Official JVC X30 / RS45 owner's thread! - Page 150 - AVS Forum
post #4471 of 4473 Old 09-28-2014, 07:17 AM
breadvan's Avatar
Originally Posted by pkarmouche View Post
I don't think any areas are accessible for cleaning, except the bulb compartment. So hopefully you can wipe inside the bulb compartment without removing the whole projector from the mount.
If you search around, there's a thread where someone shows how a hazy film can form on the glass inside the bulb compartment (accessible after the bulb housing is pulled out). As I recall, they reported an increase in sharpness and others even reported better brightness after cleaning- so it would be worth paying attention to cleaning that glass properly while you're at it.
Here it is (post 8526): Official JVC RS40/X3 Owners Thread
When you do pull the blown bulb, it would be interesting to know what version it is, and whether or not it has a "flapper". Maybe a photo of the failed bulb?
Paul
Thanks again, yes sure, will record my bulb replacement journey, although I wish I could use my money elsewhere
breadvan is offline
post #4472 of 4473 Old 09-28-2014, 09:38 PM
breadvan's Avatar
Can anyone confirm:
1. that the correct bulb model for X30 / RS45 is L2210UP ? I got that on JVC USA homepage, the 2210UG is apparently for X3.
2. the latest firmware version for X30 is: Main firmware: V1_1 \ Sub firmware: V1_3 ?
Thanks very much.
breadvan is offline
post #4473 of 4473 Old 09-29-2014, 07:43 PM
breadvan's Avatar
X30 problem continues
Any advice is appreciated.
Took the bulb out last night after the pop heard turning on the PJ Sunday evening thinking it was the bulb, the bulb appeared intact and in perfect condition (to me), so situation could be worst than I thought.
Apparently the bulb has a -003 marking on it while didn't look like there was any 'fin' in the housing to me, pictures attached for those interested.
Pop the bulb back in, plugged back power cord, still no indicator light in front.
Has anyone experienced that before and what was your solution to the problem?
ID:	286506   Click image for larger version
breadvan is offline
Jvc , Projectors , Sony , Jvc Dla X30b 3d D Ila Projector , Jvc Dla Rs45 Home Theater Projector 1080p Hdmi
Gear in this thread - 1080p by PriceGrabber.com
