Sony VPL-vw1000 - Page 352 - AVS Forum | Home Theater Discussions And Reviews
 1321Likes
post #10531 of 14231 Old 10-05-2014, 05:19 PM
RapalloAV's Avatar
Quoted: 1385 Post(s)
Liked: 336
I usually keep the RC turned most of the way down. the controls are coarser than the VW600 which I generally kept at the lowest setting as well during the comparison. When fed a UHD/4K signal, the RC controls are much finer in this mode.
Are you using a Darbee?
Yes Im using Darbee on my Lumagen 2041, set at 45.
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
post #10532 of 14231 Old 10-05-2014, 05:31 PM
zombie10k's Avatar
Quoted: 3134 Post(s)
Liked: 3222
what is your component setup order, are you scaling 1080P content to UHD on the 2041 before it gets to the Sony?
zombie10k is offline
post #10533 of 14231 Old 10-05-2014, 05:57 PM
RapalloAV's Avatar
Liked: 336
I only use Bluray and I leave the Lumagen set to 1080P.
I don't upscale it to UHD on the 2041 as I have problems with a number of the BD formats 50Hz, 60Hz, 24Hz.
Murray Thompson
X Owner RapalloAV
post #10534 of 14231 Old 10-05-2014, 06:46 PM
stevenjw's Avatar
Quoted: 407 Post(s)
Liked: 461
One of the most annoying negatives of the upgrade was that it messed with the position function. Before the upgrade, it was spot on. Now when I go from 1.85:1 custom to 2.35:1 and then back, I have to always shift the picture down about three clicks. Since I go from a 16x9 desktop HTPC to a scoped movie a lot and then back, I have to deal with this annoying new "feature". Sadly, I doubt Sony will ever correct this and not having an employee monitoring this thread doesn't help.
...Steve
"Opinions are like orgasms… mine matters most and I really don’t care if you have one or not." ;)
My HT gear
stevenjw is offline
post #10535 of 14231 Old 10-06-2014, 04:46 AM
discodol's Avatar
Quoted: 22 Post(s)
Liked: 34
+1
David Ferebee
discodol is offline
post #10536 of 14231 Old 10-06-2014, 08:03 AM
KRGM1's Avatar
Quoted: 76 Post(s)
Liked: 35
One of the most annoying negatives of the upgrade was that it messed with the position function. Before the upgrade, it was spot on. Now when I go from 1.85:1 custom to 2.35:1 and then back, I have to always shift the picture down about three clicks. .
Must have affected only certain projectors as mine does not have this issue. It is still spot on and I use this function regularly.
KRGM1 is offline
post #10537 of 14231 Old 10-06-2014, 09:26 AM
d.j.'s Avatar
Quoted: 171 Post(s)
Liked: 74
Originally Posted by Seegs108 View Post
I think the term "sealed" is a bit ambiguous here on the forum. There are no light engines hermetically sealed on home theater projectors so the chance of getting dust in them is always possible. Maybe Sony should take another look at how they're sealing it. But you aren't going to see hermetically sealed light engines, even at this price point, so it's impossible to make them 100% dust proof. I believe Barco does hermetically seal the portion of the light engine that houses the DMDs. I'm sure this drives up the cost, but them again these machines are much more expensive than the 1000ES.
Seegs / Mike
The new laser projectors is close IFAIK ( like the RZ670 and maybe LS10000 ? ), but the 1000/1100 dont come even close to the word "sealed" ( in my book, their biggest weakness at all )
This is one after 200 -300 hours use ( and no, its absolutly not in a dusty environment ) :
dj
d.j. is offline
post #10538 of 14231 Old 10-06-2014, 09:33 AM
d.j.'s Avatar
Quoted: 171 Post(s)
Liked: 74
Stevenjw
I never had the 1000 upgrade - but there has not been any difference between the position function in my 1000 versus my 1100 ( operate identically )
dj
d.j. is offline
post #10539 of 14231 Old 10-06-2014, 09:34 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1011
Man that is one under exposed image to get a 0 ire pattern to look that black on a Sony.
I have not heard of many users who have experienced a dust blob issue on a Sony.I doubt it was introduced environmentally after production but was something introduced a manufacture that migrated. Do you see it using just pure RGB, each color individually. that is, is it a blob on one of the chips of is it elsewhere? In any vent, get it serviced under warranty. At worst you will only have to wait a few months. I would argue with Sony that you should not have to pay shipping to them with such few hours but I expect you will have to.
mark haflich is offline
post #10540 of 14231 Old 10-06-2014, 10:02 AM
magicj1's Avatar
Quoted: 67 Post(s)
Does switching from 1.85:1 to 2.35:1 effect the focus?
magicj1 is offline
post #10541 of 14231 Old 10-06-2014, 10:11 AM
d.j.'s Avatar
Quoted: 171 Post(s)
Liked: 74
Mark
The Picture is taken just in front of the lens ( it is very difficult to photographers directly from the screen and my photo shooting style is miserable ), but its a easy way to photograph to show/see the spots on it !
