Epson 6010 - Page 13 - AVS Forum | Home Theater Discussions And Reviews
Old 08-13-2012, 01:15 PM
point1's Avatar
Quoted: 102 Post(s)
Liked: 31
Hey guys,
I'm looking to get feedback from people who have the 6010. I currently have an Epson 6500 right now in a dedicated theater room (lighting is a non factor). I was wondering if the 6010 is a good upgrade from this projector (my 6500 has less than 400 hours of usage since 2009) or should I wait for this year's (next year's) Epson model. If I recall, every year, Epson releases an updated model.
I think the next evolution from here on is 4k resolution right?
Jon
point1 is offline
Old 08-14-2012, 07:47 AM
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
Man I love the view of 2:35:1 but dont want to shell out 3k for a lens lol
Holiday121 is offline
Old 08-14-2012, 11:28 AM
JoeBoy73's Avatar
Quoted: 12 Post(s)
Liked: 26
The 6010 will do a 2.35 without a lens. I've seen it in person from a local dealer in Texas. Only downside is its a manual zoom cool.gif
JoeBoy73 is offline
Old 08-14-2012, 01:05 PM
Mike Garrett's Avatar
Quoted: 5568 Post(s)
Liked: 3550
Any 16:9 projector will do 2.35, but if ceiling mounted, you might get pretty tired getting a ladder out and manually changing vertical and horizontal lens shift and zoom every time you change aspect ratio. Even table top mounted, it would be a pain. The minimum that i would want on a projector if going 2.35 is power lens shift, power zoom and power focus. lens memory would be a step up from there with an A-lens being my preferred method.
mjgarrett100@gmail.com
Mike Garrett is offline
Old 08-14-2012, 05:06 PM
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
Are there any projectors that do that with power?... Is there a difference in the lens between the built in on some of the projectors?
Old 08-14-2012, 08:13 PM
Francis Medina's Avatar
Francis Medina is offline
Old 08-14-2012, 09:11 PM
jnabq's Avatar
Liked: 39
jnabq is offline
Old 08-15-2012, 05:19 AM
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
So with the panny you can zoom auto and everything and get a 2:35 screen... So if these projectors can do that what is the point of the Anamorphic lens?
Old 08-15-2012, 05:56 PM
programmergeek's Avatar
Zooming the projector you loose resolution and light. Basically you are cutting off about 1/3 of the chip it just appears black on the top and bottom. By using a lens you are getting full resolution every pixel on the chip is being sent to the screen and also all the light so you don't loose brightness. It gets worse by zooming and cutting light you are also throughing off your color calibration etc. Basically it works but an anamorphic lens is the better way but not without it's downsides as well. I suggest you go over to the 2:33 constant height board and look there a bit. Basically an anamorphic lens is the right way to do it as of now. In a couple of years we may see some new chips or 4k projectors get brigher.
Jason
Note: Any posts are of my personal opinions and not to reflect upon any business.
Jason@programmergeek.com
908 578-6466
programmergeek is offline
Old 08-16-2012, 07:13 AM
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
Thanks for the info will do some research..
Old 08-18-2012, 06:08 PM
gbickle's Avatar
Hi all,
I have have a new tw9000w (6010)....and I thought I'd ask here before taking this back.
The reds are way too saturated (thx, cinema, 3d mode) ... Faces look sunburnt ..came with firmware 1.04 installed. I know I can calibrate but thx mode should be way better than this.
Convergence is horrible, I played with panel align but it makes text lose its "punch"....its the red panel that I notice is out the most ....maybe I'm just fussy coming from dlp...I'm sitting normal distance from screen and can clearly see a red tinge around everything on a computer desktop.
On a side note I tried my panasonic glasses from my plasma tv and they are more comfortable than the Epson ones and seem to produce the same 3d picture.
gbickle is offline
Old 08-18-2012, 06:25 PM
coderguy's Avatar
Quoted: 291 Post(s)
Liked: 270
If you can see a red outline from seating distance, I'd send it back...
