Official BenQ W7000 Owners Thread - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #451 of 3883 Old 02-13-2012, 09:19 PM
ETK
ETK's Avatar
I got my firmware 1.0 W7000 last week. The 1080p/24 flicking bug in firmware 0.28 is fixed. I can't distinguish the black level things between these 2 versions. And I'm happy with the image quality.
The 2D->3D mode switching time is never a problem for me since ver 0.28 firmware when I turn off "auto search" for image source. It takes about 4~5 seconds for both versions.
I prefer the normal mode than cinema mode for more image detail.
If the image clarity is set over 2 , there are white edges appears at black objects ( clothes , paints ...etc.). So I just set clarity control to 1 or 2.
The dynamic mode which using original lamp color is with too much greenish tint. By changing to "warm color" , the image looks good. ( But I think the luminance may also dropped ... Anyway , it's bright enough for the default 3D mode. I don't use dynamic mode for watching movie at all...)
And the optoma ZD201 DLP link 3D glasses is much more comfortable than BenQ's solution with the same image quality. No ghost for 3D at all , and no rainbow observed for me and all my families. I'm very happy with my W7000. ^___^
ETK is offline
post #452 of 3883 Old 02-13-2012, 10:50 PM
WynsWrld98's Avatar
Quoted: 280 Post(s)
Liked: 106
I've read a lot of good feedback about the Optoma ZD201 glasses but they're not sold in the U.S. and apparently Optoma has no plans of selling them in the U.S. from postings here on the AVSForum about them. To make a long story short I bought a pair of the ZD201s in anticipation of buying a W7000 but due to the problems/delay in fixes for the first release of the W7000 I ended up buying an Epson 6010 which is LCD and have no use for the glasses. Anyway I just posted the ZD201s for sale on the AVSForum Classifieds if anyone is interested in buying a pair. They're brand new/factory sealed and had to be imported since not sold in the U.S.
WynsWrld98 is offline
post #453 of 3883 Old 02-14-2012, 06:17 PM
ie50dennis's Avatar
Can you make any adjustment in the 3D mode to increase brightness above the reported 1100 lumens?
ie50dennis is offline
post #454 of 3883 Old 02-14-2012, 06:43 PM
ie50dennis's Avatar
When in 3D, can you select any of the Modes: Cinema, Dynamic, Standard, User 1, User 2, User 3 ... as you can with the Sharp XV-Z17000.
post #455 of 3883 Old 02-15-2012, 08:25 AM
SOWK's Avatar
Quoted: 468 Post(s)
Liked: 360
What are the real lumens on this thing?
Projector Reviews is saying over 1500 calibrated in user 1 mode. Is this true?
But in cinema mode only around 1000?
Projector central review.
SOWK is offline
post #456 of 3883 Old 02-15-2012, 09:13 AM
Toe
Toe's Avatar
Quoted: 1453 Post(s)
Liked: 1832
Can you switch between high and low lamp in 3d?
Toe is offline
post #457 of 3883 Old 02-15-2012, 06:34 PM
ol2
ol2's Avatar
Does anyone have a W7000 with Firmware 1.00-3?
Have the issues with switching into 3D mode been corrected?
ol2 is offline
post #458 of 3883 Old 02-15-2012, 08:05 PM
jmalto's Avatar
Originally Posted by Deja Vu View Post
See post 1874 in this link.
http://www.avsforum.com/avs-vb/showt...382091&page=63
Do you recall seeing any negative consequences of using DLP Link glasses with the W7000? Are DLP Link glasses the only ones you can use with the W7000?
I believe DLP-Link only but I am not 100% positive but don't take it to the bank. I think this was discussed earlier in the thread.
I personally do not like DLP-Link but it is all preference. If I recall correctly,the BenQ introduces a red signal like my older Samsung TV to get the DLP-Link to sync up which may have an impact on calibrating the 3D modes. My buddy is ready to pull the trigger on a gaming 3D projector and I will be getting this for him in the next couple of days so I will get to see what BenQ has improved in the firmware. I am pretty much waiting on Mark to tell us they are back in stock.
jmalto is offline
post #459 of 3883 Old 02-17-2012, 07:40 PM
Ruined's Avatar
Quoted: 263 Post(s)
Liked: 82
The BenQ is DLP Link only, and DLP Link does introduce color issues - HOWEVER, if you buy the right glasses they have color correction that negates these issues.
