Give me your top three - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 11-21-2011, 06:39 AM - Thread Starter
krfuquamd's Avatar
OK, in a light controlled room onto a 8.5 wide Stewart Studiotek screen from about 14 ft away I want to know the three projectors you would want to consider if your budget was 5k give or take. 50/50 direct tv( mostly sports ) and bluray. Have plasma TV's elsewhere thruout the house and enjoy that look. Have a JVC RS1 now( have enjoyed but is the only projector I have ever had ) and on the preorder for the 45 but questioning if I might prefer something else. 3D not an issue at all. Not a tweeker so good out of the box is important. Thanks
krfuquamd is offline
post #2 of 11 Old 11-21-2011, 06:53 AM
Toe
Toe's Avatar
Quoted: 1474 Post(s)
Liked: 1842
Considering your viewing habbits, the Sony 95 seems like the way to go with its superior FI and excellent motion.
Toe is online now
post #3 of 11 Old 11-21-2011, 07:19 AM
coderguy's Avatar
Quoted: 364 Post(s)
Liked: 300
I agree the Sony's are good without a calibration, there are also a few DLP's you could look at if you wanted to start with a less expensive setup just to get a feel for the front projector world.
The Mitsubishi hc4000 is a low cost front projector solution with very good colors. However, on these lower-end units, the black levels aren't there like on the Sony, but they should match the Sony in sports or even beat it slightly, but they will be NO match for the Sony at movies.
Myself, I would suggest you need to see a few units before running out and spending $5000+. I would compare DLP to LCOS and see which you prefer. At that budget, you can do a lot, but that's part of the problem, preferences are going to make a big difference.
Access HERE from this thread
coderguy is offline
post #4 of 11 Old 11-21-2011, 07:26 AM
Mike Garrett's Avatar
Quoted: 5652 Post(s)
Liked: 3616
Under 5K excludes the VW95, but I do have a suggestion that is close. Give me a call.
mjgarrett100@gmail.com
Mike Garrett is offline
post #5 of 11 Old 11-21-2011, 08:46 AM
Toe
Toe's Avatar
Liked: 1842
He said give or take, so I assumed he could stretch it for the 95.
Toe is online now
post #6 of 11 Old 11-21-2011, 02:17 PM
ricwhite's Avatar
Quoted: 26 Post(s)
Epson 61000
ricwhite is offline
post #7 of 11 Old 11-21-2011, 03:13 PM
Tryg's Avatar
If you enjoy the look of plasmas you need to get a different screen and shoot for over 30 foot lamberts of brightness
Tryg is offline
post #8 of 11 Old 11-21-2011, 05:30 PM
Liked: 3616
What screen would you suggest? wait for it,
High Power
post #9 of 11 Old 11-21-2011, 05:47 PM
dave1969's Avatar
High Power
i got a sample of the Da Lite HP. It destroyed my blacks. Granted I only have the 3010
dave1969 is offline
post #10 of 11 Old 11-22-2011, 06:57 PM - Thread Starter
krfuquamd's Avatar
Sounds like Sony HW30 and JVC 45 are comparably priced while the JVC 55 and Sony 95 are comparably priced. What to do?
post #11 of 11 Old 11-22-2011, 07:15 PM
zombie10k's Avatar
Quoted: 2858 Post(s)
Liked: 2860
how much will you use the projector? The Sony lamp is 1/2 the price of the JVC lamp so this might be a deciding factor for those that like to watch sports and not worry about the cost of the replacement lamp.
I have the RS50 and HW30 and generally prefer the Sony for HDTV & Sports and the JVC for dark movies.
zombie10k is online now
