Sony VPL-vw1000 - Page 379 - AVS Forum | Home Theater Discussions And Reviews
 1316Likes
post #11341 of 14193 Old 04-30-2015, 09:22 PM
thrang's Avatar
Quoted: 1614 Post(s)
Liked: 1387
I never bought that Sony lost a lot of money on the upgrade.
2) the retail value of the FMP was $500 I think? Raw cost might be $100 for that useless piece of plastic?
3) the retail value of the tablet was around $600 I think. Raw cost might be $300-350?
4) the retail value of the lamp is $699 I think. Raw cost is probably $150
Logic board might be a $500 cost to Sony?
Average labor cost to install $350?
So while it was bundled to seem like a lot for your money, it was perhaps 1700-1800 dollars cost, plus another few bucks to cover shipping, management, and other incidental overhead.
What was the retail for the kit? $2500-2700?. Somewhere there I think.not sure how much dealer margin there was.
So they potentially end up 10-20% up from cost. Even factoring in variations in costs basis, and other unknowns, it's hard to see where they lost.
And if Sony were smart, a small cost basis toward a future upgrade should have been built into the initial cost of the 1000, since they knew it needed at least one change after initial design.
So if they devised a $1,000-1,200 logic board only upgrade, plus install, an upgrade to a 1200 is feasible presuming it's mostly 18 gbps hdmi and processor components.
My two cents...
OzHDHT, Seegs108 and doublewing11 like this.
thrang is offline
post #11342 of 14193 Old 05-01-2015, 07:47 AM
Mike Garrett's Avatar
Quoted: 5616 Post(s)
Liked: 3600
Originally Posted by chrisreeves View Post
I can't decide if I should upgrade now or later. Is there any chance that Sony will introduce a newer board upgrade that adds to the capability of the projector - perhaps after the introduction of UHD Blu Ray?
Later most likely will not be an option. Kits are scarce now. Normally I could just order from Tech Data, but they are out. Sony has located a few for me, but not many left. Another board for the 1000? I give that a 0.0001% chance of happening.
mjgarrett100@gmail.com
Mike Garrett is online now
post #11343 of 14193 Old 05-01-2015, 11:53 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
Thrang. Great game last bight regardless of the ultimate winner. Winning score with about 1.5 seconds left. Reminds me of a play in college along time ago with Dryden in the net. Hell of a pass by Ovechkin.
mark haflich is offline
post #11344 of 14193 Old 05-01-2015, 03:23 PM
thrang's Avatar
Liked: 1387
Yes, but a brain fart by the entire team in that last 14 seconds...why did Samuelson put out Boyle on D with Ovechkin out there, matchup they have been avoiding? Why did Vingeault have JT Miller out there, who was the worst forward defensively all game? Why did McDonagh chase Ovechkin behind the net instead of leaving him to Stepan who was back there, and go cover in front? From a shot that close why wasn't Lundqvuist's pad tight to the ice? Nothing was going upstairs...
But yes, it looked great on the 1100!
thrang is offline
post #11345 of 14193 Old 05-01-2015, 03:39 PM
Liked: 1010
Your analysis of the match ups is spot on. Its very hard to know how to cover with fast instantaneous action going on and impossible to communicate with the noise. The pad to the ice tight is hard with an instant reaction with a player in front of your pads and the natural goal tending move is to smoother rather than set up for a shot. most goals are a result of a mistake though.
post #11346 of 14193 Old 05-01-2015, 06:49 PM
Seegs108's Avatar
Quoted: 4227 Post(s)
Liked: 2097
So how would that have worked if Tech Data had some in stock? You buy it and just send it with the 1000ES to Sony for them to do the swap? Or would it have not required Sony to do anything?
Seegs108 is online now
post #11347 of 14193 Old 05-03-2015, 12:01 AM
Michael9009's Avatar
Quoted: 282 Post(s)
Liked: 75
Originally Posted by Seegs108 View Post
You just want to stick with the global whole pixel adjustment, not the zone based sub pixel stuff. It's when you start using that portion of the software you run into image degradation issues especially if you're using half pixel adjustment. The closer to whole pixel adjustments the better in terms of retaining PQ.
Is the convergence really off enough where you're considering returning it? I feel lucky. My unit is near perfect after a short 10 minute warm up. No need to touch the alignment software.
Here's right at startup:
After ~10 minutes:
The unit is practically new with 132 hours of total use:
Why does the Operation Timer show five hours more than the Lamp Timer? My projector shows equal number of hours.