I have had a lot of Sony projectors and have never had one single problem with dust spots ever - that was before the 1000 and 1100 !
And no, its not a before production problem , its after normal use, it comes and it is allways on the green panel (green spots)
Here is a picture, how its looked at new: ( ofcause in real at screen , the Black / 0 ire, is not looking green / blue, but very black .
And it has been serviced ( repeatedly ) and I never had to pay for shipping , In fact, Sony Prime Support been quite outstanding in their service all the way.
But it's still annoying that such an excellent and expensive projector, suffer from such a problem (Especially because I love all its other qualities, and in general is hard to beat)
d.j. is offline
post #10542 of 14231 Old 10-06-2014, 10:30 AM
Liked: 1011
What i am saying is that it maybe was dust already in the projector that migrated to the green panel rather than dust being sucked in and getting through the filter.
post #10543 of 14231 Old 10-06-2014, 11:09 AM
d.j.'s Avatar
Quoted: 171 Post(s)
Liked: 74
No, I ( sadly ) dont think so ( but it is a good point anyway ), I am are talking about more then one projector and I have seeing it, in many more of them,
Mark, I would actually guess that there is some in yours too, they're just not very visible - but don´t check, because once you discover them, they get annoying
d.j. is offline
post #10544 of 14231 Old 10-06-2014, 01:12 PM
turls's Avatar
Quoted: 476 Post(s)
Liked: 204
I had severe dust blobs in my 2nd unit.
I don't seem to have the issue with the unit returning to the correct position after motor functions after my unit was sent off to service. I've also played a ton with overscan (because of this issue and geometry issues I've discussed long ago in this thread) and I have the slightest overscan I can get with my masking so I cover the entire visible screen surface with picture. So if it is happening now there is a chance I may not always notice it.
To be clear, I never got 100% accuracy when returning to saved positions, but reliability definitely took a dive after the 1100 upgrade board and it has gotten much better since it was sent off to service. I did mention that being an issue but no repair notes mentioned any fix.
Speaking of stellar Sony service, Sony still hasn't sent me the rubber foot they lost off the rear of my projector. They've been "investigating" the issue for over a month.
Matt
turls is offline
post #10545 of 14231 Old 10-06-2014, 01:59 PM
stevenjw's Avatar
Quoted: 407 Post(s)
Liked: 461
Not as far as I can tell, just the shift/zoom.
...Steve
My HT gear
stevenjw is offline
post #10546 of 14231 Old 10-06-2014, 02:01 PM
stevenjw's Avatar
Quoted: 407 Post(s)
Liked: 461
I guess so, but I'm not the only one that's experience this "feature" after the upgrade.
hermosa likes this.
...Steve
My HT gear
stevenjw is offline
post #10547 of 14231 Old 10-06-2014, 03:53 PM
Liked: 1011
Only a month and you are bitching? Sony just got hammered in its negotiations to buy channel content for its new streaming smart TV content. It had the brilliant salvation plan to beat the existing providers with a serve that included the most popular channels for $30 bucks where the others charge $60 to $65. You see the providers won't provide those channels without a bunch of the low popularity ones which of course Sony must pay for. news reports are that Sony's package could cost $80 per month but Sony attempting to lick its perhaps fatal wounds is saying they will be able to compete with the $65 boys and offer a better deal. It seems Sony just can't with its new management team operating with cheaper and less experience labor and management.
post #10548 of 14231 Old 10-06-2014, 04:41 PM
OzHDHT's Avatar
Quoted: 862 Post(s)
Liked: 466
Originally Posted by d.j. View Post
Mark
Sadly my 1100 had the same scenario. I was keeping an eye out and after having the more severe dust blobs in the 1000 and sure enough after about the same approx hours maybe 400 or just after to be precise I started noticing them. This time around it's much less severe and I'm living with it. Still a nuisance to know it can happen in such a high end unit so easily.
I've also had no issue with any other Sony SXRD units to date of the great many I've owned, it's strictly been with the 1000/1100.
hermosa and d.j. like this.
