Official Sony VPL-VW95ES Owners Thread - Page 43 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
Old 11-28-2011, 01:29 PM
claymic's Avatar
The focus seems to be fine all the time once you set it. No problems with that.
It's hard to explain how much a "tick" is unless you have the projector (each adjustment is just enough that you notice a vertical line moving, which is easier to see if you have a black border where it vanishes behind). It's no where near an inch off total. Maybe 1/8 - 1/4" off vertically, but I think this amount would vary depending on your throw, the size of your screen, etc. It's probably more amplified the bigger it is projected. Say you put in the test pattern. It has a double-line for the "Frame" of the image. The outside line is where the image is displayed. Say zoom out so enough the top and bottom borders are parallel to the inside of my screen frame, and I adjust the shift and save the image. When I zoom in to get the full scope screen, this is the first "adjustment" of picture position. If it is off, it is by so little that I don't even bother adjusting it. When I switch back to 16:9 material, if I put the test pattern back on the screen, then it is zoomed in a little too much (top and bottom lines are slightly larger than the screen height), and then I need to adjust the vertical shift a by a few button presses each (It's like a pixel per press or so, ignoring the first click, which usually goes in the opposite direction) to get it to line up again vertically. It's a weird phenomenon... it's like whatever I save it has, the gears and the values saved don't sync, so they always put the image off in the same direction by a few small increments. In normal movie material you might not even notice it. But as one of my sources is my HTPC, it is very noticable with the bottom windows bar, as it starts to sneak off of the bottom of my screen (Easy to notice with the date/time and the start button)
Very thanks my friend, ts more clear for me now. This only happens when you will save the lens memory right? Dont will get worse every time i go watch a movie, right? This is my final question, i promise.
Very very thanks again.
claymic is offline
Old 11-28-2011, 01:43 PM
damelon's Avatar
Liked: 269
Exactly. This only happens while it is making the lens shift and zoom adjustments during the lens memory operation. Nothing changes except while you are in the process of recalling one of your memorized "Picture Positions". That's why I was saying it's not a deal breaker. It's just a minor inconvenience.
damelon is online now
Old 11-28-2011, 02:09 PM
claymic's Avatar
Damelon, you save my day!!!!!!!! Very thanks.
The way it was said in the RS45 thread realy freak me out. Its a shame how some people overreacting some little inconvenience like this. Thans again.
claymic is offline
Old 11-28-2011, 02:13 PM
pinstripes's Avatar
I use the chief mount (RPA 020) which has the custom bracket along with the Chief Quick Connect Ceiling Plate (http://www.chiefmfg.com/Products/CMS115) . Then just went to Home Depot and got the right length 1/2" threaded nipple pipe for the right drop height.
Once you mount the ceiling plate, then you can screw in one piece of the mount to the projector and the other to the drop column. Then you can just raise the projector up connecting the mount to the bracket and slide it in the screw-grooves and just hand-tighten the screws. Make sure if you go this route that you thread your cables through the ceiling plate, the column, and the projector bracket first or you might not be able to get enough clearance to get it through later.
It went on very easy. You will save a LOT of money if you just get a black nipple pipe from Home Depot vs a "Brand Name" Chief extension column. Like $6 vs $30. The quick connect plate came with the washers but no bolts, so I had to buy 4 bolts also (They are very cheap, and the instructions tell you the exact size you should have to put into a beam, or whatever ceiling surface you are connecting too depending on your movie room design) which I just spray-painted black.
awesome. thanks.
pinstripes is offline
Old 11-28-2011, 02:28 PM
misterkit's Avatar
I'm a little confused by the lens memory feature and how it *works* as described above. If I initially set all of the positions I want and save them, when I recall them are they in the same exact spot or do they progressively get worse? For example, if I save 16x9 and 2:40 and toggle between them, is the lens progressively moving farther away from my saved positions? Or is it when I change between them it always goes back to the same point (which is slighly off my saved position)?
misterkit is offline
Old 11-28-2011, 02:43 PM
damelon's Avatar
Liked: 269
I will check this in a couple of hours and see, at least if for me, it gets worse each time or if it is just off a little from the saved position.
