Sharp XV-Z30000 3D DLP - Page 67 - AVS Forum | Home Theater Discussions And Reviews
 52Likes
Old 06-24-2015, 09:09 PM
humbland's Avatar
Quoted: 375 Post(s)
Liked: 85
if anyone is looking for a low mile 30K, a fellow member has one for sale
Sharp 30K for sale
only 167 hours, glasses, 3D emitter, etc. The lamps are still available for a low cost.
Wow! That's the best deal on a low mileage one that I have seen in the last year or so.
I hope someone scoops it up and joins the Z30K party.
humbland is offline
Old 06-24-2015, 09:11 PM
timetells's Avatar
I'm interested in the xv z30k--put me with the seller.
timetells is offline
Old 06-24-2015, 09:37 PM
zombie10k's Avatar
Quoted: 3134 Post(s)
Liked: 3222
zombie10k is online now
Old 06-24-2015, 09:39 PM
zombie10k's Avatar
Liked: 3222
his theater is on hold for a while and wanted to give someone else a chance with this model.
Old 06-25-2015, 05:24 AM
timetells's Avatar
unable to reach seller--by using seller contact-click.
Seller may contact me at jwvarner@sbcglobal.net
Old 08-25-2015, 06:47 AM
humbland's Avatar
Quoted: 375 Post(s)
Liked: 85
Hi Sharp people,
I thought I would bump this thread and see how people are doing. What's up? Are we having fun yet?
We are enjoying our Z30K. Still waiting for a DLP 4K PJ for $4K...It could be a much longer wait then I thought a couple of years ago.
We are down to 19% lamp life and thinking about changing it out. It's a daunting task on our cathedral ceiling mount. I have been wondering how many others have attempted it. Zombie, what do you think? Is it doable from a 12 foot ladder? Or should I bite the bullet and pull the entire set up down and make the switch at ground level???
Also, we had our first glitch in the machine in quite some time. We were watching a movie last night and all of a sudden the lamp turned off and the power led started blinking red. I waited 5 min. then unplugged the PJ. When I plugged it back in and powered up, it seemed back to normal I searched the Z30K manual and could not see anything concrete. Perhaps a temporary power outage? Any ideas out there?
humbland is offline
Old 08-25-2015, 08:59 AM
zombie10k's Avatar
Liked: 3222
It depends on how sturdy the ladder is. The glitch might be a warning of a lamp failure, probably time to just swap it out.
Old 08-25-2015, 09:45 AM
Lonely Surfer's Avatar
Hi Sharp people,
My projector is up about ten feet or so. When I changed my lamp a couple years ago, I removed it (with part of the mount still attached) and brought it down to a table to work on. My lamp cover is under the mount so I had no choice but to remove the whole projector anyway. I have an Optoma HD80 which isn't that heavy. I guess it depends on the configuration of your projector but working on it at ground level is certainly less nerve-racking. It was no big deal to get it up and realigned once I had the new lamp in. Good luck!
Lonely Surfer is offline
Old 08-25-2015, 09:53 AM
humbland's Avatar
Quoted: 375 Post(s)
Liked: 85
I seem to recall that someone had 2100+ hrs on their lamp before replacement.
When they got the lamp warning notice, they just reset the lamp hrs timer and kept going. With almost 2000 posts, finding it will take awhile.
Is there any downside to doing this? With our 2.8 HP there is plenty of brightness...Why not just wait until the lamp actually burns out? I know the lamps are inexpensive, but if you saw where the Z30K is located in space (near earth orbit)...
humbland is offline
Old 08-26-2015, 11:35 PM
rgrele's Avatar
My 2 are still chugging along without incident. It will be 2 years this November. One has the original lamp, the other has the Chinese OEM lamp discussed some pages back. Have been switching projectors every 300 hours or so to measure decrease in brightness. Haven't put 1,000 hours on either one yet. I purchased 4 extra lamps from China, so at the rate I'm going I should be enjoying ghost free 3D for many years to come.
biliam1982 likes this.
rgrele is offline
Old 08-27-2015, 05:57 AM
humbland's Avatar
Quoted: 375 Post(s)
Liked: 85
Thanks for the feedback.
