ViewSonic 1080p led laser/hybrid - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 09-19-2012, 05:01 PM
fleaman's Avatar
Quoted: 38 Post(s)
Liked: 104
Originally Posted by dougri View Post
and to quote Art from his PD8150 review (since the train shot in the HC4000 review is the only in the 'shadow detail' assessment where he does not explicitly mention overexposing):
"There is simply a great deal of detail to be seen in the shrubs. also in the the lower part of the woods. This image has been greatly overexposed to make the detail more visible. When comparing with the same photo from other projectors below, remember that the exposures are all a bit different, and you have to compensate, if you want to draw your own conclusions."
Until reviewers start posting exif data, all projector settings, screen details and room treatments, comparing photos from different reviews (let alone different reviewers!) is a rather pointless path to pursue... Heck, even if they had done that, I've never calibrated my computer monitor, so I'm in no position to make judgements either wink.gif
Ok, that's very strange. I just looked at Art's PD8150 review and for the train shot image he doesn't say anything about it being overexposed?? Here is the copy/pasted words from the page that has the night train shot> http://www.projectorreviews.com/planar/pd8150/imagequality.php
Our last comparison uses the night train scene from Casino Royale. Look to the trees and shrubs on the right, especially just above the tracks. The first image is the Planar, while the second one is from the less expensive InFocus IN83. Note, the PD8150 image appears a little blurred, put that down to user error when I took the photo:
As you can see, both do extremely well, with almost identical performance. You can see a little more detail in the Planar photo, but you'll also notice it's a little brighter. Basically it's pretty much a tie, between these two excellent projectors.
Additional images widely used in our reviews for considering shadow detail, are found below.
fleaman is online now
Old 09-19-2012, 06:49 PM
fleaman's Avatar
Quoted: 38 Post(s)
Liked: 104
Originally Posted by JeffY View Post
The difference on the JVC HD 750 is around 40%
The larger the zoom range, the larger the contrast on/off difference. JVC's have large zoom ranges---about twice more than a typical DLP PJ. With that much zoom adjustment, it starts to act like a manual iris, which helps reduce light scatter (increasing contrast when zoomed down). PJ's with small zoom ranges typically have much much smaller affects on the on/off contrast.
The HD750 has a 2x zoom
The Acer has only a 1.2x zoom
JVC's typically have a larger on/off variance with zoom, but I don't remember a 40% difference (assuming ONLY the zoom was changed, not the manual iris, etc.).
The Acer will most likely have a very small difference in on/off variance with it's typical DLP limited zoom set up. At the very least, no DLP has come close to the on/off variance you mentioned when only zoom was changed.
Remember, the on/off contrast number differences between the AVF review and Kraine's is at min 400%, up to a 1000% difference!
Old 09-19-2012, 06:58 PM
woxter05's Avatar
woxter05 is offline
dougri's Avatar
Quoted: 45 Post(s)
Liked: 52
Sorry flea... Runco LS-5 review. My bad.
dougri is offline
Old 09-20-2012, 12:22 AM
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
No direspect at all wink.gif There is no need to comment the picture of casino royal in my review it's only a grab picture and not a screenshot from the Acer. This picture is only there for my readers so they are able to know wich part of the movie I'm referring.
Visit the new pjhc.fr forum here : http://www.projection-homecinema.fr/forum/
kraine is offline
Old 09-20-2012, 02:33 PM
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
kraine is offline
Old 09-20-2012, 02:41 PM
yyy484's Avatar
yyy484 is offline
Old 09-21-2012, 01:37 AM
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
kraine is offline
Old 09-21-2012, 01:41 AM
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
The PRO9000 is much much quieter than the K750 even in high lamp mode, but I'm waiting for my sample to finalize my conclusion.
kraine is offline
Old 09-21-2012, 02:59 AM
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
By the way the official price of the PRO9000 will be 1999 euros so under 3000 dollars, this thread belong to the other forum under 3000$ projectors.