Old 11-28-2011, 02:56 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 486
I have not had a single issue using the position memory settings. I go back and forth quite a bit between 3D and 2D...
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is online now
Old 11-28-2011, 02:57 PM
lovingdvd's Avatar
Quoted: 2214 Post(s)
Liked: 360
I'm writing up my impressions from a few days of critical viewing, including many hours of direct A/B comparisons with my RS20. Should have a chance to complete this later tonight or tomorrow and will post it along with some screen shots.
lovingdvd is offline
Old 11-28-2011, 03:07 PM
Gary Gleave's Avatar
Quoted: 16 Post(s)
Good to hear.
I read in this thread about a few people having problems with the lens memory jumping further out of position each time used( I think Damelon mention 1/8-1/4" for his unit). Must be some units functioning properly and others not. Maybe post up some firmware numbers?
It would bother me as I really don't want to be reaching for the remote each time changing from 2.35 to 1.78 and back. I hate it when the screen is not filled or spilled over into the masking.
It still sounds like a great projector.
By the way I haven't made up my mind on a projector yet. Nor have I had a opportunity to see the 95 in action, but I have watched a few movies on the 90.
Gary Gleave is offline
Old 11-28-2011, 03:19 PM
Kelvin1965S's Avatar
Quoted: 257 Post(s)
Liked: 152
Great LDVD, look forward to reading it in full.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is online now
Old 11-28-2011, 03:52 PM
misterkit's Avatar
Can you also check the lens memory feature issue? Im hoping this isnt "normal"
Old 11-28-2011, 04:03 PM
damelon's Avatar
Liked: 269
So I just tested it like 5 times in a row. It doesn't compound. Which is very good news as a compounding problem would become drastic over time without adjustment. It's just off by a minor fraction from the original saved position. Again, this isn't something you would notice unless you literally threw up a test pattern and looked. It's a very small difference vertically downward. I only notice it because I use my HTPC in Windows as a 16:9 source and I can see it lower in the bar after recalling a memory position. So if you never make the adjustments other than using the position for just plain movie viewing and switching, you may never notice it at all... I'm just picky!
Old 11-28-2011, 04:05 PM
misterkit's Avatar
ok thanks. so theoritically you could save it in the 'wrong' position to get it to the correct point every time. got it.
Old 11-28-2011, 04:20 PM
claymic's Avatar
If you use a htpc then you will to save in the right place to dont loose anything, but if will use a player you can easy put the zoom one or two touch more, then will can use the mask for adjust the sides. I do this with the AE7000 and AE4000. I think there is no issue with the lens memory here, only a few adjusts and every thing will gonna be fine. At last i hope.
claymic is offline
Old 11-28-2011, 04:23 PM
damelon's Avatar
Liked: 269
Actually, thanks to misterkit's response, I thought to try it out. I saved my vertical position 3 adjustments points upward for my lens memory position. (Which would initially look a little too high) and then switch back and forth between 2:35:1 and 16:9 and when it goes back to 16:9 it goes to the right spot every time. So I just needed to set it a little wrong and then it recalled to the right spot for me.
So if you are using Lens Memory.
1) Set up your positions so they look right and save them.
2) Switch back and forth and bring up your test pattern again to see if is in the exact place you set it up. (Since it might work right for some people)
... if it isn't in the EXACT spot...
3) try to see on your remote how much zoom or shift you need to change to get it to where you wanted it
4) re-record that position with it off by that much
5) use it without further issues!
Old 11-28-2011, 04:32 PM
claymic's Avatar
I am sorry for my bad english damelon, i will try do a better job in the next time. Its very hard to me write in english, so be patiente with me. I never studied english in my life, i Learned something reading reviews of projectors, only because i realy love this.
claymic is offline
Old 11-28-2011, 04:33 PM
damelon's Avatar
Liked: 269
Sorry I offended you, that wasn't my intention! In fact the way you were asking questions made me think about a solution I wouldn't have thought to try. So thank you!
