Official BenQ W7000 Owners Thread - Page 128 - AVS Forum | Home Theater Discussions And Reviews
post #3811 of 3833 Old 09-11-2014, 10:42 PM
jlpowell84's Avatar
Quoted: 843 Post(s)
Liked: 336
Well I have a a little time with this unit and coming from a very brief time with the Ben Q 1070 it is quit a bit better. I am not any where near the experience levels with projectors I have read about recently nor have I been through 30 units like AVS member SEEGS I think it was lol. Props to him for wheeling and dealing to get what he wants Anyway The picture in general is much more defined. Shadow detail is better and the crisp sharp picture teamed with my Oppo with Darbee processing makes for a picture that is not far behind my plasma I replaced. Black levels are not to a satisfying level but livable for sure to get this image size. I would say just a little better than the 1070, noticeable but not a big jump at all. So I am happy for what I payed with 600 lamp hrs and 4 pairs of 3D glasses. I will snag a couple bulbs and roll with this guy for as long as I can. I am looking into a square trade warranty for some coverage. I can hear the fan going mildly and the high pitch sound comes and goes but is really only noticeable when no audio is going. No audio is playing now and I just hear the fan. But I always have a "slight" ringing in my ears. Nothing bad but perhaps just enough to block it out. I only notice it if I think about it. Anyways obviously I am no professional reviewer but for what I payed I am very happy with this unit. And after I get past the led tv level blacks the picture is pretty dang good! I will roll through my Spears and Munsill video calibration disc in the next couple of days. If I labeled one complaint it would be the sharpness only having settings of 3-4 increments of change. A much more gradual change seems like it would be better.
PSN ID: Jlpowell84
DIY Sound Group Volt 10 surround speaker build
http://www.avsforum.com/t/1531107/di...axial-speakers
My Setup Thread
http://www.avsforum.com/forum/19-ded...4-s-setup.html
jlpowell84 is offline
post #3812 of 3833 Old 11-27-2014, 04:39 PM
astrogeeker's Avatar
well, my w7000 seems to have bought the farm after about 2 years.. was working fine last night, then today it powers up, shows a brief (5 second) low light purple screen, then goes dark. The fan comes on, and it looks like its working but no picture at all. Have tried several reboots but same behavior. Anyone have any ideas? Is this indicative of a frozen iris? Thanks for any help.
astrogeeker is offline
post #3813 of 3833 Old 11-28-2014, 01:09 AM
coderguy's Avatar
Quoted: 61 Post(s)
Liked: 163
@Astrogeeker
Could be the IRIS problem...
Can you still access the menu while the screen is all black?
Have you tried a different source on a different HDMI port?
Have you tried a VGA source or something separate from HDMI completely?
There might be a way to factory reset the projector by holding buttons down while it boots instead of just using the service menu, but I am not sure what the method is.
Do you have a spare lamp to try?
(just thinking if the lamp were overheating due to it being bad, the PJ might be going into some kind of suspend mode)
@jpowell
On 2 Benq's that I have seen, the IRIS noise goes away after 1000-2000 hours, some might take a little longer. Mine was pretty loud at first and so was another guy's in here, and both of ours are silent now.
Web Calculator v023 & v025
- Quick Peak at the new upcoming calculator
**Current Projector Calculator** -- http://www.eliteprojectorcalculator.com
Coder's Top Projector Picks of 2012 --http://www.avsforum.com/avs-vb/showthread....
coderguy is offline
post #3814 of 3833 Old 11-28-2014, 09:06 AM
nope, can't access the menu at all. tried HDMI2, but not VGA yet, will try that but i'm thinking its busted.. looks like Benq tech support takes friday after thanksgiving off, so it'll have to wait till monday to talk to them.
i did look for a way to reset via the function keys.. but i don't see anyone posting a way to do that.
thanks
post #3815 of 3833 Old 11-28-2014, 11:17 AM
talon95's Avatar
Quoted: 27 Post(s)
Liked: 25
Does the lamp stay on? Can you see some light coming through the lens after the blue/purple screen disappears?? I assume the lamp is still good since you get some light at the beginning. Can you hear the iris working when the purple screen disappears? Did you cut power to it (pull the chord)?
talon95 is offline
post #3816 of 3833 Old 11-28-2014, 11:55 AM
jlpowell84's Avatar
Quoted: 843 Post(s)
Liked: 336
@Astrogeeker
@jpowell
Nice, I don't notice it anymore. I love everything about this PJ besides black levels. It is a little distracting TBH but movies are still immersive.