Michael9009 is offline
post #11348 of 14193 Old 05-03-2015, 05:57 AM
Seegs108's Avatar
Liked: 2097
My guess is Sony put this unit through its paces at the factory? Either that or for some other reason this unit was turned on without a bulb installed.
post #11349 of 14193 Old 05-03-2015, 06:41 AM
Liked: 1010
Will the unit even turn on without a bulb? But suppose the bulb at Sony turn on in the factory or a after a few hours in the field started pulsing etc necessitating a replacement. We are all probably going to die without really knowing what happened here re the five hour difference. Back to looking for that $2 million dollar buried chest.
post #11350 of 14193 Old 05-03-2015, 06:57 AM
George Kouzev's Avatar
Quoted: 239 Post(s)
Liked: 66
Perhaps the lamp timer was reset 5 hours into the operation of the unit (no idea what prev. limp timer means)... but I like your theory more
George Kouzev is offline
post #11351 of 14193 Old 05-03-2015, 07:18 AM
Seegs108's Avatar
Liked: 2097
Maybe the lamp counter only works if you're feeding a source to the projector. So maybe the 5 hour discrepancy is just 5 hours on blue screen time as the projector was waiting for a video feed.
Lots of maybes and I suspect we'll never know why. All I can say is that I don't plan on losing any sleep over a 5 hour difference between the counters. If the difference were hundreds or thousands of hours I'd start to worry.
post #11352 of 14193 Old 05-03-2015, 07:38 AM
Liked: 3600
About the same as now. The kit is sent to you, Sony sends special shipping carton and label to you. You send projector and motherboard to Sony. It is possible Sony has removed the motherboards and have all of them already in TX and is no longer in the kit. Not 100% sure on that point.
post #11353 of 14193 Old 05-03-2015, 07:42 AM
Liked: 3600
Probably means the lamp was replaced after 5 hours of use.
post #11354 of 14193 Old 05-03-2015, 07:45 AM
Seegs108's Avatar
Liked: 2097
I don't know. If that were the case, wouldn't the "Prev. Lamp Timer" counter say 5 Hours? Unless it was reset again right after the initial reset? It's only 5 hours. No big deal.
post #11355 of 14193 Old 05-03-2015, 07:50 AM
TheSony4KRises's Avatar
Quoted: 227 Post(s)
Liked: 81
I don't know. If that were the case, wouldn't the "Prev. Lamp Timer" counter say 5 Hours? Unless it was reset twice?
Just changing the subject a tad.
Have you played with the Auto_Iris on Full yet with your newly acquired 1000es
Would be curious what your impressions are with it engaged on some material(say Harry Potter )compared to your JVC.
TheSony4KRises is offline
post #11356 of 14193 Old 05-03-2015, 08:03 AM
Liked: 3600
My guess. Projector was run for 5 hours and had a problem. Lamp timer was reset. Sony installed a test lamp in the projector and found that it solved the problem. Sony then installed a new lamp and reset lamp timer. Test lamp was in the projector less than one hour. That is why previous lamp timer lists 0 hours.
post #11357 of 14193 Old 05-03-2015, 08:04 AM
Seegs108's Avatar
Liked: 2097
Yes, I've played around with both Auto-Full and Auto-Limited. What I'll say is that Sony has oddly implemented the auto-iris. With everything but the darkest of content (ala Harry Potter) the iris works near-flawlessly. But when things get dark I don't think it closes down enough. I think Sony did this to try and stop clipped whites as much as possible. Though, with the right content it sometimes slightly clips whites. But I'd argue Sony could push it just a tad more, maybe 2-3 more stops down on the iris, without clipping being overly obvious. Let's just say I've seen other DLP projectors handle Harry Potter better than the 1000ES. The Sim2 Lumis and Runco LS-10i had more convincing blacks on some of the scenes compared to the 1000ES, where it can sometimes take on a slightly washed out appearance. Though the Lumis and LS-10i did have more clipped whites. It's a trade off I'd personally be willing to take if it meant better low APL content handling and I think the Sony could do it without too much clipping. The "black level" position of the iris is substantially different than the next iris position up when there's even just a few bright pixels on screen and I don't particularly like seeing the iris "pump" that much between black level and the next iris position up. If there was a way in the service menu where you could set the lowest iris position I'd change it in a heart beat to only a few stops lower than where it goes to with low APL content. It's almost as if Sony went "well...they won't know any better so let's just clamp down the **** out of it and they'll be impressed. Plus measured performance will be great too." But we aren't stupid and the difference between black level and the next step up is plainly obvious and I'd love it if there were some way to change it.
That's my only complaint. When things get dark the JVC's iris does a better job, but when things get above the low APL the Sony's iris is basically the best I've ever seen. JVC's iris needs a little work with brighter material. It's great performance for JVC's first try but sometimes you can see it "flickering" because it just can't make up it's mind on a position to set itself at. It can take a second or two to settle. You don't see that on the Sony. You RARELY notice it working with anything but the darkest of content. Recently I had a HW30ES here and I think it's iris is programmed the way I'd like the 1000ES iris programmed. For black level it only closes down a few stops lower than the next iris position up (when there's content on screen) and I loved it. With the 1000ES Sony is trying to make the projector better with contrast than it can it handle without obvious side effects. I'd like to see Sony offer an extra mode like the 30ES's in a future firmware update if they could.