Old 11-28-2011, 04:49 PM
claymic's Avatar
Dont worry, i do have to learn more. Thanks for the help.
claymic is offline
Old 11-28-2011, 05:00 PM
claymic's Avatar
Another question now
The Mask will work when waching a 3D movie ?
claymic is offline
Old 11-28-2011, 05:42 PM
misterkit's Avatar
Great news. Thanks for testing it
Old 11-29-2011, 05:07 AM
d.j.'s Avatar
Quoted: 164 Post(s)
Liked: 70
Mine behave just likes yours.
It shifts a little ( around 1/2 cm ) down and to the right, and like you, I think its not a big deal, but still a little sad that they didnt get it perfect in first round
dj
d.j. is offline
Old 11-29-2011, 05:25 AM
John Ballentine's Avatar
Great! Anxiously awaiting the comparison (I own an RS20 too and am considering the 95).
John Ballentine is offline
Old 11-29-2011, 11:47 AM
lovingdvd's Avatar
Liked: 360
After several viewing sessions I am glad to report that I am thrilled with the VW95. Indeed it is a very
nice upgrade to my RS20 which I’ve had for 3 years, and I spent several hours with A/B testing to draw
many conclusions.
Note that I am just a hobbyist and these are my laymen opinions. You should not make any decisions to
buy or sell a projector based on this. Everyone has different tastes so YMMV. There is no substitute for
seeing a projector you are interested in first-hand and evaluating it based on what is most important to
you, before making such decisions.
First some background on how I did the A/B testing…
For the A/B testing I used a Lumagen Radiance XS to output the same signal to both pjs over HDMI.
Memory A on the Radiance was set to display video on the RS20 and no video on the VW95. Memory B
was set vice-versa. Each memory also contained the appropriate calibration grayscale for a dE of less
than 2 from 5-100%, a gamma of 2.22, and a gamut that measured nearly perfectly for Rec 709.
The Radiance is an excellent product and provides a great deal of calibration flexibility and features. I’ll
have more to say about the Radiance in a separate write up, but for now suffice it to say that I find it an
essential tool for the HT enthusiast. The addition of the Mini line was a great idea and provides a nice
price point for a highly functional unit.
The Radiance made the A/B testing rather easy. I could just select memory A on the Radiance and see
the RS20, or memory B and see the VW95. Due to HDMI handshaking with the projector, there was
about a 3 – 4 second delay when switching between the two projectors.
For all but the darkest scenes the little bit of light that comes out of either pj when they are not getting a
signal did not impact viewing of the other (I even tested this). For more critical black level viewing,
however, I also used cardboard to completely block any light from the non-active pj.
The VW95 was ceiling mounted and running in low lamp mode with Auto Iris 1. The RS20 was table mounted
about two feet closer to the screen. It was in low lamp mode with the iris fully opened, which is the mode
I always run in. I recently replaced the bulb in the RS20, so the lamp is still quite bright. In fact the
measured lumens were approximately 10% higher on the RS20 compared to the VW95.
I watched all sorts of HD material – video and film from cable TV, and clips from several Blu-rays. Over
the course of two nights and many hours of viewing, I watched and paused well over 100 different
scenes of various types (dark, bright, video, film, etc) and flipped back and forth to make comparisons.
Overall impressions from A/B comparison
The first thing I should say is that, without the benefit of an A/B comparison, the RS20 still looks amazing
to me. I still go Wow when I see it. However, that changes when viewed in the context of the A/B
comparison, as the VW95 easily beats the RS20 in most categories.
The best way to describe my overall impressions between the two is that the RS20 looks somewhat
“murky” and a bit dull in comparison. I was amazed to see the additional contrast, pop and vibrancy
that the VW95 has – especially considering that not only were both pjs were running a 2.22 gamma with
a finely tuned Rec 709 gamut, but also because the RS20 was actually 10% brighter.
