Sony VPL-vw1000 - Page 392 - AVS Forum | Home Theater Discussions And Reviews
post #11731 of 11759 Old 08-30-2015, 08:50 AM
AVS Club Gold
Mark_H's Avatar
Quoted: 23 Post(s)
Originally Posted by thrang View Post
I own a Lumagen. They can glitch. And there are numerous settings that, if not correct, and degrade the picture. So from a video issue troubleshooting perspective, in principle it makes sense to remove a video processor as a split half process to isolate.
Well, yes, the user can mess things up, of course, but the Lumagen itself is not going to randomly "degrade"; at least I've never experienced that and have owned all the models...
I suspect user error.
My cinema: The Cave!
My kit: 15' 2.35:1 Screen Research CP2 4-way mask, Sony vw1000es, Lumagen Pro, Meridian 861/621/7x5500/2xSW5500
Mark_H is online now
post #11732 of 11759 Old 08-30-2015, 08:59 AM
Seegs108's Avatar
Quoted: 1810 Post(s)
Liked: 629
I've already concluded that the artifact is in the source...
Seegs108 is offline
post #11733 of 11759 Old 08-30-2015, 10:19 AM
voodoo1694's Avatar
Quoted: 16 Post(s)
Liked: 1
Originally Posted by Andreas21 View Post
You don´t set your brightness based on different films you set it according to a brightness pattern, if you have to set your 1100 down to around 20-25 it is something seriously wrong as it should be set at around 50 in most cases.
And if you use the 2.35 Zoom on the 1100ES you use the whole 4096x2160 pixels of the chip when watching a 16x9 film, but if you use the zoom function on a 2.35:1 screen you don´t use the whole chip as you loose many pixels in the black bars.
Where can I get an accurate brightness test pattern for the vw1100es? Also, I'm using the "Reference" preset and most advanced features are turned off. Anything that could be causing me to have to turn down the brightness that I might be overlooking? One thing I probably should note is that my room has tan walls and carpeting. The projector is also on an ottoman pretty close to the carpet (yes, it's a very lame looking theater right now).
The room will be 'theater-ized' in about 4-5 months from now with proper wall treatments, etc to turn it as dark as possible, reduce reflections and acoustically treat it. Even though it's pitch black in the room with the lights turned off, do you think the lighter color of the walls could be causing such milky blacks at "50" brightness? I wouldn't think it'd be so dramatic. You have me worried as something "seriously wrong" with a non-warrantied projector is not what I like to hear. Surely this must be something I'm overlooking as overall PQ looks beautiful but the blacks are having issues unless brightness is brought down. Please help!
voodoo1694 is offline
post #11734 of 11759 Old 08-30-2015, 09:08 PM
OzHDHT's Avatar
Quoted: 226 Post(s)
Liked: 91
A signal generator like an AccuPel if you want ultimate accuracy . But really just get a calibration disk like DVE HD or Spears & Munsil, which I personally prefer. You can also burn some test patterns to disc, there's been threads about it over the years in the forums here. You can also generate with HTPC and patterns on file, which I quite often use to check my PC's output into the 1100 etc. You need to sort that extremely low brightness setting out, if I put mine down that far you'd see no detail at all in black.
Tan walls are a bit better that white. I doubt though you'd perceive a black level issue with that wall colouring, probably the opposite. The darker you make the room the more you'll be able to perceive any limitations with a projector's black level capabilities, something I'm starting to be able to observe now that I've built a new room and with a mid grey wall and ceiling colour.
OzHDHT is offline
post #11735 of 11759 Old 08-30-2015, 09:15 PM
voodoo1694's Avatar
Quoted: 16 Post(s)
Liked: 1
Originally Posted by OzHDHT View Post
A signal generator like an AccuPel if you want to ultimate accuracy . But really just get a calibration disk like DVE HD or Spears & Munsil, which I personally prefer. You can also burn some test patterns to disc, there's been threads about it over the years in the forums here. You can also generate with HTPC and patterns on file, which I quite often use to check my PC's output into the 1100 etc. You need to sort that extremely low brightness setting out, if I put mine down that far you'd see no detail at all in black.