For instance, the popular XPAND glasses *DO NOT* have dlp link color correction, not even the x102s. So they look terrible.
On the other hand the OPTOMA BD-ZD101 which you can get on amazon *DO* have DLP link color correction and look spectacular.
So, bottom line is as long as you get the right glasses DLP link works great, and IMO better than IR due to DLP link's far better coverage/range.
Ruined is offline
post #460 of 3883 Old 02-18-2012, 06:02 AM
JerryW's Avatar
Quoted: 24 Post(s)
Liked: 36
Aren't there at least two kinds of dlp-link? One version that uses white flashes and another that uses red flashes? If that's the case, won't there be two kinds of color correction too? Has anyone determined what color flashes the w7000 uses?
Copyright is not property, it is merely a temporary loan from the public domain.
JerryW is offline
post #461 of 3883 Old 02-18-2012, 06:51 AM
Ruined's Avatar
Quoted: 263 Post(s)
Liked: 82
Perhaps, I wasn't aware there were multiple types of DLP Link (I thought it was a standard - you'd think optical sensor on dlp link glasses would not work if it varied). If there are multiple types, then yes again you'd need the right glasses for the right proj.
I know the Optoma DLP LINK glasses work well for color correction of Optoma and Mitsu DLP Link, I have no idea about BenQ though.
Ruined is offline
post #462 of 3883 Old 02-18-2012, 01:53 PM
trgraphics's Avatar
I use the Optima glasses and they seem to reduce the red tint quite well. It's fairly easy to tell by covering the sensor. I an quite happy with those glasses.
On a side note. I am using the lenses from a spair pair of glasses that I glued to the inside of the Optima glasses so I don't need to wear glasses while viewing 3d. It made a huge difference in comfort and you can't see the lenses while wearing them.
trgraphics is offline
post #463 of 3883 Old 02-18-2012, 04:15 PM
JerryW's Avatar
Quoted: 24 Post(s)
Liked: 36
Are you confirming that the w7000 uses red flash instead of white flash for dlp-link?
JerryW is offline
post #464 of 3883 Old 02-18-2012, 04:17 PM
trgraphics's Avatar
I don't know for certain, but it certainly appears that way.
post #465 of 3883 Old 02-18-2012, 04:23 PM
WynsWrld98's Avatar
Quoted: 280 Post(s)
Liked: 106
A pair of top-rated Optoma ZD201 DlpLink 3D glasses are for sale in the Front Projector section of the AVSForum Classifieds if anyone wants to buy some and report results with the W7000. These glasses are not sold in the U.S.
post #466 of 3883 Old 02-18-2012, 05:21 PM
HiFiFun's Avatar
Art took a first look at the 7000 with the new firmware and noticed a marked improvement in the black level. The complete updated review is still a few days off.
http://www.projectorreviews.com/blog...els/#more-1610
Hopefully all the 3D projectors will improve upon black level and contrast. Congratulations to Art for seeing this through and reserving judgement for many weeks.
HiFiFun is offline
post #467 of 3883 Old 02-18-2012, 05:38 PM
AV Science Sales 4's Avatar
From my experience with a firmware 1.0 one sent back by AV Science for replacement with a new unit, the DLP link is red flashes. The 3D picture viewed without the glasses is quite noticeably red tinted. The BenQ DLP link glasses almost completely negate the red tint and it can be completely zeroed out with minor calibration. AV Science has not yet received the new units but supposedly they are in shipment to us. We should be getting plenty in. Please give us a call if you would like one.
AV Science Sales 4 is offline
post #468 of 3883 Old 02-18-2012, 09:26 PM
ondaedg's Avatar
That's great news! Now I'm wondering if my 100" screen will be too small for this light cannon...
