses is brighter and better than movie theater 3D with passive glasses. 2D looks great.
Since I watch a lot more non-3D, I think I may not need any brightness boost. Not sure why the Stewart rep would recommend the ST 130 - but he assured me no hotspots.
But this is why I turned to Forum members - because several folks have the 1100ES and experience with both screens.
So the tradeoff seems to be no hotspots with the ST 100 and better 3D with the ST 130. Since 90%+ of what I watch is not 3D, the ST 100 seems like the way to go.
Again, thanks to everyone for the input. The discussion helped my decision.
hermosa is offline
post #10385 of 14274 Old 08-29-2014, 09:59 AM
Liked: 1012
You have 7 inches to spare with the minimum throw required by Stewart. Hot spotting will not be an issue at a throw of 1.3. the issue is other artifacting which you may or not be sensitive to such as sparklies and the fact that with 130 compared to 100, the screen material will never completely disappear.
ST130 G1 was originally developed by Stewart at the request and assistance of Joe Kane for CRT projectors. The maximum gain that would not hot spot at the fixed throw distance required by most CRT FPs was needed and some red push in the fabric was needed as well. The push was eliminated as the fabric matured in later generations and the smoothness needed for 4K resolution was improved. But the spayed on gain still has minor non hot spotting artifacts.
post #10386 of 14274 Old 08-29-2014, 10:03 AM
hermosa's Avatar
Quoted: 37 Post(s)
Originally Posted by mark haflich View Post
You have 7 inches to spare with the minim throw required by Stewart. Hot spotting will not be an issue at a throw of 1.3. the issue is other artifacting which you may or not be sensitive to such as sparklies and the fact that with 130 compared to 100, the screen material will never completely disappear.
ST130 G1 was originally developed by stewart at the request and assistance of Joe Kane for CRT projectors. The maximum gain that would not hot spot at the fixed throw distance required by most CRT FPs was needed and some red push in the fabric was needed as well. The push was eliminated as the fabric matured in later generations and the smoothness needed for 4K resolution was improved. But the spayed on gain still has minor non hot spotting artifacts.
Mark
If I got a swatch of the ST 130 fabric and stretched it tightly over a flat surface, would that be a realistic test of artifacts if I moved around to various positions close to the existing screen?
hermosa is offline
post #10387 of 14274 Old 08-29-2014, 10:08 AM
Liked: 1012
Mark
The test is your sensitivity to the artifacting. The problem with an A/B comparison between two fabrics is the automatic almost universal attraction to the brighter image.
The test that your propose simply won't show the much greater realism or open window, screen material disappearing effect of the 100 over the 130.
post #10388 of 14274 Old 08-29-2014, 01:34 PM
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
The thing about the 100, though, is its much greater propensity to scatter light back around your room. I was cautioned by many people when looking at screen material that even with a "black room", the st100 would light up the room a good bit. So couple the lesser gain with the propensity to light up the room and you have decreased overall contrast.
My screen is a woven AT screen (I was looking at microperf versions of the ST100 / ST130), so who knows if the light scattering is any worse than what I already have. Its certainly acceptable to me and I am very happy with my screen.
hifiaudio2 is offline
post #10389 of 14274 Old 08-29-2014, 02:05 PM
RapalloAV's Avatar
Quoted: 1626 Post(s)
Liked: 474
Im going to replace my VW500/600 to the VW1100 since I really like the image on the 500 so much.
Does the 1100 have a "blank screen" function?
I have it with the 500 via RS232 even though its not available on the remote.
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is online now
post #10390 of 14274 Old 08-29-2014, 03:05 PM
d.j.'s Avatar
Quoted: 171 Post(s)
Liked: 74
yes the projector has that function, but no, its not on the remote - but you can use an old remote with the function and learn the code or with a tablet, there is an Sony App with it on ("remote" ) its called "Pic muting"
dj
d.j. is offline
post #10391 of 14274 Old 08-29-2014, 03:29 PM
hermosa's Avatar
Quoted: 37 Post(s)
Wouldn't the ST 130 light up the room even more with its increased gain?
hermosa is offline
post #10392 of 14274 Old 08-29-2014, 03:32 PM
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
No the coating also focuses the light into a narrower viewing cone. That is why you lose gain as you go off angle. The light is focused more on the viewer straight in front, not to the side walls.
post #10393 of 14274 Old 08-29-2014, 03:57 PM
hermosa's Avatar
Quoted: 37 Post(s)
My current screen is a Screen Research with .95 gain. Would you think the light scattering would be about the same as my current screen when compared to the 1.0 gain ST 100?
I realize you haven't seen my screen, but using your HT knowledge/logic.
My current screen does somewhat light up the room but does not bother me. At only 11 feet from the screen, it encompasses much of my field of view for the most part.
hermosa is offline
post #10394 of 14274 Old 08-29-2014, 04:42 PM
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
Hard to say. Let Mark chime in since he lives with the st100 and I have only read about it and have only seen a small sample. My guess is that it would throw off a little more light than what you currently have.
post #10395 of 14274 Old 08-29-2014, 06:33 PM
Liked: 4648
If 3D is okay with your .95 gain screen, then ST100 is a better way to go, because you will get a slight improvement with 3D and a good improvement with 2D. Only thing that made me leery about ST100, is the walls. I thought you said they were a neutral gray, that can reflect a fair amount of light back to the screen.
post #10396 of 14274 Old 08-29-2014, 06:54 PM
hermosa's Avatar
Quoted: 37 Post(s)
I guess my question now is: would there be more reflected light off the walls with the ST100 than my current .95 gain screen? If not, then I would be OK with the current amount of reflection I am getting. If it were 50% more reflection, then maybe not.
