Official JVC RS55/X70 owners thread. - Page 124 - AVS Forum
post #3691 of 3719 Old 11-26-2014, 02:47 PM
DavidHir's Avatar
Quoted: 220 Post(s)
Liked: 451
Originally Posted by cdnscg View Post
Thanks for the response DavidHir. I'll reset the unit, and make the minor adjustments I did before. I've never had the pj calibrated, but was pleased with the picture before the repair.
No problem. Also keep in mind even though the projector was not calibrated, there is natural "drift" as the block and panels age over time which gradually changes the image unless adjustment/calibration is done. Think of it as periodic tune-ups.
DavidHir is offline
post #3692 of 3719 Old 11-26-2014, 08:06 PM
cdnscg's Avatar
I reset to factory in the service menu. Its nice to see there are some still interested in this thread. Therefore, I'll ask if you, are someone else, can tell me what the effect would be resetting the following in the service menu:
In Adjust: Lens position reset
In Options: Lens center
cdnscg is offline
post #3693 of 3719 Old 11-27-2014, 12:38 PM
GeorgeHolland's Avatar
Originally Posted by sr View Post
By the way, I also experienced the issue of the entire background turning purple, not just streaks, but that could just be the way we are trying to describe the problem. The projector was in the THX mode when the OPPO DVD player came out of screen saver mode and the picture turned purple. My suspicion is that it has something to do with the change in signal format and HDMI handshake. Since there are three components in the video chain; the DVD player, receiver/switcher and projector it is tough to say definitively which component is the culprit. In my case I cycled the power on the DVD player and the picture returned to normal.
I'm not sure I would characterize my screen as turning purple but occasionally when turning the system on and while in THX mode, the image color is way off; almost as if the the B of the RGB is missing. If I select another profile like Cinema and then switch back to THX, all is fine.
Recently I added a Lumagen Mini and calibrated from Cinema/Standard and am curious if I will continue to have issues.
I am not happy with the calibration, the colors could use a little more pop. I used ChromaPure auto cal and will start the process again from the beginning.
GeorgeHolland is online now
post #3694 of 3719 Old 11-27-2014, 12:48 PM
DavidHir's Avatar
Quoted: 220 Post(s)
Liked: 451
Resetting those would merely put them at the default position (I assume judged by the software programming) and would you just have to re-position/re-center the lens so the image would be centered properly on your screen. You might also have to re-zoom and re-focus the image to some degree.
DavidHir is offline
post #3695 of 3719 Old 11-27-2014, 12:52 PM
cdnscg's Avatar
Thnx
cdnscg is offline
post #3696 of 3719 Old 11-27-2014, 10:43 PM
CaptainATI's Avatar
Has anyone tried Darbee processing with eshift? Is the artifacting more apparent than without eshift?
CaptainATI is online now
post #3697 of 3719 Old 11-28-2014, 07:46 AM
the_abbot's Avatar
Quoted: 67 Post(s)
I have officially entered the world of projectors. Thanks to Zombie10k, my first pj is the RS55.
I connected my Dune up to it and fired up a bluray. Holy crap this thing looks amazing!!!!
the_abbot is offline
post #3698 of 3719 Old 11-28-2014, 09:10 AM
cdnscg's Avatar
Truly, Zombie10K has been of assistance to many of us. Welcome, and I hope you ave nothing but enjoyable hours with your RS55
cdnscg is offline
post #3699 of 3719 Old 12-03-2014, 08:41 AM
cdnscg's Avatar
I recently had the optical engine replaced in my RS55, and now notice a slight increase of 'pink' in the whites and skin tone of the image. Any suggestions on what I should adjust to compensate? I've never calibrated, and have no equipment. Any adjustments would have to be done by eye. I use picture mode 'User 1' with colour profile set to standard. Pretty much the same as the THX setting, but I can adjust the sharpness & detail.
cdnscg is offline
post #3700 of 3719 Old 12-03-2014, 09:34 AM
DavidHir's Avatar
Quoted: 220 Post(s)
Liked: 451
I am not sure of the THX setting on that unit, but I would get a hold of a calibration disc (DVE, download AVS test patterns, disney WOW, etc.) to at least calibrate basic settings. Pinks in whites, etc. are likely greyscale issues and you really need proper equipment or hire a calibrator if you want accuracy. If you are not concerned so much with accuracy, you can just eyeball it to some degree but then that can sometimes create new issues as you have to account for varying stimului, etc..
DavidHir is offline
post #3701 of 3719 Old 12-03-2014, 01:38 PM
kal
kal's Avatar
Liked: 38
+1. There's really no simple answer to what you can do "by eye". If there was, nobody would need to use calibration equipment.
Kal
kal is online now
post #3702 of 3719 Old 12-03-2014, 01:40 PM
cdnscg's Avatar
Kal
True. Thank you both for your input
cdnscg is offline
post #3703 of 3719 Old 12-04-2014, 10:26 PM
cdnscg's Avatar
Kal
Can anyone suggest the simplest calibration equipment to purchase? Not just a disc, but something that will be truly effective, without being over the top. Is there a one simple unit you can connect to the AVR/Bru-ray/PJ chain?
cdnscg is offline
post #3704 of 3719 Old 12-05-2014, 07:30 AM
kal
kal's Avatar
Liked: 38
You need software, you need a meter.
The best bang for the buck meter these days is the X-rite i1 Display Pro (called the Display 3 by some). Fast and reliable.
