Home Theater Owners Near Milwaukee WI? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 45Likes
post #181 of 784 Old 10-09-2012, 11:15 AM - Thread Starter
SOWK's Avatar
Quoted: 475 Post(s)
Liked: 369
Mcascio... Amazing theater!
Welcome to the thread.
Yours room makes my room seem very basic... Lol. Great Job!
SOWK is online now
post #182 of 784 Old 10-09-2012, 11:25 AM
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Thanks. And thanks for directing me to this thread! I wasn't aware of it. Great to see locals with similar passions. I'm sure we can learn alot from each other.
mcascio is offline
post #183 of 784 Old 10-09-2012, 11:50 AM - Thread Starter
SOWK's Avatar
Quoted: 475 Post(s)
Liked: 369
Are you going to be keeping the Panasonic or plan on upgrading soon?
SOWK is online now
post #184 of 784 Old 10-09-2012, 11:53 AM
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
The budget got wiped with the build and the newborn. But I'm hoping to add another sub then eventually a new projector.
mcascio is offline
post #185 of 784 Old 10-17-2012, 12:50 PM - Thread Starter
SOWK's Avatar
Quoted: 475 Post(s)
Liked: 369
TedO - You get any word on the Sony yet?
Anyone else doing anything new with their theaters this year?
SOWK is online now
post #186 of 784 Old 11-10-2012, 10:28 AM - Thread Starter
SOWK's Avatar
Quoted: 475 Post(s)
Liked: 369
Milwaukeesk...
Finally took the time to black out the carpet.
About 95% done, small touch ups needed yet.
Look is final though...
SOWK is online now
post #187 of 784 Old 11-10-2012, 10:40 AM
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
mcascio is offline
post #188 of 784 Old 11-10-2012, 10:41 AM
zombie10k's Avatar
Quoted: 2859 Post(s)
Liked: 2863
that looks very nice. What is the material under the felt? did you cut it to match the curve of the front bevel?
I have dark brown carpet in front of my screen that can light up pretty good reflecting off the HP screen. I've been trying to think of ideas to black it out without ripping up the existing carpet.
zombie10k is offline
post #189 of 784 Old 11-10-2012, 11:19 AM - Thread Starter
SOWK's Avatar
Quoted: 475 Post(s)
Liked: 369
Just simple foam padding for exercising.
2' x 2' pads ducked taped to be 4' x 8' then covered in pure black fabric.
Easy to work with, and easy to cut. And yes, I did match the curve of the front stage.
SOWK is online now
post #190 of 784 Old 11-10-2012, 12:32 PM
zombie10k's Avatar
Liked: 2863
great idea! Can you let me know where to get similar fabric? how is it attached? I have a several yards of the black velvet material that Dalite uses on the Cinema Contour frame. I bought it years ago to make masks but never got around to it. It had adhesive on the back for installation, but not sure how hard it is to work with. thx for the tips.
post #191 of 784 Old 11-10-2012, 01:49 PM - Thread Starter
SOWK's Avatar
Quoted: 475 Post(s)
Liked: 369
The fabric is black fleece. I had purchased it at the fabric store in Wisconsin called JoAnn fabrics.
It is physically attached to the foam pads via duct tape on the back. For the best results, fabric spray glue would be the best and duck tape on the back... Lol.
If people were going to walk on it often I would have used fabric glue.
I did that on my top and lower front stage in front of my screen and it is very nice. Also used a clothes iron to get completely flat and wrinkle free.
SOWK is online now
post #192 of 784 Old 11-11-2012, 10:27 AM - Thread Starter
SOWK's Avatar
Quoted: 475 Post(s)
Liked: 369
SOWK is online now
post #193 of 784 Old 11-11-2012, 10:47 AM
Toe
Toe's Avatar
Quoted: 1474 Post(s)
Liked: 1843
WOW! Beautiful HT SOWK! smile.gif Great idea with the foam pads covered in black in front of the screen. I might copy this idea. My floor is all blacked out right now with black velvet, but it is a PITA since it is constantly getting wrinkled from getting walked on. Your ideal would solve that and it would look better as well. Anyway, nice work.
Toe is online now
post #194 of 784 Old 11-13-2012, 01:04 PM
Samurai Jack's Avatar
I'm an easy hour from Milwaukee and am there all the time.
I own a Sharp XV-Z12000 Mark II, and a DaLite HiPower Roll-up screen (fairly transportable). I throw 106" diagonal 16:9 on it.
Toying with the idea of a BenQ W7000 or a Sony VPL-HW50ES.