I wondered how this could be. Both pjs were well calibrated and yet the one that’s putting out 10% less
lumens is displaying a cleaner, vibrant, seemingly brighter and more “contrasty” image. I suppose this is
due to the higher ANSI CR or ON/OFF of the VW95. Then again, can on/off CR really come into play in the
context of a single frame? I wouldn’t think so since the pj is still dependent on the native CR in that case,
but whatever the reason, the VW95 had a more dynamic and vibrant picture.
I will now address some characteristics that people often ask about…
Black Level
This area was very close and was hard to judge from still frames, mainly because of the time it took for
the HDMI switching. And during such handshaking the picture was getting bright, then dimmer, then a
little flash of color etc, so I would lose my frame of reference by the time the new image was displayed.
That said, when I watch the VW95 in motion and watch dark scenes, I find it to have more satisfying
black levels then the RS20. I do not know if this is because the black levels are darker, or because the
image has more vibrancy and pop to it (which can then make the blacks look darker relative to the
brighter whites), but at any rate the black levels are very satisfying to me. Also on a total fade to black it
seems the VW95 is darker, based on seeing the light on the screen and the hand-puppet test (and yes
you can still see hand puppets with the VW95).
Convergence
Given the many reports of excellent convergence from other owners, I was surprised to see that my
convergence wasn’t so great OOTB. I needed to move red down 3 and over 2, and blue over 2 using the
panel shift function. This was not the zone function, but rather the full panel shift option. Unlike the
RS20 where a single click of panel shift makes a large change, the changes are much finer with the VW95
adjustment.
After making the convergence adjustments on the VW95 using a single pixel grid, the convergence was
excellent. The only area that is a bit off was about 20% of one side of the screen had green off by a half-
pixel, perhaps more. I am sure I could use the zone adjustment to correct this. However I cannot see any
fringing or other such issues caused by it, so I am leaving it alone. I figure why engage additional
processing and possible artifacts when it’s not a problem to begin with. When I run out of things to
tinker with I may experiment with the zone adjustment, but for now I really see no need.
The VW95 makes it very easy to turn on and off the panel shift function. I used this feature to A/B many
scenes and still frames to compare the VW95 against itself both with and without the shift function
engaged. I could not detect any negative effects from using the panel shift function like I did.
Focus and Sharpness
I found it a bit difficult to get the focus just right. I prefer a manual lens focus so I can rock it back and
forth and find the sweet spot. Unlike the RS20, the VW95 is rather challenging to see individual pixels
and the grid even when right up at the screen. I used a magnifier card up at the screen to zoom in on the
pixels and set the focus at the point where they were most defined. I then checked edge to edge, up and
down, and the focus was very even. I exchanged screenshots of my focus with other VW95 owners and
we agreed our focus and pixels looked about the same up close at the screen.
The picture is sharp, but once again after years of yearning for a sharper picture I still feel like it can be
sharper. It is a bit sharper and more focused than the RS20, but my expectations were higher after
hearing for years how much better the Sony lens is and how much sharper it is. Like was the case with
the RS20, I still find for my personal taste that I need to use the sharpness control to sharpen things up
to taste, even though technically it is artificial sharpening. For now I settled on a sharpness setting of
22. The picture looks nicely sharp and focused, but not a night and day difference compared to the
RS20. My Samsung 63” plasma (PN63C8000) looks far sharper, but that is probably not a fair
comparison.
Clarity and Fine Details
This is one of the areas that the VW95 is a far stand out above the RS20 and other pjs I have owned. The
picture is very clear and crisp. The VW95 does an amazing job with fine details and textures. The picture
is also “silky smooth”.
Reflections off of water and other objects and other such shiny surfaces are real stand-outs. One such
example of this was a close up of jewelry with diamonds shown in a HD commercial. On the VW95 the
diamonds were sparkling and glistening much more than on the RS20. Likewise there is a scene in
Baraka where they are inside a structure that is made up of all glass and panning through a hallway and
showing the ceiling. The reflections and sparkles coming off of all the glass and crystals made for a jaw
dropping moment on the VW95 and does not glisten nearly as much on the RS20.
