Official BenQ W7000 Owners Thread - Page 129 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #3841 of 3867 Old 11-12-2015, 05:54 PM
Liked: 0
manual for benq w 7000
I need a a service manual for a benq w 7000
stugazz is offline
post #3842 of 3867 Old 11-12-2015, 05:58 PM
Liked: 0
service manual
sorry I don't know how to navigate this site I need a service manual for this benq w7000 can anyone direct me to where I can possibly find one thank you
stugazz is offline
post #3843 of 3867 Old 11-12-2015, 06:06 PM
Steven414's Avatar
Quoted: 43 Post(s)
The link below will get you to to a manual
www.manualowl.com/p/BenQ/W7000/Manual/150856
Steven J
Steven414 is offline
post #3844 of 3867 Old 12-28-2015, 07:28 PM
BigBreaker's Avatar
Heard a big pop on startup then had red light
I ordered a replacement bulb. Would a blown lamp do that? Or is something more serious? I don't remember how many hours it had. 1200? Seems low but maybe I am misremembering.
BigBreaker is offline
post #3845 of 3867 Old 12-29-2015, 12:56 PM
Steven414's Avatar
Quoted: 43 Post(s)
Seems my picture is suddenly out of horizontal square. I'm shooting on a 125" screen and one end is an inch and a half shorter than the other. I know the keystone adjusts the vertical square, but is there any way to adjust the horizontal?
Steven J
post #3846 of 3867 Old 01-08-2016, 06:50 AM
kuebler's Avatar
Hi,
after using my trusted W7000 for years, I would hope that from Benq (or someone else) meanwhile a brighter 3D DLP machine gets available.
Does anyone know about new models, e.g. introduced at CES? Thanks a lot for hints.
Falk Kuebler
kuebler is offline
post #3847 of 3867 Old 01-08-2016, 01:37 PM
Steven414's Avatar
Quoted: 43 Post(s)
I don't think anyone hangs out here anymore. It's become a lonely thread.
Steven J
post #3848 of 3867 Old 01-08-2016, 01:40 PM
kuebler's Avatar
Thanks for caring... But a week ago someone other than you did a post here.
Anyway... Can you give me a hint how I can find out, whether something brighter than the W7000 has become introduced? But with otherwise similar features?
Falk Kuebler
kuebler is offline
post #3849 of 3867 Old 01-08-2016, 01:54 PM
Steven414's Avatar
Quoted: 43 Post(s)
Well, I know BenQ has a couple of newer models with higher lumens than the W7000. One is the HT1085ST model which is 2200. Can't remember what the other is. You could always get a higher gain screen, but you would sacrifice some dark levels in 2D.
Steven J
post #3850 of 3867 Old 01-08-2016, 01:58 PM
kuebler's Avatar
The W7000 has 2'000, so that isn't a real difference. And AFAIK only the 7000/7500 series do have full lens shift.
I'm using a High Power screen, so that should be as much gain as is reasonable for quality viewing.
Falk Kuebler
kuebler is offline
post #3851 of 3867 Old 01-08-2016, 02:23 PM
Steven414's Avatar
Quoted: 43 Post(s)
How much are you willing to spend? There are plenty of brighter PJ's out there if money is no object. Or you could go duel PJ's. Omega Optical offers a 3D dual projection kit which allows you to use passive glasses that aren't as dark as active. I'm waiting on laser PJ prices to drop, which might be a while yet.
Steven J
post #3852 of 3867 Old 01-08-2016, 02:32 PM
kuebler's Avatar
Not really much more than 2'000 bucks, and experiments like dual PJs have got out of my aging enthusiasm's reach. And I prefer DLP.
My W7000 is reasonable enough, but only with a fresh bulb, and I thought that after a couple of years there might have been some technology update. But apparently 3D now has got totally out of mainstream...
Falk Kuebler
kuebler is offline
post #3853 of 3867 Old 01-08-2016, 03:02 PM
Steven414's Avatar
Quoted: 43 Post(s)
You could use duel W7000's. You already have one, you would just have to buy one more! I can relate to DLP's... love'em for 3D, and I am a 3D enthusiast.
I see 3D as still alive and well. A lot of PJ's still support it and plenty of 3D movies being released. I think it still in it's infant stage and will only get better. Won't be too much longer and we'll see glasses free 3D. It's already in the works.
Steven J
post #3854 of 3867 Old 01-09-2016, 02:38 AM
coderguy's Avatar
Quoted: 207 Post(s)
Liked: 235
The newer JVC's actually have brighter 3D than the Benq w7000, even though they are not brighter overall. The JVC RS-400/500/600 has reached a new pinnacle of 3D quality for any non-DLP, I think everyone now prefers the newer JVC over their DLP's for 3D easily.
