OWNERS thread for Mitsubishi HC7800 - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 371 Old 05-21-2013, 02:09 PM
emix2001's Avatar
Suggestion for everybody: play with gamma settings. Having a grey screen image comes back to life with gamma at 2.0, while is not punchy in cinema mode.
emix2001 is offline
post #272 of 371 Old 06-12-2013, 03:19 PM
fgrosell's Avatar
I just bought a Mitsu HC7800D so few days i´m very interested and also bought the Monster Vision Max 3D .
i understand and i will follow the next steps for convert the MONSTER dongle to 5 pin din, but i thing is better if i read the original page that you mention in your post for that reason
Can you give me more traces of the germany page or the link please, i ¨m very excited for this option and i want use with other 3d lens via the RF.
Thanks in advance for your help and answer
Best Regards
H.Fernando
Fernando GR
fgrosell is offline
post #273 of 371 Old 06-12-2013, 03:21 PM
fgrosell's Avatar
Originally Posted by Shauri026 View Post
Sorry for this double post...
Anyhow, I hope my post helps any fellow HC7800D owners experience a better 3D experience over the craptastical Mitsubishi 3D glasses that are used with the HC7800D.
6/02/13 a las 24:24
Hi, congratulations for your post.
Best Regards
H.Fernando
Fernando GR
fgrosell is offline
post #274 of 371 Old 06-12-2013, 10:23 PM
fgrosell's Avatar
I found it, finally this is the link , i hope help all , have to translate but are amazing the instructions and pictures step by step
http://www.cine4home.de/tests/projektoren/Mitsubishi_HC7800/Brillen/HC7800%20Brillen.htm
H.Fernando
Fernando GR
fgrosell is offline
post #275 of 371 Old 07-08-2013, 01:22 AM
ander77's Avatar
HI
I am a INFOCUS SP8602 happy owner, but since some time ago i have curiosity about this Mits. There are some questions that i would be gratefull if someone can answer.
I would like to know if this Mits has an 2D performance as stunning as INFOCUS. I love INFOCUS white levels, the sharpness and the brightness (FTL). I suppose that Mits blacks levels will be more or less like in the INFOCUS.
Could someone tell me something?
ander77 is offline
post #276 of 371 Old 07-10-2013, 11:31 PM
fgrosell's Avatar
Hi, in the Mits HC7800 the colors are very good, are fine colors in nice flesh tones , you feel the quality of this projector, the image almost always is like a movie theater, the black are not a super backer that i was waiting but are ok if you does a good calibration . I s easy.
I was following this model more than a year. I' had five proectors before this.
Also i have the BenQ w7000 and after a compare this two models, for me in quality color, in tones, in the shadws details the Mitsu looks fine.
I like so much sports like basketball, Tennis and
My son said me " father this is like a Giant Plasma"
I m using now only in 2D in a 110" curved screen and i'm happy
The w7000 is very good but the hc7800 is better hands down.
Sorry owners of the w7000.
Good look
Fernando GR
fgrosell is offline
post #277 of 371 Old 07-11-2013, 01:45 PM
jvh4's Avatar
Quoted: 80 Post(s)
Liked: 46
I started noticing this issue. At times for like 2 seconds. The picture gets really choppy. It seemed like it happened on every puck drop during the hockey playoffs. I started noticing the choppiness or some panning shots and slow motion. This only happens watching cable. Blue rays and streaming are perfect. Comcast denies any fault. Any ideas?
jvh4 is offline
post #278 of 371 Old 07-11-2013, 01:49 PM
jvh4's Avatar
Quoted: 80 Post(s)
Liked: 46
Has anyone successfully built one of those emitter convertors for use with other glasses? I'd be willing to pay someone to make one for me if they have previously done it. Obviously parts and reasonable labor. PM me.
jvh4 is offline
post #279 of 371 Old 07-11-2013, 04:06 PM
fgrosell's Avatar
Yes i did, go to this link and translate .
http://www.cine4home.de/tests/projektoren/Mitsubishi_HC7800/Brillen/HC7800%20Brillen.htm.
