Official JVC X30 / RS45 owner's thread! - Page 113 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
Old 05-03-2012, 07:03 PM
fst96se's Avatar
Quoted: 66 Post(s)
Hey all, new RS 45 owner here. This is replacing my Pioneer FPJ1.
The first thing I noticed is even with CMD off, there seems to be a bit of the "soap opera " effect. I personally hate that look. While not really bad, I definitely notice it. Can it be eliminated completely?
I absolutely love the memory lens setting. That is really the only reason why I upgraded from the pioneer. I will be doing a 156" Jamestown/seymourAV screen using the zoom method. This definitely fits the bill!
fst96se is offline
Old 05-03-2012, 07:06 PM
fst96se's Avatar
Quoted: 66 Post(s)
Also, the Peerless I was using doesn't fit the JVC. Any suggestions for a quality, affordable mount?
fst96se is offline
Old 05-03-2012, 10:38 PM
johnifehr's Avatar
Yes, the clear motion drive can be shut off in one of the settings within the menu
johnifehr is offline
Old 05-03-2012, 10:53 PM
fleaman's Avatar
Quoted: 38 Post(s)
Liked: 104
He already shut it off>
fleaman is offline
Old 05-04-2012, 04:36 AM
sanderdvd's Avatar
Quoted: 165 Post(s)
Liked: 30
Originally Posted by Joesyah View Post
Review posted to site now for those without a subscription http://www.hometheater.com/content/j...lcos-projector
from the hometheater.com review:
Most notable is the ability to support a constant image-height screen. Using a 2.35:1 screen provides a wider image area, and the X30 allows you to zoom a 2.35:1 image to fill it while zooming in for a traditional 16 x 9 image. You could also use two screens, depending on how elaborate you want your setup to be. The X30 supports the use of an anamorphic lens with its internal video processing, even with 3D sources, but using the lens memory provides the ability to do a setup that is cheaper than an optional lens. I only had the chance to use the X30 with my 16 x 9 screen, but I did play around with the lens memory function and it worked pretty well. It records all the steps involved with the shift from one position to another, including zoom, focus, and lens shift, so it can take a bit of time to switch.
Does this mean I don t need a anamorphic lens anymore for 2:35:1?!?! Can someone explain in detail, I don t understand.
And another question:
I have a custom cable for the Optoma (MV3D) glasses that make the Optoma (MV3D) emitter+glasses work with the Sony VW95 projector. Will this cable work with the X30?
sanderdvd is offline
Old 05-04-2012, 06:07 AM
gingerman's Avatar
I had good luck with a Premier mount www.mounts.com use the search for the x3 or RS40 and it shows up. I did need to get longer metric screws out of some old bags of tv wall mounts I had around other than that it works perfect.
gingerman is offline
Old 05-04-2012, 07:26 AM
Mike Garrett's Avatar
Quoted: 5649 Post(s)
Liked: 3615
Correct, as long as you have the projector mounted so that you can throw the 16:9 image and 2.34-2.40 image from the projector location, then, yes you can go without a lens. Keep in mind, with the lens, you get the lost pixels in scope movies and added brightness. So I you already have a lens, then use it. A lens is a better set up in my opinion.
mjgarrett100@gmail.com
Mike Garrett is offline
Old 05-04-2012, 08:19 AM
coderguy's Avatar
Quoted: 363 Post(s)
Liked: 300
The smoothing effect is because you are not used to a 120hz projector even with CMD off, because it is multiplying every frame x 5 (24hz x 5 = 120hz) and I believe using 5:5 pulldown.
I don't believe there is a proper way to force the projector to show it at a lower hz without side effects (maybe). You can try watching at 60hz but it will add judder, or try inverse telecine maybe (cmd 5 I think). You will probably get used to 120hz if you just keep watching it.
Access HERE from this thread
coderguy is offline
Old 05-04-2012, 08:27 AM
sanderdvd's Avatar
Quoted: 165 Post(s)
Liked: 30
So the RS45 has an option to only show the 2:35:1 content and not the black bars?
Old 05-04-2012, 09:14 AM
Liked: 3615
Yes and no. The black bars are still there. This is for those with 2.35 to 2.40 scope screens. In this application you are running a CIH (constant image height) setup. Also called the poor man's CIH setup. With a scope screen, you use the height of the screen for setup. In other words, when showing 16:9 content (also 4:3) the height of the screen governs how big the image is. You have unused screen on the right and left hand side. When watching a scope movie, the projector zooms and lens shifts so that the screen is completely filled with image. This means the black bars are above and below the screen. With this method you get a small 16:9 image and a huge scope image. The image is wide, like it is in the theater.
Keep in mind the black bars are still there so you have to be able to deal with them, as in having a dark wall (possibly a dark ceiling) so they do not show up. The only way to get completely get rid of the black bars is to use an A-lens.
