Sharp XV-Z30000 3D DLP - Page 73 - AVS Forum | Home Theater Discussions And Reviews
 53Likes
post #2161 of 2196 Old 04-28-2017, 11:08 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3583 Post(s)
Liked: 3555
Originally Posted by humbland View Post
Hi Craig,
Please excuse the noob question, but what should the reading be at the screen?
Checking so infrequently (read never) until now, it's hard to justify a large expense.
This model is the most popular on Amazon:
https://www.amazon.com/Dr-Meter-LX13...QB1PHJ0ZJQN4QD
Will it do the job?
Thoughts?
That will probably do the job. Here is a thread on how to measure lumens -
Using the CA813 light meter to measure your front projector
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #2162 of 2196 Old 04-28-2017, 11:37 AM
humbland's Avatar
Quoted: 379 Post(s)
Liked: 86
Craig Peer likes this.
humbland is online now
post #2163 of 2196 Old 04-28-2017, 12:48 PM
tradewinds's Avatar
Quoted: 16 Post(s)
Hi Craig,
Will it do the job?
Thoughts?
Thanks, yes that other one was almost two bulbs (albeit probably better with more features), at least this one is at a good price.
My Riser | My LED Star Ceiling | My HTPC Build
tradewinds is offline
post #2164 of 2196 Old 04-28-2017, 07:02 PM
Liked: 0
Originally Posted by ruijinlu View Post
Hi, just bought a used Z30K, looking for the 3D emitter which is not included. Difficult to find replacement everywhere. Wondering if those Xpand models will work. Hope someone has tried could give some comment. thanks.
just a follow up. I have tried Xpand 105 and Optoma BC300. neither is working. still searching...
ruijinlu is online now
post #2165 of 2196 Old 04-28-2017, 08:03 PM
humbland's Avatar
Quoted: 379 Post(s)
Liked: 86
Did you try Sharp customer service? They were helpful when we had issues.
They are no longer in the FP business, but they may still support their own hardware. If not, then they may point you somewhere. Worth a try...
post #2166 of 2196 Old 04-28-2017, 10:30 PM
Liked: 0
tried already, no luck. Find a nearest replacement on ebay, asking for 350$! back to search...
post #2167 of 2196 Old 04-28-2017, 11:00 PM
humbland's Avatar
Quoted: 379 Post(s)
Liked: 86
Zombie is usually our go to for this type of tech advice.
I would PM him.
post #2168 of 2196 Old 04-28-2017, 11:07 PM
zombie10k's Avatar
Quoted: 3215 Post(s)
Liked: 3292
I would PM him.
I've been looking at various places online to try and find the IR emitter. I think it was quite proprietary to this projector which will make finding one tough. I will keep looking.
zombie10k is online now
post #2169 of 2196 Old 04-29-2017, 08:05 AM
Liked: 0
here is my finding @$345.
http://www.ebay.com/itm/Sharp-3D-Syn...-/152491186270
post #2170 of 2196 Old 04-30-2017, 08:23 PM
Josh Z's Avatar
Quoted: 2280 Post(s)
Liked: 1518
Dammit, my Z30k shut down on its own again tonight, for no apparent reason. It was running fine for about two hours. I left the room for a few minutes and when I came back the projector was off and the Power light was blinking.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #2171 of 2196 Old 05-01-2017, 09:47 AM
zombie10k's Avatar
Liked: 3292
it's time to break out the screwdriver, I have the service manual if you are interested. It may be worth popping off the top case and seeing if anything obvious is happening like a fan that is still spinning but not at full speed. or any loose wiring from the fan controllers, etc.
post #2172 of 2196 Old 05-01-2017, 10:04 AM
zombie10k's Avatar
Liked: 3292
This might help also before opening it up. I don't recall looking for this but they are stating there is a status in the factory menu that will store error history.
if it's a temp error then one of the fans could be suspect.
post #2173 of 2196 Old 05-01-2017, 10:19 AM
zombie10k's Avatar
Liked: 3292
post #2174 of 2196 Old 05-01-2017, 09:26 PM
Josh Z's Avatar
Liked: 1518
I can't figure out how to get into the Factory Menu. I have the service manual, and it has a bunch of references in it to the Factory Menus or the Process Menu, but I'll be damned if I can find any instructions for how to enter it.
I Googled "Sharp projector factory menu" and found the following, but neither of these methods worked when I tried them.
Sharp Projector Service Menu Access Method 1
  1. Press {UP}, {UP}, {DOWN}, {DOWN}, {RIGHT}, {LEFT} & {ENTER} buttons on the remote control.
Sharp Projector Service Menu Access Method 2
  1. Press {INPUT}, {UP}, {DOWN}, {ENTER}, {ENTER} & {MENU} buttons on the back of the Projector.
  2. To exit the Service Menu: Press {INPUT}, {UP}, {DOWN}, {ENTER}, {ENTER} & {MENU} buttons again on the back of the Projector.
Josh Z
Josh Z is offline
post #2175 of 2196 Old 05-01-2017, 09:57 PM
Seegs108's Avatar
Quoted: 4650 Post(s)
Liked: 2284
At the bottom of Page 4-4 there's this poorly translated text:
Calling and quitting the process mode with the control keys on this model.
* Although it is possible for the process OUT to exit using the process menu.
1) Calling and quitting
With the menu not displayed, press the “ENTER”, “ENTER”, “Right ”, “Left ”, “ENTER”, “ENTER” and “MENU” keys on the KEY unit.
