Home Theater Owners Near Milwaukee WI? - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 45Likes
Old 11-27-2013, 06:19 AM
buzzard767's Avatar
Quoted: 1619 Post(s)
Liked: 2394
Originally Posted by lbrown105 View Post
I was thinking the same thing. One of the reasons I like my component rack is that it not only looks good but allows for different configurations and components. SOWK, your front stage is the same for the front speakers and sub configurations. The set up looks great, must sound great and lets you easily make changes if you feel like it (so much room behind the screen). Truly well done.
I like it too. There have been many pix with and without the screen in place. Is it easy to remove or is it raised forward like on a pulley or something. Just curious because my setup is going to be somewhat the same except not as wide and I might need to get behind the screen on occasion.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
Old 11-27-2013, 06:24 AM - Thread Starter
SOWK's Avatar
Quoted: 472 Post(s)
Liked: 363
I enlist help from my Wife (fiancé at the moment). I could do it myself, but always use help to prevent damage to corners and or the screen material. Even though Seymour Center Stage XD Material is not fragile by any means, I don't want to take extra risks.
If the screen was not 150" wide (120" wide or less) it would be a lot easier and I would be comfortable moving by myself.
SOWK is offline
Old 12-05-2013, 06:49 AM
tgrand's Avatar
Hi sowk
I live in Pewaukee Im looking to have my projector calibrated A JVC dla-x35 can you recommend any one in the area that is knowledgeable This is my third projector I have never had them calibrated before I have a decated theater room Any ideas Let me know My Phone # is 414_581-4143
Thanks in advance Tom
tgrand is offline
Old 12-05-2013, 06:56 AM - Thread Starter
SOWK's Avatar
Quoted: 472 Post(s)
Liked: 363
SOWK is offline
Old 12-05-2013, 07:13 AM
Mike_WI's Avatar
Quoted: 127 Post(s)
Liked: 79
Originally Posted by tgrand View Post
Hi sowk
I have used Craig Rounds (AVS Forum: CIR-Engineering)
http://www.cir-engineering.com/
He is in Chicago and not cheap, but very good.
He was recommended by Lumagen. He also sold, installed and calibrated with Lumagen Radiance XE.
Mike
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & output x1 cards} - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520]
HT Details: link
Mike_WI is online now
Old 12-05-2013, 07:41 AM
Verbow's Avatar
Quoted: 70 Post(s)
Liked: 58
I've used Jeff Meier from Accucal (UMR here) for my Kuro Plasma - he'll be in the area in March - and Craig Rounds for my projector as Craig lives very close to me. Both are engineers, use top notch equipment, and are great guys to boot. Money well spent and I'd highly recommend either.
Verbow is offline
Old 12-05-2013, 08:52 AM
acwebs's Avatar
SOWK calibrated my JVC RS56 himself and did an outstanding job!
acwebs is offline
Old 12-05-2013, 09:48 AM - Thread Starter
SOWK's Avatar
Quoted: 472 Post(s)
Liked: 363
acwebs - Thank you for the compliment.
*new members have been updated on first post.*
Anyone with any new projectors they want me to update the first post with?
SOWK is offline
Old 12-06-2013, 10:02 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
Anyone is SE WI have reccos on a good contractor with experience using DD, GG, channels and clip de couplers? I need to get my ceilings doen in my basement. They are drop ceiling now but I want to change them. Any PM's for this would be appreciated.
lbrown105 is offline
Old 12-07-2013, 12:38 AM - Thread Starter
SOWK's Avatar
Quoted: 472 Post(s)
Liked: 363
I hope someone in the thread can help you. I unfortunately, do not have experience with this.
SOWK is offline
Old 12-07-2013, 10:45 AM
LordJoseph's Avatar
Yo what up, in Glendale, WI
LordJoseph is offline
Old 12-07-2013, 11:02 AM - Thread Starter
SOWK's Avatar
Quoted: 472 Post(s)
Liked: 363
tgrands Theater Room:
Custom made screen frame, very comfortable setting, amazing host. Thanks again for the visit Tom.
