NEC MT830+ Banding (Official Troubleshooting Thread) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 12-20-2011, 03:20 PM - Thread Starter
2 Bunny's Avatar
Hey there, I've got a NEC MT830+ with some banding going on on the left and right sides, pictured in this post that I made in the wrong forum section. I originally thought it was a bad LCD panel or misaligned mirror, but I found that if I use the setting in the menu that flips or mirrors the image for ceiling or rear mounted projectors, it actually will instantly make the problem significantly worse, but then can be instantly put back to the way it was pictured by disabling the flip/mirror settings.
Any ideas?
- 2B
2 Bunny is offline
post #2 of 17 Old 01-02-2012, 02:49 PM - Thread Starter
2 Bunny's Avatar
Any updates on this?
- 2B
2 Bunny is offline
post #3 of 17 Old 01-09-2012, 04:25 PM - Thread Starter
2 Bunny's Avatar
- 2B
2 Bunny is offline
post #4 of 17 Old 01-28-2012, 01:56 PM - Thread Starter
2 Bunny's Avatar
- 2B
2 Bunny is offline
post #5 of 17 Old 02-03-2012, 12:04 PM - Thread Starter
2 Bunny's Avatar
- 2B
2 Bunny is offline
post #6 of 17 Old 02-10-2012, 12:23 PM - Thread Starter
2 Bunny's Avatar
Anybody know anything about what might be causing this?
- 2B
2 Bunny is offline
post #7 of 17 Old 03-03-2012, 09:26 AM - Thread Starter
2 Bunny's Avatar
- 2 Bunny
2 Bunny is offline
post #8 of 17 Old 04-20-2012, 11:49 AM - Thread Starter
2 Bunny's Avatar
- 2 Bunny
2 Bunny is offline
post #9 of 17 Old 04-20-2012, 12:00 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Originally Posted by 2 Bunny View Post
Any ideas?
- 2B
Time for a new projector!
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #10 of 17 Old 04-22-2012, 04:51 PM - Thread Starter
2 Bunny's Avatar
Maybe I should've been more clear - I'm not looking to buy a new projector, just to possibly fix this one. If anyone has any ideas for that, it would be greatly appreciated.
- 2 Bunny
2 Bunny is offline
post #11 of 17 Old 05-23-2012, 08:29 AM - Thread Starter
2 Bunny's Avatar
- 2B
2 Bunny is offline
post #12 of 17 Old 05-23-2012, 01:11 PM
New projector. Why? It would cost you WAY more to fix that then repair it, and it is extremely outdated.
AV Science Sales 3 is offline
post #13 of 17 Old 05-23-2012, 07:09 PM - Thread Starter
2 Bunny's Avatar
May be, but I'm not really looking for a new one.
- 2B
2 Bunny is offline
post #14 of 17 Old 02-05-2014, 04:24 PM
Channel 2012's Avatar
Quoted: 27 Post(s)
I was wondering the same thing myself, anyone have any ideas what causes the "banding" on one of those projectors?
Channel 2012 is offline
post #15 of 17 Old 02-05-2014, 05:50 PM
neonsky's Avatar
The same thing that causes the magenta stripes on the JVCs and the Epsons, the panel(s) have prolly been damaged from heat or age. Do a search and you'll see countless examples.
neonsky is offline
post #16 of 17 Old 02-11-2014, 05:10 PM
Quoted: 27 Post(s)
They aren't like the "JVC Magenta stripes". Those stripes kind of fade in from the edge, but the lines on mine are very exact in their position. It's okay if it can't be fixed, I was just hoping to find out if anyone knew what causes this particular problem since I couldn't find any other mention of it on the internet.
post #17 of 17 Old 02-11-2014, 05:14 PM
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2581
If it's the way you describe it's most likely a bad video processing/control board or the LCD panels themselves. As others have pointed out, don't try to fix it. For the amount of money it would cost, you can get a higher performance, newer machine with a warranty.
Seegs108 is offline
