Sony VPL-vw1000 - Page 50 - AVS Forum | Home Theater Discussions And Reviews
 1320Likes
post #1471 of 14222 Old 02-27-2012, 08:25 PM
AV Science Sales 4's Avatar
Originally Posted by OzHDHT View Post
Mark, just trying to gain some screen material insights if you don't mind. With the setup you are using with the Snomatt screen, its dedicated theater room at AVS correct? I'm very tempted by what you are saying re the extra precision of screen material of the Snomatt 100, but concerned in my less than dedicated room with it's dark front and back walls, I would regret not having the small bit of gain the 130 provides at any times other than full lights out viewing? Particularly if I made the step up to 107" wide 1.78.
Speaking window to reality, I'm finding with the best 3D source material, I now get that affect with the 1000 as well and the sense of immersion makes it even more incredible.
The theater is in my house in Maryland. We use it as an AV Science Sales showroom and test facility. Tom Huffman also uses it quite a bit.
Its a black pit except for the fromt chairs which are cream colored which I purchased long ago before I knew better.
The Snomatt is not to be used in a less than black pit room. It has a gain of one and sprays light all over the place. My black everything sucks it up killing all reflections. yYou can see a lot more of the black fabric on the walls with the Snomatt vs the Studeotec 130. My screen is small but I do not miss the gain in 2D. There is a noticeable drop off in brightness because of the reduction in screen gain. This is not surprising given how much more noticeable it is to ones eyes given how low in brightness 3D is to start with. Remember to perceive a doubling in brightness to ones eyes the brightness must increase by a factor of four. Start with a low number to begin with and a 30% increase in brightness shows up as considerable brightness. start with a much higher number as in 2D and a 30% increase is nowhere near as noticeable. I think with this projector a large screen requires a higher gain screen though I would not go much higher than 1.4 except if the throw were enogh to exceed the optical srface gain. This means with a high gain gray screen such as a Firehawk (1.25 gain) with a substrate gain of about 0.8 but a sprayed on coating of about 1.6 (.8 x 1.6=1.286) a throw of 1.6 would be needed to avoid hotspotting.
Although I know my views on HP 2.4 are not widely agreed to by owners of this screen, I would coinclude that the HP2.4 is much better thn the 2.4 because of a much greater half angle, I think one just gives up too much for the benefits of the gain. Its really easy to prefer the brightest image and the HPwill give one that, but so much else is given up. 4K requires a very good smooth textureless viewing surface. I would much rather have a dimmer screen to get what I am getting with the 1000ES.
I have sold many Studeotec 130 screens over my life and few ever complain about it. But I have seen the err darkness. The Snomatt just removes a layer of guaze from the picture. We are talking liquidity here. No grain just a smooth clear liquid. I am sure some of the 4K new materials out there would allow the machine to shine but even with my small size screen (54 x 96) I could not go down to a gain of 0.8, it would just be too dim. With this machine and its calibrated lumens in the 1600 lumens range, with a large screen one must go to a higher gain and not get some of the benefits that would be there with this machine with a screen gain of one or so. Everything we do in HT is a tradeoff, there is no perfect choice when one has a very large screen.
That said for 3D in my HT, I would choose the 2.4 HP, brightness is just too important for 3D. I will probably be getting a floor standing HP 2.4 for 3D.
Its all a personal and there is nothing wrong with liking bright over all else. To me I will take 2D less bright and not miss any bit of magic this projector is capable of and it is magic.
I am just trying to express my views here. Not start a flame war with those who think the HP 2.8 was the best screen ever and the second best the HP 2.4. I really didn't know how much more the 1000ES had to give until I switched to Snomatt.
AV Science Sales 4 is offline
post #1472 of 14222 Old 02-27-2012, 09:11 PM
thrang's Avatar
Quoted: 1675 Post(s)
Liked: 1416
Originally Posted by RevelMN View Post
that's interesting, do you know what the S/N range is?
No, I was just told mine was in that range.