Good look
Fernando GR
fgrosell is offline
post #280 of 371 Old 07-12-2013, 07:56 AM
fgrosell's Avatar
Hi, i hope you had seen an read the cine4home link page.
You will see the diagrams how can you build the cable connector for use with the Monster IR to RF converter, also you will see the places where you can buy the cable if you can't do it, but is easy .
I'm using the Optoma lens, with the Monster Converter , the Optoma 3D IR to RF converter and the Monster, are the same product only differents in brand name, you have two options .
I'm using and testing so 10 days ago . I can sent you a cable for the connection with the HC7800 if you buy some one option, any radio technic can do it . But if you like i can send you , i think with $30. I can send by mail a kit of two cables.
My PM is fgrosell@gmail.com
Best regards
H. Fernando
PD
Sorry my english,in Lima, Perú
Fernando GR
fgrosell is offline
post #281 of 371 Old 07-12-2013, 02:10 PM
jvh4's Avatar
Quoted: 80 Post(s)
Liked: 46
Best regards
H. Fernando
PD
Ok I'll take a look. I'm not good soldering but I you think it's easy I'll take a look. Thanks.
jvh4 is offline
post #282 of 371 Old 07-13-2013, 10:33 PM
fgrosell's Avatar
I forgot the glasses that i'm using with the IR to RF 3D Converter enter here : http://www.amazon.com/Optoma-BG-ZF2100GLS-Active-Shutter-Glasses/dp/B008PQJXFO/ref=sr_1_3?ie=UTF8&qid=1373775960&sr=8-3&keywords=Optoma+RF+3D+lens, good look
Fernando GR
fgrosell is offline
post #283 of 371 Old 07-14-2013, 02:30 AM
manoutdoor's Avatar
manoutdoor is offline
post #284 of 371 Old 08-01-2013, 10:57 AM
Skrilla's Avatar
Skrilla is offline
post #285 of 371 Old 08-01-2013, 12:56 PM
Seegs108's Avatar
Quoted: 4201 Post(s)
Liked: 2089
Originally Posted by Skrilla View Post
would these glasses work with the HC7800?
http://www.amazon.com/3DTV-Corp-DLP-LINK-Projectors-Mitsubishi/dp/B004G2VJM6/
No, you need IR glasses. Those are DLP link.
Seegs108 is online now
post #286 of 371 Old 08-20-2013, 11:42 AM
WichitaT's Avatar
I made the monstervision cable thats listed, and also added a female fitting to the cable that the original mits IR emitter will plug into. It works perfectly, and the 7800 has ample power to power both emitters at the same time. At least I didn't have to throw out my mits glasses.....which IMHO....as bulky and awkward as they are...provide the most flawless picture.
WichitaT is offline
post #287 of 371 Old 09-29-2013, 01:23 PM
repair4man's Avatar
I just posted my review of the HC7800. I was surprised that I am the only one to review it. I'd like to see the opinions of others, so please review if you can find the time. Thanks!
Here's the link: http://www.avsforum.com/products/mitsubishi-hc7800d-projector-full-hd-3d-projector
Reynolds:"Not much faith in plan A?"
O'Neill:"Since when has plan A ever worked?"
Stargate SG-1, episode 143, "Evolution"
repair4man is offline
post #288 of 371 Old 11-03-2013, 06:19 PM
Petit-Lion's Avatar
I received my 7800D a few days ago. First, I would like to thank all the folks of this forum for the invaluable knowledge I found here over the years!
It took a long time searching and procrastinating, imagine that the first candidate to upgrade my Infocus IN72 was the Sanyo PLV-Z3000...
Then I refined my requirements to DLP, CFI and... quietness. When the HC7800D came on the market, with 3D as a bonus, I felt my search was over, I had only to wait for an affordable price! The PP refurbished deal (still current) was the deciding factor.