Red is one of the most bothersome colors for convergence to be out too much.
Access HERE from this thread
coderguy is offline
Old 08-22-2012, 05:33 PM
scarr2k's Avatar
Bought my Epson 6010 back in march of 2012, its been fantastic. Only issue I had was occasionally I would turn it on, only to get a bulb error (red light) on the side. Did this about 3-4 times at random intervals. Called Epson Monday and they 2 day shipped me a new bulb. Just wanted to give some props to Epson support. Only took my serial and I was we'll over the 90 days but prob only 40 hours on the bulb. Nice to see good customer service. smile.gif
scarr2k is offline
Old 08-23-2012, 03:16 AM
DefRay's Avatar
Hi folks,
quick question for the Epson owners in here:
Does the 5010/6010 support shifting of the lower black bar to the top when viewing 2.35:1 content?
I'm going to use a fixed frame screen with masking from the top so the lower edge of the picture should always be on the bottom of the screen to avoid using the manual lens shift.
I know I can probably do it when playing something from the HTPC (using MPC-HC), but what about dedicated Blu-Ray/DVD players?
If that's not possible I might have to go with a JVC with motorized lens-shift after all...
DefRay is offline
Old 08-28-2012, 10:55 AM
ragged's Avatar
Anyone know a dealer in MD, near zip 21045 that has one on display or where I could order one?
ragged is offline
Old 08-28-2012, 09:14 PM
AV Science Sales 4's Avatar
Please give me a call. I live in MD, zip 20833, probably within 1/2 hour from you.
AV Science Sales 4 is offline
Old 09-02-2012, 05:18 AM
canton160's Avatar
Quoted: 24 Post(s)
Liked: 50
Originally Posted by john2910 View Post
Hello
So do more people have those anoying ghosting on the subtitles when in a 3d movie?
finally i found someone that has ghosting in subtitles in 3D.
choosing a different time for the 3D glasses stay open the 3D is perfect but the subtitles are unreadable, if i chose the option in the glasses the 3D movie gain crosstalk , ghosting and artifacts but subtitles are ok.
my 3D movies with this issue are the titles " turtles tale 3D" and " drive angry 3D" all the other 3D works well.
my projector epson tw6000 aka 3010 in usa.. the zoom is in minimal ( due to small room)
can some epson owners try their 3D movies with subtitles on, to check subtitle ghosting, I'm sure theres more people with this issue and epson need to address this with a firmware update.
thanks
Anthem MRX310 | XTZ 93.23 DIY 5.1 (Seas Jantzen Mundorf) | DXD808 | Oppo 103D | LG OLED 55EC930V | Mitsubishi HC5 | Lusoscreen 100"
canton160 is offline
Old 09-03-2012, 01:53 AM
MAZMAN808's Avatar
What do you mean with this? i dont understand it.
I watched the Avengers the other day in 3D and yes, i could also see crosstalk on the subtitles, didnt happen all the time but a few times it did and it was the first time ive seen it for me.
MAZMAN808 is offline
Old 09-03-2012, 02:54 AM
canton160's Avatar
Quoted: 24 Post(s)
Liked: 50
in the menu theres a option to "INVERSE 3D GLASSES" that allows the glasses to receive more light reducing crosstalk images in 3D
in some particulary 3D movies doing this, improves a lot the quality of 3D but gives loads of ghosting /artefacts in subtitles.
for example in "A turtle's tale 3D" on 14,54m the scene with seahorses its impossible to watch unless, i "inverse the 3D glasses" but clearly the subtitles get loads of ghosting impossible to read.
in the remote the option to "inverse 3D glasses" is by default the "user"
i imagine this bug, take so long to be address by epson , the average of users in avsforums and avforum, dont use subtitles in movies....but for the other non -english-native is a reallly annoying.