What's further odd is the condition changed tonight - now I see the reddish band at the bottom, and the band that was about a third of the way from the bottom is more than a little above the halfway point, and appears almost like a subtle rainbow:
Today:
Yesterday:
Beyond bizarre...
thrang is online now
post #1473 of 14222 Old 02-27-2012, 09:37 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 265
This would be very neat, Mark, if you got a HP2.4 for 3d, and we could really get a good comparison of how it compares to the SnoMatt (viewing angle notwithstanding). I do find the HP2.4 to give an extremely smooth (maybe fluid, to use your description), but then I haven't seen a SnoMatt for comparison.
millerwill is online now
post #1474 of 14222 Old 02-27-2012, 10:04 PM
Thrang. What happens if you shut RC off. I can cause banding by what I assume would be improper combinations of resolution and noise filtering. Put up a pixel on off pattern with your lumagen and see how playing with various RC combinations can cause some banding.
post #1475 of 14222 Old 02-28-2012, 01:06 AM
OzHDHT's Avatar
Quoted: 834 Post(s)
Liked: 444
Thanks for explaining your viewing conds Mark. That's is a big help. I know then I will stick with the Studiotek 130 material if I do go larger now. I'm def very happy with 3D performance, even though as you say you can easily crank up to a 2.4 gain for a dedicated use 3D use. If I get to build another dedicated theater moving forward, I will def equip it with Snomatt and a HP 2.4 combo!
OzHDHT is offline
post #1476 of 14222 Old 02-28-2012, 05:00 AM
thrang's Avatar
Liked: 1416
Thrang. What happens if you shut RC off. I can cause banding by what I assume would be improper combinations of resolution and noise filtering. Put up a pixel on off pattern with your lumagen and see how plaing with various RC combinations can cause the banding.
I'll check again mark, but Sony described it as a known HW issue.
That would be some major defect of RC processing to cause that type of banding - though I will say I did play with the RC settings between Sunday and Monday, and the banding is different as posted...
post #1477 of 14222 Old 02-28-2012, 06:40 AM
hifiaudio2's Avatar
Quoted: 391 Post(s)
Liked: 110
Now that quite a few people on this thread actually have the 1000, can a few of you do me a favor and just turn your unit over from table mounted position to upside down, and then back. BOTH of my units have something inside that physically shifts when its turned over, right as it reaches the full 180 degrees. Its fairly quiet, but its a distinct movement. Someone already said theirs does not do this, but I dont want to pursue with Sony if others can replicate. Since it is on both of mine, I am hesitant to think its not a common design thing, but then again, I have serial numbers that are only 4 apart. Could be something they didnt catch until a bit later.
hifiaudio2 is offline
post #1478 of 14222 Old 02-28-2012, 08:49 AM
thrang's Avatar
Liked: 1416
So no amount of adjusting or turning off settings changes the banding issue (even RC off, Panel Adjustment off, etc).
But what is odd is the banding is in different places again today:
Could this be a heat related issue?
The rainbow look almost makes me think optics, but that wouldn't explain the band being in different places.
The above picture was taken after the projector was on for 30 minutes or so..I'll leave it on for a some time and see if there's a change. But looking at all three of my screen shots will lead to some head scratching...
post #1479 of 14222 Old 02-28-2012, 09:07 AM
You need to call the ES integrator hot line and the good folks there I would think will promptly ship you an advance replacement. Your dealer should have the number and really doesn't have to get involved. Sony will pick up all expenses so you really have no worries.
post #1480 of 14222 Old 02-28-2012, 09:09 AM
thrang's Avatar
Liked: 1416
Yes, one is in transit from Texas today I believe.
I'd like to know what the issue is, and know that it is really solved. I'm not the only one that has reported some banding, though maybe others have had their units swapped rapidly enough that they haven't had the "moving" experience I'm witnessing.