Yes, I like my home made mounts
Then I had to figure out why my unit was sold as "B-stock". Factory packaging, new cosmetic condition, zero hour lamp... When I first powered it, I found an optical flaw at the bottom of the picture (when upside down), and dozens of dead pixels on the sides... The good thing is, most of the dead pixels came back to life after a few hours. Only one stays black now, very close of the right border. With the optical default unnoticeable in normal viewing, and outside of the cinemascope format, I felt happy with my deal! smile.gif
White wall in a white living room: movie nights!
Since the 3D IR emitter blocks all other remotes, including the projector remote, I found that I had to mask at least 90% of the emitter with electric tape to keep my remotes working.
So the question is, would IR glasses (say Xpand X104) work with only one tenth of the emitter lighting power? I don't have any glasses, so I would like to know before to buy either RF emitter and glasses or IR glasses...
Oh, a word about quietness. The HC7800D is as quiet in high lamp mode as the IN72 in low lamp mode. And when in low lamp mode, which is bright enough with BrilliantColor and 3D image setting, the HC7800D is definitely quiet, as quiet as my HTPC, quieter than a Nintendo Wii, and mostly inaudible in a living room environment where I can hear the wall clock. Quietness was an important requirement for me, and the HC7800D delivers!
Petit-Lion is offline
post #289 of 371 Old 11-05-2013, 09:14 AM
CoryW's Avatar
Quoted: 133 Post(s)
Liked: 97
Apparently the Estar kit and glasses work great too as they are the same as the Optima and Monster but cheaper... and they are updated to be better just like the more recent version of the Optomas:
http://www.avsforum.com/t/1489232/optoma-bg-bc100b-3d-rf-emitter-compatable-glasses
Here is the kit for $64:
http://www.amazon.com/EStar-America-ESG6100-RF-3D-Starter/dp/B00D39AUCI/ref=pd_cp_e_3
And here are extra glasses for $54:
http://www.amazon.com/EStar-America-ESG6000-RF-3D-Glasses/dp/B00D341DUQ/ref=pd_bxgy_e_text_y
Cory
Audio: Ascend Acoutics, Sennheiser HD 598, Denon AVR-S710W
Video: JVC DLA-RS400, LG OLED B6, 92" Dark Energy Abyss screen, HTPC/MadVR/Darblet, Samsung UBD-K8500 UHD Player, HDFury Integral
CoryW is offline
post #290 of 371 Old 11-06-2013, 02:08 PM
jvh4's Avatar
Quoted: 80 Post(s)
Liked: 46
Do you need to make a conversion kit for these to work with this projector? Based on info in this thread it seems only the Mitsu glasses work with this emitter.
jvh4 is offline
post #291 of 371 Old 11-06-2013, 11:30 PM
CoryW's Avatar
Quoted: 133 Post(s)
Liked: 97
Yes you have to do the conversion.
Cory
CoryW is offline
post #292 of 371 Old 11-10-2013, 06:21 AM
vallibus's Avatar
Hello all,
I have a Mits HC8000D and would like to try using that work-around solution so I could use RF glasses with the projector. I already have two pairs of Mits IR glasses, so I am particularly interested in WitchitaT's modification. I've looked over the referenced (Cine4Home) website, but I still can't quite figure out what needs to be done cable-wise. Has a step-by-step write-up been done? Can you buy modified cables? I don't mind trying to solder, but I haven't done this kind of thing before. Any suggestions appreciated.
Bruce
vallibus is offline
post #293 of 371 Old 11-10-2013, 08:14 AM
CoryW's Avatar
Quoted: 133 Post(s)
Liked: 97
Originally Posted by vallibus View Post
Hello all,
Bruce
Check out the posts by zombie10k on page 6 of this thread. That is the most I could find about the project other than Cine4home's website. Wish I could find more... I haven't done the project yet either. And I'm curious to see what WitchitaT has to contribute.
