Official Sony VPL-VW95ES Owners Thread - Page 120 - AVS Forum
 1Likes
post #3571 of 3582 Old 05-26-2014, 03:11 PM
AVfile's Avatar
Quoted: 14 Post(s)
Liked: 54
How do I know if I need a new lamp?
I measured 14 ftL in Cinema1 LOW lamp on a 96" ST130 which seemed plenty bright to me. On high lamp is was over 22 ftL. This was at max throw (1.0 zoom).
- AVStefan
If you like someone's post, just use the Like button to give thanks.
AVfile is offline
post #3572 of 3582 Old 05-27-2014, 01:10 AM
Elix's Avatar
Quoted: 20 Post(s)
Either when the picture is getting too dim for your taste or when lamp hours are approaching lamp life specification - for security reasons. 14 ftL is plenty bright for me.
Elix is offline
post #3573 of 3582 Old 05-27-2014, 12:41 PM
Craig Peer's Avatar
Location: In my home theater ( when I'm not rock climbing, cycling or kayaking ) - Sacramento CA area
Quoted: 121 Post(s)
Liked: 227
That seems plenty bright to me too. When you drop below 12 foot lamberts in high lamp, or the picture is dimmer in even high lamp than you like, or the projector tells you to change the lamp, then it's time to put a new one in.
Craig Peer, AV Science Sales. Direct Line - 585-671-2972
I'm available 8:30am - 4:30pm PST, Monday - Friday Email me at craig@avscience.com
http://shop.avscience.com/
Yes, we sell Home Theater gear right here at AVS !!
JVC, Sony, Epson, DPI, SV Sound, Martin Logan, RBH, Klipsch, and many more!
Craig Peer is offline
post #3574 of 3582 Old 06-08-2014, 07:44 PM
AVfile's Avatar
Quoted: 14 Post(s)
Liked: 54
^^ thanks guys. That's what I thought too but the unit is saying please replace the bulb and there are 2000 hrs on the clock. Dealer included a new bulb so I'm going to change it now. Wish me luck... I hope it doesn't get too much brighter!
EDIT: yikes! With the fresh lamp I am now getting 17 ftL in low and 29 ftL in high, and this is with white level calibrated!
I was getting a flicker in low lamp which is now gone. The old lamp also had a strange blue shift that was difficult to calibrate out without causing a red background, now it calibrates real nice biggrin.gif
- AVStefan
AVfile is offline
post #3575 of 3582 Old 06-10-2014, 11:41 PM
bathes2051's Avatar
FYI I've been using mine in High lamp, and it starting flickering occasionally around 1900 hours, then it went away.
The projector then started showing the warning after 2000 hours, although the lamp was still fine, unless I switched to Low mode, and it would then flicker again.
Then after 2100 the lamp started flickering in High mode, and that's when I changed it.
AVfile likes this.
bathes2051 is online now
post #3576 of 3582 Old 06-18-2014, 11:35 AM
Craig Peer's Avatar
Quoted: 121 Post(s)
Liked: 227
We have one VW95 B stock projector left if anyone is looking for a great deal !
post #3577 of 3582 Old 06-26-2014, 06:24 PM
Liked: 0
Hi, I am in a kind of dilemma. I just purchased a BenQ W1300 (1150$) but found after my purchase that someone was selling a VW95 at a reasonable price (2500$) which is just inside my budget. So I am still able to return the BenQ, but the thing is that I have already purchased screen material for a DIY fixed screen (grey material, so low gain) because of the BenQs average black levels.
Since the VW95 have a low lumen output and much better black levels, I guess I would need to purchase a new screen material again? I am afraid that the low lumen will be a problem.
Should I keep the BenQ W1300 or buy the used VW95 (400 hours)?
I am upgrading from an Optoma HD70 (1280x720, 2006 model) so I guess both will be a super big upgrade for me.
My screen will be 90-90".
Room measurements (H:2m,L:5m,W:2,6m)
**red area will be covered by black fabric, so will have good light control, but not perfect. Window is totally blackout out when watching movies.
rankiz is offline
post #3578 of 3582 Old 06-26-2014, 07:05 PM
stephenbr's Avatar
Quoted: 28 Post(s)
The Sony will be great for your set up.
stephenbr is online now
post #3579 of 3582 Old 06-27-2014, 05:34 PM
AVfile's Avatar
Quoted: 14 Post(s)
Liked: 54
I find it very bright even after calibration.
Low lamp, picture contrast 81, 96" ST 130 screen: 17 ftL.
On high lamp it is too bright (at night).
AVfile is offline
post #3580 of 3582 Old 07-12-2014, 07:41 AM
AVfile's Avatar
Quoted: 14 Post(s)
Liked: 54
Is this projector supposed to have two bright corners? Top left and bottom right (when ceiling mounted).
There is also a small bright blob in the center only visible on a black background. Dust blob or internal reflection?
AVfile is offline
post #3581 of 3582 Old 07-12-2014, 07:52 AM
Andreas21's Avatar
Liked: 76
Bright corners can be a problem, but with the VW95 it is quite rare. The bright blob in the center when diplaying a black picture sounds like a dust blob.
Regards
Andreas
My Homecinema
Andreas21 is offline
post #3582 of 3582 Old 07-13-2014, 10:39 AM
AVfile's Avatar
Quoted: 14 Post(s)
Liked: 54
Thanks. I tried blowing it out when I changed the bulb but I did not disassemble further. I tried focusing on the blob but it remains a blob, not sure where it would be, perhaps between the lens elements? Optical block looked very clean with flashlight.
Do you advise removing the chassis cover and blowing it out? I find the fan is getting a bit noisy too.
AVfile is offline
Sony Vpl Vw95es Full Hd 3d Home Cinema Projector
User Tag List