Scenes with fine details and particles look rather striking as well on the VW95. For example snow, dust,
smoke, sand, leaves on trees out in the distance, etc look more real and defined than I am used to
seeing. All these properties combine to deliver a very life-like picture, particularly when the HD quality
is very high.
Shadow Detail
The shadow detail I see on the VW95 is outstanding. What is crushed in the blacks on my RS20 is shown
in great detail on the VW95. A fellow RS20 owner mentioned that shadow detail is a function of gamma,
which I agree with. He says he can see level 17 and 18 on test patterns. On the RS20 in my light
controlled room in total darkness I definitely cannot see 17 and never have been able to, and 18 is even
a bit questionable. And my gamma at 5% is at 2.2 and not crushed and my black level (brightness) is set
correctly. Raising the brightness even a single click not only still does not resolve level 17, but also raises
the entire black floor.
There were many scenes where the shadow detail was much better on the VW95 than the RS20. One
such example is in Monsters, Inc. Toward the end of the movie Sully is trying to escape with the girl. He
opens a door and looks inside and sees a long and narrow tunnel. On the RS20 it is mostly black with
some highlights and details. On the VW95 the tunnel is much more lit up and much finer details and
highlights can be seen.
Motion and Artifacts
As would be expected, the motion handling on the VW95 is very good and far better than the RS20. I set
the MotionFlow to Low, and in some cases to High (do not notice much of a difference between these
two settings). Watching sports on the VW95 is a lot more enjoyable. Gone are the zebra-stripe red
fringing from referee jerseys and scrolling text as can be seen on the RS20. Although I will note that
while scrolling text looks great on the VW95, it still doesn’t look 100% perfect (but close enough).
Hockey is very enjoyable to watch on the VW95. The players indeed look like they are gliding freely. This
is especially noticeable after play stops and they just coast around a bit. It gives a good sense to the
feeling of “being there”, like I am looking over the glass from the lower level. Football looks great too,
with hard thrown spirals keeping form and shape nicely. The super slow-motion replays are a joy to
watch too.
On such example of the VW95’s superior motion handling jumped out at me when I wasn’t looking for it.
There is a scene in Baraka where they are showing several huge waterfalls. As I was A/B-ing this scene I
noticed that the water was keeping its full form, shape and definition as it rolled over the falls and was
falling. You could still make out its particles and structure while it fell just fine. On the RS20 it still looked
like water of course, but many of these fine details were lost in the motion.
I have watched this scene many times on my RS20 and of course it never dawned on me that some of
these details were getting lost. Without the benefit of an A/B test I would not have appreciated the
improvement that the VW95 added to scenes like this. It seems that whether the little things like this
are directly noticed or not, they all contribute to the VW95 providing that “being there” feel more-so
than other projectors I have had.
It should be noted, however, that my VW95 is not artifact-free. There are some occasions where a
moire-like effect pattern can be seen as the camera pans or zooms over certain types of patterns. In
some cases it is very subtle and quick, and in other cases it is more pronounced and a distraction.
One thing that may provide a hint is that I have only noticed this while watching video on broadcast HD.
I have not noticed it at all on movies (film) on broadcast TV or on Blu-ray movies or the XBOX/PS3
gaming.
I have done some very basic and preliminary troubleshooting and haven’t been able to pinpoint the
source of this yet. So far I tried turning off the panel shift function, turning off Motion Flow, turning off
Sharpness (min) and yet the artifact is still reproducible. When I have a chance I will try bypassing my VP
to eliminate that as well. The good part is that I have clips on my DVR where this occurs so I can easily
test different settings and experiment. If anyone has some ideas on what types of settings or changes to
try in order to pinpoint the source of this, please let me know!
Uniformity
Overall the uniformity of the VW95 is very good. There is a very slight pinkish tone that can be seen in
some full field gray test patterns. It might be my imagination, but it seems to have improved since I first
got the unit, and I have not seen this in any real world material (although at first I thought I may have). It
could also be a newer calibration setting I am using (maybe I was driving red too hard before).