Old 05-04-2012, 10:55 AM
fleaman's Avatar
Quoted: 38 Post(s)
Liked: 104
Hmmm....so there's a slight soap opera effect regardless
Not something I wanted to hear
fleaman is offline
Old 05-04-2012, 11:09 AM
fleaman's Avatar
Quoted: 38 Post(s)
Liked: 104
With lens memory I believe you can do something in-between too, correct? Like if you had 2 separate screens, say a drop down 2.32 115" (45x105), and a drop down 16:9 100" (49x87), so not CIH.
fleaman is offline
Old 05-04-2012, 11:26 AM
rjmelkon's Avatar
Sorry if you already did this but do you have sharpness,enhanced detail and
noise reduction all at 0?
rjmelkon is offline
Old 05-04-2012, 02:22 PM
BigM555's Avatar
I purchased this one http://www.tigerdirect.com/applicati...5975&CatId=626 and I've been very pleased with it. Had no problems at all with this one fitting my X30.
BigM555 is offline
Old 05-06-2012, 12:00 AM
sanderdvd's Avatar
Quoted: 165 Post(s)
Liked: 30
My RS45 makes is more noisy then my previous RS25 (normal lamp mode). I have a feeling that something is 'wrong' with the fans or something.
Old 05-06-2012, 12:23 AM
Joesyah's Avatar
Must be..I can't hear mine unless I put my ear next to one of the exhaust vents.
Joesyah is offline
Old 05-06-2012, 02:20 AM
sanderdvd's Avatar
Quoted: 165 Post(s)
Liked: 30
mine is a X30 by the way (europe). Maybe the X30s behave different?
Old 05-06-2012, 02:42 AM
steviedr's Avatar
My X30 is silent, only when I change to high lamp mode can I hear it.
steviedr is offline
Old 05-06-2012, 02:48 AM
sanderdvd's Avatar
Quoted: 165 Post(s)
Liked: 30
then something must be wrong with my X30. I can hear it very good from 3 meters away from it.
Old 05-06-2012, 05:47 AM
RAGARSA's Avatar
My X3 europeo normal lamp mode is a tomb, only hear something so high a ventilation meter.
RAGARSA is offline
Old 05-06-2012, 06:36 AM
Axel's Avatar
Quoted: 73 Post(s)
Liked: 24
Just wondering if your PJ might be running in 3D mode.
That causes the fan on my RS45 to rev up. In this setting or in high altitude/high mode are the only ones I can hear the fan, even if I am right next to the PJ.
One other thought, maybe the ventilation path into or out of the PJ is blocked, causing the unit to heat up. Or a clogged filter?
____
Axel
Axel is offline
Old 05-06-2012, 09:38 AM
avted's Avatar
Make sure your not set to high altitude mode
avted is offline
Old 05-06-2012, 12:10 PM
sanderdvd's Avatar
Quoted: 165 Post(s)
Liked: 30
No, it s not in high altitude mode, not in 3D mode and not in high lamp mode.
Old 05-06-2012, 02:00 PM
Liked: 3615
True, but the black bars are still there on the scope screen. You could actually do three screens. That is probably a little more advanced that what he is asking. Besides, I would have to take a serious look at a 4-way masking screen, before considering going the dual screen route. This is if you are starting from scratch. if you already have a 16:9 drop down screen and considering adding a 2.35, then that would be a pretty good route to go. I hate having a smaller scope image compared to when just watching HDTV.
Old 05-06-2012, 03:43 PM
jimjans's Avatar
My x30 froze with a little square in the right corner i attach a picture this has occured three times just wondering if anyone else has seen this...
Attachment 245689
Attachment 245688
jimjans is offline
Old 05-06-2012, 03:46 PM
Liked: 3615
Attachment 245689
Attachment 245688
First I have heard of this happening. Are you running the latest firmware?
Old 05-06-2012, 04:06 PM
jimjans's Avatar
Yes running the latest firmware
jimjans is offline
Old 05-06-2012, 05:07 PM
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 904
I bet you any amount of money that your HDMI cable is NOT good enough.
After changing my HDMI cable to a monoprice 22awg cable...I've never had that problem again.
Trust me it's a bad HDMI cable...
good luck
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
Old 05-07-2012, 02:02 AM
steviedr's Avatar
This has happened to me a few times.
I have it connected to an amp, the pic would freeze but audio still fine so I knew it was projector. All I do is change the hdmi source on amp (eg sat to DVD and back again) and back to the original and it clears it. NO need to crash projector.
steviedr is offline
Old 05-07-2012, 02:07 AM
steviedr's Avatar
I have a decent hdmi cable as well although it is 12M and updated firmware in February.
But as I have stated, it's not a big deal, simply change the source and back.
Think it's happened 4 times in 160 hrs, I'll pay more attention to it, it only happens when changing source, so maybe on the ps3 and decided to watch a DVD. It has never happened during viewing, which makes me think its some sort of handshake issue?
steviedr is offline
Jvc , Projectors , Sony , Jvc Dla X30b 3d D Ila Projector , Jvc Dla Rs45 Home Theater Projector 1080p Hdmi