My audio is provided via a full Ascend Acoustics 7.1 system (340 SE's LCR, 200's side and rear) and a pair of Hsu STF-2's I picked up ages ago for a song, that produce plenty of thud in their corner positions. The seats are a couple of sofa's embedded with Aura transducers.
I started my room with a DIY screen, an Infocus X1 (after being tempted first by the debut digital goodness that was the Panny PT-AE1000U...I've been on here a while), and a DIY anamorphic lens. I picked up newer equipment over the years, learned a lot, and started the build of the room proper, but then life got in the way.
Having finished a major remodel upstairs, I'm now back to tinkering with the batcave, and hoping to start up the actual room build once again after the holidays.
*shakes off dust*
Each moment only once.
Samurai Jack is offline
post #195 of 784 Old 11-13-2012, 01:37 PM
Mcascio, what modeling software are you using for your theater build?
post #196 of 784 Old 11-14-2012, 05:06 AM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
SOWK,
There is a specific forum on AVS for this type of thread (just a heads up in case you were not aware wink.gif).
http://www.avsforum.com/f/61/area-home-theater-meets
Jason
Media Room = Vizio 4K 70" lcd/Denon x4100/Audiosource Amp 100/Klipsch speakers/Velodyne subs/Sony BDP s780/PS4 Pro/X1S/WiiU/PS3/360/Wii/Game PC/Multi-Arcade / #standwithscotty / My HT SLIDESHOW
DaGamePimp is offline
post #197 of 784 Old 11-14-2012, 09:52 AM
mante's Avatar
SOWK,
Very nice looking theater. I've also used the same JoAnn's black fleece fabric in our "man cave" and have had excellent results using it. My other half didn't want me to paint the white walls and white ceiling, so I simply stapled the fleece to the first 6 feet of the ceiling, walls, and floor. The fleece worked so well at absorbing the reflected light, I covered my subs with it. Inexpensive solution and very easy to vacuum.
Cj in Madison
mante is offline
post #198 of 784 Old 11-14-2012, 09:56 AM - Thread Starter
SOWK's Avatar
Quoted: 475 Post(s)
Liked: 369
Tell us a little about the setup and I'll put you in the front post.
SOWK is online now
post #199 of 784 Old 11-16-2012, 01:28 PM
dmoneyman2323's Avatar
Quoted: 32 Post(s)
Liked: 33
Originally Posted by mcascio View Post
Projector: Panasonic AE-4000u
Screen: Seymour AV - Center Stage XD 136" wide 2.35:1
Speakers: M&K S-5000 THX (LCR), M&K SS-150 THX (Highs, Wides, Rears, Sides)
Subs: M&K MX-350 (Need to add one more)
Electronics: Onkyo TX-NR 3008 (RECEIVER), Emotiva XPA-5 (AMP), Cinemar MLD-4000 16 TB (Storage), Cinemar Software Suite (Movie Selection User Interface)
Build Thread: http://www.avsforum.com/t/1208912/the-cinemar-home-theater-construction-thread
That's amazing, what app is that on your ipad? I need that one, also what is that on the wall outside the theater is that just a tv on the wall?
Mike_WI likes this.
Displays: JVC RS4910 Projector | 125-inch 2.35:1 Elite Cinetension2 Screen | Panasonic 58V10 Plasma TV
Sources: Yamaha RX-A800 | Microsoft XBOX One | Dish Hopper | Intel i5 Nuc w/ Openelec | Behringer iNuke 3000DSP
Speakers: DIY Fusion-12 Tempest (L/R) | DIY 88-Special (C) | DIY Volt-10 Speakers (Surr L/R) | Subwoofers: MartyCube w/ Stereo Integrity SI-18 X 2
dmoneyman2323 is offline
post #200 of 784 Old 11-16-2012, 01:42 PM
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Thanks dmoneyman2323.
I'm running our Cinemar home automation and media management software on the iPad.
The LED TV is used to display the currently playing movie poster and metadata along with start and end times. I was able to easily build a customized screen for the movie poster TV using MainLobby.
There's more details in my build thread on both pieces if you'd like more info. My build thread link is in my signature.
Mike_WI likes this.
mcascio is offline
post #201 of 784 Old 11-23-2012, 01:59 PM - Thread Starter
SOWK's Avatar
Quoted: 475 Post(s)
Liked: 369
Mario can I ask how much your d-box setup was?
Also just got done with my HT meet with TedO!
Wonderful AVSer, and a pleasure to have over.