The brightness uniformity is also very good, but not perfect. About 20% of one side of the screen
vertically seems a tad bit darker when viewing a full field 100% pattern. But again nothing that is
noticeable with real-world content or that jumps out at me.
My VW95 may have very slight brighter corners. It is hard to tell. Your eyes can play tricks on you in the
dark, especially as dark as things get with the iris fully clamps down on a 0% pattern. Most of the time it
seems there are no bright corners. Although sometimes I think I may see just a hint of them. Even
though I am very sensitive to bright corners, I am happy to report that even if they are there it is very
slight and does not affect the PQ in any way and is not really noticeable (if I’m not quite sure I am seeing
them when gawking for them, I am not going to worry about it for sure!).
The uniformity is one area I give the RS20 an advantage. My RS20 is nearly perfect in this regard, as far
as having no color shift, being evenly lit and not even the slightest hint of bright corners. That said, I do
not see any real world benefit from this advantage, and the VW95 still seems to have a darker fade to
black as mentioned earlier.
Calibration
As has been mentioned by others, the VW95 OOTB settings are very good. dE was off by about 3 on
mine. However I am perplexed at why the default gamma is 8. This gamma measures very poorly,
basically falling off a cliff in the upper end. In one of AVS member SOWK’s calibration reports you can
see how this gamma measures by looking at his pre-calibration numbers. I set gamma to OFF and
calibrated the unit using the Radiance 21pt grayscale.
I did not use it or measure it, but SOWK reported that using the RCP causes some linear tracking issues
at other saturation levels, and that this did not occur with RCP off. This sounds like the same or similar
issue than what RS20 users have faced. I used the Radiance’s gamut controls to dial in Rec 709, starting
with the Wide 3 color space which I found necessary to get enough room to move the points exactly
where I needed to. It may be possible to do this with the Normal or Wide 1 setting. I didn’t stick with it
long enough to find out (it seemed like I would not have enough room so I changed direction before fully
experimenting), and another AVS member has reported good results doing so.
I did some A/B testing on the VW95 between my Rec 709 calibration in the Radiance compared to the
default gamut in Normal mode on the VW95. It is not very easy to switch back and forth instantly so it is
hard to compare exactly. But it seems that the default Normal mode is very good. It is very close to my
calibrated results if perhaps a tad bit under saturated compared to mine. If you do not have a Radiance
or the means to calibrate one, it is probably best to just run in Normal mode with RCP off then to worry
about it or mess with RCP.
Also note that the Wide 1 color space is very tastefully done for those who like a more saturated gamut.
In this mode green, yellow and red are basically pushed out, but not obnoxiously so. For some animated
movies I could see running in Wide 1 just to add more punch and fun to the image.
I did not use Sony’s ImageDirector software, but if you do not have a Radiance you can supposedly use it
to dial in the RGB gamma for the 5-95% range. This would be similar I suppose to the built in custom
gamma controls in the RS20, which can be used with great patience and some trickery (well
documented elsewhere). I understand that the later generation of JVCs made the custom gamma easier
to work with, but I have not used it.
Much has already been said about the CMS and gamut on the RS20. For those that follow my posts, I
spent nearly 100 bulb hours years ago trying to come up with a compromise of settings that tracked
decently across various saturation levels and still provided a gamut close to Rec 709. In comparison to
the Rec 709 provided by the OOTB settings or calibrated settings on the VW95, the CMS settings I was
using on the RS20 left the picture rather under saturated.
In order to provide an apples-to-apples comparison of the VW95 and RS20, I used the Radiance to dial in
Rec 709 on the RS20 so that it was nearly identical to that on the VW95. Therefore in my assessment I
did not notice any benefit in color on the VW95 versus the RS20. However, if one does not have a
Radiance or other VP that can deliver good CMS results, then the VW95 may offer an advantage in color
reproduction as well.
As far as measurements go, as I reported a week or so ago I measured 120,000:1 on/off on the VW95
with auto iris on in low lamp mode. This compares to about 30,000:1 or 50,000:1 that I get with the
RS20 (depending on its lamp and iris setting) without an auto iris. In my configuration the VW95 is not as
bright as the RS20. The VW95 with about 80 hours on the bulb is putting out 325 lumens from near the
back of the throw range. This output seems somewhat lower than what other VW95 owners have
reported.
