Sony VPL-vw1000 - Page 470 - AVS Forum | Home Theater Discussions And Reviews
 1262Likes
post #14071 of 14074 Unread Today, 09:51 AM
blee0120's Avatar
Quoted: 332 Post(s)
Liked: 162
Originally Posted by erkq View Post
In the contrast department too. The 1000 is from early 2012, over 4 1/2 years old! Look at what JVC was doing back then and feel better. Projector tech moves too fast. You can't compare projectors with an almost 5 year age gap and feel good about the P/P ratio of the older one.
When has projector technology moved fast? The Sony 1000/1100 can still play UHD BD in SDR709 without an external processor and SDR2020 with an external processor. And this is a 5 year old projector
roxiedog13 likes this.
blee0120 is online now
post #14072 of 14074 Unread Today, 10:40 AM
Andreas21's Avatar
Quoted: 836 Post(s)
Liked: 497
Originally Posted by Mike Garrett View Post
The amount of pincushion depends on your throw. Shorter throw, more pincushion. Longer throw, less pincushion. Easy enough to calculate the amount of pincushion you would have. What is your screen height and what is your throw?
How do you calculate this when different lenses have different pincushion, the Isco 1.25x has less pincushion than the Isco IIIL as an example. But throw distance is a factor like you say.
Regards
Andreas
My Homecinema
Calibration software: Lightspace and Calman. TPG: Murideo Fresco SIX-G
Meters: Klein K-10 A and Jeti 1501. THX II certified.
Andreas21 is online now
post #14073 of 14074 Unread Today, 10:50 AM
Mike Garrett's Avatar
Quoted: 4818 Post(s)
Liked: 2968
Forgot he was talking 1.25. I can calculate for 1.33 lens, but not for the 1.25.
Andreas21 likes this.
Call for CEDIA SPECIALS
mike@avscience.com
Sony, JVC, Epson, Denon, Marantz, Yamaha, Onkyo, Parasound, Triad, Atlantic Tech, M&K, RBH, SVS, Stewart, Seymour, Falcon, DNP, SI, SE, Carada, MicroLite.
Mike Garrett is online now
post #14074 of 14074 Unread Today, 05:25 PM
roxiedog13's Avatar
Quoted: 881 Post(s)
Liked: 337
Originally Posted by BakeApples View Post
Honestly, i can`t afford it but if that`s what it takes, i will get it
How much is "mild" pincushion? Can you see it right away or do you have to really "look for it"?
Do you happen to have a screenshot showing this effect?
You'll have to run about 1 1/2" over on the ends to fill the center of a flat screen . I did it a couple of years and didn't really notice
but I did also have a 3" black velvet border that soaked up the overscan well .
There is a big advantage to getting a curved screen with the A-lens btw. If you run a 1.3-1.6 gain screen that is direct reflective and curved
you will not loose contrast compared to a flat white matt screen. This is especially true if your theater walls and ceiling are lighter, less if the
theater room is a bat cave. My VW600ES was 10,600:1 native and 200,000:1 with DI. the curved screen really helped to retain this contrast level.
Dedicated Theater: JVC X950R/RS600 , Panamorph DC1 Anamorphic Lens, Draper TecVision XT1800X Screen, 2.40:1 132" diagonal curved 36FT radius, Denon X7200WA , 7.2.4 Atmos, Paradigm Monitor 11 fronts, Monitor 3 Center, Monitor V7 Rear, SA-ADP In-wall Surround, Niles DS-7 In-Ceiling, Subwoofers: (4000 watts peak) Klipsch RW-12 + SVS PC13-Ultra
roxiedog13 is online now
Casio Rs 232 Adapter Catalog Category Projectors Accessories , Sony Vpl Vw1000es Projector