kraine is offline
yyy484's Avatar
thanks a lot kraine
waiting every review from you ....
k750 vs pro9000
and the only problem with laser/led pj will be the price !!!
but em more excited next year
price cut - more laser/led pj from others products
as you said the thread shouldn't be here
but its good to see every body moving to laser/led tech
yyy484 is offline
Old 09-21-2012, 03:03 AM
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
I must receive my press sample in the middle of october, so there is no more much time to wait smile.gif
kraine is offline
Old 09-21-2012, 04:55 AM
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
kraine is offline
Old 09-21-2012, 06:33 AM
yyy484's Avatar
again thanks alot kraine for all the info ........
yyy484 is offline
Old 09-21-2012, 07:35 PM
Raine0's Avatar
Quoted: 52 Post(s)
Pity they didn't show the movie presentation in more favourable conditions. Maybe then, you'd have a better idea of the black levels of this unit. Anyways, great job Kraine! And looking forward to your thoughts!
Raine0 is offline
Old 09-22-2012, 12:17 AM
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
I was able to watch the PRO9000 without lights in the room for a short time, the black level seems very good, at least as good as the K750.
kraine is offline
Old 09-22-2012, 06:17 AM
yyy484's Avatar
both 90% i could say the same
but with different room and name !!!
so i don't i expect pro9000 much better then k750 or worse
i can say slight difference here and there with the software features ( various company ) but with the same materials employed on them !!
all of that we will see the deference but not faraway from each others
something better here other better there
we have to wait and see
yyy484 is offline
Old 09-22-2012, 06:52 AM
Raine0's Avatar
Quoted: 52 Post(s)
"at least as good as the K750." The Acer black levels still is a mystery to some and also debatable still. cool.gif
Raine0 is offline
Old 10-06-2012, 08:47 AM
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
kraine is offline
Old 10-06-2012, 09:32 AM
JeffY's Avatar
JeffY is offline
Old 10-06-2012, 02:04 PM
yyy484's Avatar
Mr kraine we are waiting your lovely review and comparison with acer k750 smile.gif
yyy484 is offline
Old 10-08-2012, 04:09 AM
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
kraine is offline
Old 10-08-2012, 05:01 AM
yyy484's Avatar
could you make a new thread on $3k-
not sure some dealer write like $4.7K eek.gif and thats no way (IMO)
and UK market say like $2k
yyy484 is offline
Old 10-08-2012, 05:02 AM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Caesar is mildly impressed!
Elix is offline
Old 10-08-2012, 10:45 AM
73shark's Avatar
Quoted: 366 Post(s)
Liked: 176
Threads are usually started in the price point that they are originally priced at when first released.
Good example is the ViewSonic Pro8100 that started at $5,000 and once released for consumer purchase dropped below $3,000. Stayed in the >$3K thread tho. smile.gif
In space, no one can hear you scream . . .
73shark is offline
Old 10-08-2012, 12:27 PM
yyy484's Avatar
yyy484 is offline
Old 10-08-2012, 03:36 PM
fleaman's Avatar
Quoted: 38 Post(s)
Liked: 104
Old 10-09-2012, 05:55 AM
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
kraine is offline
Old 10-09-2012, 06:38 AM
danieledmunds's Avatar
Quoted: 20 Post(s)
Liked: 25
Nice review, thanks.
Gotta love Google Translate: "The overall score is amputated by colorimetry is far from optimum gearbox output, calibration is required in the case of PRO9000. "
danieledmunds is offline
Old 10-09-2012, 08:34 AM
3dprojector's Avatar
Quoted: 148 Post(s)
Liked: 66
I'm lost with this Google Translate?
so which one would you take,the winner in a simple plain English,the acer k750,viewsonic pro9000,if you are looking for overall PQ?
3dprojector is online now
Mitsubishi Hc3000u High Definition 720p Dlp Home Theater Projector