Dimensionality (2D viewing)
On the VW95 once in a while certain scenes come on that are just draw dropping in terms of depth and
dimensionality in 2D viewing. The RS20 is no slouch in this area either, but the effect is more
pronounced on the VW95.
On the couple of occasions that friends have seen the unit, different people have remarked with “look at
that!” and “wow!”, and asked me if they were watching 3D. Clearly they have not experienced true 3D
at home to think that, but the point remains – the fine details, shadow detail, high contrast and other
characteristics on the VW95 contribute to great depth and dimensionality.
3D
I find the 3D on the VW95 rather excellent and enjoyable. It is not perfect and there is ghosting at
times, but it easily exceeds my expectations. Note that my impressions are based on the MonsterVision
/ Optoma 3D glasses. I rarely use the Sony glasses as they are reserved for the last to arrive. But I will
say this about them – they are not as bright, not as clear and introduce a little color shift and “dulling”
compared to the MonsterVision / Optoma glasses. Also the battery seems weak. It’s flashing after just a
few hours of usage. I need to look more closely at it. Maybe they are not turning off or the batteries are
not great (both pairs do the same). Yes it is a noticeable and appreciable difference between these
glasses, for certain.
The first thing I should mention is that, although I am still experimenting, it seems that a warm up period
of 30 – 45 minutes is necessary for the 3D to work very well with little or no ghosting – at least with SbS,
TnB or 720p60 frame packed. In these modes the 3D is pretty unwatchable to me from a cold start
(rather blurry, lots of ghosting, and bothersome to the eyes). I believe this is similar to what others have
reported on different manufacturer’s pjs as well. The 1080p24 frame packed from Blu-ray may not be
affected nearly as much by a cold start – I have to go back and test this though.
In 1080p24 frame packed the glasses run at 96hz (48hz per eye). And in all other modes they run at
120hz (60hz per eye). I believe the idea is that with 24sf material they can take advantage of the native
multiples of 24 which I suppose is better for motion without the need to alter the frame count. However
I am very sensitive to flicker so in this mode I see some flicker particularly on bright scenes and it can be
somewhat distracting at times. Note that many people are not sensitive to flicker and will not likely
notice it. In the other 3D modes at 120hz I do not see any flicker.
I like watching the 1080p24 frame packed 3D with Motion Enhancer set to High. Note that the Motion
Enhancer control is only available in this 3D mode, unfortunately. I did not initially realize the extent of
the downside of this, but after spending a night trying some very fast scrolling PS3 3D games like Sonic
Generations, I certainly do.
More specifically, very fast non-stop scrolling 3D games do not look choppy, but it is harder on the eyes
and a bit blurry compared to playing on my Samsung plasma in 3D. I believe the plasma has its own motion
handling that does runs in 3D mode, which could account for the difference. I am reaching out to
Sony engineering to see if they will consider adding support for Motion Flow with SbS, TnB and 720p60
frame packed 3D.
It should also be noted that Dark Frame Insertion (DFI) is not available at all in 3D, which I don’t think
actually matters because I have yet to find a situation where DFI offered an improvement anyway.
Overall I think the 3D is very well done. It is plenty bright for me, even with darker movies. 3D gaming
through the PS3 looks great as well. In high lamp mode I am getting about 525 lumens. This of course
does not account for the light loss through the glasses, which is estimated by some at around 50% (in
general, not specific to the VW95). On my 106” diagonal Firehawk 1.3 gain screen that would work out
to about 10ftL through the glasses. It may not sound like a lot, but it is plenty bright and punchy for me,
and exceeds my expectations for brightness.
Summary
The RS20 is an exceptional projector and puts up a good fight considering it is 3 generations old at this
point. Without the benefit of the A/B testing I would have been harder pressed to realize the
differences. Although the VW95 is clearly better to me and worth the upgrade, keep in mind that it is
not a day and night difference so expectations should be kept in check (I originally went into this
upgrade thinking some of the differences, like sharpness, would be greater than they are).