post #11358 of 14193 Old 05-03-2015, 12:05 PM
Liked: 1010
[QUOTE=Seegs108;33952290] But we aren't stupid . . . . /QUOTE]
Please don't speak for me here by charitably characterizing my level of intelligence.
chrisreeves likes this.
post #11359 of 14193 Old 05-03-2015, 12:18 PM
turls's Avatar
Quoted: 466 Post(s)
Liked: 196
Originally Posted by thrang View Post
What's the difference between that and the one that actually mentions the Sony projector in the description? These types of listings are red flags for me on Ebay, besides the fact the cheaper one supposedly has a 30 day longer warranty:
http://www.ebay.com/itm/Philips-LMP-...-/111604972527
Matt
UMR on HDR vs 4K: The benefit of greater saturation and luminance capability is...not very evident in all images unlike more pixels which can be seen in every scene.
turls is offline
post #11360 of 14193 Old 05-03-2015, 12:33 PM
Seegs108's Avatar
Liked: 2097
They both mention the compatible projectors (including the 1000ES/1100ES) in the description. Not sure why they list a 30 day difference with the warranty. I suppose the easiest way to see if they're genuine is to call Philips and give them the serial number with your bulb.
post #11361 of 14193 Old 05-03-2015, 05:20 PM
DaveN's Avatar
Quoted: 71 Post(s)
Any idea how many watts fan pulls on this unit? I had a Liebert UpStation 1500VA Double-Conversion Online Tower/Rackmount 2U UPS Refurbished (GXT2-1500RT-120B) in my last house but the fan is noisy and it was in an adjacent equipment room. Now I need a UPS for power outages but I am trying to estimate the size needed to allow lamp cooling if I turn off the PJ when the power goes out. Do I need a sine wave unit for the fan? Has anyone timed how long the fan runs? Suggestions?
DaveN is offline
post #11362 of 14193 Old 05-03-2015, 08:21 PM
Quoted: 20 Post(s)
Liked: 8
I am looking at 3 ups
1. Cyberpower
http://www.amazon.com/gp/aw/d/B00429...kVL&ref=plSrch
2. Apc
http://www.apc.com/products/resource...LK&tab=options
3. Panamax or furman. They both look the same
http://www.furmansound.com/product.p...d=F1500-UPS_CE
http://www.panamax.com/Products/Batt...kup/MB1500.php
The cheapest is the cyber power, then the furman. Panamax and apc is about the same price.
Anyone recommend one of these?
Sony4k is offline
post #11363 of 14193 Old 05-04-2015, 12:29 AM
Quoted: 227 Post(s)
Liked: 81
@seegs
Thanks for your observations!
post #11364 of 14193 Old 05-04-2015, 06:04 AM
zombie10k's Avatar
Quoted: 2850 Post(s)
Liked: 2845
I checked this with a Killawatt on the 1100, here is some info:
stand by - 10 watts
boot up - 170 watts
low lamp, full warm up - 380 watts
high lamp, full warm up - 462 watts
cool down - 86 watts, this takes exactly 2 minutes to shut down -> back to idle @ 10 watts.
DaveN, turls and mark haflich like this.
zombie10k is offline
post #11365 of 14193 Old 05-04-2015, 06:42 AM
Liked: 1010
That's what I said in post 11,350. Things are really really slow around here. Only going to get slower until IFA in Berlin.
post #11366 of 14193 Old 05-04-2015, 06:47 AM
Liked: 1010
stand by - 10 watts
boot up - 170 watts
This is a truly AMAZING post.
post #11367 of 14193 Old 05-04-2015, 09:14 AM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 264
stand by - 10 watts
boot up - 170 watts
Very useful info--thanks much!
It makes me even more glad that I've recently installed solar PV panels on my roof; will generate ~ 8000 kwh/yr, i.e., ~ 22 kwh/day. So if I run my 1100 10 hrs a day (high lamp), it consumes ~ 5 kwh per day, about 20% of my total power usage!
millerwill is online now
post #11368 of 14193 Old 05-04-2015, 09:20 AM
stevenjw's Avatar
Quoted: 346 Post(s)
Liked: 379
I have a whole house generator that kicks in after 10 seconds. I have my projector and other stuff hooked up to two APC 1500VA UPS units from Costco that work well to cover the difference and protect for quick brown outs and power surges. Pretty inexpensive and the battery can be easily replaced.
...Steve
"Opinions are like orgasms… mine matters most and I really don’t care if you have one."
My HT gear
stevenjw is online now
post #11369 of 14193 Old 05-04-2015, 12:28 PM
Liked: 3600
As far as I know, only five up-grade kits are left available as of today.
post #11370 of 14193 Old 05-04-2015, 01:31 PM
Seegs108's Avatar
Liked: 2097
Just bought my upgrade kit from Mike.
Thanks again!
Casio Rs 232 Adapter Catalog Category Projectors Accessories , Sony Vpl Vw1000es Projector