The JVC beats any bright DLP in image quality hands down, I don't think you'd prefer a DLP over a JVC if you saw a new JVC. I seriously doubt it, but they are a bit on the pricey side, but the RS-400 isn't that much more than some of the Benqs were at one point in time.
Access HERE from this thread
OLD --- Coder's Top Projector Picks of 2012 --http://www.avsforum.com/avs-vb/showthread....
coderguy is offline
post #3855 of 3867 Old 01-09-2016, 05:08 AM
kuebler's Avatar
Thanks for jumping in. This has given me the opportunity of researching a little bit and making my mind of what I might really want.
I came to the conclusion that - other than in my ancient enthusiast's time - I don't really want to undertake efforts in changing my rusty setup, with which I still feel reasonably comfortable.
So my best chance is to more often change bulbs, for getting the initial brightness which is sufficient even in 3D. In 2D I have plenty of brightness, and thus for my relative rare 3D viewing I can swap a second alternative lamp module with a fresh bulb.
But perhaps someone can point me at the hidden risks of getting a sub-par non-original bulb. Where do I get the cheapest original bulb? Not the complete W7000 lamp replacement module, but just an original bulb. Phillips or Osram or such. Thanks for any hint.
Falk Kuebler
kuebler is offline
post #3856 of 3867 Old 01-09-2016, 08:43 PM
coderguy's Avatar
Quoted: 207 Post(s)
Liked: 235
You can get them on Amazon or Ebay, but you have to be careful that you are buying the real thing.
You should be able to get a used JVC RS-400 in a year or two for around $2200 or so with a square trade warranty.
coderguy is offline
post #3857 of 3867 Old 01-10-2016, 04:02 AM
kuebler's Avatar
Yeah, that's exactly why I'm asking. From you as a JVC guy I cannot expect experience with W7000 bulbs, but maybe some W7000 owner here can chime in?
Falk Kuebler
kuebler is offline
post #3858 of 3867 Old 01-10-2016, 04:05 AM
coderguy's Avatar
Quoted: 207 Post(s)
Liked: 235
lol, I own the w7000 as well. A lot of the IRIS posts and measurements in this thread were done by yours truly.
kuebler likes this.
coderguy is offline
post #3859 of 3867 Old 01-10-2016, 04:08 AM
kuebler's Avatar
Uups, sorry...
Falk Kuebler
kuebler is offline
post #3860 of 3867 Old 01-14-2016, 09:10 PM
boulder_bum's Avatar
Quoted: 48 Post(s)
Not sure if anyone will respond, but where exactly can you get updated firmware (and how do you install)?
My Google-fu is failing me at the moment.
boulder_bum is offline
post #3861 of 3867 Old 01-14-2016, 11:34 PM
kuebler's Avatar
My own experience may be outdated, and it may not be valid for your country. But I had several Wx000 PJs, and one couldn't do a firmware update by oneself. Instead after calling Benq service and getting an RMA number I had to ship it to a service station, where they updated the firmware. Free of charge, but shipping to the service station was mine.
This applied only to situations, where Benq considered the firmware update as essential for good operation. But that was always the case.
I doubt however, that the W7000 has got a firmware update since some eternity...
Falk Kuebler
kuebler is offline
post #3862 of 3867 Old 01-15-2016, 11:48 AM
Steven414's Avatar
Quoted: 43 Post(s)
Kuebler is correct. No new updates available for W7000.
Steven J
post #3863 of 3867 Old 01-15-2016, 12:23 PM
Quoted: 48 Post(s)
I may have version 1.00 firmware and I'm trying to make sure I get 1.03. I need to figure out how that process works, since I couldn't find any downloads online.
post #3864 of 3867 Old 01-15-2016, 01:27 PM
kuebler's Avatar
Just 3 posts back...
Falk Kuebler
kuebler is offline
post #3865 of 3867 Old 01-15-2016, 02:03 PM
Steven414's Avatar
Quoted: 43 Post(s)
I cant' remember exactly where it's at off the top of my head, but there's a way to see what firmware version you have in the menu. I do remember it's not hard to find. Just scan through menu and you should find it.
Steven J
post #3866 of 3867 Old 01-15-2016, 05:22 PM
Quoted: 48 Post(s)
I did see that. Thanks for the response!
I was actually hoping that the procedure was different in the US.
It does show 1.00 in that menu, I just read elsewhere that what it says might not be accurate in some cases (you might actually have 1.03 and see the same thing, for example).
post #3867 of 3867 Old 01-16-2016, 09:41 AM
kwk2293's Avatar
Quoted: 33 Post(s)
Liked: 25
If u have a benq w7000+ the firmware should be 1.00 if u have a benq w7000 the firmware should be 1.03 u need to check and see which model u have
kwk2293 is online now
Benq , Projectors , Benq W7000 Home Projection System , Dlp Projector 2000 1080p