SOWK is offline
Old 12-07-2013, 11:24 AM - Thread Starter
SOWK's Avatar
Quoted: 472 Post(s)
Liked: 363
SOWK is offline
Old 12-10-2013, 11:41 PM
LordJoseph's Avatar
Originally Posted by SOWK View Post
LordJoseph: tell us about your setup?
BenQ w1080st 1080p projector
Elite Cinegray 5D screen (8 feet)
Denon AVR-X1000 receiver
Yamaha speaker system
Xbox One (or the Xbone/Xbrick as I call it)
Xbox 360
DirecTV HR-34? HD-DVR receiver
It's my first projector and I haven't attempted to calibrate it yet, I have the Spears and Munsil calibration blu-ray.  Also I'm swapping the screen out, I screwed up and bought a high gain screen (1.5) and it's too bright, retro-reflective, so I'm going with the Cinewhite material instead
So I'm pretty much a noob but do you think a darblet would be worth the investment with this projector?
Old 12-11-2013, 04:34 AM - Thread Starter
SOWK's Avatar
Quoted: 472 Post(s)
Liked: 363
I personally think the Darblet will help any setup. Just keep it in HD mode 40 or less and your good.
It can cause to much of a processed look above 40.
SOWK is offline
Old 12-11-2013, 10:42 AM
LordJoseph's Avatar
Well you seem to know your stuff, sounds like a good investment.
One other question, when I finally calibrate my projector it has this ISF advanced calibration area that requires a passcode to get into....do I need to get into that or just normal calibration?
Thanks advance
Old 12-11-2013, 02:05 PM - Thread Starter
SOWK's Avatar
Quoted: 472 Post(s)
Liked: 363
You normally can calibrate right from the normal user menu.
You should not need to get into the ISF advanced calibration menu.
SOWK is offline
Old 12-12-2013, 01:39 PM - Thread Starter
SOWK's Avatar
Quoted: 472 Post(s)
Liked: 363
Updates Incoming:
Projector:
JVC DLA-X500R
Audio Interconnect Cables:
Signal Cable Silver Resolution Reference Analog Interconnects
(For my front left and front right speaker to match the length and tonality of the Silver Resolution Reference Analog Interconnect for my new center channel.)
*This will probably be my last equipment update till a true 4K Oppo Blu-Ray Player with 4K Darbee and affordable 4K Projector come out.*
SOWK is offline
Old 12-12-2013, 02:28 PM
blee0120's Avatar
Quoted: 433 Post(s)
Liked: 231
Updates Incoming:
Projector:
JVC DLA-X500R
You are going to be waiting 18-24mo, I am thinking the same. I'm going to wait until January to see if I should get one of these jvc projectors. At first I thought that since these will not play 4k blu rays that I should wait. However, the new 4K projectors might not be compatible with 4k blu rays and we have over a year to even see a 4k blu ray. I just want to make sure with the 4k input that it provides a better picture with 4k material than 2k with eshift 3 applied. Even Jason said the Sony 1000es doesn't show its true ability until 4k content is displayed.
blee0120 is offline
Old 12-12-2013, 02:30 PM - Thread Starter
SOWK's Avatar
Quoted: 472 Post(s)
Liked: 363
I will probably wait for a 4K input that can do 60Htz at 4:4:4.
this 4:2:0 crap is just that... Crap.
SOWK is offline
Old 12-12-2013, 02:33 PM
blee0120's Avatar
Quoted: 433 Post(s)
Liked: 231
Also, 18Gbps chips too unlike Sony's 10.2Gbps chips
blee0120 is offline
Old 12-12-2013, 04:14 PM
Seegs108's Avatar
Quoted: 4220 Post(s)
Liked: 2094
I don't quite understand the hubbub about Sony using 10.2Gbps chips. I understand to fully take advantage of the HDMI 2.0 spec we need that higher throughput rate, but Sony is a huge player in the consumer media distribution economy. They basically wrote the specs on bluray and you can bet your sweet ass they're going to have a huge, if not the proportionally largest, say on what the BD4K standard will be. With that said, I'm fairly certain they already have a VERY good idea on what the standards will be. Hence the choice to roll out the upgrade now and not wait for 18Gbps chips to come out.