The two big players in the software field these days are ChromaPure and CalMAN. Free HCFR software is available. The 'official' version is no longer supported so it's too old to support the newer Display 3 meter, but there's a non-official/publicly managed version that's available that supports the meter.
Kal
kal is online now
post #3705 of 3719 Old 12-05-2014, 07:39 AM
AVS Club Gold
AV Science Sales 5's Avatar
Quoted: 682 Post(s)
Liked: 534
leave that alone.
Mike Garrett, AV Science Sales Call Me: 585-671-2968
Email Me: Mike@AVScience.com
Brands we sell: http://avscience.com/brands/
Call for B-stock projectors
Stewart, Seymour, SE, SI, Falcon, DNP & more.
RBH, Martin Logan, Triad, Atlantic Tech., MK Sound, BG Radia, SVS & Def Tech, Denon, Marantz & Yamaha .
AV Science Sales 5 is online now
post #3706 of 3719 Unread 12-05-2014, 08:40 AM
cdnscg's Avatar
Originally Posted by AV Science Sales 5 View Post
leave that alone.
Thanks. I did. Saw no reason to reset. Image is pretty clear, just the colour needs calibrating.
cdnscg is offline
post #3707 of 3719 Unread 12-05-2014, 08:47 AM
cdnscg's Avatar
Kal
Thanks kal. Does the X-rite work well with Mac OS X 10.9.5 & 10.10.1? Would you recommend including the X-rite colour checkchecker passport? If I understand correct, i1 has all the software and equipment I would need to calibrate colour, grey scale....
cdnscg is offline
post #3708 of 3719 Unread 12-05-2014, 09:33 AM
zombie10k's Avatar
Quoted: 374 Post(s)
Liked: 401
great news, post some photos of the new HT when you get a chance. That RS55 is a great copy, I hope you enjoy it.
zombie10k is online now
post #3709 of 3719 Unread 12-05-2014, 09:42 AM
zombie10k's Avatar
Quoted: 374 Post(s)
Liked: 401
cdnscg - Can you run windows on this mac? I would suggest looking at a display pro 3 + chromapure. the D3 pro is referenced against an expensive meter and the offsets to make the meter more accurate are built into your software license of chromapure. It's easy to learn the calibration workflow with this software. Just calibrating greyscale alone can make a big difference in overall picture quality.
post #3710 of 3719 Unread 12-05-2014, 11:04 AM
kal
kal's Avatar
Liked: 38
It's the software, not the meter, that works on the OS.
Like Zombie, I recommend (and use) ChromaPure. For full disclosure, I used to sell others but now only sell ChromaPure (because I prefer how the licensing/support works).
Kal
kal is online now
post #3711 of 3719 Unread 12-05-2014, 11:58 AM
cdnscg's Avatar
Kal
So X-rite i1 Display Pro is just the meter (equipment part), and ChromaPure the software. They have to be purchased seperatley.
Does ChromaPure work easily with Mac's? I'm not loading Windows on my computer.
cdnscg is offline
post #3712 of 3719 Unread 12-05-2014, 12:13 PM
kal
kal's Avatar
Liked: 38
They can, but discounted bundles are available too.
Not a native mac version. ChromaPure does run fine on a Mac however, using Windows emulators such as Parallels Desktop or a split partition using Boot Camp.
Kal
kal is online now
post #3713 of 3719 Unread 12-05-2014, 02:16 PM
AVS Club Gold
Quoted: 682 Post(s)
Liked: 534
For those interested in this projector, I would check out a B-stock RS6710.
post #3714 of 3719 Unread 12-05-2014, 02:37 PM
coderguy's Avatar
Quoted: 49 Post(s)
Liked: 152
I would love one, but I don't think you'd take my library card for collateral to "check it out"...
Web Calculator v023 & v025
- Quick Peak at the new upcoming calculator
**Current Projector Calculator** -- http://www.eliteprojectorcalculator.com
Coder's Top Projector Picks of 2012 --http://www.avsforum.com/avs-vb/showthread....
coderguy is online now
post #3715 of 3719 Unread Yesterday, 06:04 PM
cdnscg's Avatar
Kal
Not interested in introducing any Windows system into my mac. Are there products similar to ChromaPure that run on native iOS for mac?
cdnscg is offline
post #3716 of 3719 Unread Yesterday, 09:35 PM
AVS Club Gold
Quoted: 682 Post(s)
Liked: 534
If it had been a Gold library card we could have considered it, but mute point now. All of them are sold.
post #3717 of 3719 Unread Today, 08:27 AM
zombie10k's Avatar
Quoted: 374 Post(s)
Liked: 401
there's no real options for the key applications (Chromapure / Spectracal) other than running a version of windows on the Mac.
We use this all the time at work, it runs as an application, there is less commitment vs. parallels
http://www.vmware.com/products/fusion/features
post #3718 of 3719 Unread Today, 11:28 AM
kal
kal's Avatar
Liked: 38
Not to my knowledge.
Kal
kal is online now
post #3719 of 3719 Unread Today, 12:21 PM
coderguy's Avatar
Quoted: 49 Post(s)
Liked: 152
Wow, that was fast. JVC B-stock deals are the best deal anyone can possibly get on a projector. I want a B-stock x500 next year maybe, hopefully you'll get some in.
It's supposed to be -moot- but I am having trouble hearing you :P
Jvc , Jvc Dla X70 Projector
