marantz vp11s2 step down voltage question - AVS Forum | Home Theater Discussions And Reviews
Old 01-16-2012, 12:27 PM - Thread Starter
rc30matt's Avatar
Hi All
Does anyone know whether a US model Marantz VP11S2 (which displays next to the AC input on the back of the pj "120v~60hz") will automatically do a step down if fed 240V (ie a Europe/UK voltage). I want to avoid an external step down transformer if i can avoid it.
Thanks for any advice etc
rc30matt is offline
Old 01-17-2012, 04:49 AM
gvera's Avatar
In case it helps, I own a VP15 and I have an external step down transformer to use it, we have 220V in Uruguay.
gvera is offline
Old 01-17-2012, 05:29 AM
dyates69's Avatar
Hi Matt, sent you a PM. Hope you enjoy your 11S2 as much as I am mine.
dyates69 is offline