Minus this, what a projector!
post #1481 of 14222 Old 02-28-2012, 09:11 AM
mookie b's Avatar
Quoted: 17 Post(s)
Liked: 26
Thrang, did the banding show up right away or after some use?
mookie b is offline
post #1482 of 14222 Old 02-28-2012, 09:15 AM
thrang's Avatar
Liked: 1416
I noticed it while watching some golf in the first five hours or so, then started looking at some test patterns
Subsequently, I'm noticing the changing position over the past
Few days - projector itself hasn't moved
post #1483 of 14222 Old 02-28-2012, 09:20 AM
thrang's Avatar
Liked: 1416
To check if it was a light path issue through the lense elements (the rainbow effect gives that feel), I shifted the image down a few feet and lifted the front of the projector up to change the angle through the lens - no difference.
post #1484 of 14222 Old 02-28-2012, 11:04 AM
The golf ratings for the match play golf event were miserable. The rained out NASCAR event way out drew the golf. Golf needs Phil or Tiger to be playing well.
post #1485 of 14222 Old 02-28-2012, 05:24 PM
G-Rex's Avatar
Quoted: 488 Post(s)
Liked: 313
Originally Posted by thrang View Post
What screen ratio is that? 144 scope width would be 61 high, 144 16:9 wide would be 81 high, unless my calculations are wrong...
Yeah I'm leaning to the 2.4 HP given how pleased I am with the 2.8 - I will have a sno matt and some si samples, so i'll see if the belief of better clarity with someting like the sno matt matters when compared to the high power material...
Thrang please post your observations re the HP 2.4 vs the Snowmatt/ST100. Few have compared both, especially with a 4k projector. Should be interesting. Thanks.
G-Rex is offline
post #1486 of 14222 Old 02-28-2012, 05:26 PM
thrang's Avatar
Liked: 1416
Well, SI was really pleasant and is sending samples, as are DaLite for the 2.4 HP.
So far, one voicemail and two emails to Stewart have gone unanswered, so I'm getting the opinion they are not that interested in the business...
post #1487 of 14222 Old 02-28-2012, 05:28 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 265
With all the talk about banding, I put up the AVS full screen gray scale to check it out over the whole IRE range, and really don't see anything of significance.
While I had up the 100 IRE screen I also took a fc reading to check the lumen output, now at 102 hrs on the lamp. I get 1100 lumens. This is in low lamp, Reference preset, RC 'on' at 20/20, DI on 'limited', MF 'off', Contrast max, Br at 51, color temp D65, Sharpness 10, Smooth Grad 'low', Black level adj 'off', gamma 2.2, BT709, everything else 'off', Aspect = 2.35 Zoom (so that I get a 17x9 HDTV pic). Great pic.
post #1488 of 14222 Old 02-28-2012, 05:31 PM
thrang's Avatar
Liked: 1416
And after being on for several hours today, the banding was in different positions on my unit...so hoping the new one is clear of this issue. I sent another email to Sony showing the variations and asking for some answer as to the cause, but so far no response.
Still a fantastic projector, once this issue is resolved...
post #1489 of 14222 Old 02-28-2012, 05:35 PM
G-Rex's Avatar
Quoted: 488 Post(s)
Liked: 313
I had the same poblem. Stewart does not send samples out directly to consumers as they did in the past (unless you are very persistent as I was). It is much easier to have a dealer request the samples and Stewart will drop ship them to you. While requesting the ST100, you might want to request a ST130 sample for comparison.
G-Rex is offline
post #1490 of 14222 Old 02-28-2012, 05:37 PM
thrang's Avatar
Liked: 1416
Nothing like going the extra mile in a tough economy...
post #1491 of 14222 Old 02-28-2012, 05:42 PM
mookie b's Avatar
Quoted: 17 Post(s)
Liked: 26
I e-mailed Stewart yesterday about screen samples and got a response email this morning. Strange they didn't write you back...
mookie b is offline
post #1492 of 14222 Old 02-28-2012, 06:05 PM
thrang's Avatar
Liked: 1416
The "request@" email on their site? Thats what I did, and again tonight... we'll see...
post #1493 of 14222 Old 02-28-2012, 06:27 PM
mookie b's Avatar
Quoted: 17 Post(s)
Liked: 26
Yes, that one, and they emailed me back at 7:30 am today asking for my address. I bet they'll write you back tomorrow.
mookie b is offline
post #1494 of 14222 Old 02-28-2012, 07:21 PM
Stewart will not send out samples. They supply their dealers with samples and any Stewart dealer should be able to send you a sample immediately. We have plenty. I am traveling tomorrow, but if you call the AV Science Sales toll free number, Cindy will be happy to send you or anyone else here a sample.
