JVC DLA-HD1 / RS1 Replacement Lamps? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By GlenC
  • 1 Post By usualsuspects
post #1 of 20 Old 10-01-2011, 11:13 AM - Thread Starter
penguin killer's Avatar
Hi,
I own an DLA HD1 and my lamp is now at 3700 hours. I'd like to replace it, but I'm searching all over the place and finding JVC lamps, OEM lampts etc. Do the owners in this thread have any recommendations for lamps? If I'm looking at results on the web, how can I be sure that they are the actual JVC lamps and not OEM ones?
thanks,
Sean
penguin killer is offline
post #2 of 20 Old 10-02-2011, 06:08 AM
kkpro's Avatar
Quoted: 136 Post(s)
Liked: 73
I was always told to use the original lamp. I have had 2 replacements. I use the BHL-5009 and found AVS to be the least expensive. I have also heard that you can get the bare bulb and replace it in the existing housing which would be a cheaper solution. I have not tried any of the aftermarket.
kkpro is offline
post #3 of 20 Old 10-02-2011, 06:55 AM
Mike Garrett's Avatar
Quoted: 6697 Post(s)
Liked: 4381
Send me an email and I can help you.
mjgarrett100@gmail.com
Mike Garrett is offline
post #4 of 20 Old 10-02-2011, 02:15 PM - Thread Starter
Thanks Mike. I sent you a mail from my work account.
post #5 of 20 Old 10-26-2011, 09:10 PM
GlenC's Avatar
I finally got a OSRAM replacement bulb to install in the JVC housing. Initial result is approximately 25% more light from a new JVC bulb. I will be watching its performance and hope to have time to analyze the spectrum and resulting colorspace.
salehdidit likes this.
Glen Carter<br />
Home Theater Calibration<br />
GlenC is offline
post #6 of 20 Old 01-12-2012, 05:03 PM
tekkumala's Avatar
Where did you get the replacement bulb?
tekkumala is offline
post #7 of 20 Old 01-12-2012, 09:44 PM
GlenC's Avatar
I get the bulbs from my distributor
Glen Carter<br />
GlenC is offline
post #8 of 20 Old 03-27-2012, 10:27 AM
jxo
jxo's Avatar
Glenn: how has your experience been with the Osram replacement? Have an RS1 coming due for a new bulb. Is the osram easily installed in the JVC housing?
How to best get the Osram bulb?
Jim
jxo is offline
post #9 of 20 Old 03-28-2012, 09:54 AM
GlenC's Avatar
I haven't had the projector on for a couple months ... been busy and also breaking in a RS65 for calibration. The bulb has performed great and I think it has been much better than the OEM. Haven't had time to calibrate it. The installation requires cutting leads from original bulb, installing wire terminals, getting screws to attach leads.
Glen Carter<br />
GlenC is offline
post #10 of 20 Old 03-28-2012, 11:01 AM
D_B_0673's Avatar
Quoted: 57 Post(s)
sounds complicated, any pictures???
Dan
D_B_0673 is offline
post #11 of 20 Old 10-22-2015, 01:37 PM
abontrager's Avatar
Hi Everyone,
I'm also now looking to replace the bulb in my RS-1. Any suggestions on best place to purchase? Would like to buy the bulb and housing as a complete set so I don't mess anything up. Just about to hit 2,000 hours and would like to get this taken care of.
I see the Osman (sp?) bulb is getting good reviews, but is there an actual JVC replacement that isn't nearly $200?
abontrager is offline
post #12 of 20 Old 10-22-2015, 01:57 PM
Quoted: 1188 Post(s)
Liked: 671
The retail on it is $400 and believe it or not there is not a huge mark up on these. I doubt you will find one for near $200, you would have to look at an after market one. If you want the JVC one I would call AVS, they would be competitive.
Ellebob is offline
post #13 of 20 Old 10-23-2015, 10:39 AM
abontrager's Avatar
Thanks Ellebob
What good aftermarket replacement bulbs are recommended?
post #14 of 20 Old 10-23-2015, 10:39 AM
abontrager's Avatar
Thanks Ellebob
post #15 of 20 Old 10-24-2015, 06:15 AM
usualsuspects's Avatar
Quoted: 18 Post(s)
Liked: 30
purelandsupply.com is where I get my replacement bulbs from. I did a lot of research on replacement bulbs - what ones were good, what ones were junk and why. Short version is: OEM bulb in 3rd party cage = MUCH lower cost and same performance as OEM.
My research is here: Adventures in VW40/50/60 bulbs
I have recommended PLS to friends and use them for my own projectors (three different projectors now), never had any problems. I used to DIY my own OEM bulbs + recycled or 3rd party cages but I don't bother to do it anymore, easier just to get a lamp from PLS. Save yourself a lot of money and go with them. There are two different links below, but the bulb part number is the same.
http://www.purelandsupply.com/jvc-lc...s_dla-rs1.html
http://www.purelandsupply.com/jvc-lc...s_dla-hd1.html
rrg likes this.
usualsuspects is offline
post #16 of 20 Old 10-24-2015, 07:16 AM
Liked: 671
We have used the Diamond lamps and have had no problems with them.
Ellebob is offline
post #17 of 20 Old 10-25-2015, 11:48 AM
abontrager's Avatar
Thanks UsualSuspects. Just ordered my RS-1 bulb from PLS.
post #18 of 20 Old 11-13-2015, 08:54 AM
photosurrealism's Avatar
Unhappy
Anyone got bum lamps lately? I thought my previous lamp wasn't up to snuff, but thought maybe it was just me. It eventually burned out (a first for me- I have a shelf full of well-used but working lamps) and I ordered a replacement from JVC.
New lamp appears dim and has gotten dimmer according to measurements from the whitegoods light meter app on my phone. I know those measurements aren't likely to be numerically significant, but they seem to be consistent day-to-day. I took the measurement with the front camera and the phone pressed up against the center of my screen (face up, of course) late at night when there's nearly no ambient light from downstairs.
I'm going to take the same measurement from an old lamp tonight to clinch it, but I think it's a lemon. Are things getting worse or am I just unlucky?
photosurrealism is offline
post #19 of 20 Old 11-14-2015, 09:02 PM
EricE's Avatar
Quoted: 73 Post(s)
I just got a replacement bulb the other day and when I put it in the projector it looked dimmer than my OEM bulb that was still going strong at 2200 hours. I compaired it to my other replacement bulb and the OEM and I saw that the new bulb was not sitting straight in the housing.
I took it appart and aligned everything correctly. Tried it again and wow it was nice and bright. Hopefully it will last at least 600 hours till 4k projectors come down in price...
EricE is offline
post #20 of 20 Old 01-31-2016, 05:59 AM
oventurini's Avatar
I did that too but mine blew up after less than 6 months. very disappointing. what about yours?
oventurini is offline