Thanks Oz - I'm actually using a matte white milliskin spandex screen with grey spandex behind it (courtesy of the DIY section here.... This will be completely temporary until my actual Seymour screen comes in a few months), but even when projected on the bare tan wall I experienced the same issue needing to decrease brightness. Are there any in-menu settings I should look at that could possibly create washed out blacks? I did futz around with settings quite a bit, but nothing really seemed to do anything dramatic. Reference is definitely the setting I like the most. Is there any way it could just be the tan walls bouncing light and washing out the black levels? Again, this is my first projector - I'm starting as a total newb here so I apologize if I'm asking silly questions...
post #11736 of 11759 Old 08-30-2015, 09:25 PM
OzHDHT's Avatar
Quoted: 226 Post(s)
Liked: 91
Thanks Oz - I'm actually using a white spandex screen with grey spandex behind it, but even when projected on the bare tan wall I experienced the same issue needing to decrease brightness. are there any in-menu settings I should look at that could possibly create washed out blacks?
Not sure what a 'spandex' screen is, sounds like some kind of female hosiery. Of course wall or materials you project on to are going to influence your image results. If all your settings are otherwise untouched out of the box, then reference should be yielding a damn sight better picture than you're experiencing currently. I can't think of a way to screw up your black levels that dramatically with settings other than brightness on the projector side. There a few ways to screw it up from the source, like wrong output levels say 0-255 PC vs 16-235 Video. A good question is are you trying other sources, like Cable/Sat/FTA, media players, etc. and experiencing the same issues?
OzHDHT is offline
post #11737 of 11759 Old 08-30-2015, 09:34 PM
voodoo1694's Avatar
Quoted: 16 Post(s)
Liked: 1
I'll try connecting the puck tonight and see what happens... Right now it's hooked up to a SurfacePro3 tablet via DisplayPort-to-HDMI. No strange settings on the SurfacePro3 that I'm aware of.
post #11738 of 11759 Old 08-30-2015, 09:52 PM
thrang's Avatar
Quoted: 642 Post(s)
Liked: 539
Unless I missed it, you haven't said what your source devices are, what receiver or pre-pro your connecting through to the 1100, any video processors, etc...what's the "map" of your set up, and what are video related settings in each device (as noted earlier, this sounds like an HDMI brightness range mismatch)
It's hard to help without some level of detail...
OzHDHT likes this.
thrang is online now
post #11739 of 11759 Old 08-30-2015, 09:57 PM
voodoo1694's Avatar
Quoted: 16 Post(s)
Liked: 1
It's hard to help some level of detail...
Absolutely nothing. I literally have a Surface Pro hooked up directly to the projector and I'm listening to movies on headphones. It's the absolute saddest thing you'll ever see. The projector is sitting on an ottoman right now - it's not even ceiling mounted since I'm waiting for a chief mount to come in
Everything is trickling in slowly over the next few months... All equipment is ordered or pre-ordered as we speak with exception to a few things, since construction is starting months from now. All I have now is the projector, DIY screen and a SurfacePro3 - nothing betwixt them.
post #11740 of 11759 Old 08-30-2015, 10:02 PM
OzHDHT's Avatar
Quoted: 226 Post(s)
Liked: 91
If I was going to straight up target a source issue, I'd say do you happen to know what video levels the Surface is putting out? If it is putting out 16-235 you could have an issue right there. I had an issue with my HTPC after swapping back to an Nvidia GPU a couple of weeks ago and trying to run the output at 10 bits which forced it into limited dynamic range 16-235 @ 4K and washed out my black levels. Fortunately it was very simple to diagnose with Nvidia control panel and switch back to 8 bit get full output range setting back. I would take the Surface out of the equation as a source frankly and try something like a standard blu ray player, or even say normal laptop equipped with Nvidia or ATI graphics. The puck should also be fine to test with of course.
thrang and voodoo1694 like this.
OzHDHT is offline
post #11741 of 11759 Old 08-30-2015, 10:07 PM
voodoo1694's Avatar
Quoted: 16 Post(s)
Liked: 1
Thanks Oz, I'll report back. Just having a minor heart attack here hoping nothing is wrong with this projector..
post #11742 of 11759 Old 08-30-2015, 10:13 PM
OzHDHT's Avatar
Quoted: 226 Post(s)
Liked: 91
No worries. Given your somewhat 'compromised' video source, I would point the finger towards that long before the projector itself.
voodoo1694 likes this.