I highly doubt Sony wants to double dip on spending money for another upgrade to the 1000/1100 which means the 10.2 Gbps chip inside should suffice for any major future media distribution type formats that arrive in 4K. I'm going to go out on a limb here and say that those complaining about the chip choice Sony went with on the new 4K projectors are worried for no reason.
Seegs108 is online now
Old 12-12-2013, 05:20 PM
blee0120's Avatar
Quoted: 433 Post(s)
Liked: 231
I rather wait for a 18Gbps chip or until we know what we actually need for 4k blu rays than spend $10k+ on something that might change in a year. Plus, we doesnt want the best possible? 18 is better than 10
blee0120 is offline
Old 12-12-2013, 05:49 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
No it isn't unless you have sources and displays that can use it and need it. You don't need Type II HS HDMI cables for low resolutions and actually I don't need them for 50 ft runs at 4k, all I had to do was add a Lumagen HDMI/HDMI extender.
Mike_WI likes this.
mark haflich is offline
Old 12-16-2013, 11:06 AM - Thread Starter
SOWK's Avatar
Quoted: 472 Post(s)
Liked: 363
Any other Wisconsin faithfuls going to upgrade projectors / speakers / Amps / Receivers this year?
I don't want to be the only one upgrading... lol.
SOWK is offline
Old 12-16-2013, 01:29 PM
agrsiv95's Avatar
I'm at the point where it's big$$$ for small gains, so I'm out till I get a new venue wink.gif
agrsiv95 is offline
Old 12-17-2013, 07:58 AM
JeffK's Avatar
I'll be completing my original build out, so I suppose that will be an upgrade of sorts smile.gif
So far, this is what it looks like for equipment.
Already purchased:
Projector - Sony VPL-HW55ES
Receiver - Denon X4000
L/R Speakers - B&W DM604S3 (existing)
Center - B&W LCR600 (existing)
Soon to be purchased:
Screen - SnapAV Dragonfly 120" 16:9 Matte White screen
Subs - Episode ES-SUB-12-300-MB 12" Powered Sub (Qty. 2)
Rear speakers - Sonance VP66R (have to be in ceiling do to room configuration)
Blu-ray/DVD source - unsure right now
HTPC - to be built yet. I have a 10TB NAS with most of my movies ripped, and use a Boxee Box in my living room as the source. I need something better for the theater/bar smile.gif
Jeff
JeffK is offline
Old 12-17-2013, 09:04 AM - Thread Starter
SOWK's Avatar
Quoted: 472 Post(s)
Liked: 363
Nice set of components there.
JeffK, what format are your movies in?
MKV / ISO / or something else?
SOWK is offline
Old 12-17-2013, 05:23 PM
JeffK's Avatar
Right now most DVD's are ISOs and Blurays are 1080p mkv. The mkv's look fine on a 60" Plasma, but I may rip everything to ISO once the projector is setup and working. I'll see how it looks once I'm up and running and then go from there. I can't wait to get home from work tonight, as most of the bar cabinets should be installed smile.gif
JeffK is offline
Old 12-17-2013, 07:59 PM - Thread Starter
SOWK's Avatar
Quoted: 472 Post(s)
Liked: 363
SOWK is offline
Jvc Rs50u , Sony Vpl Vw95es Full Hd 3d Home Cinema Projector , Sony Vpl Hw50es 3d Projector , Marantz Vp 11s2 Dlp Projector , Epson 5010 Powerlite Home Cinema 3d Front Projector , Panasonic Ptae8000u Hd Projector , Jvc Dla Rs4810 3d Home Theater Projector