Cory
CoryW is offline
post #294 of 371 Old 11-10-2013, 09:51 PM
CoryW's Avatar
Quoted: 133 Post(s)
Liked: 97
Okay, so this shows some of the connection guts on the 5 pin mini-din side of things:
http://www.smartpropoplus.com/dnn/Hardware/ESkyminiDIN/tabid/92/Default.aspx
And this is a nice tutorial on the guts of the 1/8 mini rca:
http://www.wikihow.com/Solder-Stereo-Mini-Plugs
Cory
CoryW is offline
post #295 of 371 Old 11-11-2013, 07:12 AM
vallibus's Avatar
Cory,
Those are excellent resources. I'm beginning to get a glimmering of what needs to be done. By the way, I messaged marketing at Cine4Home and inquired if they sell the modified cable. Or if they don't, who might.
Bruce
vallibus is offline
post #296 of 371 Old 11-11-2013, 07:56 AM
CoryW's Avatar
Quoted: 133 Post(s)
Liked: 97
I found a cable online from the UK made by Belkin. Ordered several of them to share with others if they work. Will keep you posted.
Cory
CoryW is offline
post #297 of 371 Old 11-14-2013, 11:17 AM
schumy's Avatar
whilst i was searching for the MonsterVision RF emitter kit i found the Chinese made IR 3D glasses which can be used with the HC7800 stock IR emitter. The glasses seem to be based on the same construct as the MonsterVision RF glasses hence just a fraction of the stock Mitsubishi 3D glasses' weight and come with built in rechargeable battery etc. Price is also a fraction of the stock ones. Picture quality is just as good. Extremely pleased with the purchase saved me the time and cost with the RF conversion. If anyone is interested I can help out with the ordering and shipping (dont think the Chinese supplier will ship overseas), PM me.
Cheers
schumy is offline
post #298 of 371 Old 11-14-2013, 11:24 AM
schumy's Avatar
watching 3D is no longer a weight lifting exercise smile.gifsmile.gifsmile.gif
BTW does anyone know the weight of the stock Mitsubishi glasses? these aftermarket ones are said to be about 40g.
schumy is offline
post #299 of 371 Old 11-14-2013, 12:50 PM
3dprojector's Avatar
Quoted: 140 Post(s)
Liked: 63
Originally Posted by 3dprojector View Post
I have the xpand x104,and it's working for me,never tried another one,so can't make comparisons.
Am I missing something?
why do you need to go for rf?
3dprojector is online now
post #300 of 371 Old 11-14-2013, 10:36 PM
CoryW's Avatar
Quoted: 133 Post(s)
Liked: 97
Well, for one you don't have to buy the Mitsubishi emitter so that will save a good amount of money. And as you can see above the glasses are only around $55 and the set with the emitter and a pair of glasses is $65... so we are looking at a very cheap emitter.
I also heard that RF doesn't lose brightness that IR glasses lose... so maybe they are brighter. I believe the Cine4home review used the 1st generation Optoma / Monster glasses. There is a second edition that is supposedly brighter and lighter.
OLD DESIGN:
http://www.amazon.com/Optoma-Technology-BG-3DRFGLASSES-Rechargeable-Glasses/dp/B005JRMLVK/ref=pd_sim_e_1
http://www.amazon.com/MonsterVision-radiofrequency-compatible-BG-ZF2100GLS-emitter-see/dp/B0091W97PM/ref=pd_sim_e_3
NEW DESIGN:
http://www.amazon.com/Optoma-BG-ZF2100GLS-Active-Shutter-Glasses/dp/B008PQJXFO/ref=pd_sim_e_4
http://www.amazon.com/EStar-America-ESG6000-RF-3D-Glasses/dp/B00D341DUQ/ref=pd_cp_e_2
And lastly, if the Belkin cables I had imported here (should be here next week hopefully) works, then there is zero hassle or soldering necessary! Will keep you posted.
Cory
CoryW is offline
Sony Vpl Hw30es 300 Inch 1080p Front Projector , Mitsubishi Hc7800d Projector Full Hd 3d Projector