Not having seen the ST 100, i have no comparative reference point.
hermosa is offline
post #10397 of 14274 Old 08-29-2014, 07:11 PM
Liked: 4648
What fabric is your 0.95 screen?
post #10398 of 14274 Old 08-29-2014, 07:36 PM
hermosa's Avatar
Quoted: 37 Post(s)
Unfortunately I don't know the fabric brand name. It is a 7 year old screen from Screen Research. The only fabric reference on the paperwork is"solid pix white". Not very helpful, I know. My previous HT installer is out of business, so I can't get any info from him.
I guess my only path is to go with the ST 100 and hope it is the right choice.
I can always paint my HT completely black.
hermosa is offline
post #10399 of 14274 Old 08-29-2014, 08:35 PM
Liked: 1012
OK. I went to the Screen Research website and they have one fabric that has a 1.0 gain that I bet is very similar to yours. most pure white screens have a gain slightly less than one and to bring them up to 1.0, they need a very small amount of sprayed on gain. ST100 is such a screen. Surprisingly, the half gain (viewing cone) on the ST100 is less than 90 degrees from center while the Screen research half angle is much much greater than 90. I conclude that the ST100 will throw less light to the side walls than your Screen Research fabric.
I have a tasteful black fabric on my walls. It is not as black as black velvet and you can barely see the fabric when watching content but it is very very dim and it does not appear to be bright enough to reflect any appreciable amount of light back onto the screen.
post #10400 of 14274 Old 08-29-2014, 08:53 PM
hermosa's Avatar
Quoted: 37 Post(s)
Excellent and very interesting. Thanks, Mark for the effort. I believe after all the dialog, the ST 100 is my choice. I will live with light scatter or do something to mitigate the reflection if It bothers me. I do know if I got sparklies from the 130, it would constantly irritate me. I see zero artifacts now with my current screen.
hermosa is offline
post #10401 of 14274 Old 08-30-2014, 12:29 AM
turls's Avatar
Quoted: 477 Post(s)
Liked: 205
Interesting, I see I have access to that pic muting command available in Control4, what is the purpose of this command?
Also, what app are you referring to that can access commands on the 1100ES? I can't find it in the Google Play store.
Matt
turls is offline
post #10402 of 14274 Old 08-30-2014, 06:18 AM
d.j.'s Avatar
Quoted: 171 Post(s)
Liked: 74
It just mute / remove / blank the Picture ( you get a completly Black screen )
Sorry, dont know the apps name ( it is already on the Sony tablet I have )
dj
d.j. is offline
post #10403 of 14274 Old 08-30-2014, 12:29 PM
RapalloAV's Avatar
Liked: 474
One only needs this feature say if you have a stage curtain covering the screen. I cue up a movie, set it on pause then blank the image from the curtain before guests come into the cinema. When I dim the lights and the footlights, the curtain opens and the image then hits the screen at the same time.
I call the function on my ipad, "Douser" this is the name that we used in all the projections rooms I worked in for 35+ years. This is exactly how it is done in all cinemas, you can have the light hitting the screen when the audience is arriving, or during intermission music, advertising playing etc etc etc....
The red handle in this image is a lamphouse douser
Murray Thompson
X Owner RapalloAV
post #10404 of 14274 Old 08-30-2014, 02:58 PM
turls's Avatar
Quoted: 477 Post(s)
Liked: 205
Thanks, I think I might have some use for it during times where I have a bigger picture than the screen when I use the 1100ES zoom functions for different aspect ratios in my motorized masking CIH setup. Kind of distracting to have the image visible during some of that.
Matt
turls is offline
post #10405 of 14274 Old 08-30-2014, 03:55 PM
RapalloAV's Avatar
Liked: 474
This is exactly how they use the function also in the cinema. When the lens turret turns the douser (screen blank) closes so one doesn't see the lens and aperture plates move.
Murray Thompson
X Owner RapalloAV
post #10406 of 14274 Old 08-31-2014, 05:23 PM
hermosa's Avatar
Quoted: 37 Post(s)
Do the folks on the Forum with calibration expertise recommend an ISF calibration with the 1100ES or not? If I have one done, I have to import a calibrator from 4-5 hour drive away.
hermosa is offline
post #10407 of 14274 Old 08-31-2014, 09:29 PM
Liked: 1012
You really don't need to calibrate it. Just be sure you set contrast and brightness, and really its just brightness, contrast can be set to anything from about 90 to 100 with no real effect, brightness will be correctly set between a range of 49 to 51 depending on the machine, use a test disc, set sharpness to 10, set RC to on for R and about 3 or 4 for filtering, set to d65 and rec 709. Add a good three fingers of bourbon and a good cubano and you should be good to go.
post #10408 of 14274 Old 08-31-2014, 09:38 PM
hermosa's Avatar
Quoted: 37 Post(s)
Hah! Thanks, Mark. I can always count on you for good -- and cheeky-- advice.
I was a little worried at getting an ISF calibration and then thinking the picture was diminished without a way to reverse it.
hermosa is offline
post #10409 of 14274 Old 09-01-2014, 06:06 AM
Liked: 1012
Reversing it is never a problem. There are fixed color memories for the preset temps and spaces and custom ones. Further, there is no Color Management System in the unit anyway. You can, of course, create two point custom gray scales using the custom color memories, but that is it. Color space errors can not be corrected but the unit is pretty much on setting the color temp to d65
post #10410 of 14274 Old 09-01-2014, 10:55 AM
mry110's Avatar
Quoted: 133 Post(s)
Liked: 52
Can someone PM me with what I should expect to pay for a 1100ES? I just sold my equipment with my house and have to start over (boo hoo ). I am really wrestling with the 600ES vs 1100ES decision.
mry110 is offline
Casio Rs 232 Adapter Catalog Category Projectors Accessories , Sony Vpl Vw1000es Projector