Overall I am very happy with the VW95, and the direct comparison to the RS20 helped me appreciate
the VW95 even more. The characteristics that make the VW95 really stand out are its great looking
contrast and the way white really pops, satisfying blacks, its exceptional display of fine details, shadow
detail, and motion handling.
Screenshots
Attached are some screenshots I took of the VW95 using my iPhone 4S at a resolution of 3264x2448.
Three are in this post, then 3 follow in the next post. In order to fit
them here I loaded them in Photoshop, cropped them to remove most of the area outside where the
screen was, and resized them to have a width of 1280 (the max allowed here). The height will vary based
on how I cropped. Some resolution and detail was lost in the process (although the original pictures did
not pick up the fine details to begin with). No other changes were made.
Standard rules apply here regarding screenshots – they are just for fun and to give you a rough idea of
how things look on my screen. For the most part the colors are similar to what is in the pictures. The
pictures do not come close to showing off the real beauty that is on screen though. For example there is
a ton of black crush in the photos, many fine details (in the blacks and otherwise) are lost, they are a bit
out of focus (I did not use a tripod) compared to the real thing, and some dithering may have occurred
from the camera.
Any questions? Just let me know!
Old 11-29-2011, 11:48 AM
lovingdvd's Avatar
Liked: 360
Attached are three more screens from the VW95.
Old 11-29-2011, 11:49 AM
claymic's Avatar
Very thanks lovingdvd.
claymic is offline
Old 11-29-2011, 12:26 PM
Quoted: 257 Post(s)
Liked: 152
Thanks very much for the review LDVD.
Particularly relevant to me as a Mini3D owner myself, using your Radiance should have levelled the playing field in terms of them both being calibrated to match rec709. I suppose you could have closed the iris a little more on the RS20 to match the brightness levels (I don't know if you have a lux meter?) but I suppose this wouldn't have made much difference to your conclusions.
I really appreciate the time and trouble you went to in order to compare these two models fairly. I also like your summary in that we're not talking night and day improvements these days. In isolation it's maybe easier to keep with what you already have unless there is a particular issue (like red fringing) if you can resist the need for 'retail therapy'.
Old 11-29-2011, 12:52 PM
maximus74's Avatar
Quoted: 92 Post(s)
Liked: 32
Hi,lovingdvd
Yes indeed the Sony 95ES is a fantastic projector.My wife too noticed right away and she like it, a lot more then RS20.
Your review like always is a very well done,very carefully structured and i feel it like i was there.
Congratulation for your choice
I am very happy with my choice,too
maximus74 is offline
Old 11-29-2011, 12:54 PM
thrang's Avatar
Quoted: 1601 Post(s)
Liked: 1374
Excellent, detailed review Ric
thrang is offline
Old 11-29-2011, 01:03 PM
mdrew's Avatar
Quoted: 13 Post(s)
lovingdvd - I'm curious what iris position you had the RS20 set to, and if you run the lamp in low or high?
You and I have very similar set ups (Firehawk, XS, RS20) and I have been waiting to hear your comparison between the two machines. Thanks for taking the time to post the detailed write up. It is helpful. I'm still inclined to hear more about the RS55, but am leaning pretty hard toward the Sony.
mdrew is offline
Old 11-29-2011, 01:11 PM
unidisk's Avatar
For those living in Canada and purchased the unit from local autherized dealer, I found that the 95ES is listed under professional product section and you need to use the following link to register the product.
https://productregistration.sony.ca/registration/pro.do
Here is the link to the warranty info.
http://www.sony.ca/sonyca/view/engli...ranty_V1.8.pdf
I also attached the warranty document. It is 3 years for VPL with labor and parts. It is different from the normal ES 1 year warranty coverage in Canada.
can_ProductWarranty_V1.8.pdf 55.5791015625k . file
AVfile likes this.
unidisk is offline
Sony Vpl Vw95es Full Hd 3d Home Cinema Projector