NOTE: When adjusting in the process mode, set a signal with a vertical frequency of 60 Hz or no signal. (May not be properly adjusted with other signals.)
Resetting the lamp timer for this model
1) Resetting procedure
In Stand-by, run this command to clear the operating time of the lamp to 0 and turn on the power.
Press and hold “Down ”, “ENTER”, and “MENU”, and then press the “STANDBY/ON” key of the set.
Seegs108 is offline
post #2176 of 2196 Old 05-01-2017, 10:31 PM
Josh Z's Avatar
Liked: 1518
OK, thanks. I'll try it tomorrow. What is the Key Unit? Does that mean the projector body rather than the remote?
Josh Z
Josh Z is offline
post #2177 of 2196 Old 05-01-2017, 11:42 PM
Seegs108's Avatar
Liked: 2284
I'd imagine that was poorly translated and meant to mean "remote".
Seegs108 is offline
post #2178 of 2196 Old 05-02-2017, 05:35 AM
zombie10k's Avatar
Liked: 3292
I would open it up at this point, they give 4 locations to check the connections to see if there are any obvious issues. Also a chance to inspect the fans and manually spin them to see if they are catching (bad bearings, etc).
post #2179 of 2196 Old 05-02-2017, 08:13 AM
Josh Z's Avatar
Liked: 1518
You want to pop by and help?
Josh Z
Josh Z is offline
post #2180 of 2196 Old 05-02-2017, 12:47 PM
Seegs108's Avatar
Liked: 2284
Don't be too scared to take the top off the chassis. Single chip DLP projectors are relatively simple designed projectors compared to the three chip brethren we see from Epson, Sony and JVC. Plus taking the top off won't take long or pose a difficult and lengthy process/problem. All you'd be doing is checking that connections aren't loose and that the fans are spinning freely. Not much of a tear down process. I've had the top off of the Z30K when I had it here. It's relatively easy to take off compared to some of the other projectors (even other si ngle chip DLPs) that I've had here. If you lived in upstate New York I'd gladly offer my assistance.
Seegs108 is offline
post #2181 of 2196 Old 05-02-2017, 01:41 PM
zombie10k's Avatar
Liked: 3292
I would have gutted that projector like a fish by now if it was acting up like that.
maybe he'll send it to one of us for a surgery session. The best case would be a bad fan or loose connection. if any of the components are shot, it's going to be near impossible to get parts.
I've been watching a lot of 3D on this lately. it's still amazes me how good 3D is on this projector (no x-talk, no flicker). I just discovered after many years that it has lens memory, ahead of it's time for 2012.
post #2182 of 2196 Old 05-02-2017, 01:54 PM
Josh Z's Avatar
Liked: 1518
I have family in Clayton, but it's a long drive from here.
Josh Z
Josh Z is offline
post #2183 of 2196 Old 05-02-2017, 08:20 PM
Josh Z's Avatar
Liked: 1518
I got into the factory menu tonight.
Name:	Sharp Factory Menu.jpg
Josh Z
Josh Z is offline
post #2184 of 2196 Old 05-02-2017, 08:23 PM
Josh Z's Avatar
Liked: 1518
Would a fan not qualify as a "component"? As I recall, humbland sent his original Z30k in for repair and the fan couldn't be replaced, so they eventually sent him a different refurbed projector.
Josh Z
Josh Z is offline
post #2185 of 2196 Old 05-02-2017, 08:26 PM
zombie10k's Avatar
Liked: 3292
I think it depends which fan, it might be able to be replaced with an equivalent size / CFM rating if we can identify which one could be having an issue.
Seegs108 likes this.
post #2186 of 2196 Old 05-02-2017, 08:51 PM
zombie10k's Avatar
Liked: 3292
There's fan 1 and 2 in the first photo. power supply and front right intake. both look like traditional square fans.
rear exhaust
I may have to jimmy open the 30K and install some noctua fans.
all the sharp original parts are gone, I just looked from the service manual, no one has them. But these don't look too hard to source.
post #2187 of 2196 Old 05-02-2017, 08:53 PM
Seegs108's Avatar
Liked: 2284
It's good to see it's just a fan. That's an easy fix. Like Zombie said, you can use an equivalent size fan with the same CMF rating if you can't find the same exact model. Fans are standardized so they normally can be used in multiple applications if need be. I say "normally" because on occasion they can have a custom shape or size. I didn't look too hard into the service manual to see what the fans look like. I'll take a look now.
Seegs108 is offline
post #2188 of 2196 Old 05-02-2017, 08:57 PM
Seegs108's Avatar
Liked: 2284
There's also a fan here that cools the lamp chamber directly:
If it's that fan it will be a bit harder to find a replacement for.
Seegs108 is offline
post #2189 of 2196 Old 05-02-2017, 09:05 PM
zombie10k's Avatar
Liked: 3292
yes if it's that one it could be tough depending on the size. I just checked the service menu, my history is clear. The projector has ~700 original hours.
I watched Underworld 3D on this recently, the iris works surprisingly well in 3D mode.
post #2190 of 2196 Old 05-02-2017, 09:16 PM
Josh Z's Avatar
Liked: 1518
How will I tell which fan it is?
Josh Z is offline
Mitsubishi Hc5 , Sharp An3dg20b 3d Glasses Black Single , Sharp He Xvz17000 300 Inch 1080p Front Projector , Benq W7000 Home Projection System , Panasonic Viera Tc P65vt50 65 Inch Plasma Tv , Sharp Xv Z30000 Dlp