Old 09-03-2012, 06:19 AM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
So you are SAYING Avengers is Released on Blu-Ray in Australia already???
drhankz is offline
Old 09-03-2012, 07:18 AM
MAZMAN808's Avatar
Canton160
Thanks, i didnt know about the inverse 3D glasses bit, i always wondered what that did, so i'll give it a go next time i watch a 3D movie.
drhankz,
Yes, Avengers was released here on the 28th of August, sorry champ that you have to wait biggrin.gif
Old 09-03-2012, 07:21 AM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
Canton160
drhankz,
I have it on ORDER.
drhankz is offline
Old 09-03-2012, 12:31 PM
canton160's Avatar
Quoted: 24 Post(s)
Liked: 50
Canton160
drhankz,
from another forum about the inverse 3D glasses.
"Inverse 3D glasses switches left and right images or rather, what your left eye sees with what the right eye sees and vice versa.
Therefore something in the foreground gets pushed to the background and so on.
It should only be used for images that are incorrectly formatted.
It does not make any changes to light throughput.
From P.58 of the manual:
"Reverses the synchronization timing for the left/
right shutters on the 3D Glasses and the left/right
images. Enable this function if the 3D effect is not
displayed correctly."
Old 09-18-2012, 11:18 AM
bcpeery's Avatar
CAN SOMEBODY PLEASE POST SOME PICS OF MOVIES!!!!!!!! LOL
bcpeery is offline
Old 09-18-2012, 02:08 PM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
NO NEED TO
drhankz is offline
Old 09-18-2012, 02:14 PM
Special FX_45's Avatar
LOL, that was the biggest thing that caught my eye as well in his post. Can't wait for release day next week!
FOR SALE - Definitive Technology CLR3000. PM me if interested.
Special FX_45 is offline
Old 09-21-2012, 07:31 PM
jnabq's Avatar
Liked: 39
PS3 3D glasses on sale at bestbuy if you need any. $30
jnabq is offline
Old 09-23-2012, 02:09 AM
gbickle's Avatar
Just an update for those that may be interested. (check my post number 371)
I sent it back to Epson because I wasn't happy with the Red panel convergence. I had a good play with the panel align feature but it would always make it worse somewhere else on the picture from the green or blue panel. Never get it right over the whole screen.
Epson sent it back and sure enough they had just had a play with the panel align feature. The Green panel was now worse than the red was. When I flicked up the Menu I could see obvious green lines around where it was supposed to be white. Also a purplish shadow had been introduced which I could see around Channel logos and subtitles.
I contacted Epson again and sent them some photos of the new problem and they replied back that the technician had said that the projector was fine from normal viewing distances and basically insinuated that I was being too fussy. Ill say this, if my Computer LCD monitor was anywhere near this bad I would find it unusable for text.
So long story short, I sold the projector at an $800 loss and will never buy Epson again. I think ill go DLP now or maybe SXRD as I have owned JVC LCOS and Sony SXRD before and the panel alignment had been fine.
I have uploaded a picture of how the Epson Menu looked (Epson deemed this fine and not a problem ... I know the whole panel cant be aligned perfectly because I had a problem getting it good and obviously the Epson "Technician" did as well)
gbickle is offline
Old 10-29-2012, 09:45 PM
DeaconDan's Avatar
I'm hoping someone can help me with actual orientation of the 6010 power connector. When looking at the rear of the PJ, feet down (power connector on right), is the power connector
--- or ---
I will have very tight clearance at the rear of projector and need to order some right angle connectors for power and USB. The input diagram in the 6010 manual shows single prong to the left, which contradicts the photo on projectorreviews.com's review of the 5010 (I can't find a rear view photo of the 6010.
DD
DeaconDan is offline
Old 10-30-2012, 04:18 PM
sparky7's Avatar
--- or ---
DD
here's some, http://www.hifi.com.cn/content-137-16-1.html same as 5010.
mark
sparky7 is offline
Epson Powerlite Pro Cinema 6010 Projector