Anyone have a recommendation for a 100" screen in a darkened room? I do plan on using it for sports, movies, video games and 3d.
ondaedg is offline
post #469 of 3883 Old 02-18-2012, 10:18 PM
WynsWrld98's Avatar
Quoted: 280 Post(s)
Liked: 106
May be a light cannon for 2D but certainly won't be for 3D unless you have a high gain screen
post #470 of 3883 Old 02-18-2012, 11:30 PM
jmalto's Avatar
I think it is funny how PC says the blacks are still not great but Art's impressions are much more positive. I wonder if his engineering sample was that much farther off than the retail units now that he got a shipping unit?
Only one way to tell, hopefully I can get one of these soon to test.
jmalto is offline
post #471 of 3883 Old 02-19-2012, 03:38 AM
ETK
ETK's Avatar
Yes , like all the other mode ( normal , cinema, dynamic ...)
You can set lamp power to normal or economic , and can adjust brightness / color tint / sharpness / detail / frame creation ...etc.
I don't have calibration software and equipment . I think the reported lumina could be changed by all these fine tune. But I don't know if we can tune out a brighter 3D mode with all good contrast / color accuracy / black level ... etc.
Anyway , I can accept the 3D brightness in my cave
ETK is offline
post #472 of 3883 Old 02-19-2012, 05:22 AM
SOWK's Avatar
Quoted: 468 Post(s)
Liked: 360
He may have a hardware upgraded one as well...
He saying that the the black level performance matches or beats the Sony VPL-HW30???
Not sure how you take that as not great...
SOWK is offline
post #473 of 3883 Old 02-19-2012, 08:04 AM
Toe
Toe's Avatar
Liked: 1832
Nice! Thanks ETK.
Toe is offline
post #474 of 3883 Old 02-19-2012, 08:18 AM
Cru-Jones's Avatar
Can anyone report that BenQ fixed the 3D switching issue (long wait times) with the latest update?
Also has anyone noticed tearing when when playing a PS3 game in 3D SBS?
I currently own a W5000 and I'm debating between the W7000 and the H9500BD for my upgrade.
Cru-Jones is offline
post #475 of 3883 Old 02-19-2012, 10:37 AM - Thread Starter
zombie10k's Avatar
Quoted: 2805 Post(s)
Liked: 2742
if it matched the black level of the HW30, I'd be quite happy with that considering it's a DLP. I still have my HW30 and will get a chance soon to compare the new version of the W7000 to it.
zombie10k is offline
post #476 of 3883 Old 02-19-2012, 11:39 AM
Deja Vu's Avatar
Quoted: 931 Post(s)
Liked: 936
I would think that if it matches the HW30 for black levels in 2D mode then it should beat it in 3D mode with a working DI. I'll be interested in your comments. It also sounds like the BenQ 3D glasses are matched for this projector as they should be.
I had another look at Art's HW30 review and I could hardly find a word about its 3D performance -- did I miss something?
Deja Vu is offline
post #477 of 3883 Old 02-19-2012, 06:11 PM
HiFiFun's Avatar
Originally Posted by kraine View Post
Mark I was wrong my W7000 sample have the 0.22 firmware, same as yours.
[/url]
Since Kraine's review sample had the old firmware, there is now some basis that the W7000's performance will surpass that of the Acer H9500.
In other words a role reversal. Who is still in the game? Who got busted?
HiFiFun is offline
post #478 of 3883 Old 02-19-2012, 06:18 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
Zombie10K. Please give me a call. RT under planning. Sony 1000ES arrives my place on Tuesday.
mark haflich is offline
post #479 of 3883 Old 02-19-2012, 07:48 PM
trgraphics's Avatar
Is it safe to send in the projector now and be sure to get the upgraded hardware and firmware?
post #480 of 3883 Old 02-19-2012, 08:38 PM
Liked: 1010
Yes. But you might have to do it through your dealer.
Benq , Projectors , Benq W7000 Home Projection System , Dlp Projector 2000 1080p
