Official Sony VPL-VW95ES Owners Thread - Page 121 - AVS Forum
 3Likes
post #3601 of 3608 Old 11-07-2014, 12:35 PM
masodes's Avatar
Liked: 0
here i've linked the quick pre-calibration reports if anyone is interested.
http://1drv.ms/1tmg5ei
masodes is offline
post #3602 of 3608 Old 11-07-2014, 04:47 PM
jebj's Avatar
I spoke to Sony today. Since Sony Japan is now involved it will take longer, maybe up to 2 or 3 weeks in total. The local techs are asked to performed various experiments and tests then feedback the results. This likely takes a full day each time instructions are given and results are sent back to Japan.
jebj is online now
post #3603 of 3608 Old 11-07-2014, 11:49 PM
masodes's Avatar
Liked: 0
jebj, would you send me your "Prime Support Ref" and "Job Number"?
i'd like to let the "EU Prime Support" know that somewhere else they are dealing a bit different with problems.
i'm afraid that in my case they haven't even done any measurements. if so they would have seen that something has to be messed up with my projector.
thanks and keep us informed!
masodes is offline
post #3604 of 3608 Old 11-08-2014, 06:06 AM
jebj's Avatar
Masodes, I think it might be best to see what the final outcome is before stirring things up. This might cause problems for the service center and tech that I am dealing with, especially if my specific work order is referenced. For now you can perhaps tell them that a customer in Toronto has a similar problem with the VW95ES and the local service center is performing measurements to validate the problem. I also provided them with Calman screen captures showing the pre-calibration measurements at 50 hours vs around 500 hours to clearly show the change in gamma and gamut.
jebj is online now
post #3605 of 3608 Old 11-11-2014, 11:18 AM
masodes's Avatar
Liked: 0
That makes sense. I'm hoping the best for you!
In the meantime i found two german guys who also had to deal with the same problem. They both took their projectors to Prime Support. The first one got the whole optical block replaced and everything was working perfectly again. The other one had to cope with Sony's claim that this is reasonable wear and tear of the optical block.
masodes is offline
post #3606 of 3608 Old 11-21-2014, 05:19 PM
jebj's Avatar
Well, I picked up the projector last Friday and just had a good look at it today. They replaced the Optical Block and included multiple Sencore charts showing gamma and white balance before and after the new block. The gamma is definitely better. There is however a new problem related to the Iris. I set up white balance with Iris OFF and got average de2000 around 1.7. If the iris is then set to Manual or Auto, there is a big increase in Green which is quite obvious visually and the average de2000 is over 5. I have no idea why a new block would interact with the Iris like this but I intend to call Sony again and if necessary it will go back. I suspect that all testing was done with the Iris off based on notes written on the charts.
jebj is online now
post #3607 of 3608 Old 11-21-2014, 07:57 PM
AVfile's Avatar
Quoted: 52 Post(s)
Liked: 62
Did they leave any of the custom settings with their calibrated values that you could try, see if it is stable and compare to your calibrations?
I calibrate with the IRIS Off (otherwise results are unstable). After calibrating I turn it back on (Auto1) and I don't notice green, in fact it looks amazing. I never tried it in Manual so I will try that next time and take some measurements.
- AVStefan
If you like someone's post, just use the Like button to give thanks.
AVfile is offline
post #3608 of 3608 Old Yesterday, 12:11 AM
masodes's Avatar
Liked: 0
interesting news.
would you now send me your "Prime Support Ref" and "Job Number"?
masodes is offline
Sony Vpl Vw95es Full Hd 3d Home Cinema Projector