OzHDHT is online now
post #10549 of 14231 Old 10-07-2014, 09:36 AM
TheSony4KRises's Avatar
Quoted: 233 Post(s)
Liked: 87
I actually have the opposite problem........it shifts/zooms perfectly(most of the time) but usually requires a few extra clicks that I have to apply manually to focus accurately.
BTW---I have a 1000 which has not been upgraded to a 1100.
TheSony4KRises is offline
post #10550 of 14231 Old 10-07-2014, 08:10 PM
xtremehomtheatr's Avatar
Liked: 0
Selling my Lumagen 2041
Selling my Lumagen 2041. I think this was a very worthwhile upgrade for my VPL-1000ES. I think it really made the video quality better for DirecTV and BluRay. The Darbee was a very noticeable improvement too. It also fixed my sound problem with the 4K puck and my Mcintosh MX151. Let me know anyone is interested.
xtremehomtheatr is offline
post #10551 of 14231 Old 10-09-2014, 06:59 AM
audiovideoholic's Avatar
Quoted: 646 Post(s)
Liked: 211
It did on my first unit. Pre upgrade.
audiovideoholic is offline
post #10552 of 14231 Old 10-09-2014, 07:31 AM
RickAVManiac's Avatar
Quoted: 185 Post(s)
Liked: 166
Last night I install my Sony VW1100 (replacing my very very old VW500 )
First reaction, wow the VW500 was a great of a projector
If we only did a quick look, we can think it's the same machine.
But after more testing, with the right source, I can easily see some worth improvement.
The lens do make a difference, my unit is corner to corner focus perfect and uniform. The image seem more naturally sharp. Also the black level is improved by a noticeable margin.
Nothing more to add for today but I will continue my testing and report back.
HoustonHoyaFan and d.j. like this.
RickAVManiac is offline
post #10553 of 14231 Old 10-15-2014, 06:14 PM
RapalloAV's Avatar
Liked: 336
Why would Sony default all the contrast settings on the 1100 at MAX when they default all the rest at 50%
Ive never seen a projector that has the contrast defaulted to 100% MAX....
I don't use these settings from the proj as I have a Lumagen 2041, but just thought this was odd???
Murray Thompson
X Owner RapalloAV
post #10554 of 14231 Old 10-16-2014, 05:27 AM
ShaharT's Avatar
Quoted: 29 Post(s)
Hi,
After many years of inactivity, I'm finally building a new home theater.
I'm considering buying the VW1100ES, and in the process of researching the best screen aspect ratio, size and masking solution to go with this projector.
At the moment, it likely will be constant image height 2.35:1 a/r screen 140" wide on 60" high, with vertical masking for when projecting 16:9 content on the screen in order not to leave white-border on the left & right sides of the image when this aspect ratio is projected on a screen that is wider than the projected image.
I just read something on the projector brochure I couldn't quite understand. I'm quoting -
"The VPL-VW1100ES delivers a widescreen-friendly resolution of 4096 x 2160 based on the DCI specification. This means viewers can enjoy movies without annoying black bars at the top and bottom of the screen."
I understand I can easily switch aspect ratios with the motorized focus, len shift and zoom.
But can anyone please explain what the above quote from the pj brochure means?
While I'm at it - do you have an estimate of how many owners of this projector selected a 2.35 aspect ratio screen vs. a 16:9 screen? And how many opted for a screen with vertical or horizontal masking?
I'm researching at best as I can, and still not 100% sure what's the best decision re: screen-size, masking solution.
Many thanks.
ShaharT is offline
post #10555 of 14231 Old 10-16-2014, 06:40 AM
Mike Garrett's Avatar
Quoted: 6140 Post(s)
Liked: 3942
Originally Posted by ShaharT View Post
Hi,
Many thanks.
They are talking about the lens memory. Rather than you selecting lens shift and zoom to adjust each function to fit the image to your screen each time, you do it once and store it in memory. Then you just select the saved setting when ever you want to switch from one to another.
Aspect ratio selection has more to do with what content you watch and what works best with your room. It also has to do with what you value most. If you are big into sports, then 16:9 makes the most sense. If you are width limited, then 16:9 makes the most sense. If you are height limited, then consider scope. If you are a movie buff and that is your priority, then consider scope. If you want it all, then constant image size, but you will always have black bars or unused screen. The perfect screen to me would be constant image size with 4 way masking, but this costs a boatload. Some people go scope, because they want block buster scope films to be more grand than HDTV.