OzHDHT is offline
post #11743 of 11759 Old 08-31-2015, 12:25 AM
voodoo1694's Avatar
Quoted: 16 Post(s)
Liked: 1
Well, I tried several free demos on the puck and it's really inconclusive... I made sure to put default settings back on 'Reference'. I still feel it's either too bright or washed out in some cases... and now I'm noticing the colors aren't really popping in some demos where I feel they probably should. I saw a Jimmy Kimmel concert as part of the free videos and for the most part, blacks did seem decent (although the fog machine made it a little hard to tell jet black from milky black during parts of the concert). I looked at the TRILUMINOS Display demo and was definitely not impressed. Colors looked somewhat muted and not super pleasing. I figure for a Sony demo, the colors should jump off the screen. "Bright TV" mode helped a little and noticed some reds and greens boosting in saturation a bit (I noticed they punched up the color to "60" for that preset). I really wonder what's happening. I feel like I need someone to take a look at it since I'm not a good judge of what should look normal for a projector. Anyone in Sacramento willing to see if I really have an issue? I really don't have anything to compare this projector to...
Let me also ask the folks with this projector - when the puck is loading a vid and all you see is a black background and white text with the video title, should that black background be totally, 100% deep black? It looks more like a dark grey to me... A lot of mostly-black images projected look dark grey.
post #11744 of 11759 Old 08-31-2015, 04:54 AM
thrang's Avatar
Quoted: 642 Post(s)
Liked: 539
Here's a pretty good article on RGB Limited vs Full:
http://referencehometheater.com/2014...ll-vs-limited/
Here is an image of how spandex should be used:
This is the closest image I could find showing the use of spandex related to home theaters - a showing of The Amazing Spider-Man:
So as Oz said, perhaps the unconventional screen and source is contributing to you seeing 50 (or more) shades of grey...
OzHDHT, d.j. and nucky like this.
post #11745 of 11759 Old 08-31-2015, 02:27 PM
RapalloAV's Avatar
Quoted: 636 Post(s)
Liked: 122
Seegs I want to thank you. Since I copied your RC setting of just 20 without the Noise Filter section ON, I really think my image is heaps better. The artefact I was seeing from time to time seems to be less to almost unnoticeable. I think the noise filter section adds more problems than its worth. So Ive actually gone higher on resolution than I used to be, but OFF on Noise filter.
Remember my settings were:
Resolution = 12
Noise Filter = 12
Murray Thompson
X Owner RapalloAV
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is online now
post #11746 of 11759 Old 08-31-2015, 03:29 PM
Seegs108's Avatar
Liked: 629
My philosophy has always been that a projector shouldn't need extra filters/enhancements to get an image to look good and that the overuse of such enhancements normally does more harm than good. Glad to see that I've brought another person back over from the dark side.
Seegs108 is offline
post #11747 of 11759 Old 08-31-2015, 03:34 PM
RapalloAV's Avatar
Quoted: 636 Post(s)
Liked: 122
Yes thanks again. You only now have to sell all those toys. Sometimes I find it hard selling good stuff in NZ, I have a Denon AVR X-5200 that's almost new that Ive tried to sell for months and months, just stopped advertising it now, as Im not about to give it away for free
Murray Thompson
X Owner RapalloAV
post #11748 of 11759 Old 08-31-2015, 03:35 PM
Andreas21's Avatar
Quoted: 280 Post(s)
Liked: 152
Resolution = 12
Noise Filter = 12
When I had the 1100 I had it set at Resolution 5 and Noise 0.
Regards
Andreas
My Homecinema
Andreas21 is online now
post #11749 of 11759 Old 08-31-2015, 03:41 PM
Seegs108's Avatar
Liked: 629
Were you using a 1080p input or a UHD input? The strength of RC changes depending on what resolution you input to the projector. I use 20 with a UHD input because RC isn't nearly as strong as 20 would be be with a 1080p input. Normally I just 0 or 5 with a 1080p input. Noise reduction at 0 with both resolutions.
