OWNERS Thread for the Panasonic PT-AE7000U 3D Projector - Page 150 - AVS Forum
post #4471 of 4486 Old 12-04-2014, 07:49 AM
kyoo's Avatar
Question blue vertical line
I have started seeing a blue vertical line all the way from top to bottom.. just a single one just to the right of mid-screen, I'd say.. It comes and goes.. so far it is pretty infrequent. It happens on any input from my pre-amp, so it's either introduced by the pre-amp, the hdmi booster, the hdmi cable, or the PJ.. Any ideas, folks?
I'm still on my original lamp, as well.. not sure if a blue line would be a sign of a failing lamp.. I imagine not..
kyoo is offline
post #4472 of 4486 Old 12-04-2014, 10:37 AM
ckenisell's Avatar
Quoted: 28 Post(s)
Liked: 24
How does one know that it's time to change the lamp? Do these bulbs get dimmer over time, start to flicker, or simply die out?
If the 3D is so dim that it's hard to watch, is it time to change the bulb? I need to check the hours on this unit. Is there an estimated window on number of hours to replace the bulb?
Chet
ckenisell is offline
post #4473 of 4486 Old 12-09-2014, 10:41 PM
BTron's Avatar
My AE7000 started flickering at the 800 hour mark. Tried leaving it in Eco for a few days and switching back, better for a bit, now still flickering. Bought it Jan 2014 so still under warranty, anyone have experience getting this resolved? Do I just call Pano or drive it my local service center?
BTron is offline
post #4474 of 4486 Old 12-22-2014, 08:56 AM
effdbee's Avatar
I think I would just take it to the warranty service center. There is nothing they can do over the phone.
effdbee is offline
post #4475 of 4486 Old 12-30-2014, 06:40 PM
Spirit84's Avatar
I am hoping that one of the experts has an answer for this relatively small issue:
On the Panasonic AE-7000:
Sometimes - I would say around every 2-3 hours - the pciture on the screen vanishes for about 3 seconds and then returns. The sound is unaffected.
Has anyone ever experienced this issue?
Spirit84 is offline
post #4476 of 4486 Old 12-30-2014, 08:19 PM
David Susilo's Avatar
Quoted: 335 Post(s)
Liked: 429
I'm getting sick and tired of my 7000. Crosstalk in 3D is getting worse, bulb at 800 hours start to flicker and never goes away (I'm on my 4th bulb, 800 hours, flickering again).
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED, QAV, AUVI & DownUnder Audio Magazine
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #4477 of 4486 Old 12-30-2014, 10:14 PM
deano86's Avatar
Quoted: 40 Post(s)
Liked: 56
Does it happen with all sources? I have had similar issues happen due to a poor connection somewhere in your HDMI signal path.. try reseating and/or swapping your cables and see if that changes anything.
deano86 is offline
post #4478 of 4486 Old 12-30-2014, 10:55 PM
Spirit84's Avatar
Thanks for the reply. Is it possible that it might be the projector or does your intuition tell you that it is HDMI based?
Spirit84 is offline
post #4479 of 4486 Old 01-01-2015, 07:22 AM
Eric Liebman's Avatar
Same vertical lines
I also see these lines on occasion.. but generally have a blank WHITE screen whenever I start up... I then have to shut down and restart and then it works fine. Weird thing is that it did this since I bought it but moved from Asia back to the States and didn't get the chance to repair. Sat in storage for a year and then didn't do that any longer. Now after using it around 10 times, it's starting to do that again.
Must be some glitch in the projector...?
Eric Liebman is offline
post #4480 of 4486 Old 01-01-2015, 02:39 PM
deano86's Avatar
Quoted: 40 Post(s)
Liked: 56
Well, anything is possible... but your symptom more likely seems to indicate a drop in the video signal somewhere along the way to your projector and thus the resulting blue screen ( is this what it does, or does it just go black?) while it syncs back up....
deano86 is offline
post #4481 of 4486 Old 01-01-2015, 04:12 PM
Spirit84's Avatar
Screen turns gray/black NOT blue. Clue?
Spirit84 is offline
post #4482 of 4486 Old 01-01-2015, 05:30 PM
deano86's Avatar
Quoted: 40 Post(s)
Liked: 56
Not necessarily...could be dependant on what component is directly hooked to your projector...For example: when I switch channels on my Directv receiver, and i tune to a channel that is using a different resolution, there is a black screen pause of a couple seconds. When switching on my bluray player, I have a blue screen for a few seconds....I would also maybe try using the other HDMI input on your projector just to compare...
deano86 is offline
post #4483 of 4486 Old 01-01-2015, 05:35 PM
LowellG's Avatar
Quoted: 227 Post(s)
Liked: 129
I red light comes on the projector and doesn't go off at the 3800 hour mark. You also get a warning when you turn it on. I had 4006 hours on my bulb when I replaced it. I never watch 3D. Anybody want to buy some glasses cheap?
Lowell
The MARVELous Home Theater: http://www.avsforum.com/forum/19-ded...e-theater.html
LowellG is online now
post #4484 of 4486 Old 01-05-2015, 03:17 PM
Spirit84's Avatar
Thanks Deano for the reply. I think I should be a lttle clearer about my issue. The dropout of the picture actually occurs while I am watching a movie. So, for example, say I am watching Netflix; the screen goes gray for about 3 seconds and then returns to normal. Sound is unaffected.
your thoughts?
Spirit84 is offline
post #4485 of 4486 Old 01-06-2015, 09:18 AM
deano86's Avatar
Quoted: 40 Post(s)
Liked: 56
Same thing....switch inputs , cables , etc just to see if there is any change... Only does it with Blu ray player?... Or cable/satellite too?... If it doesn't do it for all sources, sure seems like connection/cable issue...
deano86 is offline
post #4486 of 4486 Unread Today, 09:09 PM
razza's Avatar
Is anyone able to provide feedback on the reliability of the ae7000 when compared to the ae4000? Both similar or is one more reliable than the other?
razza is online now
Panasonic , Panasonic Pt Ae7000u 1080p Full Hd Projector , Projectors , Blu Ray Players
Gear in this thread - Ae7000u by PriceGrabber.com