Toe likes this.
PSN ID: Jlpowell84
My Setup Thread
post #3817 of 3833 Old 11-28-2014, 04:13 PM
-yes lamp stays on
-yes i can see a very small amount of light coming through.. looks like a rainbow if i look directly into it
-don't hear the iris working
-did not cut the power to it
post #3818 of 3833 Old 12-02-2014, 05:49 AM
memmo's Avatar
Quoted: 61 Post(s)
Liked: 50
I wonder if anyone has any ideas...
A friend has a W7000 that is currently not working that he is willing to donate to me. He went to change the lamp a few months ago and didn't have any luck -- infact he's now left the the "lamp issue" red light on at all times. He suggested that changing the bulb is rather cumbersome and he figures he either bent or damaged something as both his old lamp and new lamp result in the same error. I'm going to pick it up from him next weekend to see if I can get it going -- wondering if anyone might have any advice on what I can look out for?
The Big Bay Home Theater Build Thread
My personal theater build on Kempenfelt Bay, Barrie Ontario Canada
memmo is offline
post #3819 of 3833 Old 12-02-2014, 06:15 AM
dfarina's Avatar
I had a spare lamp that I decided to use due to the fact my original lamp was getting dim and the picture was getting a little washed out(hoping it's the lamp).After installing the new lamp I had no picture,and there was no light whatsoever coming out of it,thought possibly I had installed it wrong,so I redid the whole process with the same results(no light).Put my old lamp in and it is working like before,so my new lamp had to be defective.I contacted the retailer I purchased the lamp from(MyProjectorLamps)and to there credit they offered to send a new lamp even though it was out of warranty without having to even return the deffective lamp.Just wanted to show how good there customer service is,hoping the new lamp will get my W7000 back to its new picture quality.
dfarina is offline
post #3820 of 3833 Old 12-08-2014, 03:35 PM
dfarina's Avatar
I put the new bulb in and what an incredible difference!!!The contrast and brightness is a night and day difference,not sure how many hours were on my old bulb due to the fact I reset my projector in my time with it a few times.Benq rates the lamp life at 2000 hours and I suspect that's the time when the bulb starts losing its contrast and brightness,I probably had more than 3000 hrs on my old bulb,but wow what an amazing change.
dfarina is offline
post #3821 of 3833 Old 12-08-2014, 07:09 PM
coderguy's Avatar
Quoted: 61 Post(s)
Liked: 163
Originally Posted by astrogeeker View Post
-yes lamp stays on
That really sucks, sorry to hear that. I always dread an expensive electronic piece going out right after the warranty.
Is it completely out of warranty?
Did you buy it on a credit card, most CC's extend it another year?
(oh though I think MFR warranty was only 1-year on the w7000 huh)
See how much Benq would charge you for a diagnostic?
If it's too much, and as a LAST RESORT - I suppose I could take a look at it for you if you've exhausted all other possibilities and try to reset it, but you'd have to send it with a new lamp first (you can get them online for like $80).
If you want to ship it to me PM me and I will try to reset it for you and then ship it back. Since I have another Benq w7000 here, I might be able to figure something out by troubleshooting. I would not normally offer this, but if I were in your shoes, I'd be a bit upset at having a throw-away unit right after 2 years.
coderguy is offline
post #3822 of 3833 Old 12-13-2014, 02:00 PM
memmo's Avatar
Quoted: 61 Post(s)
Liked: 50
Anyone have an old (but working) lamp they'd sell me cheaply? I'm trying to figure out if a w7000 is pooched or if it's the 2 lamps I have here. When I turn it on, fans come on but then I get the yellow power light and red lamp light on both lamps.
memmo is offline
post #3823 of 3833 Old 12-16-2014, 08:06 PM
jlpowell84's Avatar
Quoted: 843 Post(s)
Liked: 336
Nice! I have like 750 lamp hours on mine. 9ft viewing distance on a 93 inch solid surface screen. PJ sits like 11.5 throw distance. Brightness is crazy!
PSN ID: Jlpowell84
My Setup Thread
post #3824 of 3833 Old 12-19-2014, 07:01 AM
well BENQ stepped up and RMA'd it free of charge, other than the $100 shipping to CA (insured).. it was the iris, and even though it was out of warrantee they fixed it free so hard to complain.. thanks for the offer though. one thing i *THINK* i notice now is that its back is the picture is generally dimmer. need to play with the settings some more.
post #3825 of 3833 Old 01-06-2015, 08:22 AM
kuebler's Avatar
Question Anybody knows something brighter?