His Sony HW50 is a golden sample...
Colors were dead on accurate after a quick greyscale calibration.
Best I have ever seen!!!
Shadow detail was top notch, motion was near perfect, focus was 98% perfect.
All I have to say is the new JVC better blow me away, or I'll be the owner of a Sony HW50.
SOWK is online now
post #202 of 784 Old 11-23-2012, 02:11 PM
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Hi SOWK,
I bought my DBOX about 6 years ago used. The model I have is no longer available. They have a variety of different options now so I'm not sure what they go for these days. They do have a dealer locator though on their website that you could give a call and get some official prices.
I'm guessing you may be spending $10 -15k or so. Less for a single chair option.
You'll have to keep us posted on how the JVC compares to the Sony HW50.
mcascio is offline
post #203 of 784 Old 11-23-2012, 02:20 PM
zombie10k's Avatar
Liked: 2863
where did you set the gamma? The last one I calibrated, I set it to 2.2 and it was very close across the board, much better than any of the Epson presets.
what did you think of the RC?
post #204 of 784 Old 11-23-2012, 02:31 PM - Thread Starter
SOWK's Avatar
Quoted: 475 Post(s)
Liked: 369
Gamma at 2.22
Average 2.21 even with the auto iris on.
I personally disliked the RC (even on min) on everything but "soft" blu-ray titles. Way too digital looking *update (I did not get a chance to set mpeg to low though.) read that after he left. So I was getting way to much noise in the image.
Soft titles like Star Wars episode 1 looked way better with it on.
Tron legacy and extremely loud and incredibly close, looked much too "digital" then I would ever like. And Noise Filtering was so subtle.
It's amazing to see the difference though. Like the camera is out of focus with it off... When using demo mode or turning on/off.
SOWK is online now
post #205 of 784 Old 11-23-2012, 04:24 PM
zombie10k's Avatar
Liked: 2863
thx for the info. I'm curious to see the e-shift2 in comparison to the RC which I would sometimes tweak based on what kind of content I was watching. The early claims stated that it would keep the background out of focus (no noise) yet still sharpen other areas. we'll both find out soon.
@ mcascio - wow that is a fantastic theater setup.. very nice.
post #206 of 784 Old 11-24-2012, 08:23 AM
TedO's Avatar
Quoted: 26 Post(s)
Liked: 27
I just wanted to publicly thank SOWK for helping me with test my Sony HW50. The pictures of his HT do not do it justice, very nice setup and the man himself is very knowledgeable in both the video and audio sides of this hobby.
I couldn’t be happier with the results of the testing. My HW50 looks to be a good projector for my needs and performed well. Now all I have to do is finish my room to start enjoying it at home. Lots of work ahead of me.
Thanks Tony.
TedO is offline
post #207 of 784 Old 11-24-2012, 07:58 PM
Midwest User1's Avatar
Tell us your schedule, and well see what we can fit in...
I'm back in the thread from a fairly long break! Just been busy with kid activities for many months and have now got some time to visit the forums again.
Anyway I'd love to have Sowk and Milwaukeesk over for a calibration/visit/hangout.
I still have all of the same gear from my post #61
Midwest User1 is offline
post #208 of 784 Old 11-24-2012, 09:49 PM
TedO's Avatar
Quoted: 26 Post(s)
Liked: 27
Mcascio,
In the pictures the recessed ceiling goes from star field, to red accent then to blue. Do you have all three and just switch to whichever one fits the mood? I really like the star feild but from what I've seen those are a lot of work to build.
TedO is offline
post #209 of 784 Old 11-25-2012, 06:25 PM
Milwaukeesk's Avatar
Quoted: 24 Post(s)
Milwaukeesk...
What's up SOWK. Nice move on the carpet. Looks great. Did it make a big difference.
BTW great to see the thread going so strong. Some great setups!
Milwaukeesk is offline
post #210 of 784 Old 11-29-2012, 08:41 AM
mcascio's Avatar
Quoted: 77 Post(s)
Liked: 106
Hi Samurai Jack,
I used Netwek's Lightwave 3D for the design and layout of my theater.
mcascio is offline
Jvc Rs50u , Sony Vpl Vw95es Full Hd 3d Home Cinema Projector , Sony Vpl Hw50es 3d Projector , Marantz Vp 11s2 Dlp Projector , Epson 5010 Powerlite Home Cinema 3d Front Projector , Panasonic Ptae8000u Hd Projector , Jvc Dla Rs4810 3d Home Theater Projector