ShaharT likes this.
mjgarrett100@gmail.com
Mike Garrett is offline
post #10556 of 14231 Old 10-16-2014, 07:31 AM
discodol's Avatar
Quoted: 22 Post(s)
Liked: 34
I have a 2.35 screen with vertical masking bars that drop down for 16.9. Most newer movies seem to be in 2.35 so it is a bummer when something like cable tv is in 16.9 and I have to look at a smaller image.
I am so glad I got the VW1000 that was upgraded to the VW1100, it is a decision I am sure you will be happy with too!
ShaharT likes this.
David Ferebee
discodol is offline
post #10557 of 14231 Old 10-17-2014, 04:21 AM
ShaharT's Avatar
Quoted: 29 Post(s)
Really appreciate your feedback – thank you.
Another question, this time on seating distance from a 4K image.
I read online that seating distance from 4K content (or upscaled to 4K content) can and maybe should be closer than the conventional previous wisdom of up to 3.5 times the screen height.
We initially planned a 130” wide 2.35 a/r screen (141” diagonal), that’s supposed to drop between the side speakers and above the center speaker.
The room is under construction, but I stopped by the construction site today, and using masking tape, drew it on the wall. And… that screen did not seem “big” enough for that room.
By moving the screen to be in front of the speakers instead of the original plan of dropping down between the side speakers and above the center speaker, I can now plan for a larger screen (that will be perforated for sound) that can also have its bottom closer to the floor. [First question – is there a best practice on how low above floor level should a screen end at?]
What would nicely fit in when taking the screen in front of the speakers is now a 162” wide 2.35 a/r screen (176” diagonal).
Visually looking at the masking tape glued to the wall to simulate this larger size – I loved it!
I read the VPL-VW1100ES can easily fill a 176” image without compromising brightness, so that’s not a concern.
Now I need to make sure this new screen size is not too big for where the seating is planned to be……
Using this online calculator http://myhometheater.homestead.com/v...alculator.html (that can only take a 16:9 based image size for its calculation of seating distance – so I’ve entered the constant-height 16:9 image that will projected on this 2.35 screen, which is 123” wide on 69” with a 141” diagonal) I see that THX recommended viewing distance is about 16 feet from a screen of this size – a distance that is about as far back as my room would allow. Which means if I got something wrong – I might end up with a screen too big for where my seating distance is.
So my question is – am I doing the math right? Will a reasonable viewing distance of 16 feet work with a constant image height 2.35 176” diagonal screen / 16:9 141” diagonal? And is the math different for 4K content? And a less important question mentioned earlier above, is if there’s best practice on how low above floor level should the screen end, if there’s no practical limitation (center speaker now behind the screen).
The reason I’m so fixated on this, is that I need to tell my contractor where in the concrete ceiling to leave an opening for the screen case (right next to the wall behind, so the screen drops right in front of the tv and between the speakers, or 2 foot forward in the ceiling, in front of the speakers) as well as the dimensions of this opening.
I really appreciate your kindness and patience with me and my questions.
Best,
Shahar
ShaharT is offline
post #10558 of 14231 Old 10-17-2014, 05:01 AM
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
"I read online that seating distance from 4K content (or upscaled to 4K content) can and maybe should be closer than the conventional previous wisdom of up to 3.5 times the screen height."
I have a 200" scope (185" wide) screen and just took a measurement and I sit 13 feet from the screen. I have a JVC projector which really is not quite bright enough of course. I am using a Panamorph UH480 with a DIY Seymour XD AT curved screen. IMO that distance calculator is no longer relevant, YMMV of course.
I love being that close but of course it is not for everybody so I would definitely test this before I bought/built the screen. Just give it a chance because at first it may seem overwhelming but after a few minutes you might not be able to go smaller. It should be much much better with the Sony1100 than the JVC.
Hope this helps,
Moto
ShaharT likes this.
MX48 is offline
post #10559 of 14231 Old 10-17-2014, 06:28 AM
millerwill's Avatar
Quoted: 466 Post(s)
Liked: 266
Best,
Shahar
I also like to sit fairly close (~11 ft from a 144" W screen), but as said viewing distance is a very personal thing. Also, my screen is taller than a 2.35 one would be of this width because I wanted a larger 16x9 pic than a 2.35 would have allowed (~ 5 ft); mine is 6 ft H, i.e., a 2.0 AR.
ShaharT likes this.
millerwill is offline
post #10560 of 14231 Old 10-17-2014, 06:48 AM
Liked: 3942
Best,
Shahar
I sit one screen width or 2.4 screen heights from my scope screen and like this distance. Nobody has complained of being too close.
ShaharT likes this.
Casio Rs 232 Adapter Catalog Category Projectors Accessories , Sony Vpl Vw1000es Projector