I do find it next to impossible to determine how a screen will perform based on just puting up a small sample. Certain things however can be observed but the thing that grabs one most (unfairly) is which one is brightest. Be sure to put up on of pixel patterns and determine sharpness. Look for grain. Black levels etc. Hotspotting can't be observed on many high gain screens this way.
post #1495 of 14222 Old 02-28-2012, 07:57 PM
coderguy's Avatar
Quoted: 390 Post(s)
Liked: 307
Originally Posted by joerod View Post
Another viewing day coming tomorrow. Can't wait.
Sounds like people were pretty impressed with your viewing over there. Sounds like a pretty awesome projector too.
Access HERE from this thread
coderguy is online now
post #1496 of 14222 Old 02-28-2012, 08:20 PM
adidino's Avatar
Quoted: 345 Post(s)
Liked: 273
Thought you might find this an interesting read. Found this on the Screen section. Some image comparisons taken between a Runco DX44d and Sony VW1000.
Here's an interesting article created by one of our dealers in the UK. He installed a 170" wide Center Stage XD screen, and fired two projectors to record their differences.
http://www.geckohomecinema.com/1080p-vs-4k.html
The 1080p shown in the screen shots is a 3 chip 1080p DLP Runco VX44d (£80,000), and the 4K projector is of course the new Sony VPL VW1000ES (£16,800). They were fed identical material from the same player, both onto the XD screen. First, it's amazing the difference in detail from changing only the projector. Keep in mind that while the Sony's 4K may seem like ridiculous overkill for now, this incredible performance improvement is available at a fraction of the cost of the 3-chip Runco. Of course, the Runco is crazy-price, but it always makes my heart flutter when something much less expensive performs so much better.
Also, please note that the performance of this nearly-six figure, otherwise state of the art projector is not being limited by the Center Stage XD screen. In fact, the screen has so much more to resolve. Also, while the argument is solid that if you buy a quality, reference projection screen it will last through several projectors and be the best investment in the room, keep in mind how inexpensive the XD screen is relative to the other equipment.
adidino is offline
post #1497 of 14222 Old 02-28-2012, 08:27 PM
Ben Withrow's Avatar
Quoted: 57 Post(s)
Liked: 45
Millerwill, what is your throw ratio?
Ben
Ben Withrow is offline
post #1498 of 14222 Old 02-28-2012, 08:31 PM
coderguy's Avatar
Quoted: 390 Post(s)
Liked: 307
Interesting read, although I'm not too sure about them trying to demonstrate 4k on my 1080p monitor :P...
I trust what you guys say though, plus I've seen one at the cinema and did notice some benefits of 4k.
That one demo reminded me of the old Magnavox commerical where they show the parrot in a tropical paradise, and you think, dang that looks good, I need a new TV, but then you realized you were watching it on your own TV, and yes those commericals are from 10 to 20 years ago I believe.
post #1499 of 14222 Old 02-28-2012, 09:48 PM
mookie b's Avatar
Quoted: 17 Post(s)
Liked: 26
Had our first 3d movie tonight...Hugo. Personally, I don't really get why it received such great reviews, BUT the 3d was phenomenal. Really excites me about future 3d now that I have this projector.
mookie b is offline
post #1500 of 14222 Old 02-29-2012, 04:49 AM
joerod's Avatar
Quoted: 656 Post(s)
Liked: 534
100% agree. First rate 3D, slooooow story. I almost fell asleep about 5 times. Damn you HIDef Digest (again) for the BS review. They have been on a roll lately. Trusting their reviews is like pulling an praying!!
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
Martin Logan Stage X & Theos FS:
http://www.avsforum.com/forum/209-au...l#post51592513
joerod is online now
Casio Rs 232 Adapter Catalog Category Projectors Accessories , Sony Vpl Vw1000es Projector