What was you lamp changing experience like? Is it something you would attempt from a 12 foot ladder?
Also, rather than search back through the posts, can you link to the replacement lamp order site?
I was hoping by now to be upgrading to a 4K PJ, but the implementation seems stuck in the slow lane. Like you, I can see the Z30K as a player in our HT going forward (a good thing).
humbland is offline
Old 08-30-2015, 01:57 AM
rgrele's Avatar
The tutorial posted by Zombie10k was a big help to me in changing out the lamp. If you're at all handy and comfortable working with PC's, then I'd say that it isn't much more difficult than changing out a hard drive or memory. My projector is on a shelf, not ceiling mounted, so I can't say how difficult it might be to remove the lamp assembly from atop a 12' ladder. Once it's out though, just follow the well written, illustrated instructions, and you'll save some money.
Here's the link I used:
http://www.aliexpress.com/item/Origi...961655107.html
rgrele is offline
Old 08-30-2015, 03:27 AM
biliam1982's Avatar
Quoted: 415 Post(s)
Liked: 214
Jason, thought I bookmarked your post for the change out but I guess not. Can you link it?
biliam1982 is online now
Old 08-30-2015, 03:29 AM
biliam1982's Avatar
Quoted: 415 Post(s)
Liked: 214
Eric, I'm coming up on 2k hours again. Last I checked it was just over 12% left I think.
It's not too difficult to swap the lamp if you can get the cover off and pull the housing out.
Will you have to take down the projector to do that?
Old 08-30-2015, 11:16 AM
zombie10k's Avatar
Liked: 3222
Hi, here is the link to the step by step instructions for swapping out the lamp
I heard that the Mad Max 3D is going to look excellent on the Sharp 30K. heard the sound is remarkable as well too. get your copy on Tuesday
Seegs108 and biliam1982 like this.
Old 08-30-2015, 11:54 AM
ClemsonKev's Avatar
my copy in 1080p 3D came out on pira... bay a few weeks ago. ROCKS on my z30k!
ClemsonKev is offline
Old 08-30-2015, 09:20 PM
humbland's Avatar
Quoted: 375 Post(s)
Liked: 85
[QUOTE=biliam1982;36882698]Eric, I'm coming up on 2k hours again. Last I checked it was just over 12% left I think.
Will you have to take down the projector to do that?[/QUOTE
Guys, I appreciate everyone's help. I think that I will need to get a second set of hands and another ladder. That's what it took originally to get the Z30K up into orbit. Then we'll unhook everything and bring it back to mission control and swap out the lamp. It's a hassle, but I just do not feel comfortable doing a 12 foot balancing act...
Any thoughts on just waiting for it to burn out, then attempting it?
humbland is offline
Old 08-30-2015, 09:59 PM
biliam1982's Avatar
Quoted: 415 Post(s)
Liked: 214
[quote=humbland;36903458]
This time I think I'll let the lamp go past EOL. See what happens. Should it cause an issue and break the projector, it'll just give me a reason to upgrade when the new batch of recruits comes out in the fall, post CEDIA.
I believe my lamps have been lasting me roughly 1yr 3mo, give or take.
Old 09-02-2015, 08:58 AM
humbland's Avatar
Quoted: 375 Post(s)
Liked: 85
Hi guys,
I decided to check out replacement bulbs and they are <$80 each now.
In looking, I came upon an entire bulb/housing replacement for even less...
http://www.aliexpress.com/store/prod...434999994.html
What do you think? It seems like it should be a drop in, "plug and play" fix.
Am I missing something?
humbland is offline
Old 09-02-2015, 09:07 PM
biliam1982's Avatar
Quoted: 415 Post(s)
Liked: 214
Hi guys,
If that's a legit replacement.....Damn that's a good deal!