Seegs108 is offline
post #11750 of 11759 Old 09-01-2015, 01:12 AM
Andreas21's Avatar
Quoted: 280 Post(s)
Liked: 152
This was with a 1080p input, with native UHD/4K input the RC did not do very much in my eyes, I never upscaled 1080p to UHD/4K as I let the VW1100 do the upscaling and I use a Oppo 105D as a source and know some of you think MadVR does a much better upscaling than the VW1100. But with a UHD/4K source you loose Motionflow and I liked to use it at low in many cases. I owned this projector for over three years and knew it very well.
Regards
Andreas
My Homecinema
post #11751 of 11759 Old 09-01-2015, 06:21 AM
Seegs108's Avatar
Liked: 629
With a 4K input you can still use DFI if you want motion to look better, though at the cost of lumen output. The difference between MadVR and Sony's internal scaling is large enough to my eyes that I'm fine with losing out on frame interpolation, though I would only very very rarely use it, so for me it's no big deal. You can still use the DI, RC and and most of the settings in the expert menu with a 4K input which are all the features I'd want to use anyways. On a personal level there's no loss of functionality for me.
OzHDHT and Dirk44 like this.
Seegs108 is offline
post #11752 of 11759 Old 09-01-2015, 09:24 AM
Andreas21's Avatar
Quoted: 280 Post(s)
Liked: 152
Of course I know this, but DFI for me is a no go as you loose way to much brightness. The weakest point on the VW1100 is the iris in very low APL scenes like when Woldemort attacks Hogwarts in Harry Potter 7 and when the soldiers attack Bin Laden in Zero Dark Thirty and many others. In mid and high APL scenes it is almost undetectable and better than most irises, the funny thing is that the iris on the HW55 does not have the same problems in the scenes I mentioned earlier.
When you compare the MadVR scaling vs the Sony do you use RC on the Sony?
Regards
Andreas
My Homecinema
post #11753 of 11759 Old 09-01-2015, 07:46 PM
OzHDHT's Avatar
Quoted: 226 Post(s)
Liked: 91
I concur, having finally been able to get full time 4K from my HTPC as at a couple of months ago when I bought my new 8802 processor. I definitely prefer the results achieved with MadVR via the HTPC. I'm not a major fan of motion control personally, except when trying to emulate HFR in films and some 3D content.
OzHDHT is offline
post #11754 of 11759 Old Yesterday, 01:55 PM
d.j.'s Avatar
Quoted: 115 Post(s)
Liked: 50
It is a pc versus video level issu, you have - like Thrang and Mark H says.
1: go into the HDMI setting and try both limited and full and see if one of them will not display Black correct at a brigthness setting arround "50 " +/- 3 ( the auto function can sometimes get it wrong.)
or try a BD player
I really dont thing your projector has any problems at all.
dj
d.j. is offline
post #11755 of 11759 Old Yesterday, 02:02 PM
voodoo1694's Avatar
Quoted: 16 Post(s)
Liked: 1
Thanks DJ I will try that. I'm also bringing over my projector to Craig Peer's house (works in sales here on the forum), who was kind enough to let me set up my projector and compare it to his vw600ES in an ideal setting. He's only 30 mins away and a fantastic resource to have locally. Great guy.
post #11756 of 11759 Old Today, 02:26 AM
RapalloAV's Avatar
Quoted: 636 Post(s)
Liked: 122
I just turned on Super White tonight for the first time, gee it makes the image look very dynamic, especially on a large screen!
Does anyone use it?
If so is it clipping whites?
Murray Thompson
X Owner RapalloAV
post #11757 of 11759 Old Today, 02:34 AM
AVS Club Gold
Mark_H's Avatar
Quoted: 23 Post(s)
Test patterns are your friend...
post #11758 of 11759 Unread Today, 03:33 AM
RapalloAV's Avatar
Quoted: 636 Post(s)
Liked: 122
Yes I was going to check those tomorrow but wondered if anyone uses it?
I hear no talk of it here...
What is it really doing to the image???
Murray Thompson
X Owner RapalloAV
post #11759 of 11759 Unread Today, 03:47 AM
thrang's Avatar
Quoted: 642 Post(s)
Liked: 539
There's no talk because there's no option called Super White...
Are you talking about Clear White in the Advanced Menu?
Sony Vpl Vw1000es Projector , Casio Rs 232 Adapter Catalog Category Projectors Accessories