I'm happy with my Benq W7000 PJing to an High Power 160" screen. But only in 2D.
With an absolutely new lamp it is just bright enough in 3D, but doesn't keep so long, and shuffling lamps is a nuisance for me and my credit card.
I'm aware of the fact, that 3D is no longer an overly interesting business for the industry, so new and improved developments are probably rare, if any at all. But does anybody know something, maybe from the current CES?
The PJ should be able to project at about the center axis of the screen, so probably a lens shift is unavoidable.
I would prefer a DLP model, but as there may not exist so many with DLP, 3D and lens shift, I would also bite the bullet and accept LCD.
Any help highly appreciated.
Falk Kuebler
kuebler is offline
post #3826 of 3833 Old 01-06-2015, 04:40 PM
Steven414's Avatar
Quoted: 32 Post(s)
Originally Posted by kuebler View Post
I'm happy with my Benq W7000 PJing to an High Power 165" screen. But only in 2D.
I'm aware of the fact, that 3D is now longer an overly interesting business for the industry, so new and improved developments are probably rare, if any at all. But does anybody know something, maybe from the current CES?
Well, that is a pretty huge screen for the 7000 to fill. You start to lose a lot of quality on anything over 140" with this PJ. I can see how that would render your 3D pretty much usless. There are other PJ's out there that would fit the bill for you, but they're going to cost! Sony has a couple to choose from.
Steven J
Steven414 is online now
post #3827 of 3833 Old 01-06-2015, 11:07 PM
kuebler's Avatar
You're quite exactly right!
At about 130" diagonal the 3D brightness is reasonable, while at 160" (as it is de facto in 2D) it feels pretty dark. Although the room is completely light controlled, and the HP screen characteristics are not bad.
But while 130" may sound reasonable, it is subjectively not. When everybody is used to the immersion feeling of the beautiful 160" 2D picture, then watching a "mere" 130" feels like a significant step back, adding negatively to already being forced to glasses. My wife already opposes 3D when the kids still want it.
Which ones do you think offer a significant step forward in effective 3D brightness, while maintaining a bearable price/performance ratio (but not measured in 3D fanatics terms)?
Falk Kuebler
kuebler is offline
post #3828 of 3833 Old 01-11-2015, 02:20 PM
kuebler's Avatar
Has ever anybody experimented with a brighter lamp?
On my bulb replacement box they state: "UHP E21.7 250/300"
On Amazon I can find this one, but also one described as "UHP E21.7 1.3 264/330"
I suppose that E21.7 stands for the physical dimension, which would make it compatible, if correct.
Has ever anybody experimented with a brighter lamp in this projector, of if not in the W7000, in a comparable PJ for judging what would happen?
Falk Kuebler
kuebler is offline
post #3829 of 3833 Old 03-23-2015, 08:02 AM
as i previously posted, my iris died at around 900 hours. i got it repaired by benQ, but ever since i got it back, the picture seems 'darker' or 'faded'. i did another WoW disc calibration, but it just doesn't seem as bright/colorful as i remember it. could my bulb need replacing after less than 1000 hours?
post #3830 of 3833 Old 03-24-2015, 09:04 AM
Steven414's Avatar
Quoted: 32 Post(s)
My bulb went over 2000 hrs before it grew noticeably dimmer. I would think its 'unlikely' that your bulb suddenly went dimmer after the repair. Unfortunately the only way to know for sure is to try a new bulb. Amazon has the bulb without the housing for $112. Not hard to replace.
Steven J
post #3831 of 3833 Old 03-27-2015, 05:34 AM
theaccent's Avatar
Hi All,
Does anyone know how to enable the 12v trigger on this projector, I have looked through the normal menu and the service menu but can't find anything...
theaccent is offline
post #3832 of 3833 Old Yesterday, 12:09 PM
jlpowell84's Avatar
Quoted: 843 Post(s)
Liked: 336
I am going to be putting up my W7000 for sale soon if anyone knows anyone
PSN ID: Jlpowell84
My Setup Thread
post #3833 of 3833 Old Today, 06:46 AM
Steven414's Avatar
Quoted: 32 Post(s)
What are you asking for it?
Steven J
Benq , Projectors , Benq W7000 Home Projection System , Dlp Projector 2000 1080p
Gear in this thread - 1080p by PriceGrabber.com
