Sony VPL-vw1000 - Page 363 - AVS | Home Theater Discussions And Reviews
post #10861 of 10877 Old 01-16-2015, 03:29 PM
Ron Jones's Avatar
Quoted: 315 Post(s)
Liked: 337
If I recall correctly the VW1100 (or upgraded VW1000) can accept 10-bit video in either 4:2:0 or 4:2:2 at 24 Hz.
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
post #10862 of 10877 Old 01-16-2015, 03:32 PM
Seegs108's Avatar
Quoted: 848 Post(s)
Liked: 382
It can accept 12bit 4:4:4 video at 24hz. There's more than enough bandwidth for the current motherboard/HDMI implementation to do this and I believe there is some Sony literature posted in this thread saying the SXRD panels are 12bit panels.
Seegs108 is online now
post #10863 of 10877 Old 01-23-2015, 11:41 AM
Sandel's Avatar
RS232 codes
Hi there,
after upgrading the motherboard of my VW1000 to a VW1100, my RS232 codes don't seem to work any longer... Does anybody know where I could get the VW1100 codes for my remote?
Sandel is offline
post #10864 of 10877 Old 01-23-2015, 02:53 PM
Deepsky4565's Avatar
Focus and Ethernet problems since 1100 upgrade
Since upgrading the focus keeps drifting. Every time we start a new theater session, I need tweak the focus, I didn't before. Also the ethernet port seems dead. Nothing on the port at all. My warrantee is up in a few months, but the cost, hassle ans downtime makes me question whether I should ship it in for repair. Anyone else experience these issues?
Deepsky4565 is offline
post #10865 of 10877 Old 01-23-2015, 03:10 PM
turls's Avatar
Quoted: 118 Post(s)
Liked: 58
Are you sure your RS232 port works? My IP and RS232 were dead after the upgrade. Didn't realize it right away (long story) and ended up having to ship the thing off to get it fixed. The codes shouldn't have changed much if at all.
Matt
turls is offline
post #10866 of 10877 Old 01-23-2015, 03:18 PM
thrang's Avatar
Quoted: 149 Post(s)
Liked: 176
Early versions of the 1000 had issues with IP and RS-232 control - but that addressed with the logic board upgrade is my understanding.
I know for IP, you have to setup specific addresses that are permitted to control the device, perhaps four or five maximum. Even if you set the IP address in the GUI, it will not be controllable until you do this.
If you've already done this, ignore me. Otherwise, search this thread for the setup procedure and control port number.
It is a hassle but I would fix it unless you never plan to sell it.
thrang is online now
post #10867 of 10877 Old 01-23-2015, 03:46 PM
hifiaudio2's Avatar
Quoted: 160 Post(s)
Liked: 77
I know I am still in love with the image it throws (even if it has dimmed a bit). If it does indeed accept 12 bit 4:4:4 then it seems I am set for a while still.
If only it were Laser or LED driven with even more lumens I would consider it almost perfect. Until HDR or something it clearly doesn't do convinces me otherwise of course!
hifiaudio2 is offline
post #10868 of 10877 Old 01-23-2015, 04:09 PM
Sandel's Avatar
I only noticed that the Sony isn't responding to my RS232 connected remote any longer. But of course it might be an option as well that the ports are dead. How can I make sure?
Sandel is offline
post #10869 of 10877 Old Yesterday, 07:36 PM
darksets's Avatar
So is the 1000/1100 obsolete? It doesn't support the UHD standard that is emerging. I was considering buying one but it seems I should wait.
Tasos
darksets is offline
post #10870 of 10877 Old Yesterday, 07:58 PM
hifiaudio2's Avatar
Quoted: 160 Post(s)
Liked: 77
Which part of the standard are you referring to?
post #10871 of 10877 Old Today, 10:13 AM
darksets's Avatar
Originally Posted by hifiaudio2 View Post
which part of the standard are you referring to?
hdmi 2.0
darksets is offline
post #10872 of 10877 Old Today, 10:46 AM
hifiaudio2's Avatar
Quoted: 160 Post(s)
Liked: 77
I am not sure what you mean. The upgraded 1000 and base 1100 support hdmi 2.0.
post #10873 of 10877 Old Today, 02:29 PM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 1009 Post(s)
Liked: 620
Correct. I posted that the panels could handle 12 bits, after confirming with Sony.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me: Mike@AVScience.com
Brands we sell: http://avscience.com/brands/
Call for B-stock projectors
Stewart, Seymour, SE, SI, Falcon, DNP & more.
RBH, Martin Logan, Triad, Atlantic Tech., MK Sound, BG Radia, SVS & Def Tech, Denon, Marantz & Yamaha .
AV Science Sales 5 is online now
post #10874 of 10877 Old Today, 02:32 PM
AVS Club Gold
Liked: 620
Tasos
The Sony should support everything that you will be able to get on a 4K BD, at least for a few years. By that, I mean, I am not expecting rec2020 to appear on BD's for a few years.
post #10875 of 10877 Old Today, 02:35 PM
Seegs108's Avatar
Quoted: 848 Post(s)
Liked: 382
Most likely the first round of UHD BD will be 10bit 4:2:0 P3 HEVC UHD video. There are a few 1080p projectors such as the Runco Q750i (though you'd need to get around HDCP 2.2 for this model) and the Epson LS10000 that can do P3 color space properly and accept and display 10bit video but they are still 1080p at heart. The 1100ES is the only consumer projector out there that can display this new format properly.
post #10876 of 10877 Old Today, 05:30 PM
rak306's Avatar
Quoted: 63 Post(s)
Liked: 25
I'm not convinced we will see P3 sources anytime soon. That is, I'm expecting the first UHD sources to be 8 bit, 4:2:0 rec 709.
Of course, I could be wrong.
rak306 is online now
post #10877 of 10877 Old Today, 05:35 PM
Seegs108's Avatar
Quoted: 848 Post(s)
Liked: 382
Don't know about the bit depth part, but I hope it's not 8 bit, but regarding the use of P3 I think if UHD BD has SMPTE 2086 in it's spec there'd be absolutely no reason not to use P3 seeing how they don't have any extra work to do to bring this color gamut to us on UHD BD considering the DCI master is already color graded for P3.
Sony Vpl Vw1000es Projector , Casio Rs 232 Adapter Catalog Category Projectors Accessories
