JVC 2011-2012 lamp measurement project - Page 14 - AVS Forum | Home Theater Discussions And Reviews
post #391 of 391 Old 05-19-2014, 09:36 AM
[Europe]Boogiem's Avatar
Quoted: 31 Post(s)
Originally Posted by NL-MindfluX View Post
Would be definitly worthy to take the following variables in your data:
- bulb serie (rev. 1: QLL0194-001, rev. 2: QLL0194-002, rev. 3: QLL0194-003)
- housing serie (rev. 1: plastic flow tunnel, rev. 2: metal flow tunnel)
- high altitude mode (on, off)
- room temperature
- rooom climate control (yes, no)
- and maybe some coding ratio's for lamp mode use (normal, high)
THANK YOU for that info - I have been lloking for a while how to see which version the lamp for the X30 is and You just made my day since I can see its a v.3 smile.gif
QLL0194-003
metal flow tunnel
I will paste that info into owners thread - thanks again
Boogie
Livingroom: JVC DLA-X30 @ 4m wide curved 2.35:1 Studiotek
Marantz AV7702, Primare A30.7 + Emotiva XPA-5, Oppo BDP-93,PS-3,HTPC, Samsung digital box
JBL TiK Sub, Ti6K, Ti2K, Ti1K, XTi20, XTi10, REL Q150E
Bedroom: Pioneer KRP-500M, Denon AVR3805
QLN 603,601MK2,Wharfdale DFS
[Europe]Boogiem is offline
Jvc Dla Rs45 Home Theater Projector 1080p Hdmi , Jvc Dla Rs55 Bundle , Jvc Pro Dla Rs65u3d Reference Series 3d Home Cinema 4k Projector