Nice find, Eric!
We need Jason to chime in and vet this thing.
Old 09-02-2015, 09:29 PM
zombie10k's Avatar
Liked: 3222
that might be the right lamp but the housing doesn't look right. I would be nervous to try any aftermarket housing, it could damage the projector.
has anyone else seen Mad Max yet on their Sharp 30k? it looks great in 3D.
Old 09-03-2015, 06:44 AM
biliam1982's Avatar
Quoted: 415 Post(s)
Liked: 214
Good to know, thx Jason!
I'm waiting to do some upgrades to my theater system before I watch it, along with some others I've been saving.
Old 09-06-2015, 09:39 PM
rgrele's Avatar
The 3D looks great on my 30K! It's a well made, wall to wall action film.
rgrele is offline
Old 09-07-2015, 02:11 AM
fpr
fpr's Avatar
Quoted: 12 Post(s)
Hi,
This weekend my Sharp Z30K took longer than normal to switch on. It took three attempts to start the lamp. The lamp has about 350 hours of use.
Has it happened something similar to someone?
fpr is offline
Old 09-07-2015, 04:17 AM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
Originally Posted by fpr View Post
Hi,
I had a similar issue after not using the unit for a while. The lamp went on and then went off. Had to unplug and replug the unit to get it to start. This only happened once so far.
rwestley is offline
Old 09-07-2015, 04:40 AM
fpr
fpr's Avatar
Quoted: 12 Post(s)
My issue is different, when I switch on the projector, while the green led blink, the ballast power on the lamp at the third attempt.
Until now, it turns on the lamp the first attemp and rarely at the second attemp, but the ballast had never needed three attempts to power on the lamp.
Once the ballast has managed to turn on the lamp, the projector has worked correctly, but left me worried.
fpr is offline
Old 09-07-2015, 10:23 AM
zombie10k's Avatar
Liked: 3222
Old 09-07-2015, 01:44 PM
humbland's Avatar
Quoted: 375 Post(s)
Liked: 85
I was having a phantom "turn off" problem. I wondered about the lamp cooling well.
So I got a long vacuum wand and carefully cleaned out the vents.
It's an easy thing to try.
You might try a call to Sharp tech support. I have wondered if they were even servicing the Z30K.
We had a 3 year warranty. Not sure if it's worth anything...
Keep us posted.
Good luck.
humbland is offline
Old 09-08-2015, 12:02 AM
fpr
fpr's Avatar
Quoted: 12 Post(s)
Can there be a problem if it continues happening?
I thought that while the ballast power on the lamp and the projector working correctly I will not call to Sharp tech support.
What do you think?
fpr is offline
Old 09-10-2015, 09:48 AM
humbland's Avatar
Quoted: 375 Post(s)
Liked: 85
Keep us posted.
Good luck.
Well, it's now happening more frequently "gulp"
Time to bite the bullet and try a new lamp.
The prices for replacement lamp units has really dropped...
I was thinking of just ordering this one from Sears
http://www.sears.com/sharp-xv-z3000-...&mktRedirect=y
It says in the description that it's a "brand new" replacement bulb and housing for the Z30K.
Jason, you're the man. What do you think?
A new bulb and housing for the price of a bulb? Sounds too good to be true, but since there can not be much demand, perhaps people are getting rid of them.
If it's the real deal, then it would be worth having one around, even if only to make the switch that much easier.
FWIW, here is another one:
http://www.lampspros.com/sharp-xv-z3...FchlfgodLjALow
They can't all be wrong...
Thoughts?
humbland is offline
Mitsubishi Hc5 , Sharp An3dg20b 3d Glasses Black Single , Sharp He Xvz17000 300 Inch 1080p Front Projector , Benq W7000 Home Projection System , Panasonic Viera Tc P65vt50 65 Inch Plasma Tv , Sharp Xv Z30000 Dlp
